EtreCheck version: 3.4.7 (461)
Report generated 2018-06-17 07:47:20
Runtime: 1:48
Performance: Excellent
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Click the [Clean up] link to delete unused files.
Hardware Information: ⓘ
iMac (27-inch, Late 2013)
iMac - model: iMac14,2
1 3,4 GHz Intel Core i5 (i5-4670) CPU: 4-core
32 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
BANK 1/DIMM1
Handoff/Airdrop2: supported
Wireless: en1: Unknown
iCloud Quota: 3.65 GB available
Video Information: ⓘ
NVIDIA GeForce GTX 775M - VRAM: 2048 MB
iMac 2560 x 1440
Disk Information: ⓘ
Samsung SSD 850 EVO 1TB disk0: (1 TB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [APFS Container]: 1000.00 GB
USB Information: ⓘ
USB30Bus
LaCie P9227 Slim
P9227 Slim disk2: (1 TB)
Time Machine (disk2s1 - Journaled HFS+) /Volumes/Time Machine : 1.00 TB (884.67 GB free)
Generic 4-Port USB 3.0 Hub
SABRENT USB Storage
Apple Inc. BRCM20702 Hub
Apple, Inc. Keyboard Hub
Apple Inc. Apple Keyboard
Generic 4-Port USB 2.0 Hub
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
SSD (disk1s1 - APFS) / [Startup]: 1000.00 GB (553.81 GB free)
Physical disk: disk0s2 1000.00 GB (553.81 GB free)
(disk1s2) <not mounted> [Preboot]: 1000.00 GB
(disk1s3) <not mounted> [Recovery]: 1000.00 GB
(disk1s4) /private/var/vm [VM]: 1000.00 GB
System Software: ⓘ
macOS High Sierra 10.13.5 (17F77) - Time since boot: about one hour
Gatekeeper: ⓘ
Possible adware: ⓘ
Unknown file: /Library/LaunchAgents/com.disaffectionate.mp.plist
/Library/disaffectionate.mp/disaffectionate.mp.app/Contents/MacOS/disaffectionate.mp
One possible adware file found. [Remove/Report]
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.corespeechd.plist
/System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Executable not found!
One orphan file found. [Clean up]
Kernel Extensions: ⓘ
/Library/Extensions
[not loaded] com.midlandeurope.MidlandUpdaterSupport (1.3 - SDK 10.8) [Lookup]
System Launch Agents: ⓘ
[failed] com.apple.corespeechd.plist (? ? ? - installed 2017-11-01) - /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd: Executable not found!
[not loaded] 9 Apple tasks
[loaded] 179 Apple tasks
[running] 104 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 37 Apple tasks
[loaded] 185 Apple tasks
[running] 111 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2018-03-03) [Lookup]
[not loaded] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2018-03-03) [Lookup]
[loaded] com.disaffectionate.mp.plist (? e5f45318 41109ad0 - installed 2018-06-17) [Lookup]
[loaded] com.epson.esua.launcher.plist (Seiko Epson Corporation - installed 2018-03-03) [Lookup]
[loaded] com.oracle.java.Java-Updater.plist (? cf19c071 41c76fb7 - installed 2018-04-23) [Lookup]
Launch Daemons: ⓘ
[running] com.adobe.adobeupdatedaemon.plist (Adobe Systems, Inc. - installed 2018-03-03) [Lookup]
[loaded] com.apple.installer.osmessagetracing.plist (Apple, Inc. - installed 2018-05-30)
[running] com.objectiveSee.blockblock.plist (? ? ? - installed 2018-03-02) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script e3fefdd2 - installed 2018-04-23) [Lookup]
User Launch Agents: ⓘ
[loaded] org.freedownloadmanager.fdm5.helper.plist (SoftDeluxe, Inc - installed 2018-06-17) [Lookup]
User Login Items: ⓘ
smcFanControl Applicazione
(/Applications/smcFanControl.app)
Internet Plug-ins: ⓘ
Silverlight: 5.1.50901.0 (installed 2018-03-04) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2018-06-13)
JavaAppletPlugin: Java 8 Update 171 build 11 (installed 2018-04-23) Check version
AdobeAAMDetect: 3.0.0.0 (installed 2018-03-03) [Lookup]
Safari Extensions: ⓘ
[enabled] Free Download Manager - FreeDownloadManager.org - http://freedownloadmanager.org (installed 2018-01-10)
[not loaded] uBlock - Chris Aljoudi - https://chrismatic.io/ (installed 2015-08-18)
[enabled] Adblock Plus - Eyeo GmbH - https://adblockplus.org/ (installed 2018-03-04)
3rd Party Preference Panes: ⓘ
Java (installed 2018-03-28) [Lookup]
Time Machine: ⓘ
Skip System Files: NO
Auto backup: YES
Volumes being backed up:
SSD: Disk size: 1000.00 GB Disk used: 446.19 GB
Destinations:
Time Machine [Local]
Total size: 1.00 TB
Total number of backups: 50
Oldest backup: 08/03/18, 15:39
Last backup: 17/06/18, 07:15
Backup size 1.00 TB < (Disk used 446.19 GB X 3)
Top Processes by CPU: ⓘ
4% WindowServer
2% kernel_task
1% fontd
0% BlockBlock
0% mds
Top Processes by Memory: ⓘ
1.75 GB kernel_task
135 MB Finder
111 MB WindowServer
102 MB mds_stores
99 MB cfprefsd
Input Output Process name
136 KB 57 KB Mail
65 KB 57 KB mDNSResponder
7 KB 12 KB apsd
7 KB 2 KB cloudd
7 KB 1006 B netbiosd
5.88 WindowServer
1.50 BlockBlock
0.30 AdobeUpdateDaemon
0.22 trustd
Virtual Memory Information: ⓘ
27.84 GB Available RAM
22.84 GB Free RAM
4.16 GB Used RAM
4.99 GB Cached files
0 B Swap Used
BaseCamp: (installed 2018-05-28)
Mactracker: 7.7.3 (installed 2018-05-30)
Mactracker: 7.7.4 (installed 2018-06-07)
GoPro Quik: (installed 2018-06-16)
Remo Repair MOV: (installed 2018-06-16)
Yodot MOV Repair: (installed 2018-06-17)
MacKeeper: (installed 2018-06-17)
2018-06-17 06:38:49 Yodot MOV Repair.app Hang [Open]
2018-06-16 21:31:51 QuickLookUIService Crash [Open]
Cause: dyld3: launch started
Sandbox registration internal error: Incoming message euid:0 does not match secinitd uid:501.
