problemi all'accensione
cdimaio53
Recentemente quando accendo il computer (sono solito spegnerlo tutte le sere, faccio bene?) la schermata rimane bianca per un tempo lunghissimo, prima che avvenga il caricamento del SO.
Per il resto non noto alcun particolare problema.
Da cosa può dipendere?
Nel caso servisse, riporto le risultanze di EtreCheck
EtreCheck version: 3.4.7 (461)
Report generated 2018-07-18 09:04:01
Runtime: 2:24
Performance: Excellent
Problem: Other problem
Hardware Information: ⓘ
iMac (21.5-inch, Mid 2011)
iMac - model: iMac12,1
1 2,7 GHz Intel Core i5 (i5-2500S) CPU: 4-core
12 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
2 GB DDR3 1333 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
4 GB DDR3 1333 MHz ok
BANK 1/DIMM1
Handoff/Airdrop2: not supported
Wireless: en1: 802.11 a/b/g/n
iCloud Quota: 637 MB available
Video Information: ⓘ
AMD Radeon HD 6770M - VRAM: 512 MB
iMac 1920 x 1080
Disk Information: ⓘ
WDC WD1001FALS-403AA0 disk1: (1 TB) (Rotational)
[Show SMART report]
EFI (disk1s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
Macintosh HD (disk1s2 - Journaled HFS+) /Volumes/Macintosh HD : 999.35 GB (451.03 GB free)
Recovery HD (disk1s3 - Journaled HFS+) <not mounted> [Recovery]: 650 MB
CT240BX300SSD1 disk0: (240,06 GB) (Solid State - TRIM: No)
[Show SMART report]
(disk0s2) <not mounted> [APFS Container]: 239.85 GB
OPTIARC DVD RW AD-5680H ()
USB Information: ⓘ
USB20Bus
hub_device
Apple, Inc. Keyboard Hub
Apple Inc. Apple Keyboard
Hewlett-Packard HP LaserJet Professional M1212nf MFP
Apple Inc. BRCM2046 Hub
USB20Bus
hub_device
Sunplus Innovation Technology. USB to Serial-ATA bridge
00BEVT-16A0RT0 disk3: (500,11 GB)
LC 500Gb (disk3s1 - ExFAT) /Volumes/LC 500Gb : 500.11 GB (7.53 GB free)
USB 2.0 Hub
USB 2.0 Hub
TOSHIBA External USB 3.0
Hewlett-Packard HP Color LaserJet CM2320fxi MFP
External USB 3.0 disk4: (2 TB)
TOSHIBA 2Tb (disk4s1 - ExFAT) /Volumes/TOSHIBA 2Tb : 2.00 TB (1.16 TB free)
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
Macintosh SSD (disk2s1 - APFS) / [Startup]: 239.85 GB (195.84 GB free)
Physical disk: disk0s2 239.85 GB (195.84 GB free)
(disk2s2) <not mounted> [Preboot]: 239.85 GB
(disk2s3) <not mounted> [Recovery]: 239.85 GB
(disk2s4) /private/var/vm [VM]: 239.85 GB
System Software: ⓘ
macOS High Sierra 10.13.5 (17F77) - Time since boot: less than an hour
Configuration files: ⓘ
/etc/hosts - Count: 17
Gatekeeper: ⓘ
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.corespeechd.plist
/System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Executable not found!
One orphan file found. [Clean up]
Kernel Extensions: ⓘ
/System/Library/Extensions
[not loaded] com.devguru.driver.SamsungComposite (1.4.45 - SDK 10.6) [Lookup]
/System/Library/Extensions/ssuddrv.kext/Contents/PlugIns
[not loaded] com.devguru.driver.SamsungACMControl (1.4.45 - SDK 10.6) [Lookup]
[not loaded] com.devguru.driver.SamsungACMData (1.4.45 - SDK 10.6) [Lookup]
[not loaded] com.devguru.driver.SamsungMTP (1.4.45 - SDK 10.5) [Lookup]
[not loaded] com.devguru.driver.SamsungSerial (1.4.45 - SDK 10.6) [Lookup]
[not loaded] com.samsung.driver.ssudumdrv (1.3) [Lookup]
System Launch Agents: ⓘ
[failed] com.apple.corespeechd.plist (? ? ? - installed 2017-11-01) - /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd: Executable not found!
