Apr 30 01:22:23 MacBook-Pro-di-Roberto UCAgent[471]: 2 [DC] Couldn't connect to daemon
Apr 30 01:22:33 --- last message repeated 1 time ---
Apr 30 01:22:33 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1]: assertion failed: 16E195: launchd + 99001 [22A1A952-D186-3371-8E10-1C7AAA0FFCA8]: 0x11
Apr 30 01:22:33 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.emond): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 30 01:22:33 MacBook-Pro-di-Roberto UCAgent[471]: 2 [DC] Couldn't connect to daemon
Apr 30 01:22:38 --- last message repeated 1 time ---
Apr 30 01:22:38 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Apr 30 01:22:43 --- last message repeated 2 times ---
Apr 30 01:22:43 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1]: assertion failed: 16E195: launchd + 99001 [22A1A952-D186-3371-8E10-1C7AAA0FFCA8]: 0x11
Apr 30 01:22:43 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.emond): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 30 01:22:43 MacBook-Pro-di-Roberto UCAgent[471]: 2 [DC] Couldn't connect to daemon
Apr 30 01:22:53 --- last message repeated 1 time ---
Apr 30 01:22:53 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1]: assertion failed: 16E195: launchd + 99001 [22A1A952-D186-3371-8E10-1C7AAA0FFCA8]: 0x11
Apr 30 01:22:53 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.emond): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 30 01:22:53 MacBook-Pro-di-Roberto UCAgent[471]: 2 [DC] Couldn't connect to daemon
Apr 30 01:22:59 --- last message repeated 1 time ---
Apr 30 01:22:59 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Apr 30 01:23:03 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1]: assertion failed: 16E195: launchd + 99001 [22A1A952-D186-3371-8E10-1C7AAA0FFCA8]: 0x11
Apr 30 01:23:03 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.emond): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 30 01:23:03 MacBook-Pro-di-Roberto UCAgent[471]: 2 [DC] Couldn't connect to daemon
Apr 30 01:23:04 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.ReportCrash.Root[1060]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash.DirectoryService
Apr 30 01:23:08 MacBook-Pro-di-Roberto UCAgent[471]: 2 [DC] Couldn't connect to daemon
Apr 30 01:23:13 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1]: assertion failed: 16E195: launchd + 99001 [22A1A952-D186-3371-8E10-1C7AAA0FFCA8]: 0x11
Apr 30 01:23:13 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.emond): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 30 01:23:13 MacBook-Pro-di-Roberto UCAgent[471]: 2 [DC] Couldn't connect to daemon
Apr 30 01:23:23 --- last message repeated 1 time ---
Apr 30 01:23:23 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1]: assertion failed: 16E195: launchd + 99001 [22A1A952-D186-3371-8E10-1C7AAA0FFCA8]: 0x11
Apr 30 01:23:23 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.emond): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 30 01:23:23 MacBook-Pro-di-Roberto UCAgent[471]: 2 [DC] Couldn't connect to daemon
Apr 30 01:23:33 --- last message repeated 1 time ---
Apr 30 01:23:33 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1]: assertion failed: 16E195: launchd + 99001 [22A1A952-D186-3371-8E10-1C7AAA0FFCA8]: 0x11
Apr 30 01:23:33 MacBook-Pro-di-Roberto com.apple.xpc.launchd[1] (com.apple.emond): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 30 01:23:33 MacBook-Pro-di-Roberto UCAgent[471]: 2 [DC] Couldn't connect to daemon
sudo rm -rf /Applications/Wireshark* /Library/Application\ Support/Wireshark /Library/LaunchDaemons/org.wireshark.ChmodBPF.plist /Library/LaunchDaemons/org.wireshark.XQuartzFixer.plist /private/var/db/BootCaches/*/app.org.wireshark.Wireshark.playlist /private/var/folders/mr/*/T/wireshark_pcapng_* ~/.wireshark ~/.wireshark-etc ~/Library/Preferences/org.wireshark.Wireshark.plist
UCAgent è una componente di UnderCover.rbrtgtt ha scritto:... - Undercover non l'ho mai installato, ho scoperto che esiste da quando me ne hai parlato. Ho fatto anche una ricerca con Easyfind ma non ha trovato nulla...
Se ti serve disinteressati di FaceTime che non usi.rbrtgtt ha scritto:... - Citrix è un'applicazione che mi serve per lavoro, non posso eliminarla. Come si può disattivare ? Mi permetto ancora un'osservazione : ho Citrix da 4 anni, ma solo adesso FaceTime ha smesso di funzionare. C'è un sistema per "congelarla" ?...
