Time Machine
yale
Ragazzi non so perchè EtreCheck mi segnala in rosso che ho un USB riservato a Time Machine piccolo...sbaglio qualcosa o forse interpreto male?
 EtreCheck version: 3.4.7 (461)
Report generated 2018-03-07 16:44:15
Runtime: 1:51
Performance: Excellent
Hardware Information: ⓘ
    iMac (27-inch, Late 2013)
    iMac - model: iMac14,2
    1 3,4 GHz Intel Core i5 (i5-4670) CPU: 4-core
    32 GB RAM Upgradeable - [Instructions]
        BANK 0/DIMM0
            8 GB DDR3 1600 MHz ok
        BANK 1/DIMM0
        BANK 0/DIMM1
        BANK 1/DIMM1
    Handoff/Airdrop2: supported
    Wireless:  en1: Unknown
    iCloud Quota: 3.64 GB available
Video Information: ⓘ
    NVIDIA GeForce GTX 775M - VRAM: 2 GB
        iMac 2560 x 1440
Disk Information: ⓘ
    Samsung SSD 850 EVO 1TB disk0: (1 TB) (Solid State - TRIM: Yes)
    [Show SMART report]
        EFI (disk0s1 - MS-DOS FAT32) <not mounted>  [EFI]: 210 MB
        (disk0s2) <not mounted>  [APFS Container]: 1000.00 GB
USB Information: ⓘ
     USB30Bus
        Toshiba External USB 3.0
            External USB 3.0 disk3: (1 TB)
                EFI (disk3s1 - MS-DOS FAT32) <not mounted>  [EFI]: 210 MB
                Time Machine (disk3s2 - Journaled HFS+) /Volumes/Time Machine : 999.86 GB (931.14 GB free)
        Apple Inc. BRCM20702 Hub
        VIA Labs, Inc.          USB2.0 Hub
        Apple, Inc. Keyboard Hub
            Apple Inc. Apple Keyboard
Thunderbolt Information: ⓘ
    Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
    SSD (disk1s1 - APFS) /  [Startup]: 1000.00 GB (633.07 GB free)
        Physical disk: disk0s2 1000.00 GB (633.07 GB free)
    (disk1s2) <not mounted>  [Preboot]: 1000.00 GB
    (disk1s3) <not mounted>  [Recovery]: 1000.00 GB
    (disk1s4) /private/var/vm  [VM]: 1000.00 GB
System Software: ⓘ
    macOS High Sierra  10.13.3 (17D102) - Time since boot: about 8 hours
Gatekeeper: ⓘ
System Launch Agents: ⓘ
    [not loaded]    8 Apple tasks
    [loaded]    172 Apple tasks
    [running]    110 Apple tasks
System Launch Daemons: ⓘ
    [not loaded]    37 Apple tasks
    [loaded]    183 Apple tasks
Launch Agents: ⓘ
    [not loaded]    com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2018-03-03) [Lookup]
    [not loaded]    com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2018-03-03) [Lookup]
    [loaded]    com.epson.esua.launcher.plist (Seiko Epson Corporation - installed 2018-03-03) [Lookup]
Launch Daemons: ⓘ
    [running]    com.adobe.adobeupdatedaemon.plist (Adobe Systems, Inc. - installed 2018-03-03) [Lookup]
    [loaded]    com.apple.installer.osmessagetracing.plist (Apple, Inc. - installed 2018-02-17)
    [running]    com.objectiveSee.blockblock.plist (? ? ? - installed 2018-03-02) [Lookup]
User Launch Agents: ⓘ
    [loaded]    org.freedownloadmanager.fdm5.helper.plist (SoftDeluxe, Inc - installed 2018-03-07) [Lookup]
User Login Items: ⓘ
    smcFanControl    Applicazione
        (/Applications/smcFanControl.app)
Internet Plug-ins: ⓘ
    Silverlight: 5.1.50901.0 (installed 2018-03-04) [Lookup]
    AdobeAAMDetect: 3.0.0.0 (installed 2018-03-03) [Lookup]
    QuickTime Plugin: 7.7.3 (installed 2018-01-19)
Safari Extensions: ⓘ
    [enabled]    Free Download Manager - FreeDownloadManager.org - http://freedownloadmanager.org (installed 2018-01-10)
    [not loaded]    uBlock - Chris Aljoudi - https://chrismatic.io/ (installed 2015-08-18)
    [enabled]    Adblock Plus - Eyeo GmbH - https://adblockplus.org/ (installed 2018-03-04)