[not loaded] 9 Apple tasks
[loaded] 172 Apple tasks
[running] 112 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 35 Apple tasks
[loaded] 180 Apple tasks
[running] 118 Apple tasks
Launch Agents: ⓘ
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2018-07-18) [Lookup]
[loaded] com.microsoft.update.agent.plist (Microsoft Corporation - installed 2018-04-20) [Lookup]
[loaded] com.oracle.java.Java-Updater.plist (? ebe1dceb f36eaba4 - installed 2018-04-30) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-04-29) [Lookup]
[loaded] com.apple.installer.osmessagetracing.plist (Apple, Inc. - installed 2018-05-30)
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2018-07-18) [Lookup]
[loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2018-04-20) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script fa56dec8 - installed 2018-03-27) [Lookup]
User Launch Agents: ⓘ
[loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2018-04-13) [Lookup]
User Login Items: ⓘ
Dropbox Applicazione
(/Applications/Dropbox.app)
Backup e sincronizzazione di Google Applicazione
(/Applications/Backup and Sync.app)
AppCleaner SmartDelete SMLoginItem - Hidden (Julien Ramseier - installed 2016-01-03)
(/Volumes/Macintosh HD/Applications/AppCleaner.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app)
AppCleaner SmartDelete SMLoginItem - Hidden (Julien Ramseier - installed 2017-12-19)
(~/Desktop/UTYLIYIES/AppCleaner disistalla programmi.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app)
(/Volumes/Macintosh HD/Users/[redacted]/Desktop/AppCleaner disistalla programmi.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app)
AppCleaner SmartDelete SMLoginItem - Hidden (Julien Ramseier - installed 2018-05-12)
(/Volumes/Macintosh HD/Users/[redacted]/Library/Mobile Documents/com~apple~CloudDocs/Desktop/UTYLIYIES/AppCleaner disistalla programmi.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app)
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 29.0.0.171 (installed 2018-05-21) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2018-06-13)
Flash Player: 29.0.0.171 (installed 2018-05-21) Outdated! Update
jdk: Unknown (installed 2018-04-30)
o1dbrowserplugin: 5.41.3.0 (installed 2018-01-20) [Lookup]
SharePointBrowserPlugin: 14.4.1 (installed 2017-12-19) [Lookup]
googletalkbrowserplugin: 5.41.3.0 (installed 2015-12-11) [Lookup]
MeetingJoinPlugin: Unknown (installed 2017-12-19) [Lookup]
JavaAppletPlugin: Java 10.0.1 build 10 (installed 2018-04-30) Check version
3rd Party Preference Panes: ⓘ
Flash Player (installed 2018-04-29) [Lookup]
Java (installed 2018-04-30) [Lookup]
Time Machine: ⓘ
Auto backup: YES
Volumes being backed up:
Macintosh SSD: Disk size: 239.85 GB Disk used: 44.01 GB
Destinations:
63 [Local]
Total size: 999.86 GB
Total number of backups: 52
Oldest backup: 24/12/17, 07:22
Last backup: 16/07/18, 00:29
Backup size 999.86 GB > (Disk size 239.85 GB X 3)
Top Processes by CPU: ⓘ
28% Safari
16% com.apple.WebKit.Networking
11% accountsd
8% com.apple.Safari.SafeBrowsing.Service
7% WindowServer
Top Processes by Memory: ⓘ
1.07 GB kernel_task
270 MB Backup and Sync
233 MB mds_stores
168 MB Dropbox
111 MB Mail
Input Output Process name
61 KB 177 KB Dropbox
97 KB 46 KB mDNSResponder
132 KB 2 KB com.apple.Safari.SafeBrowsing.Service
88 KB 16 KB com.apple.WebKit.Networking
79 KB 17 KB Mail
3.64 Safari
3.58 WindowServer
3.12 Mail
2.78 com.apple.WebKit.WebContent
1.66 hidd
Virtual Memory Information: ⓘ
8.08 GB Available RAM
1.69 GB Free RAM
3.92 GB Used RAM
6.39 GB Cached files
0 B Swap Used
2018-07-18 08:53:33 Last shutdown cause: 3 - Hard shutdown
2018-07-17 18:37:35 com.apple.WebKit.WebContent High CPU use [Open] [Details]
2018-07-16 11:15:02 Backup and Sync.app Crash [Open]
Cause: objc_msgSend() selector name: updatePath:withStatus:
cdimaio53 ha scritto:
mer, 18 lug 2018 09:09
... quando accendo il computer (sono solito spegnerlo tutte le sere, faccio bene?) la schermata rimane bianca per un tempo lunghissimo, prima che avvenga il caricamento del SO...