EtreCheck version : 3.2.3 (363)
Rapport créé le 2017-05-07 01:02:05
Télécharger EtreCheck chez https://etrecheck.com
Temps d’exécution : 3:59
La vitesse : Satisfaisante
Cliquez sur les liens [Rechercher] pour plus d’informations chez Communautés d’assistance Apple.
Cliquez sur les liens [Les détails] pour plus d’informations sur cette ligne.
Problème : Autre problème
Les informations matérielles : ⓘ
MacBook Pro (13 pouces, mi-2012)
[Les caractéristiques techniques] - [Le guide de l’utilisateur] - [Garantie & service]
MacBook Pro - modèle : MacBookPro9,2
1 2,5 GHz Intel Core i5 (i5-3210M) CPU: 2-core
16 GB RAM Extensible - [Instructions]
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Bluetooth: Bon - Handoff/Airdrop2 disponible
Wireless: en1: 802.11 a/b/g/n
La batterie : Santé = Satisfaisant - Comptage de cycles = 29
Les informations vidéo : ⓘ
Intel HD Graphics 4000
Color LCD 1280 x 800
Les logiciel du système : ⓘ
macOS Sierra 10.12.4 (16E195) - Temps depuis le démarrage : moins d’une heure
Les informations des disques : ⓘ
APPLE HDD HTS545050A7E362 disk0 : (500,11 Go) (Rotational)
[Afficher le rapport SMART]
EFI (disk0s1) <non monté> : 210 Mo
Recovery HD (disk0s3) <non monté> [Restauration] : 650 Mo
Macintosh HD (disk1) / [Startup] : 498.89 Go (115.30 Go libre)
Core Storage: disk0s2 499.25 Go Online
HL-DT-ST DVDRW GS41N ()
Les informations USB : ⓘ
Apple Inc. BRCM20702 Hub
Les informations Thunderbolt : ⓘ
Apple Inc. thunderbolt_bus
Les fichiers de configuration : ⓘ
/etc/hosts - Nombre : 1
Le gatekeeper : ⓘ
Mac App Store et développeurs identifiés
Les extensions du noyau : ⓘ
/Library/Extensions
[engagé] com.globaldelight.driver.Boom2Device (1.2 - SDK 10.10 - 2017-03-31) [Rechercher]
/System/Library/Extensions
[engagé] com.dvdfab.kext.fabio (1.0 - 2017-03-31) [Rechercher]
[engagé] com.globaldelight.driver.BoomDevice (1.1 - SDK 10.1 - 2017-03-31) [Rechercher]
Les éléments de démarrage : ⓘ
Jaksta : Chemin : /Library/StartupItems/Jaksta
Les éléments de démarrage ne fonctionne plus dans OS X Yosemite ou ultérieur
Les agents de lancement systèmes : ⓘ
[désengagé] 6 tâches d’Apple
[engagé] 179 tâches d’Apple
[en marche] 97 tâches d’Apple
Les daemons de lancement systèmes : ⓘ
[désengagé] 43 tâches d’Apple
[engagé] 178 tâches d’Apple
Les agents de lancement : ⓘ
[engagé] com.citrix.AuthManager_Mac.plist (2017-03-21) [Rechercher]
[en marche] com.citrix.ReceiverHelper.plist (2017-03-21) [Rechercher]
[en marche] com.citrix.ServiceRecords.plist (2017-03-21) [Rechercher]
[engagé] com.divx.dms.agent.plist (2016-12-09) [Rechercher]
[engagé] com.divx.uninstall.converter.plist § (2017-03-23)
[engagé] com.divx.uninstall.player.plist § (2017-03-23)
[engagé] com.divx.uninstall.preferences.plist § (2017-03-23)
[engagé] com.divx.update.agent.plist ✔︎ (2016-12-09) [Rechercher]
[en marche] com.ecamm.iglasses3agent.plist (2015-10-04) [Rechercher]
[engagé] com.google.keystone.agent.plist ✔︎ (2017-03-29) [Rechercher]
[engagé] com.oracle.java.Java-Updater.plist (2017-04-29) [Rechercher]
[en marche] com.orbicule.UCAgent.plist (2015-08-24) [Rechercher]
[désengagé] com.teamviewer.teamviewer.plist ✔︎ (2015-09-06) [Rechercher]
[désengagé] com.teamviewer.teamviewer_desktop.plist ✔︎ (2015-08-06) [Rechercher]
[engagé] org.macosforge.xquartz.startx.plist ✔︎ (2014-08-12) [Rechercher]
Les daemons de lancements : ⓘ
[engagé] com.InsanelyMac.PandoraHelper.plist (2017-03-14) [Rechercher]
