Rilasciato per il download
Pacifist 3.2.5
WHAT'S NEW
Version 3.2.5:
Fixed an issue that caused incomplete text to appear in the “Quick Start” window
Fixed an issue that could cause the splash screen to display incorrectly on machines with Intel Iris graphics (hopefully permanently this time)
Various internal architectural improvements
Various bug fixes
http://www.charlessoft.com" onclick="window.open(this.href);return false;
Link diretto:
http://www.charlessoft.com/pacifist_dow ... _3.2.5.zip" onclick="window.open(this.href);return false;
Pacifist 3.2.9
• Fixed an issue that could cause -[__NSCFCalendar components:fromDate:] warnings to get logged to the console when using languages other than English
• Fixed an issue that could cause files inside packages that are in disk images hosted on an HTTP server not to extract properly
• The QuickLook plug-in should now be able to handle .xar archives
• Fixed an exception that could sometimes be thrown on extracting resources from a package
• Fixed a crash that could occur when extracting files to a pre-Lion FileVault
• Various security improvements
Link diretto:
http://www.charlessoft.com/pacifist_dow ... _3.2.9.zip" onclick="window.open(this.href);return false;
Pacifist 3.2.10
• Added support for the OS X 10.9.3 full installer
• Fixed a bug that could cause crashes and other undesired behavior while extracting from .zip archives
• Fixed a bug that caused the “Find” feature not to work properly for text files in the file viewer
Link diretto:
http://www.charlessoft.com/pacifist_dow ... 3.2.10.zip" onclick="window.open(this.href);return false;
- Software Expert Gold
Pacifist - 3.2.12
Fixed a problem that caused some packages not to load properly on OS X 10.6.8
Fixed a problem that could cause the “Please insert disk” dialog to appear spuriously in some cases.
Maurizio
- Stella nascente
Grazie, ho aggiornato.
Pacifist - 3.2.13
Fixed a problem that could cause crashes while loading the OS X installer on OS X Lion.
Vi segnalo il rilascio di
Pacifist 3.2.14
• Added experimental support for Mac OS X 10.10 (“Yosemite”) packages
• Fixed a bug that caused errors on extracting from certain packages
• Fixed a bug that could cause package scripts not to extract properly
• Fixed a bug that could cause crashes during the “Verifying Files” stage for some packages
• Fixed a bug that could cause false positives during the verification process
• Fixed a bug that could cause errors on extracting files from archives with certain properties
• Fixed a performance issue that could cause some packages to load slowly
• Worked around an oddity in Apple’s install packages that caused some .icns files not to extract properly
• Fixed a cosmetic issue affecting the display of checksums
Link diretto:
http://www.charlessoft.com/pacifist_dow ... 3.2.14.zip" onclick="window.open(this.href);return false;
Pacifist - 3.2.15
FFixed a bug that could cause spurious DiskArbitration errors when extracting certain files.
Pacifist - 3.2.16
Fixed a bug that could affect the integrity of the extracted files when extracting symbolic links in rare cases.
Pacifist - 3.2.17
Fixed a bug that caused some packages not to load properly.
Pacifist - 3.5
Faster performance when loading packages
Much faster performance when extracting from OS X 10.10 Yosemite packages
Much better performance and efficiency when loading archives from HTTP URLs
Incorporated a new XAR extraction engine, written from scratch
Better performance when loading packages from HTTP URLs
Added detection of the Yosemite installer to the "Open Apple Installers" button
Now verifies the packages' embedded signatures before opening them
Fixed a bug that caused resource forks not to extract properly from some .zip archives
Now uses HTTPS instead of HTTP for automatic updates, for greater security
Other miscellaneous bug fixes.
Pacifist - 3.5.1
Fixed a bug that sometimes caused exceptions to be thrown when extracting files from BaseSystemResources.pkg
Fixed a bug that sometimes caused spurious permissions errors when extracting from ZIP archives
Fixed a bug that sometimes caused exceptions to be thrown when loading archives from HTTP URLs
Double-clicking now works to select applications in the "Open Apple Installers" dialog box.
Visitano il forum: Apple [Bot], SemrushBot [Bot] e 22 ospiti
