dopo essermi presentato nella giusta sezione vi espongo il mio problema.
Possessore di un Imac metà 2007 el capitan sono entrato nel pallone per una esasperante lentezza.
Qui sotto proverò ad inserirei resoconti di EtreCheck e smartUtility.
Vi chiedo cortesemente, vista la mia poca dimestichezza, di spiegarmi passo passo evntuali interventi.
EtreCheck version: 3.1.5 (343)
Report generated 2017-04-08 19:05:40
Runtime 6:36
Performance: Below Average
Hardware Information: ?
iMac (20-inch, Mid 2007)
iMac - model: iMac7,1
1 2,4 GHz Intel Core 2 Duo (Duo) CPU: 2-core
4 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
2 GB DDR2 SDRAM 667 MHz ok
BANK 1/DIMM1
Wireless: en1: 802.11 a/b/g/n
Video Information: ?
ATI,RadeonHD2600 - VRAM: 256 MB
iMac 1680 x 1050
System Software: ?
OS X El Capitan 10.11.6 (15G1217) - Time since boot: about one hour
Disk Information: ?
WDC WD3200AAJS-40RYA0 disk0 : (320,07 GB) (Rotational)
[Show SMART report]
hd interno (disk0s2) / [Startup]: 319.21 GB (30.55 GB free) - 7 errors
Drive failure!
USB Information: ?
Apple Inc. Built-in iSight
Gatekeeper: ?
Anywhere
Kernel Extensions: ?
/Library/Extensions
[not loaded] expressvpn.tap (20150118 - 2017-03-23) [Support]
[loaded] expressvpn.tun (20150118 - 2017-03-23) [Support]
/System/Library/Extensions
[not loaded] com.devguru.driver.SamsungComposite (1.4.14 - SDK 10.6 - 2017-03-23) [Support]
[not loaded] com.tomtom.driver.UsbEthernetGadget (1.0.0d1 - 2017-03-23) [Support]
/System/Library/Extensions/ssuddrv.kext/Contents/PlugIns
[not loaded] com.devguru.driver.SamsungACMControl (1.4.14 - SDK 10.6 - 2013-11-04) [Support]
[not loaded] com.devguru.driver.SamsungACMData (1.4.14 - SDK 10.6 - 2013-11-04) [Support]
[not loaded] com.devguru.driver.SamsungMTP (1.4.14 - SDK 10.5 - 2013-11-04) [Support]
[not loaded] com.devguru.driver.SamsungSerial (1.4.14 - SDK 10.6 - 2013-11-04) [Support]
System Launch Agents: ?
[not loaded] 8 Apple tasks
[loaded] 162 Apple tasks
[running] 69 Apple tasks
System Launch Daemons: ?
[failed] com.apple.sandboxd.plist (2017-01-12)
[not loaded] 44 Apple tasks
[loaded] 156 Apple tasks
[running] 89 Apple tasks
Launch Daemons: ?
[loaded] com.BlueStacks.AppPlayer.bstservice_helper.plist (2017-02-10) [Support]
[loaded] com.adobe.ARMDC.Communicator.plist (2017-01-10) [Support]
[loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (2017-01-10) [Support]
[running] com.adobe.adobeupdatedaemon.plist (2017-02-21) [Support]
[running] com.adobe.agsservice.plist (2017-03-10) [Support]
[loaded] com.adobe.fpsaud.plist (2017-02-28) [Support]
[loaded] com.expressvpn.tap.plist (2016-07-09)
[loaded] com.expressvpn.tun.plist (2016-07-09)
[loaded] com.malwarebytes.HelperTool.plist (2017-02-12) [Support]
[loaded] com.oracle.java.Helper-Tool.plist (2016-04-01) [Support]
User Launch Agents: ?
[loaded] com.adobe.AAM.Updater-1.0.plist (2017-02-19) [Support]
[failed] com.adobe.ARM.[...].plist (2015-01-14) [Support] - /Applications/Adobe Reader.app/Contents/MacOS/Updater/Adobe Reader Updater Helper.app/Contents/MacOS/Adobe Reader Updater Helper: Executable not found!
