27/04/16 08:37:17,000 syslogd[45] ASL Sender Statistics
27/04/16 08:37:34,372 apsd[77] MessageTracer: load_domain_prefix_whitelist:120: Missing default whitelist file: /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Resources/SubmitDiagInfo.default.domains
27/04/16 08:38:12,063 apsd[77] MessageTracer: load_domain_prefix_whitelist:120: Missing default whitelist file: /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Resources/SubmitDiagInfo.default.domains
27/04/16 08:38:38,869 apsd[77] MessageTracer: load_domain_prefix_whitelist:120: Missing default whitelist file: /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Resources/SubmitDiagInfo.default.domains
27/04/16 08:38:40,439 apsd[77] MessageTracer: load_domain_prefix_whitelist:120: Missing default whitelist file: /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Resources/SubmitDiagInfo.default.domains
27/04/16 08:38:48,138 Mail[495] Stream 0x7fc512ec7b70 is sending an event before being opened
27/04/16 08:38:48,305 Mail[495] {"status":"400","schemes":"Bearer","scope":"https://mail.google.com/"}
27/04/16 08:38:48,422 Mail[495] XOAUTH2 requires user
27/04/16 08:38:48,422 Mail[495] Failed to start the SASL connection
SASL(-1): generic failure: XOAUTH2 requires user
27/04/16 08:38:48,422 Mail[495] No worthy mechs found
27/04/16 08:38:48,435 Mail[495] Stream 0x7fc512e34620 is sending an event before being opened
27/04/16 08:38:48,458 Mail[495] Stream 0x7fc515e25d30 is sending an event before being opened
27/04/16 08:38:48,465 Mail[495] Stream 0x7fc51529ea80 is sending an event before being opened
27/04/16 08:38:48,488 Mail[495] Stream 0x7fc512cd30a0 is sending an event before being opened
27/04/16 08:38:48,700 Mail[495] Stream 0x7fc515311860 is sending an event before being opened
27/04/16 08:38:49,596 secd[365] SOSAccountThisDeviceCanSyncWithCircle sync with device failure: (null)
27/04/16 08:38:50,275 accountsd[379] AIDA Notification plugin running
27/04/16 08:38:50,449 com.apple.AddressBook.InternetAccountsBridge[506] Checking iCDP status for DSID 671592997 (checkWithServer=0)
27/04/16 08:38:50,455 com.apple.AddressBook.InternetAccountsBridge[506] XPC Error while checking if iCDP is enabled for DSID 671592997: Error Domain=NSCocoaErrorDomain Code=4099 "The connection to service named com.apple.cdp.daemon was invalidated." UserInfo={NSDebugDescription=The connection to service named com.apple.cdp.daemon was invalidated.}
27/04/16 08:38:50,456 com.apple.AddressBook.InternetAccountsBridge[506] Daemon connection invalidated!
27/04/16 08:38:50,522 sandboxd[135] ([506]) com.apple.Addres(506) deny mach-lookup com.apple.cdp.daemon
27/04/16 08:38:52,443 apsd[77] MessageTracer: load_domain_prefix_whitelist:120: Missing default whitelist file: /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Resources/SubmitDiagInfo.default.domains
27/04/16 08:38:57,053 launchservicesd[78] SecTaskLoadEntitlements failed error=22
27/04/16 08:39:04,597 secd[365] SOSAccountThisDeviceCanSyncWithCircle sync with device failure: (null)
27/04/16 08:39:11,752 com.apple.WebKit.WebContent[820] The urlification failed too many times, probably because the layout or the DOM changed under our feet. Stop retrying...
27/04/16 08:39:29,760 Safari[810] KeychainGetICDPStatus: keychain: 0
27/04/16 08:39:29,761 Safari[810] KeychainGetICDPStatus: status: on
27/04/16 08:39:38,687 Safari[810] KeychainGetICDPStatus: keychain: 0
Visitano il forum: Nessuno e 52 ospiti
