EtreCheck version: 3.4.6 (460)
Report generated 2017-11-21 00:29:07
Runtime: 5:58
Performance: Below Average
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Click the [Clean up] link to delete unused files.
Problem: Other problem
Description:
Plugin UploadedManager
Hardware Information: ⓘ
iMac (21.5-inch, Late 2013)
iMac - model: iMac14,1
1 2.7 GHz Intel Core i5 (i5-4570R) CPU: 4-core
BANK 0/DIMM0
4 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Handoff/Airdrop2: supported
Wireless: en1: 802.11 a/b/g/n/ac
iCloud Quota: 42.85 GB available
Video Information: ⓘ
Intel Iris Pro - VRAM: 1536 MB
iMac 1920 x 1080
Disk Information: ⓘ
APPLE HDD HTS541010A9E662 disk0: (1 TB) (Rotational)
[Show SMART report]
(disk0s2) <not mounted> [CoreStorage Container]: 999.35 GB
Recovery HD (disk0s3 - HFS+) <not mounted> [Recovery]: 650 MB
USB Information: ⓘ
USB30Bus
Apple Inc. BRCM20702 Hub
Western Digital Ext HDD 1021
Ext HDD 1021 disk2: (2 TB)
Elements (disk2s1 - Journaled HFS+) /Volumes/Elements : 2.00 TB (1.39 TB free)
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
Macintosh HD (disk1 - Journaled HFS+) / [Startup]: 999.01 GB (912.15 GB free)
Physical disk: disk0s2 999.35 GB Online
OmniDiskSweeper (disk3 - HFS+) /Volumes/OmniDiskSweeper : 67 MB (60 MB free)
Physical disk: Disk Image 67 MB (60 MB free)
System Software: ⓘ
macOS High Sierra 10.13.1 (17B48) - Time since boot: about 11 hours
Gatekeeper: ⓘ
Possible adware: ⓘ
Adware: ~/Library/LaunchAgents/com.appart.AppArt.plist
Adware: ~/Library/LaunchAgents/com.applicationstats.AppStats.plist
2 possible adware files found. [Remove/Report]
Clean up: ⓘ
~/Library/LaunchAgents/com.skype.skype.shareagent.plist
/Applications/Skype.app/Contents/Library/LaunchServices/com.skype.skype.shareagent.bundle/Contents/MacOS/com.skype.skype.shareagent
Executable not found!
One orphan file found. [Clean up]
Kernel Extensions: ⓘ
/Library/Application Support/Kaspersky Lab/KAV/Bases/Cache
[loaded] com.kaspersky.kext.kimul (46) [Lookup]
[loaded] com.kaspersky.kext.mark.1.0.6 (1.0.6 - SDK 10.9) [Lookup]
/System/Library/Extensions
[loaded] com.kaspersky.kext.klif (3.3.0d1) [Lookup]
[loaded] com.kaspersky.nke (2.1.0) [Lookup]
System Launch Agents: ⓘ
[not loaded] 8 Apple tasks
[loaded] 167 Apple tasks
[running] 113 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 34 Apple tasks
[loaded] 179 Apple tasks
[running] 117 Apple tasks
Launch Agents: ⓘ
[failed] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2017-01-12) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2017-09-28) [Lookup]
[running] com.kaspersky.kav.gui.plist (? 6b215336 2ee1db3f - installed 2017-11-20) [Lookup]
[loaded] com.oracle.java.Java-Updater.plist (? 130509c6 be93c7fb - installed 2017-04-23) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2017-01-12) [Lookup]
[loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2017-01-12) [Lookup]
[loaded] com.adobe.fpsaud.plist (? 2afb3af7 defea098 - installed 2017-10-26) [Lookup]
[not loaded] com.apple.installer.cleanupinstaller.plist (? 1963bf56 0 - installed 2017-11-13)
[running] com.cleverfiles.cfbackd.plist (Justin Johnson - installed 2017-09-15) [Lookup]
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2017-10-13) [Lookup]
[running] com.kaspersky.kav.plist (Kaspersky Lab UK Limited - installed 2017-11-20) [Lookup]
[loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2017-04-13) [Lookup]
[loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e cf9ce3fb - installed 2014-02-26) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script e3fefdd2 - installed 2017-03-15) [Lookup]
[loaded] com.purevpn.macapp.HelperTool.plist (GZ Systems Limited - installed 2016-01-12) [Lookup]
User Launch Agents: ⓘ
[running] com.appart.AppArt.plist (? 5dee8426 7617e226 - installed 2016-09-02) Adware! [Remove/Report]
~/Library/Application Support/AppPolicy/AppArt
[running] com.applicationstats.AppStats.plist (? 75ef3e3c dfbefa0e - installed 2016-12-28) Adware! [Remove/Report]
~/Library/Application Support/Spigot/AppStats
[loaded] com.bittorrent.uTorrent.plist (BitTorrent, Inc - installed 2016-03-17) [Lookup]
[loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2017-08-11) [Lookup]
[loaded] com.skype.skype.shareagent.plist (? 9e64636f 0 - installed 2017-11-13) [Lookup] - /Applications/Skype.app/Contents/Library/LaunchServices/com.skype.skype.shareagent.bundle/Contents/MacOS/com.skype.skype.shareagent: Executable not found!
