Musica: 8 software Audio Editing e non solo...
Tutto sul pinguino per Mac
a-mac
8 Best Open Source Music Making Softwares for Linux (anche per Mac OS X e windows)
1. Audacity (http://www.audacityteam.org/" onclick="window.open(this.href);return false;)
2. Cecilia (http://ajaxsoundstudio.com/software/cecilia/" onclick="window.open(this.href);return false;)
3. Mixxx (http://www.mixxx.org/" onclick="window.open(this.href);return false;)
4. Ardour (https://ardour.org/" onclick="window.open(this.href);return false;)
5. Hydrogen Drum Machine (http://hydrogen-music.org/hcms/" onclick="window.open(this.href);return false;)
6. Guitarix (http://guitarix.org/" onclick="window.open(this.href);return false;)
7. Rosegarden (http://www.rosegardenmusic.com/" onclick="window.open(this.href);return false;)
8. Qtractor (http://qtractor.sourceforge.net/qtractor-index.html" onclick="window.open(this.href);return false;)
articolo: https://goo.gl/aNCiK5" onclick="window.open(this.href);return false;
fonte: http://www.tecmint.com/" onclick="window.open(this.href);return false;
_ UNIX: Live Free or Die
Interessanti le versioni per Mac. Grazie.
a-mac
quasi tutti o tutti sono per Mac OS X !
:wink:
adesso sistemo i link con i download per OS X... :P
a-mac
Front-ends: IDEs and music composition environments
Download Cecilia 5.2.1
OSX (10.5 to 10.11)
http://ajaxsoundstudio.com/downloads/Cecilia5_5.2.1.dmg" onclick="window.open(this.href);return false;
http://ajaxsoundstudio.com/works/" onclick="window.open(this.href);return false;
https://sourceforge.net/projects/cecilia/" onclick="window.open(this.href);return false;
CECILIA is an environment for music and signal-processing that uses Csound as its underlying audio processing engine. One can think of CECILIA as a completely programmable sound-processing tool, with real-time interactive processing on soundfiles or live
http://cecilia.sourceforge.net/" onclick="window.open(this.href);return false;
a-mac
Mixxx computer program for DJing music per Mac OS X
n. 1 Top Free Mac App Worldwide, Mac App Store, February 2011
Download Now (Mixxx 2.0 Stable) per Mac OS X
http://downloads.mixxx.org/mixxx-2.0.0/ ... xintel.dmg" onclick="window.open(this.href);return false;
Download Mixxx 2.0.0 for Mac OS X 10.5+ (Intel)
http://www.macupdate.com/app/mac/33059/mixxx" onclick="window.open(this.href);return false;
Mixxx is an open source computer program for DJing music
https://en.wikipedia.org/wiki/Mixxx" onclick="window.open(this.href);return false;
https://youtu.be/g8ezCqolx04" onclick="window.open(this.href);return false;
a-mac
Ardour is an open source, collaborative effort of a worldwide team including musicians, programmers, and professional recording engineers. Per Mac OS X!
https://it.wikipedia.org/wiki/Ardour" onclick="window.open(this.href);return false;
https://ardour.org/download" onclick="window.open(this.href);return false;
http://www.macupdate.com/app/mac/17260/ardour" onclick="window.open(this.href);return false;
Audio Engineers
Musicians
Soundtrack Editors
Composers
Audio and MIDI Multi-Track Recording and Editing
Plugins with Full Sample Accurate Automation
Transport Sync and External Control Surfaces
Powerful Anywhere-to-Anywhere Signal Routing
Video Timeline
https://ardour.org/building_osx_native.html" onclick="window.open(this.href);return false;
https://ardour.org/images/retina_no_plugs2.png" onclick="window.open(this.href);return false;
https://ardour.org/features.html" onclick="window.open(this.href);return false;
https://ardour.org/requirements.html" onclick="window.open(this.href);return false;
dalla wikipedia: https://it.wikipedia.org/wiki/Ardour" onclick="window.open(this.href);return false;
Registrazione
Le capacità di registrazione di Ardour sono limitate solo dall'hardware su cui è installato. Non ci sono limitazioni software, più la capacità dell'hardware è alta, più Ardour sarà in grado di registrare. Se l'hardware non è dei più potenti ardour riconosce automaticamente le zone in cui viene risentita la latenza e corregge automaticamente gli errori posizionando la registrazione dove avrebbe dovuto essere senza latenza.
