Non sono errati.Zaza1976 ha scritto:... Però è strano che, praticamente ovunque, diano suggerimenti errati...
diskutil list
diskutil info
Device Identifier: disk4s2
Device Node: /dev/disk4s2
Whole: No
Part of Whole: disk4
Volume Name: macOS Sierra 10.12 Install Disk - 10.12.6
Mounted: Yes
Mount Point: /Volumes/macOS Sierra 10.12 Install Disk - 10.12.6
Partition Type: Apple_HFS
File System Personality: Journaled HFS+
Type (Bundle): hfs
Name (User Visible): Mac OS Extended (Journaled)
Journal: Journal size 8192 KB at offset 0x3c000
Owners: Disabled
OS Can Be Installed: Yes
Media Type: Generic
Protocol: USB
SMART Status: Not Supported
Volume UUID: 8CDF8B69-67E3-3D7D-8DA8-CE82AB6454DB
Disk / Partition UUID: 7F2C934D-E04B-41D4-B26B-2A8A0251D9ED
Disk Size: 7.7 GB (7709089792 Bytes) (exactly 15056816 512-Byte-Units)
Device Block Size: 512 Bytes
Volume Total Space: 7.7 GB (7709089792 Bytes) (exactly 15056816 512-Byte-Units)
Volume Used Space: 5.1 GB (5106581504 Bytes) (exactly 9973792 512-Byte-Units) (66.2%)
Volume Available Space: 2.6 GB (2602508288 Bytes) (exactly 5083024 512-Byte-Units) (33.8%)
Allocation Block Size: 4096 Bytes
Read-Only Media: No
Read-Only Volume: No
Device Location: External
Removable Media: Removable
Media Removal: Software-Activated
/dev/disk0 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *525.1 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_HFS Macintosh HD 524.3 GB disk0s2
3: Apple_Boot Recovery HD 650.0 MB disk0s3
/dev/disk1 (internal, physical):
0: GUID_partition_scheme *1.0 TB disk1
1: EFI EFI 209.7 MB disk1s1
2: Apple_HFS Progetti 999.9 GB disk1s2
/dev/disk2 (internal, physical):
0: GUID_partition_scheme *1.0 TB disk2
1: EFI EFI 209.7 MB disk2s1
2: Apple_HFS Archivio 999.9 GB disk2s2
/dev/disk3 (internal, physical):
0: GUID_partition_scheme *256.1 GB disk3
1: EFI EFI 209.7 MB disk3s1
2: Apple_HFS Librerie 255.7 GB disk3s2
/dev/disk4 (external, physical):
0: GUID_partition_scheme *8.1 GB disk4
1: EFI EFI 209.7 MB disk4s1
2: Apple_HFS macOS Sierra 10.12 I... 7.7 GB disk4s2
Visitano il forum: Apple [Bot] e 13 ospiti