User Login Items: ⓘ
Dropbox Applicazione
(/Applications/Dropbox.app)
iTunesHelper Applicazione (Apple, Inc. - installed 2017-11-01)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
SmartDaemon Applicazione
(/Library/Application Support/CleverFiles/SmartDaemon.app)
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 27.0.0.187 (installed 2017-11-15) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2017-10-25)
AdobePDFViewerNPAPI: 17.012.20098 (installed 2017-11-16) [Lookup]
AdobePDFViewer: 18.009.20044 (installed 2017-11-16) [Lookup]
Flash Player: 27.0.0.187 (installed 2017-11-15) [Lookup]
RL Secure Plug-In Layer: Unknown (installed 2016-11-28) [Lookup]
npTemWebRTCPlugin: TemWebRTCPlugin_x86_64 0.8.876 (installed 2016-08-02) [Lookup]
SharePointBrowserPlugin: 14.7.3 (installed 2017-04-13) [Lookup]
JavaAppletPlugin: Java 8 Update 131 build 11 (installed 2017-04-23) Check version
User internet Plug-ins: ⓘ
UploadManager: Unknown (installed 2017-09-12) [Lookup]
Picasa: 1.0 (installed 2015-07-10) [Lookup]
ContentManager: Unknown (installed 2017-09-12) [Lookup]
RocketEngine: Unknown (installed 2017-09-12) [Lookup]
Safari Extensions: ⓘ
[enabled] Kaspersky URL Advisor - Kaspersky Lab - http://kaspersky.com (installed 2015-06-05)
[enabled] Virtual Keyboard - Kaspersky Lab - http://kaspersky.com (installed 2015-06-05)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2017-10-26) [Lookup]
FUSE (installed 2017-07-18) [Lookup]
Java (installed 2017-04-23) [Lookup]
Time Machine: ⓘ
Mobile backups: OFF
Auto backup: YES
Volumes being backed up:
Macintosh HD: Disk size: 999.01 GB Disk used: 86.86 GB
Destinations:
Elements [Local]
Total size: 2.00 TB
Total number of backups: 145
Oldest backup: 28.10.15, 18:35
Last backup: 20.11.17, 23:47
Size of backup disk: Adequate
Backup size 2.00 TB > (Disk used 86.86 GB X 3)
Top Processes by CPU: ⓘ
3% WindowServer
3% mds
2% kernel_task
2% kav
1% kav_agent
Top Processes by Memory: ⓘ
833 MB kernel_task
613 MB com.apple.WebKit.WebContent
372 MB OmniDiskSweeper
248 MB com.apple.WebKit.WebContent
229 MB kav
Input Output Process name
998 KB 359 KB mDNSResponder
417 KB 229 KB Dropbox
124 KB 66 KB netbiosd
69 KB 98 KB kav
120 KB 33 KB Mail
5.22 WindowServer
1.40 kav
1.00 kav_agent
0.60 launchd
Virtual Memory Information: ⓘ
2.44 GB Available RAM
83 MB Free RAM
5.56 GB Used RAM
2.36 GB Cached files
45 MB Swap Used
Adobe Flash Player: (installed 2017-10-25)
ifolor Designer: 3.3.0 (installed 2017-10-28)
ifolor Designer: 3.3.1 (installed 2017-11-13)
Adobe Flash Player: (installed 2017-11-15)
Adobe Acrobat Reader DC (18.009.20044): (installed 2017-11-16)
2017-11-21 00:04:54 com.apple.WebKit.Plugin.32 Crash [Open]
Cause: *** CFRelease() called with NULL ***
2017-11-20 23:02:48 kav Crash [Open]
sudo launchctl unload /Library/LaunchDaemons/com.adobe.ARMDC.Communicator.plist;sudo launchctl unload /Library/LaunchDaemons/com.adobe.ARMDC.SMJobBlessHelper.plist;sudo launchctl unload /Library/LaunchAgents/com.adobe.ARMDCHelper.*.plist
sudo rm -rf /Library/LaunchDaemons/com.adobe.ARMDC.Communicator.plist /Library/LaunchDaemons/com.adobe.ARMDC.SMJobBlessHelper.plist /Library/LaunchAgents/com.adobe.ARMDCHelper.*.plist /Applications/Adobe\ Acrobat\ Reader\ DC.app /Library/Preferences/com.adobe.reader.DC.WebResource.plist /Library/Application\ Support/Adobe/ARMDC /Library/Application\ Support/Adobe/ARMNext /Library/Application\ Support/Adobe/HelpCfg /Library/Application\ Support/Adobe/Reader/DC /Library/Internet\ Plug-Ins/AdobePDFViewer.plugin /Library/Internet\ Plug-Ins/AdobePDFViewerNPAPI.plugin /Library/PrivilegedHelperTools/com.adobe.ARMDC.* ~/Library/Application\ Support/Adobe/AcroCef ~/Library/Application\ Support/Adobe/Acrobat/DC ~/Library/Application\ Support/CEF ~/Library/Logs/DiagnosticReports/AdobeReader_*.crash ~/Library/Preferences/com.adobe.AdobeRdrCEF.plist /private/var/db/receipts/com.adobe.RdrServicesUpdater.* /private/var/db/receipts/com.adobe.acrobat.DC.* /private/var/db/receipts/com.adobe.armdc.*