La schermata resta bianca PRIMA che cominci a vedere la basta di caricamento avanzare?
Tempo lunghissimo... Prova a quantificare.
30 secondi?
1 minuto?
Due minuti?
10 minuti?
Il disco SSD in che posizione l'hai installato?
Al posto del vecchio HD e l'HD l'hai messo al posto del Superdrive?
Oppure hai messo l'SSD al posto del Superdrive.
Oppure è SSD estertno?
Quante periferiche sono collegate all'accensione?
Hai provato ad accendere con tutto scollegato, escluso mouse e tastiera?
Il problema deriva, a mio parere, da una incongruenza dell'hardware con l'assetto di sistema.
Ci sono dei problemi software marginali che vedremo poi.
Spegnere la sera?
Io spengo quando trasloco di casa e riavvio quando aggiorno o in caso di problemi software.
Ma non è vietato dalla legge spegnere a fine sessioni.
Perché spegni, o hai spento prima del check, togliendo l'alimentazione (o col bottone)?
utente_autoeliminato
Oggetto del messaggio: Re: problemi all'accensione
La prima cosa che farei è il solito reset PRAM e SMC
https://support.apple.com/it-it/ht204063
Tante volte si risolve e non ha controindicazioni.
Leggere attentamente le avvertenze d'uso. Non somministrare sotto i 14 anni. :D
cdimaio53
faxus ha scritto:
mer, 18 lug 2018 09:38
30 secondi?
1 minuto?
Due minuti?
10 minuti?
La prossima volta che l'accendo (domani) quantifico. A naso direi non 10 m minuti ma sicuramente più di 2
L'SSD è sul 3° slot
HD e superdrive sono rimasti al loro posto
4HD (compreso quello di Time Machine), 2 stampanti e la tastiera; ho un hub alimentato
Anche in questo caso prima di accendere domani scollegherò tutto e riferirò
Spegnere la sera?
In vero un pò di tempo fa non lo spegnevo neanche io. Ora, da quando ho istallato in maniera permanente la batteria di HD (a seguito dell'acquisto dell'hub) spengo ogni sera per non lasciare in funzione gli HD che non hanno il pulsante di spegnimento. Se li attacco solo alla bisogna finisce che ometto di fare i back-up di tanto in tanto.
Prima del check avevo spento (con il bottone) perché la barra non si decideva a presentarsi. Mi è sembrato di aver atteso un tempo troppo lungo (certamente inusuale) ed ho spento per riprovare.
Domani proverò anche il reset PRAM
Per ora va bene così; grazie, buona notte ed a domani
D
mer, 18 lug 2018 22:51
... L'SSD è sul 3° slot
HD e superdrive sono rimasti al loro posto...
Eh?
