[quote]EtreCheck version: 3.4.6 (460)
Report generated 2017-11-18 15:38:27
Runtime: 3:51
Performance: Good
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Hardware Information: ⓘ
iMac (21.5-inch, Late 2015)
iMac - model: iMac16,1
1 1,6 GHz Intel Core i5 (i5-5250U) CPU: 2-core
8 GB RAM Not upgradeable
BANK 0/DIMM0
4 GB DDR3 1867 MHz ok
BANK 1/DIMM0
Handoff/Airdrop2: supported
Wireless: en1: 802.11 a/b/g/n/ac
iCloud Quota: 4.88 GB available
Video Information: ⓘ
Intel HD Graphics 6000 - VRAM: 1536 MB
iMac 1920 x 1080
Disk Information: ⓘ
APPLE HDD HTS541010A9E662 disk0: (1 TB) (Rotational)
[Show SMART report]
Macintosh HD (disk0s2 - Journaled HFS+) / [Startup]: 999.35 GB (873.67 GB free)
Recovery HD (disk0s3 - HFS+) <not mounted> [Recovery]: 650 MB
USB Information: ⓘ
USB30Bus
Western Digital Elements 10B8
Elements 10B8 disk1: (1,5 TB)
time machine (disk1s1 - Journaled HFS+) /Volumes/time machine : 1.50 TB (227.67 GB free)
Western Digital Elements 1042
Elements 1042 disk2: (500,11 GB)
500 (disk2s1 - MS-DOS FAT32) /Volumes/500 : 500.11 GB (288.52 GB free)
Western Digital My Passport 0740
My Passport 0740 disk3: (500,07 GB)
500 MUSICA (disk3s1 - MS-DOS FAT32) /Volumes/500 MUSICA : 500.07 GB (477 MB free)
Broadcom Corp. Bluetooth USB Host Controller
USB2.0 Hub
GODO USB3.0 External HDD
EZRX-00L4HB0 disk4: (1 TB)
1 tera (disk4s1 - Journaled HFS+) /Volumes/1 tera : 1.00 TB (686.99 GB free)
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
System Software: ⓘ
macOS High Sierra 10.13.1 (17B48) - Time since boot: about 5 hours
Configuration files: ⓘ
/etc/hosts - Count: 60
Gatekeeper: ⓘ
Possible adware: ⓘ
Unknown file: ~/Library/LaunchAgents/com.Hannibalian.ij.plist
~/Library/Hannibalian.ij/Hannibalian.ij.app/Contents/MacOS/Hannibalian.ij
Unknown file: ~/Library/LaunchAgents/com.pneumatometer.vm.plist
~/Library/pneumatometer.vm/pneumatometer.vm.app/Contents/MacOS/pneumatometer.vm
2 possible adware files found. [Remove/Report]
Kernel Extensions: ⓘ
/Library/Application Support/Roxio
[not loaded] com.roxio.TDIXController (2.0) [Lookup]
/Library/Extensions
[not loaded] com.FTDI.driver.D2XXHelper (1.0 - SDK 10.11) [Lookup]
/System/Library/Extensions
[loaded] com.Cycling74.driver.Soundflower (1.6.7 - SDK 10.7) [Lookup]
[not loaded] com.wacom.kext.wacomtablet (Wacom Tablet 6.3.17-5 - SDK 10.11) [Lookup]
System Launch Agents: ⓘ
[not loaded] 8 Apple tasks
[loaded] 169 Apple tasks
[running] 110 Apple tasks
[killed] One Apple task
one process killed due to insufficient RAM
System Launch Daemons: ⓘ
[failed] com.apple.postfix.master.plist (Apple, Inc. - installed 2017-10-25)
[not loaded] 37 Apple tasks
[loaded] 180 Apple tasks
[running] 111 Apple tasks
Launch Agents: ⓘ
[loaded] com.oracle.java.Java-Updater.plist (? 811f7b0a 72ac4dde - installed 2017-11-18) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2017-08-10) [Lookup]
[loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2017-08-10) [Lookup]
[loaded] com.macpaw.CleanMyMac3.Agent.plist (MacPaw Inc. - installed 2017-11-13) [Lookup]
[loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2017-09-15) [Lookup]
[loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2017-10-20) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script e3fefdd2 - installed 2017-11-18) [Lookup]
[not loaded] org.eyebeam.SelfControl.plist (Charlie Stigler - installed 2017-11-10) [Lookup]
User Launch Agents: ⓘ
[loaded] com.Hannibalian.ij.plist (? 47eacc33 c7d1edb5 - installed 2017-07-21) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2017-09-28) [Lookup]
[loaded] com.macpaw.CleanMyMac3.Scheduler.plist (MacPaw Inc. - installed 2017-11-12) [Lookup]
[loaded] com.pneumatometer.vm.plist (? 4324a2d8 41109ad0 - installed 2017-10-24) [Lookup]
