Ciao non penso....
Ciao se ti riferisci a FileVault : no
Ciao, il mod. è il seguente: Transcend TS512GSSD370S SSD370S HardDisk
Un Fusion Drive fatto da due SSD! Forte.
Non è l'unico: la pagina di cui ho dato il link sopra trattava proprio di gente che ha la stessa configurazione.
Paolofast ha scritto: ↑lun, 15 ott 2018 20:16Allora, San Google mi ha fatto scoprire due cose:
1) questo dice la Apple:
OK, Apple closed by bug again, with an explanation from engineering that provides a rationale for this being an invalid Core Storage configuration:
Engineering has provided the following information regarding this issue:
Your CoreStorage configuration is invalid. APFS cannot convert all the different ways people can configure CoreStorage devices. We only convert default configurations that we ship from the factory.
I responded as follows:
Let me suggest the following clarification to this explanation. In fact, my CoreStorage configuration is perfectly valid: I was able to manually reformat it as APFS and then proceed with a manual installation of Mojave. A more accurate explanation would be: “During Mojave installation, we will only support migration from a default factory Fusion drive configuration.”
I would also suggest that since 1- Fusion paired hard drives do regularly fail/require drive replacement in the real world and 2- the level of pain inflicted in this case by having Mojave installation fail with a cryptic, inaccurate message that forces the user to research the issue and the perform a relatively complex manual installation, that Apple reconsider this approach. At the very least, provide an accurate explanation of why the installation failed.
Traduzione veloce: l'unità Fusion non è quella di fabbrica, non riesco a trasformarla nel nuovo Fusion Drive APFS di Mojave e quindi l'aggiornamento fallisce.
Come direbbero a Roma: "Ma li mortacci vostri!!!"
2) Nello stesso post dove appare la risposta Apple viene data una soluzione. Ma devi avere un backup di TimeMachine.
Allora, PRIMA di aggiornare segui queste istruzioni:
a) Crea una chiavetta di avvio dall'installer di Mojave (Se cerchi in questo forum c'è spiegato come fare svariate volte).
b) Riavvia il computer e tieni premuto il tasto opzione (ALT)
c) Seleziona come disco di avvio la chiavetta
d) Dalla schermata iniziale apri Utility Disco e inizializza (formatta) il disco logico MacIntosh HD e chiudi Utility Disco
e) Apri il terminale (da uno dei menù in alto) e dividi il fusion drive. A questo link ci sono delle istruzioni del 2013 che spero siano ancora valide, altrimenti spera che faxus, il più esperto in queste cose, posti lui la procedura.
https://spider-mac.com/2013/01/05/divid ... ive-apple/
f) Sempre da terminale, crea di nuovo il fusion drive. A questo link ci sono delle istruzioni del 2016 che spero siano ancora valide, altrimenti spera che faxus, il più esperto in queste cose, posti lui la procedura.
https://www.informaticanapoli.it/come-c ... e-sui-mac/
NOTA: i due link indicati sono il primo risultato utile in italiano che compare da una ricerca su Google. Se qualcuno ha di meglio, lo posti.
g) Chiudi il terminale e riapri Utility Disco
h) Inizializza il fusion drive appena creato, scegliendo come formato APFS
i) Esci da Utility Disco, tornando così alla schermata principale e da lì ripristina con Time Machine
Riavvia e ti troverai il tuo Mac esattamente come prima, ma con il Fusion Drive APFS creato da Mojave e potrai aggiornare tranquillamente.
Il link alla pagina dove ho trovato tutto questo è qui:
https://forums.macrumors.com/threads/ma ... 491/page-3
E comunque, PRIMA, fai un backup (anche con Time Machine) e aggiorna il firmware, se non è già aggiornato.
Lascia stare il mitico e dicci se ha funzionato.Gianluca03 ha scritto: ↑mer, 17 ott 2018 10:19Ciao Paolo, grazie mille post molto esaustivo "mitico"
