diskutil list
dscl . list /Volumes/Macintosh\ HD/Users | grep -v '_'
-bash-3.2# diskutil list
/dev/disk0 (disk image):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme +2.1 GB disk0
1: Apple_HFS OS X Base System 2.0 GB disk0s1
/dev/disk1 (internal, physical):
0: GUID_partition_scheme *500.3 GB disk1
1: EFI EFI 209.7 MB disk1s1
2: Apple_APFS Container disk2 500.1 GB disk1s2
/dev/disk2 (synthesized):
0: APFS Container Scheme - +500.1 GB disk2
Physical Store disk1s2
1: APFS Volume Macintosh HD 475.6 GB disk2s1
2: APFS Volume Preboot 44.2 MB disk2s2
3: APFS Volume Recovery 517.8 MB disk2s3
4: APFS Volume VM 1.1 GB disk2s4
/dev/disk3 (disk image):
0: untitled +5.2 MB disk3
/dev/disk4 (disk image):
0: untitled +524.3 KB disk4
/dev/disk5 (disk image):
0: untitled +524.3 KB disk5
/dev/disk6 (disk image):
0: untitled +524.3 KB disk6
/dev/disk7 (disk image):
0: untitled +2.1 MB disk7
/dev/disk8 (disk image):
0: untitled +524.3 KB disk8
/dev/disk9 (disk image):
0: untitled +524.3 KB disk9
/dev/disk10 (disk image):
0: untitled +12.6 MB disk10
/dev/disk11 (disk image):
0: untitled +4.2 MB disk11
/dev/disk12 (disk image):
0: untitled +1.0 MB disk12
/dev/disk13 (disk image):
0: untitled +2.1 MB disk13
/dev/disk14 (disk image):
0: untitled +524.3 KB disk14
/dev/disk15 (disk image):
0: untitled +524.3 KB disk15
/dev/disk16 (disk image):
0: untitled +1.0 MB disk16
/dev/disk17 (disk image):
0: untitled +6.3 MB disk17
/dev/disk18 (disk image):
0: untitled +6.3 MB disk18
/dev/disk19 (disk image):
0: untitled +524.3 KB disk19
/dev/disk20 (disk image):
0: untitled +2.1 MB disk20
-bash-3.2#
-bash-3.2# dscl . /Volumes/Macintosh\ HD/Users | grep -v '_'
dscl (v10.13)
usage: dscl [options] [<datasource> [<command>]]
datasource:
localhost (default) or
localonly (activates a DirectoryService daemon process
with Local node only - daemon quits after use
<hostname> (requires DS proxy support, >= DS-158) or
<nodename> (Directory Service style node name) or
<domainname> (NetInfo style domain name)
options:
-u <user> authenticate as user (required when using DS Proxy)
-P <password> authentication password
-p prompt for password
-f <filepath> targeted file path for DS daemon running in localonly mode
(example: /Volumes/Build100/var/db/dslocal/nodes/Default)
(NOTE: Nodename to use is fixed at /Local/Target)
-raw don't strip off prefix from DS constants
-plist print out record(s) or attribute(s) in XML plist format
-url print record attribute values in URL-style encoding
-q quiet - no interactive prompt
commands:
-read <path> [<key>...]
-readall <path> [<key>...]
-readpl <path> <key> <plist path>
-readpli <path> <key> <value index> <plist path>
-create <record path> [<key> [<val>...]]
-createpl <record path> <key> <plist path> <val1> [<val2>...]
-createpli <record path> <key> <value index> <plist path> <val1> [<val2>...]
-delete <path> [<key> [<val>...]]
-deletepl <record path> <key> <plist path> [<val>...]
-deletepli <record path> <key> <value index> <plist path> [<val>...]
-list <path> [<key>]
-append <record path> <key> <val>...
-merge <record path> <key> <val>...
-change <record path> <key> <old value> <new value>
-changei <record path> <key> <value index> <new value>
-diff <first path> <second path>
-search <path> <key> <val>
-auth [<user> [<password>]]
-authonly [<user> [<password>]]
-passwd <user path> [<new password> | <old password> <new password>]
-bash-3.2#
ls /Volumes/Machintosh\ HD/Users
cp -Rp /Volumes/Macintosh\ HD/Users/tuonomeutente /Volumes/nomediscodicopia
Visitano il forum: Google [Bot] e 25 ospiti
