sudo rm /Library/Preferences/.3FAD0F65-FC6E-4889-B975-B96CBF807B78
Mar 31 00:04:15 Air-di-AS shutdown[879]: halt by aschianese:
Mar 31 00:04:15 Air-di-AS shutdown[879]: SHUTDOWN_TIME: 1490911455 227514
Mar 31 14:45:43 localhost kernel[0]: Previous shutdown cause: 5
Mar 31 14:46:34 Air-di-AS GoogleSoftwareUpdateDaemon[321]: 2017-03-31 14:46:34.679 GoogleSoftwareUpdateDaemon[321/0x7fff7c45d000] [lvl=2] -[KeystoneDaemon main] GoogleSoftwareUpdateDaemon inactive, shutdown.
Mar 31 15:46:58 Air-di-AS shutdown[957]: halt by aschianese:
Mar 31 15:46:58 Air-di-AS shutdown[957]: SHUTDOWN_TIME: 1490968018 261155
Mar 31 15:46:58 Air-di-AS com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): System shutdown initiated by: shutdown.957<-sessionlogoutd.956<-launchd.1
Mar 31 15:47:49 localhost kernel[0]: Previous shutdown cause: 5
È inutile che fai il modesto, tutti sanno che il 75% del lavoro lo fai tu... noi ci becchiamo solo i ringraziamenti!faxus ha scritto:Eh, sì. È bello questo Forum...
Mar 31 15:46:58 Air-di-AS kernel[0]: Kext loading now disabled.
Mar 31 15:46:58 Air-di-AS kernel[0]: Kext unloading now disabled.
Mar 31 15:46:58 Air-di-AS kernel[0]: Kext autounloading now disabled.
Mar 31 15:46:58 Air-di-AS kernel[0]: Kernel requests now disabled.
Mar 31 15:46:58 Air-di-AS kernel[0]: Process launchd [1] disabling system-wide I/O Throttling
Mar 31 15:46:58 Air-di-AS kernel[0]: Process launchd [1] disabling system-wide CPU Throttling
Mar 31 15:47:47 localhost bootlog[0]: BOOT_TIME 1490968067 0
Mar 31 15:47:48 localhost syslogd[43]: Configuration Notice:
ASL Module "com.apple.AccountPolicyHelper" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
ASL Module "com.apple.Accounts" claims selected messages.
Mar 31 15:47:48 --- last message repeated 1 time ---
ASL Module "com.apple.authd" sharing output destination "/var/log/asl" with ASL Module "com.apple.asl".
Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
Mar 31 15:46:58 Air-di-AS com.apple.xpc.launchd[1] (com.apple.iTunesHelper.54112[304]): Service exited with abnormal code: 1
la spunta significa che lo nascondi, non che non si apra all’avvioAsChianese ha scritto:Fra l'altro non riesco a capire neanche questo passaggio:
iTunes Helper è l'unico programma che ho tra quelli che dovrebbero partire all'avvio. Ma è spuntato nella lista...Codice: Seleziona tutto
Sembrerebbe solo che l'aggiornamento automatico di Google non funzioni come dovrebbe.AsChianese ha scritto:Ecco...
defaults write com.google.Keystone.Agent checkInterval 0
Impossibile.GLOP ha scritto:... tutti sanno che il 75% del lavoro lo fai tu...
Posso solo dirti che corrispondono ad un servizio di hosting web della Germania.AsChianese ha scritto:... Ho installato il semplicissimo Hosts. Ma quando vado nella sua icona, da preferenze di sistema, noto che all'interno della lista ci sono già degli indirizzi IP bloccati. Sono 6 e tutti riferiti all'IP 127.0.0.1 ed hanno come nomi obdev.at, 83.169.2.77, hetzner.obdev.at e wtf.obdev.at... Ma cosa sono? Chi li ha messi?...
Trova un esempio sul link al mio post in questo Forum su come fareAsChianese ha scritto:... Se provo a mettere gli IP datimi per MacKeeper mi dice "inserire un indirizzo valido"...
Il fatto è che nel syslog non che alcun riferimento.AsChianese ha scritto:... Al primo riavvio dopo aver eseguito il comando da terminale e fatto tutto il necessario con OnyX, la rotellina esce sempre e i tempi sono quelli li (10-15 sec). Sic!
Al secondo spegnimento idem come sopra... Sempre la maledetta rotellina... :| :| :| :|
Come fare?
Mar 31 15:46:58 Air-di-AS WindowServer[147]: _CGXGetWindowOrderingGroup: Operation on a window 0x13 requiring rights 0x5 by caller Dashboard
Mar 31 15:46:58 Air-di-AS com.apple.xpc.launchd[1] (com.apple.lateragent[394]): Service exited due to signal: Killed: 9
Mar 31 15:46:58 Air-di-AS com.apple.xpc.launchd[1] (com.apple.wifi.WiFiAgent[292]): Service exited due to signal: Killed: 9
Mar 31 15:46:58 Air-di-AS com.apple.xpc.launchd[1] (com.apple.cloudphotosd[337]): Service exited due to signal: Killed: 9
Mar 31 15:46:58 Air-di-AS loginwindow[93]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0xe00e}
Mar 31 15:46:58 Air-di-AS loginwindow[93]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0xf00f}
Mar 31 15:46:58 Air-di-AS loginwindow[93]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x14014}
Mar 31 15:46:58 Air-di-AS loginwindow[93]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x1a01a}
Mar 31 15:46:58 Air-di-AS com.apple.xpc.launchd[1] (com.apple.storeuid[652]): Service exited due to signal: Killed: 9
Mar 31 15:46:58 Air-di-AS loginwindow[93]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x1d01d}
Mar 31 15:46:58 Air-di-AS loginwindow[93]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x1e01e}
Mar 31 15:46:58 Air-di-AS loginwindow[93]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x21021}
Mar 31 15:46:58 Air-di-AS loginwindow[93]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x31031}
Mar 31 15:46:58 Air-di-AS loginwindow[93]: BUG in libdispatch client: kevent[EVFILT_PROC] enable: "No such file or directory" - 0x2
Mar 31 15:46:58 Air-di-AS com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent[434]): Service exited due to signal: Killed: 9
Mar 31 15:46:58 Air-di-AS com.apple.xpc.launchd[1] (com.apple.EscrowSecurityAlert[402]): Service exited due to signal: Killed: 9
Mar 31 15:46:58 Air-di-AS com.apple.xpc.launchd[1] (com.apple.FolderActionsDispatcher[271]): Service exited due to signal: Killed: 9
Mar 31 15:46:58 Air-di-AS sessionlogoutd[956]: sessionlogoutd Launched
Mar 31 15:46:58 Air-di-AS sessionlogoutd[956]: DEAD_PROCESS: 93 console
Mar 31 15:46:58 Air-di-AS sharingd[256]: 15:46:58.214 : SCDynamicStoreCopyConsoleUser returned NULL
Mar 31 15:46:58 Air-di-AS sharingd[256]: 15:46:58.214 : SDActivityAdvertiser::consoleUserChanged: Stopping for user 501 on logout
Mar 31 15:46:58 Air-di-AS sharingd[256]: 15:46:58.215 : SCDynamicStoreCopyConsoleUser returned NULL
Mar 31 15:46:58 --- last message repeated 2 times ---
Visitano il forum: Nessuno e 32 ospiti