[engagé] com.adobe.fpsaud.plist (2017-04-17) [Rechercher]
[engagé] com.applian.JakstaConfigDaemon.plist (2016-05-20) [Rechercher]
[engagé] com.axoniclabs.DeepSleepCmd.plist ✔︎ (2015-08-11) [Rechercher]
[engagé] com.cyberghostsrl.CyberghostPrivilegedHelper.plist ✔︎ (2017-01-06) [Rechercher]
[engagé] com.google.keystone.daemon.plist ✔︎ (2017-04-17) [Rechercher]
[engagé] com.malwarebytes.HelperTool.plist ✔︎ (2017-04-16) [Rechercher]
[engagé] com.microsoft.autoupdate.helpertool.plist ✔︎ (2016-09-10) [Rechercher]
[engagé] com.microsoft.office.licensingV2.helper.plist ✔︎ (2016-09-10) [Rechercher]
[engagé] com.oracle.java.Helper-Tool.plist § (2017-03-15) [Rechercher]
[en marche] com.projectosx.clover.daemon.plist § (2015-09-18) [Rechercher]
[engagé] com.spotflux.Spotflux.tun.plist ✔︎ (2017-03-23)
[engagé] com.teamviewer.Helper.plist ✔︎ (2015-09-06) [Rechercher]
[désengagé] com.teamviewer.teamviewer_service.plist ✔︎ (2015-09-06) [Rechercher]
[engagé] net.tunnelblick.tunnelblick.tunnelblickd.plist ✔︎ (2015-09-19) [Rechercher]
[engagé] org.macosforge.xquartz.privileged_startx.plist ✔︎ (2014-08-12) [Rechercher]
Les agents de lancement pour l’utilisateur : ⓘ
[engagé] com.adobe.ARM.[...].plist (2015-09-13) [Rechercher]
[engagé] net.tunnelblick.tunnelblick.LaunchAtLogin.plist ✔︎ (2015-09-19) [Rechercher]
Les plug-ins internets : ⓘ
FlashPlayer-10.6 : 25.0.0.163 - SDK 10.9 (2017-05-01) [Rechercher]
QuickTime Plugin : 7.7.3 (2017-03-31)
DivX Web Player : 3.6.0.321 - SDK 10.10 (2016-08-12) [Rechercher]
AdobePDFViewer : 10.0.0 (2015-09-13) [Rechercher]
Flash Player : 25.0.0.163 - SDK 10.9 (2017-05-01) [Rechercher]
o1dbrowserplugin : 5.41.3.0 - SDK 10.8 (2015-12-18) [Rechercher]
CitrixICAClientPlugIn : 11.8.2 - SDK 10.7 (2013-10-23) [Rechercher]
OVSHelper : 1.1 (2016-08-12) [Rechercher]
googletalkbrowserplugin : 5.41.3.0 - SDK 10.8 (2015-12-11) [Rechercher]
PepperFlashPlayer : 25.0.0.127 - SDK 10.9 (2017-04-02) [Rechercher]
JavaAppletPlugin : Java 8 Update 131 build 11 (2017-04-29) Vérifier la version
Les plug-ins internets pour l’utilisateur : ⓘ
Unity Web Player : UnityPlayer version 2.6.1f3 (2015-08-23) [Rechercher]
Les extensions de Safari : ⓘ
Antidote-Safari - Druide informatique inc. - http://www.antidote.info/ (2016-12-07)
FastestTube - Kwizzu - http://fastesttube.kwizzu.com/ (2016-10-30)
Open in Internet Explorer - Parallels - http://www.parallels.com (2016-03-13)
Les panneaux de préférences tiers : ⓘ
Flash Player (2017-04-17) [Rechercher]
Java (2017-04-29) [Rechercher]
Le Time Machine : ⓘ
Time Machine n’est pas configuré !
L’utilisation du CPU par processus : ⓘ
8% assistant_service
5% kernel_task
4% helpd
4% WindowServer
1% fontd
L’utilisation de la RAM par processus : ⓘ
923 Mo kernel_task
164 Mo mdworker(14)
147 Mo com.druide.AgentAntidote
82 Mo WindowServer
66 Mo mds_stores
Les informations de la mémoire virtuelle : ⓘ
13.25 Go RAM disponible
10.88 Go RAM libre
2.75 Go RAM utilisé
2.37 Go Fichiers en cache
0 o Fichier d’échange utilisé
Les informations du diagnostic : ⓘ
2017-05-07 00:51:44 Auto-examen - succès
Les fichiers enlevés par EtreCheck : ⓘ
2017-04-30 23:58:34 - /Library/LaunchDaemons/org.wireshark.ChmodBPF.plist - Inconnu
2017-05-01 00:00:19 - ~/Library/LaunchAgents/com.bittorrent.uTorrent.plist - Inconnu
2017-05-01 00:19:57 - /Library/LaunchDaemons/org.wireshark.ChmodBPF.plist - Inconnu
Visitano il forum: Nessuno e 56 ospiti
