EtreCheck version: 3.4.7 (461)
Report generated 2018-03-07 16:44:15
Runtime: 1:51
Performance: Excellent
Hardware Information: ⓘ
iMac (27-inch, Late 2013)
iMac - model: iMac14,2
1 3,4 GHz Intel Core i5 (i5-4670) CPU: 4-core
32 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
BANK 1/DIMM1
Handoff/Airdrop2: supported
Wireless: en1: Unknown
iCloud Quota: 3.64 GB available
Video Information: ⓘ
NVIDIA GeForce GTX 775M - VRAM: 2 GB
iMac 2560 x 1440
Disk Information: ⓘ
Samsung SSD 850 EVO 1TB disk0: (1 TB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [APFS Container]: 1000.00 GB
USB Information: ⓘ
USB30Bus
Toshiba External USB 3.0
External USB 3.0 disk3: (1 TB)
EFI (disk3s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
Time Machine (disk3s2 - Journaled HFS+) /Volumes/Time Machine : 999.86 GB (931.14 GB free)
Apple Inc. BRCM20702 Hub
VIA Labs, Inc. USB2.0 Hub
Apple, Inc. Keyboard Hub
Apple Inc. Apple Keyboard
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
SSD (disk1s1 - APFS) / [Startup]: 1000.00 GB (633.07 GB free)
Physical disk: disk0s2 1000.00 GB (633.07 GB free)
(disk1s2) <not mounted> [Preboot]: 1000.00 GB
(disk1s3) <not mounted> [Recovery]: 1000.00 GB
(disk1s4) /private/var/vm [VM]: 1000.00 GB
System Software: ⓘ
macOS High Sierra 10.13.3 (17D102) - Time since boot: about 8 hours
Gatekeeper: ⓘ
System Launch Agents: ⓘ
[not loaded] 8 Apple tasks
[loaded] 172 Apple tasks
[running] 110 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 37 Apple tasks
[loaded] 183 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2018-03-03) [Lookup]
[not loaded] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2018-03-03) [Lookup]
[loaded] com.epson.esua.launcher.plist (Seiko Epson Corporation - installed 2018-03-03) [Lookup]
Launch Daemons: ⓘ
[running] com.adobe.adobeupdatedaemon.plist (Adobe Systems, Inc. - installed 2018-03-03) [Lookup]
[loaded] com.apple.installer.osmessagetracing.plist (Apple, Inc. - installed 2018-02-17)
[running] com.objectiveSee.blockblock.plist (? ? ? - installed 2018-03-02) [Lookup]
User Launch Agents: ⓘ
[loaded] org.freedownloadmanager.fdm5.helper.plist (SoftDeluxe, Inc - installed 2018-03-07) [Lookup]
User Login Items: ⓘ
smcFanControl Applicazione
(/Applications/smcFanControl.app)
Internet Plug-ins: ⓘ
Silverlight: 5.1.50901.0 (installed 2018-03-04) [Lookup]
AdobeAAMDetect: 3.0.0.0 (installed 2018-03-03) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2018-01-19)
Safari Extensions: ⓘ
[enabled] Free Download Manager - FreeDownloadManager.org - http://freedownloadmanager.org (installed 2018-01-10)
[not loaded] uBlock - Chris Aljoudi - https://chrismatic.io/ (installed 2015-08-18)
[enabled] Adblock Plus - Eyeo GmbH - https://adblockplus.org/ (installed 2018-03-04)
3rd Party Preference Panes: ⓘ
None
Time Machine: ⓘ
Skip System Files: NO
Auto backup: YES
Volumes being backed up:
SSD: Disk size: 1000.00 GB Disk used: 366.93 GB
Destinations:
Time Machine [Local]
Total size: 999.86 GB
Total number of backups: 10
Oldest backup: 07/03/18, 09:11
Last backup: 07/03/18, 16:36
Size of backup disk: Too small
Backup size 999.86 GB < (Disk used 366.93 GB X 3)
Top Processes by CPU: ⓘ
9% fdm
6% kernel_task
4% WindowServer
1% BlockBlock
1% launchd
Top Processes by Memory: ⓘ
1.68 GB kernel_task
306 MB FluidApp
275 MB mds_stores
219 MB fdm
201 MB WindowServer
Input Output Process name
6.65 GB 716 MB fdm
826 KB 147 KB mDNSResponder
509 KB 259 KB Mail
27 KB 2 KB netbiosd
11 KB 17 KB apsd
13.30 fdm
6.02 WindowServer
1.88 BlockBlock
0.26 AdobeUpdateDaemon
Virtual Memory Information: ⓘ
27.30 GB Available RAM
23.10 GB Free RAM
4.70 GB Used RAM
4.20 GB Cached files
0 B Swap Used
Enpass: 5.6.3 (installed 2018-03-02)
Total Video Converter Pro: 4.3.9 (installed 2018-03-02)
PDF Toolkit+: 2.3 (installed 2018-03-02)
EPSON Scan: (installed 2018-03-02)
EPSON Printer: (installed 2018-03-02)
Epson Connect Printer Setup: (installed 2018-03-02)
EpsonNet Config: (installed 2018-03-02)
EPSON PC-FAX: (installed 2018-03-02)
Epson Scanner ICA Driver: (installed 2018-03-02)
Garmin Express: (installed 2018-03-02)
Photoshop CC 2017: (installed 2018-03-03)
EPSON Software Updater: (installed 2018-03-03)
Epson Connect Printer Setup: (installed 2018-03-03)
EPSON Printer: (installed 2018-03-03)
Microsoft Silverlight Internet Browser Plugin: 5.1.50901.0 (installed 2018-03-04)
Lame Library v3.99.5 for Audacity: (installed 2018-03-06)
2018-03-06 18:15:34 FACEBOOK.app Hang [Open]
2018-03-06 18:04:00 Audacity.app Crash [Open]
Cause: abort() called
2018-03-05 09:21:03 com.apple.WebKit.WebContent High CPU use [Open] [Details]