[running] com.spotify.webhelper.plist (Spotify - installed 2017-11-10) [Lookup]
User Login Items: ⓘ
Android File Transfer Agent Applicazione
(~/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app)
Mail Applicazione
(/Applications/Mail.app)
CleanMyMac 3 Menu Applicazione (? 0 - installed 2017-10-26)
(/Applications/CleanMyMac 3.app/Contents/MacOS/CleanMyMac 3 Menu.app)
com.adobe.SwitchBoard.monitor.plist MachInit - Hidden
(/etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist)
Mach Init items are deprecated
Internet Plug-ins: ⓘ
AdobeAAMDetect: 3.0.0.0 (installed 2017-05-01) [Lookup]
FlashPlayer-10.6: 26.0.0.151 (installed 2017-08-14) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2017-10-25)
AdobePDFViewerNPAPI: 17.012.20098 (installed 2017-11-17) [Lookup]
AdobePDFViewer: 18.009.20044 (installed 2017-11-17) [Lookup]
Flash Player: 26.0.0.151 (installed 2017-08-14) Outdated! Update
Silverlight: 5.1.50901.0 (installed 2016-10-23) [Lookup]
WacomTabletPlugin: WacomTabletPlugin 2.1.0.6 (installed 2016-07-23) [Lookup]
JavaAppletPlugin: Java 8 Update 151 build 12 (installed 2017-11-18) Check version
Safari Extensions: ⓘ
[enabled] AdBlock - BetaFish, Inc. - https://getadblock.com" onclick="window.open(this.href);return false; (installed 2017-11-15)
[enabled] DuckDuckGo - DuckDuckGo - http://duckduckgo.com" onclick="window.open(this.href);return false; (installed 2017-08-10)
[not loaded] Open in Internet Explorer - Parallels - http://www.parallels.com" onclick="window.open(this.href);return false; (installed 2017-11-15)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2017-07-25) [Lookup]
Java (installed 2017-11-18) [Lookup]
Witch (installed 2017-08-06) [Lookup]
Time Machine: ⓘ
Auto backup: YES
Volumes being backed up:
Macintosh HD: Disk size: 999.35 GB Disk used: 125.68 GB
Destinations:
time machine [Local]
Total size: 1.50 TB
Total number of backups: 49
Oldest backup: 29/08/2017, 13:45
Last backup: 18/11/2017, 14:36
Size of backup disk: Adequate
Backup size 1.50 TB > (Disk used 125.68 GB X 3)
Top Processes by CPU: ⓘ
3% AddressBookSourceSync
3% WindowServer
2% kernel_task
2% com.apple.WebKit.WebContent
2% Safari
Top Processes by Memory: ⓘ
816 MB kernel_task
606 MB Safari
296 MB com.apple.WebKit.WebContent
155 MB mds_stores
146 MB com.apple.WebKit.WebContent
Input Output Process name
2 MB 77 KB mDNSResponder
1 MB 37 KB com.apple.WebKit.Networking
61 KB 25 KB Mail
44 KB 12 KB netbiosd
15 KB 26 KB usbmuxd
12.60 backupd
3.22 com.apple.WebKit.WebContent
3.20 Safari
2.42 WindowServer
1.72 mds
Virtual Memory Information: ⓘ
3.88 GB Available RAM
1.03 GB Free RAM
4.12 GB Used RAM
2.86 GB Cached files
12 MB Swap Used
Microsoft AutoUpdate: (installed 2017-10-20)
GravitDesigner: 3.2.5 (installed 2017-10-21)
Telegram: 3.5.2 (installed 2017-10-23)
Mactracker: 7.7 (installed 2017-10-26)
Telegram: 3.5.3 (installed 2017-10-31)
Fotor Photo Editor: 3.4.1 (installed 2017-11-02)
SketchBook: 8.5.2 (installed 2017-11-02)
Evernote: 6.13 (installed 2017-11-03)
App Cleaner & Uninstaller: 4.6 (installed 2017-11-10)
AntiSleep: 1.3 (installed 2017-11-10)
Garmin Express: (installed 2017-11-13)
PDF Reader Pro Free: 2.1 (installed 2017-11-13)
PDF Reader Pro Free: 2.1.1 (installed 2017-11-16)
Open Any File: 1.2.3 (installed 2017-11-17)
Adobe Acrobat Reader DC (18.009.20044): (installed 2017-11-17)
Music Converter: 1.5.2 (installed 2017-11-17)
Java 8 Update 151: (installed 2017-11-18)
2017-11-17 21:26:25 WindowServer Crash [Open]
Cause: StartTime:2017-11-17 21:24:12
GPU:
VirtDisplay0
Assertion failed: (0 && "Attempting to get MTLTexture with no MTLDevice"), function GetMTLTexture, file /BuildRoot/Library/Caches/com.apple.xbs/Sources/CoreDisplay/CoreDisplay-79.8/CoreDisplay/Display/DisplaySurface.mm, line 498.
/quote]