In ogni caso, al prossimo riavvio, se altre manovre non hanno cambiato il valore dell'accensione e resta in minuti:
- Avvia in modalità dettagliata (verbose mode)
Si fa tenendo i tasti ⌘+V abbassati, fino a che non compare del testo bianco su fondo nero.
Alla fine si avvierà normalmente.
Cerca di leggere il motivo o capire, lo indicherà, cosa sta facendo in tutto quel tempo di attesa
Intendeva che è stato collegato al terzo connettore SATA sotto la logic board
Il mio livello di conoscenza hardware è raccogliticcio...
Adesso so che c'è un terzo connettore per le memorie di massa.
Pensa te...
Aspettiamo, se c'è, qualche indicazione, in bianco su nero...
faxus ha scritto:
gio, 19 lug 2018 11:33
Pensa te...
Non su tutti i modelli però.
iMac (27-inch, Mid 2010)
iMac (27-inch, Mid 2011)
iMac (21.5-inch, Late 2011)
cdimaio53
gio, 19 lug 2018 14:13
Pensa te...
Questo è il mio
cdimaio53
faxus ha scritto:
gio, 19 lug 2018 09:40
Eh?
Incredibile (per me)!
Ho staccato tutto (tranne tastiera) ed il mac è partito immediatamente: neppure il tempo di percepire lo schermo bianco.
A questo punto ho pensato di lasciare collegato al mac solo la tastiera ed l'HD di Time Machine e di collegare gli altri HD e le stampanti al Hub che staccherò dopo spento e ricollegherò dopo acceso.
ma, secondo voi, cosa accade se evito nuovamente di spegnere il computer tutte le sere, mettendolo unicamente in stop e lasciandovi collegato l'anzidetto HD di Time Machine? Che probabilità ho di accorciargli la vita e rimanere a secco all'improvviso?
Dal punto di vista del sistema operativo, spegnere o mettere in stop non cambia quasi nulla.
Se spegni tieni molti meno componenti sotto tensione rispetto allo stop.
Il punto è che quando accendi il sistema controlla tutti i dischi attaccati, quindi se hai una batteria di dischi esterni attaccati, ci impiega una vita a controllarli.
Ecco il perché avevi una partenza lenta.
Personalmente prima di spegnere il Mac espello tutti i dischi esterni (salvo Time Machine) e li spengo (o scollego se sono autoalimentati).
TimeMachine sempre attaccato mi rallenta qualche secondo la partenza ma a me va bene così.
Suggerirei anche a te di fare lo stesso.
Però mi raccomando: quando fai gli aggiornamenti di sistema, stacca tutto meno mouse e tastiera (ma proprio tutto, anche hub e Time Machine), fai l'aggiornamento e poi riattacca.
Quanto a dischi esterni e lo Stop, storicamente sono sempre andati d'accordo come Tom e Jerry, come Silvestro e Speedy Gonzales, insomma, se metti in Stop con più dischi esterni attaccati, ti può andare bene come ti può causare problemi tipo mancata riattivazione dei dischi, ecc., soprattutto quando lo stop dura un po' di ore.
Si va a (s)fortuna.
Il perché tecnico, se ne hanno voglia, te lo diranno quelli più esperti di me. Io, semplicemente, quando vado in Stop, PRIMA espello e stacco tutti i dischi esterni (sempre salvo Time Machine) e sono sicuro di non avere problemi.
Sì, il disco Time Machine è, per quel che mi riguarda, esente da questi problemi, se è l'unico a rimanere attaccato durante spegnimento o stop.
Non so perché, ma ho sperimentato che è così.
Paolofast ha scritto:
ven, 20 lug 2018 10:26
... il disco Time Machine è, per quel che mi riguarda, esente da questi problemi, se è l'unico a rimanere attaccato durante spegnimento o stop.
Èd è vero (nella quasi totalità).
La spiegazione è semplicissima.
Perché ha un assistente, Time Machine
faxus ha scritto:
ven, 20 lug 2018 13:08
Ah, ecco.
Grazie.
