Oppure iMovie o Finalcut o Premiere.You have a Matroska (*.mkv) file with H.264 video and AAC audio. The Matroska container format is not supported (and therefore not playable) by default on Microsoft Windows, Mac OS X (without additional software) or various hardware devices, but H.264 and AAC is! This means you can open the file in Avidemux, change the output format to MP4 (which is the container format supported by default on those platforms), and save it in copy mode. Audio and video tracks will be left untouched, so it will be quick and lossless. Only the wrapper, the container, will be different. If the H.264 video was encoded with basic features supported on those platforms, the file should now be playable there.
Con Handbrake posso convertire anche h264?J.T.Kirk ha scritto:Se trovi h265 li converti con Handbrake (ultime versioni).
Dipende da quali sono quelle originarie e quali vuoi ottenere.Cizzu ha scritto: Le impostazioni corrette quali sono? Qui mi perdo.
Visitano il forum: Yandex [Bot] e 18 ospiti
