Stranezze di Safari
Finalmente adesso si capisce il problema.
Bastava scriverlo invece che postare rinvii ad immagini su hot link senza indicazioni... Grazie.
Io, su High Sierra e con Safari TP lo vedo così:
Ma proprio ieri, con Sierra, ci sono passato per vedere un prezzo, e vedevo lo stesso.
Ti manca qualche plugin, evidentemente
barbatopo
Questo è il log, spero di aver seguito bene la guida
Process:               Safari [40597]
Path:                  /Applications/Safari.app/Contents/MacOS/Safari
Identifier:            com.apple.Safari
Version:               11.0 (13604.1.38.1.6)
Build Info:            WebBrowser-7604001038001006~6
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Safari [40597]
User ID:               501
Date/Time:             2017-10-12 11:39:31.204 +0200
OS Version:            Mac OS X 10.13 (17A405)
Report Version:        12
Anonymous UUID:        D0B9BD2A-2338-EE1F-755D-8C7BD046273E
Sleep/Wake UUID:       1D53A729-068E-447D-93A3-09CD28AF110C
Time Awake Since Boot: 360000 seconds
Time Since Wake:       340000 seconds
System Integrity Protection: enabled
Crashed Thread:        5  Dispatch queue: WebResourceLoadStatisticsStore Process Data Queue
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [0]
Thread 5 Crashed:: Dispatch queue: WebResourceLoadStatisticsStore Process Data Queue
0   com.apple.WebKit              	0x00007fff3f4b9e5e WebKit::WebResourceLoadStatisticsStore::createEncoderFromData() const + 512
1   com.apple.WebKit              	0x00007fff3f2ef347 WebKit::ResourceLoadStatisticsPersistentStorage::writeMemoryStoreToDisk() + 59
2   com.apple.WebKit              	0x00007fff3f2ef97c WTF::Function<void ()>::CallableWrapper<WebKit::ResourceLoadStatisticsPersistentStorage::finishAllPendingWorkSynchronously()::$_4>::call() + 24
3   libdispatch.dylib             	0x00007fff5812c7a2 _dispatch_call_block_and_release + 12
4   libdispatch.dylib             	0x00007fff58124f64 _dispatch_client_callout + 8
5   libdispatch.dylib             	0x00007fff5813942b _dispatch_queue_serial_drain + 635
6   libdispatch.dylib             	0x00007fff5812c30e _dispatch_queue_invoke + 373
7   libdispatch.dylib             	0x00007fff5813a117 _dispatch_root_queue_drain_deferred_wlh + 332
8   libdispatch.dylib             	0x00007fff5813def0 _dispatch_workloop_worker_thread + 880
9   libsystem_pthread.dylib       	0x00007fff583e8033 _pthread_wqthread + 980
10  libsystem_pthread.dylib       	0x00007fff583e7c4d start_wqthread + 13
barbatopo
faxus ha scritto:Finalmente adesso si capisce il problema.
Quale plugin potrebbe mancare...?
Il crash di Safari non incide su questa discussione.
È stato un crollo casuale della memoria o della cache
barbatopo ha scritto:... Quale plugin potrebbe mancare...?
Non si vede,
Ma un'analisi del contenuto della pagina evidenzia che è un'impossibilità di decodificare una font.
Quindi:
- Safari > Preferenze > Sicurezza > Abilita JavaScript, Consenti WebGL, Consenti plugin.
Deseleziona eventualmente: Blocca finestre a comparsa.
- Safari > Preferenze > Vista > Codifica testo
Poi vedi se va
barbatopo
Allora, da sicurezza non c'è né consenti WebGL né consenti Plugin. Il resto ho fatto come hai detto tu.
In preferenze non c'è il tab Vista. Se intendi il menù tra modifica e Cronologia, andando su codifica testo è selezionato default.
In ogni caso continua a non andare.
Ho anche provato a creare un altro utente, ovviamente senza account iCloud in modo che Safari non avesse nessuna impostazione presa appunto dal Cloud, ma isba lo stesso.