3rd Party Preference Panes: ⓘ
    None
Time Machine: ⓘ
    Skip System Files: NO
    Auto backup: YES
    Volumes being backed up:
        SSD: Disk size: 1000.00 GB Disk used: 366.93 GB
    Destinations:
        Time Machine [Local]
        Total size: 999.86 GB
        Total number of backups: 10
        Oldest backup: 07/03/18, 09:11
        Last backup: 07/03/18, 16:36
            Backup size 999.86 GB < (Disk used 366.93 GB X 3)
Top Processes by CPU: ⓘ
         9%   	fdm
         6%   	kernel_task
         4%   	WindowServer
         1%   	BlockBlock
         1%   	launchd
Top Processes by Memory: ⓘ
    1.68 GB   	kernel_task
    306 MB    	FluidApp
    275 MB    	mds_stores
    219 MB    	fdm
    201 MB    	WindowServer
    Input     	Output    	Process name
    6.65 GB   	716 MB    	fdm
    826 KB    	147 KB    	mDNSResponder
    509 KB    	259 KB    	Mail
    27 KB     	2 KB      	netbiosd
    11 KB     	17 KB     	apsd
     13.30	fdm
      6.02	WindowServer
      1.88	BlockBlock
      0.26	AdobeUpdateDaemon
Virtual Memory Information: ⓘ
    27.30 GB  	Available RAM
    23.10 GB  	Free RAM
    4.70 GB   	Used RAM
    4.20 GB   	Cached files
    0 B       	Swap Used
    Enpass: 5.6.3 (installed 2018-03-02)
    Total Video Converter Pro: 4.3.9 (installed 2018-03-02)
    PDF Toolkit+: 2.3 (installed 2018-03-02)
    EPSON Scan:  (installed 2018-03-02)
    EPSON Printer:  (installed 2018-03-02)
    Epson Connect Printer Setup:  (installed 2018-03-02)
    EpsonNet Config:  (installed 2018-03-02)
    EPSON PC-FAX:  (installed 2018-03-02)
    Epson Scanner ICA Driver:  (installed 2018-03-02)
    Garmin Express:  (installed 2018-03-02)
    Photoshop CC 2017:  (installed 2018-03-03)
    EPSON Software Updater:  (installed 2018-03-03)
    Epson Connect Printer Setup:  (installed 2018-03-03)
    EPSON Printer:  (installed 2018-03-03)
    Microsoft Silverlight Internet Browser Plugin: 5.1.50901.0 (installed 2018-03-04)
    Lame Library v3.99.5 for Audacity:  (installed 2018-03-06)
    2018-03-06 18:15:34    FACEBOOK.app Hang [Open]
    2018-03-06 18:04:00    Audacity.app Crash [Open]
        Cause:        abort() called
    2018-03-05 09:21:03    com.apple.WebKit.WebContent High CPU use [Open] [Details]
iMac-inch, M1, 2021 Chip Apple M1 Memoria 8GB macOS Sonoma 14.4.1
Uno_qualunque
Credo che sia un falso errore. Vuol dire che secondo Etrecheck il tuo backup disk dovrebbe essere circa il triplo di dimensioni rispetto all'attuale occupazione del disco di sistema. Ci sei vicino, tra l'altro.
yale
Grazie per la risposta. Se ho capito bene, ho un backup di 68 GB e Time Machine invece mi indica che il mio Backup è di 366 GB. Vabbè
yale ha scritto:Grazie per la risposta. Se ho capito bene, ho un backup di 68 GB e Time Machine invece mi indica che il mio Backup è di 366 GB. Vabbè
No, EtreCheck guarda la capienza del tuo HD di sistema (non la dimensione del contenuto) e ti segnala in rosso se l'HD di TimeMachine ha una capienza inferiore a tre volte quella del disco di sistema.
Apple consiglia come minimo il doppio, EtreCheck il triplo.
Insomma, se il tuo hd è da 1TB, per Apple il disco di Time Machine deve essere come minimo 2TB (ma di più è meglio), per EtreCheck il disco di Time Machine deve essere come minimo 3TB (ma di più è meglio).
yale
Grazie a tutti. Tutto chiaro... anzi limpido. Il mio inglese, ogni giorno che passa, è sempre più maccheronico :laughing6:
Visitano il forum: Yandex [Bot] e 21 ospiti
