Curiosità....ma non troppo!
genepi
Premessa: PowerBookG4-1.5GHz; 2GB ram; MacOS 10.5.8; HD 250GB.
Sono curioso di sapere perchè:
- i permessi che si "modificano" sono sempre gli stessi; cosa/chi li modifica?
- alcuni file non vengono riparati
- altri file vengono messi dove non dovrebbero essere.
Che motivi ci sono a tutto questo se non "smanetto"....? p.es. non ho scelto io dove mettere ACL (....che cos'è?)
Vedi report sottostante:
Started verify/repair permissions on disk disk0s3 PBgianky
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/DVD.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/FRSettings.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/FRSources.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/Movies.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/Music.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/Photos.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/Podcasts.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/TV.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/PrivateFrameworks/BackRow.framework/Versions/A/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "System/Library/CoreServices/Menu Extras/RemoteDesktop.menu/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r--
Permissions differ on "Library/Internet Plug-Ins/JavaPluginCocoa.bundle/Contents/CodeResources", should be -rw-rw-r-- , they are lrw-rw-r--
Permissions differ on "System/Library/CoreServices/Expansion Slot Utility.app/Contents/Resources/PCIELaneConfigTool", should be -rwxr-xr-x , they are -rwsr-sr-x
Warning: SUID file "System/Library/CoreServices/Expansion Slot Utility.app/Contents/Resources/PCIELaneConfigTool" has been modified and will not be repaired
Permissions differ on "private/var/spool/cups/cache/rss", should be drwxr-xr-x , they are drwxrwxr-x
ACL found but not expected on "Applications/Utilities"
ACL found but not expected on "sbin"
ACL found but not expected on "private"
Finished verify/repair permissions on disk disk0s3 PBgianky
E' la prima volta che mi capita, non mi è mai successo con versioni precedenti a Leopard.
Il report postato è quello generato da Onyx (che conosco dai tempi di 10.2.x; prima usavo OS 7.x-8.x-9.x)
Ho provato anche con TechToolPro5.0.7...stesso risultato.
La "pulce nell'orecchio" mi è venuta il mese scorso quando ho dovuto sostituire l'HD (un Toshiba da 60GB a 7200rpm con un WD da 250GB a 5200) dove ho riscontrato la stessa tipologia di "difetti" (solo i files spostati non erano gli stessi; nel caso precedente era ODBC e non ACL) e alla fine si sono "scassati" 1/3 di settori dell'HD.
Che il problema da software (files messi nel posto sbagliato) diventi hardware (le testine dell'hd che "grattano" in posti dove credono di trovare ciò che non c'è...e a forza di grattare fanno il buco) ? :lol:
Dopo tutti i "predicozzi" sull'uso del computer......sapere quello che si fa, usare il buonsenso, chiedere prima di fare danni......ecc, le domande, a questo punto, sono sorte spontanee; anche se, "apparentemente" per ora, tutto sembra funzionare ( e ti credo, hd nuovo, sistema installato da zero e tutto pulito.....in teoria....ma permessi sporchi!).
ciao e grazie
kiruzzo
Direi che è tutto normale.. non mi preoccuperei!!
Alcuni di quei permessi, non è possibile modificarli quindi puntualmente te li ritrovi!!
Stai tranquillo :wink:
genepi
Tranquillo mica tanto....dopo l'ultima esperienza :!: :roll:
....e comunque a chi risponde alle domande sarà inviato un bel ..."nigutin d'or"! :lol: :lol: :lol:
Stato: Connesso
Visitano il forum: ZoomBot [Bot] e 11 ospiti
cron