sudo rm -rf /Library/Internet Plug-ins/AdobePDFViewer.plugin /Library/Internet Plug-ins/AdobePDFViewerNPAPI.plugin
Ci riuscirai certamente.nene ha scritto:Mamma mia che casino ..... spero di riuscire a fare tutto senza fare danni, quindi sarebbe meglio disinstallare l'antivirus???
Report generated 2017-11-21 16:49:28
Runtime: 10:43
Performance: Poor
Description:
BANK 0/DIMM0
BANK 1/DIMM0
iMac 1920 x 1080
Disk Information: ⓘ
[Show SMART report]
Recovery HD (disk0s3 - Journaled HFS+) <not mounted> [Recovery]: 650 MB
USB Information: ⓘ
USB30Bus
Virtual disks: ⓘ
Macintosh HD (disk1 - Journaled HFS+) / [Startup]: 999.01 GB (914.95 GB free)
System Software: ⓘ
macOS High Sierra 10.13.1 (17B48) - Time since boot: less than an hour
Gatekeeper: ⓘ
[loaded] 178 Apple tasks
[running] 102 Apple tasks
[loaded] 187 Apple tasks
[running] 109 Apple tasks
Launch Agents: ⓘ
[running] com.kaspersky.kav.gui.plist (? 6b215336 2ee1db3f - installed 2017-11-21) [Lookup]
Launch Daemons: ⓘ
[running] com.kaspersky.kav.plist (Kaspersky Lab UK Limited - installed 2017-11-21) [Lookup]
User Login Items: ⓘ
iTunesHelper Applicazione (? 0 - installed 2017-11-01)
[enabled] Kaspersky URL Advisor - Kaspersky Lab - http://kaspersky.com" onclick="window.open(this.href);return false; (installed 2015-06-05)
[enabled] Virtual Keyboard - Kaspersky Lab - http://kaspersky.com" onclick="window.open(this.href);return false; (installed 2015-06-05)
Time Machine: ⓘ
Mobile backups: OFF
Auto backup: YES
Macintosh HD: Disk size: 999.01 GB Disk used: 84.06 GB
Destinations:
Elements [Local]
Total size: 2.00 TB
Total number of backups: 148
Last backup: 21.11.17, 16:00
Backup size 2.00 TB > (Disk used 84.06 GB X 3)
8% com.apple.WebKit.WebContent
3% WindowServer
3% kernel_task
2% ReportCrash
2% kav
726 MB kernel_task
365 MB com.apple.WebKit.WebContent
237 MB kav
148 MB Dropbox
147 MB Safari
2 MB 265 KB kav
36 KB 29 KB mDNSResponder
5 KB 13 KB apsd
4 KB 3 KB Dropbox
3 KB 2 KB netbiosd
3.80 kav
2.20 com.apple.WebKit.WebContent
1.62 assistant_service
0.96 kav_agent
4.15 GB Available RAM
102 MB Free RAM
3.85 GB Used RAM
4.05 GB Cached files
0 B Swap Used
2017-11-21 16:42:05 com.apple.WebKit.Plugin.32 Crash [Open]
2017-11-21 15:03:16 com.apple.WebKit.Networking Crash [Open]
Cause: terminating with uncaught exception of type std::__1::system_error: mutex lock failed: Invalid argument
abort() called
Files deleted by EtreCheck: ⓘ
2017-11-21 13:54:08 - ~/Library/LaunchAgents/com.appart.AppArt.plist - Unknown
2017-11-21 13:54:08 - ~/Library/LaunchAgents/com.applicationstats.AppStats.plist - Unknown
2017-11-21 13:54:44 - ~/Library/LaunchAgents/com.skype.skype.shareagent.plist - Unknown
/code]
Hai letto cose in giro scritte da incompetenti.nene ha scritto:... una cosa che mi fa veramente paura, non aver antivirus, faccio spesso dei pagamento on line ed altro ed è per questo che mi fa venire la pelle d'oca ho letto un po' in giro che avere un antimalware in grado di effettuare una scansione on-demand del computer quando necessario (evitando così l’appesantimento dovuto al controllo in tempo reale del sistema) non sarebbe male, che ne pensi...