[failed] com.adobe.ARM.[...].plist (2013-06-23) [Support] - /Volumes/cartella/Applications/Adobe Reader.app/Contents/MacOS/Updater/Adobe Reader Updater Helper.app/Contents/MacOS/Adobe Reader Updater Helper: Executable not found!
[failed] com.apple.CSConfigDotMacCert-[...]@me.com-SharedServices.Agent.plist (2012-05-01) - /System/Library/Frameworks/CoreServices.framework/Frameworks/OSServices.framework/Versions/A/Support/CSConfigDotMacCert: Executable not found!
[loaded] com.google.keystone.agent.plist (2017-01-14) [Support]
[running] com.microsoft.LaunchAgent.SyncServicesAgent.plist (2017-04-08) [Support]
[loaded] com.nchsoftware.photopad.schedule.LikeSurvey.plist (2014-09-09) [Support]
[running] com.nds.pcshow.plist (2016-07-09)
[loaded] com.nds.pcshow.uninstall.plist (2017-03-23)
Internet Plug-ins: ?
AdobeAAMDetect: 3.0.0.0 - SDK 10.9 (2017-02-21) [Support]
FlashPlayer-10.6: 25.0.0.127 - SDK 10.9 (2017-03-15) [Support]
Default Browser: 601 - SDK 10.11 (2017-01-08)
QuickTime Plugin: 7.7.3 (2017-01-08)
CANONiMAGEGATEWAYDL: 2.1.0.1 (2006-04-21) [Support]
Flash Player: 25.0.0.127 - SDK 10.9 (2017-03-15) [Support]
CANONiMAGEGATEWAYLI: 2.1.0.1 (2006-04-21) [Support]
JavaAppletPlugin: Java 8 Update 91 build 14 (2017-02-21) Check version
SharePointBrowserPlugin: 14.6.6 - SDK 10.6 (2016-07-14) [Support]
Silverlight: 5.1.50901.0 - SDK 10.6 (2017-02-18) [Support]
iPhotoPhotocast: 7.0 (2012-08-21)
Safari Extensions: ?
Open in Internet Explorer - Parallels - http://www.parallels.com" onclick="window.open(this.href);return false; (2016-08-16)
3rd Party Preference Panes: ?
Flash Player (2017-02-28) [Support]
Java (2016-05-10) [Support]
Time Machine: ?
Skip System Files: NO
Mobile backups: OFF
Auto backup: YES
Volumes being backed up:
hd interno: Disk size: 319.21 GB Disk used: 288.67 GB
Destinations:
maxtor [Local]
Total size: 999.86 GB
Total number of backups: 6
Oldest backup: 03/04/17, 04:10
Last backup: 05/04/17, 17:57
Size of backup disk: Excellent
Backup size 999.86 GB > (Disk size 319.21 GB X 3)
Top Processes by CPU: ?
4% WindowServer
2% kernel_task
1% com.apple.WebKit.WebContent(4)
0% nsurlsessiond(2)
0% fontd
Top Processes by Memory: ?
545 MB com.apple.WebKit.WebContent(4)
476 MB kernel_task
123 MB mds_stores
102 MB Safari
102 MB mdworker(6)
Virtual Memory Information: ?
1.73 GB Available RAM
175 MB Free RAM
2.27 GB Used RAM
1.56 GB Cached files
0 B Swap Used
Diagnostics Information: ?
Apr 8, 2017, 05:23:23 PM Self test - passed
Apr 5, 2017, 07:36:08 PM /Library/Logs/DiagnosticReports/sandboxd_2017-04-05-193608_[redacted].crash
/usr/libexec/sandboxd
Apr 5, 2017, 07:07:20 PM /Library/Logs/DiagnosticReports/sandboxd_2017-04-05-190720_[redacted].crash
Files deleted by EtreCheck: ?
Apr 2, 2017, 09:45:21 PM - ~/Library/LaunchAgents/com.bittorrent.uTorrent.plist
Apr 2, 2017, 09:45:21 PM - ~/Library/Caches/com.apple.Safari/Extensions/Omnibar.safariextension
/code]
P.S.
non so come aggiungere la schermata di smartutility