Mixaggio
Ardour rende disponibili infinite tracce e bus, ovviamente anche in questo caso il limite è dato solo dall'hardware in uso. I parametri di gain, pan e plugin possono essere completamente automatizzati. I dati campione sono mixati e mantenuti interamente in 32 bit per la massima fedeltà della definizione sonora.
Editing
Ardour supporta il drag, il trim, lo split e il timestretching alle zone registrate con risoluzione sample-level. Un crossfade editor versatile e una beat machine sono inclusi in Ardour. Con Ardour è possibile effettuare infiniti "undo/redo", e ha anche la caratteristica "snapshot", per salvare lo stato corrente del progetto.
Mastering
Ardour può essere usato come ambiente di masterizzazione e finalizzazione. La sua integrazione con JACK rende possibile l'utilizzo di strumenti di mastering come JAMin per il processo dei dati audio. Ardour può anche esportare in formato TOC e CUE, che permettono la creazione di CD audio.
Midi
Ardour supporta frequenze di campionamento digitale differenti legate alla misura della capacità dell'hardware, agli input ed output e al numero differente di formati di file. MMC (MIDI Machine Control) e le superfici dei controlli MIDI generici possono essere usati per controllare e mixare anche manualmente, o automaticamente.
a-mac
Montaggio di audio digitale
Hydrogen: advanced drum machine for Mac OS X
download: http://www.hydrogen-music.org/hcms/node/21" onclick="window.open(this.href);return false;
forum: http://www.hydrogen-music.org/hcms/forum/13" onclick="window.open(this.href);return false;
http://www.hydrogen-music.org/hcms/" onclick="window.open(this.href);return false;
http://www.macupdate.com/app/mac/41346/hydrogen" onclick="window.open(this.href);return false;
https://sourceforge.net/projects/hydrogen/" onclick="window.open(this.href);return false;
http://freecode.com/projects/hydrogen/" onclick="window.open(this.href);return false;
https://it.wikipedia.org/wiki/Hydrogen_(software" onclick="window.open(this.href);return false;)
Hydrogen è una drum machine avanzata creata da Alessandro Cominu (Comix), un programmatore italiano. Il suo scopo è rendere disponibile la programmazione professionale di pattern di batteria in maniera semplice e intuitiva.
https://en.wikipedia.org/wiki/Hydrogen_(software" onclick="window.open(this.href);return false;)
Features
Pattern-based sequencer, with unlimited number of patterns and ability to chain patterns into a song.
Up to 64 ticks per pattern with individual level per event and variable pattern length.
32 instrument tracks with volume, mute, solo, pan capabilities.
Multi-layer support for instruments (up to 16 samples for each instrument).
Ability to import/export song files.
Support for LADSPA effects.
Real-time slide control for swing.
Option to slightly randomize velocity, time, pitch and swing functions to give a more "human" playback.
Multiple patterns playing at once.
GMkit, the drum kit features: Kick, Stick, Snare Jazz, Hand Clap, Snare Rock, Tom Low, Closed HH (high hat), Tom Mid, Pedal HH (high hat), Tom Hi (high), Open HH (high hat), Cowbell, Ride Jazz, Crash, Ride Rock, and Crash Jazz.
https://youtu.be/r9H8gJtzz_s" onclick="window.open(this.href);return false;
a-mac
Guitarix per Mac OS X
https://sourceforge.net/projects/guitarix/files/OSX/" onclick="window.open(this.href);return false;
https://sourceforge.net/projects/guitarix/files/" onclick="window.open(this.href);return false;
https://youtu.be/hlGKDQj2Wmk?list=PLeRY ... q-k5pgn17b" onclick="window.open(this.href);return false;
Guitarix – Linux Rock Guitar Amplifier è un’applicazione per creare gli effetti audio della nostra Chitarra. L’applicazione utilizza Jack (Jack Audio Connektion Kit) con un ingresso e due uscite. Progettato per ottenere nice thrash / metal / rock / blues chitarra suoni.
Ci sono controlli per bassi, medi, alti, il guadagno (in / out), compressore, preamp, tubo, unità, overdrive, oversample anti-aliase, Fuzz, l’equilibrio, la distorsione, freeverb, risposta all’impulso, vibrato, chorus, Crybaby (wah) e echo. Per la ‘pressione‘ del suono è possibile utilizzare il feedback e feedforward cursori.
Torna a “Linux su Mac”