faxus ha scritto:...- Elimina i plugin...
~/Library/Internet Plug-ins/UploadManager
~/Library/Internet Plug-ins/Picasa
~/Library/Internet Plug-ins/RocketEngine
- Aggiorna Java
- Elimina CleverFile e toglilo anche da preferenze di Sistema > Utenti e gruppi > Elementi del login ...
Scommetto che:nene ha scritto:... ~/Library/Internet Plug-ins/UploadManager ~/Library/Internet Plug-ins/Picasa
~/Library/Internet Plug-ins/RocketEngine... non gli ho trovati, nella cartella non ci sono...
viewtopic.php?f=5&t=19867&start=75#p457896" onclick="window.open(this.href);return false;nene ha scritto:... Java non posso aggiornarlo visto che ho macOS Sierra 10.13.1 e l'ultima versione è:macOS Sierra 10.12...
Se non lo trovi, forse è invisibile.nene ha scritto:... CleverFile non ho potuto eliminarlo visto che non risulta ( ci sono Dropbox, SmartDaemon e iTunesHelper)...
sudo rm -rf /.cleverfiles
Te l'ho detto, procurati un SSD economico e adatto al Mac (per esempio un Crucial MX300).nene ha scritto:... Fammi sapere cosa devo fare, a questo punto mi Sto arrivando! che tornerò a Sierra (sempre che ci riesca....)...
Report generated 2017-11-22 02:20:33
Runtime: 4:20
Performance: Good
Description:
Plugin
BANK 0/DIMM0
BANK 1/DIMM0
iMac 1920 x 1080
Disk Information: ⓘ
USB Information: ⓘ
USB30Bus
Virtual disks: ⓘ
Macintosh HD (disk1 - Journaled HFS+) / [Startup]: 999.01 GB (924.94 GB free)
System Software: ⓘ
Gatekeeper: ⓘ
[loaded] 174 Apple tasks
[running] 106 Apple tasks
[loaded] 186 Apple tasks
[running] 110 Apple tasks
Launch Agents: ⓘ
Launch Daemons: ⓘ
User Login Items: ⓘ
None
Time Machine: ⓘ
Mobile backups: OFF
Auto backup: YES
Macintosh HD: Disk size: 999.01 GB Disk used: 74.07 GB
Destinations:
Elements [Local]
Total size: 2.00 TB
Last backup: 22.11.17, 01:48
Backup size 2.00 TB > (Disk used 74.07 GB X 3)
6% WindowServer
3% kernel_task
2% sandboxd
2% com.apple.WebKit.WebContent
0% fontd
636 MB kernel_task
159 MB Dropbox
108 MB mds_stores
100 MB com.apple.WebKit.WebContent
93 MB Safari
68 KB 103 KB Dropbox
63 KB 12 KB Mail
39 KB 27 KB mDNSResponder
37 KB 14 KB cloudd
15 KB 4 KB com.apple.WebKit.Networking
8.14 WindowServer
4.32 mds
2.12 com.apple.WebKit.WebContent
1.54 mds_stores
5.00 GB Available RAM
1.80 GB Free RAM
3.00 GB Used RAM
3.20 GB Cached files
0 B Swap Used
2017-11-21 20:20:12 com.apple.WebKit.Plugin.32 Crash [Open]
abort() called
Direi che va bene, è la normalità.nene ha scritto:... penso di aver fatto tutto, qui ti posto l'ultimo controllo EtreCheck, devo dire che dopo aver tolto l'antivirus quando ho riavviato tutto sembraba addirittura più veloce ...
sudo /System/Library/Filesystems/fusefs_txantfs.fs/Support/uninstall-package.sh
/Library/ internet Plug-ins
Non tutti, qualcuno potrebbe essere utile.nene ha scritto:... devo cancellare tutti file al interno della cartella anche quelli al interno della cartella Disabled Plug-ins?...
Cestina solo quelli indicati
Visitano il forum: Apple [Bot], Yandex [Bot] e 7 ospiti
