EtreCheck version: 4.1 (4A162)
Report generated: 2018-03-03 19:19:43
Runtime: 6:11
Performance: Below Average
Major Issues:
Anything that appears on this list needs immediate attention.
No Time Machine backup - Time Machine backup not found.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems.
Low performance - EtreCheck report took over 5 minutes to run. This is unusual.
Vintage hardware - This machine may be considered vintage.
Hardware Information:
iMac (21.5-inch, Mid 2010) - Vintage!
iMac Model: iMac11,2
1 3.06 GHz Intel Core i3 (i3) CPU: 2-core
12 RAM At maximum
BANK 0/DIMM0
4 GB DDR3 1333 ok
BANK 1/DIMM0
4 GB DDR3 1333 ok
BANK 0/DIMM1
2 GB DDR3 1333 ok
BANK 1/DIMM1
2 GB DDR3 1333 ok
Video Information:
ATI Radeon HD 4670 - VRAM: 256 MB
iMac 1920 x 1080
Drives:
disk0 - Crucial_CT525MX300SSD1 525.11 GB (Solid State - TRIM: No)
Internal SATA 3 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 - Macintosh HD (Journaled HFS+) 524.25 GB
disk0s3 - Recovery HD (Journaled HFS+) [Recovery] 650 MB
disk1 - WL640GLSA854G 640.14 GB (Mechanical)
disk1s1 - 6***B (MS-DOS FAT32) 640.14 GB
disk2 - WD 499.41 GB
External FireWire
disk2s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk2s2 - 5***b (Journaled HFS+) 499.06 GB
Mounted Volumes:
disk0s2 - Macintosh HD 524.25 GB (502.41 GB free)
Journaled HFS+
Mount point: /
Network:
Interface en0: Ethernet
One IPv4 address
Interface fw0: FireWire
Interface en1: Wi-Fi
802.11 a/b/g/n
One IPv4 address
Interface en2: Bluetooth PAN
System Software:
macOS Sierra 10.12.4 (16E195)
Time since boot: Less than an hour
System Load: 3.38 (1 min ago) 3.29 (5 min ago) 2.74 (15 min ago)
Security:
System
Status
Gatekeeper
System Integrity Protection
Enabled
Kernel Extensions:
/System/Library/Extensions
[Not Loaded] EyeTVAfaTechHidBlock.kext (1.1)
[Not Loaded] EyeTVCinergy450AudioBlock.kext (1.1)
[Not Loaded] EyeTVCinergyXSAudioBlock.kext (1.1)
[Not Loaded] EyeTVEmpiaAudioBlock.kext (1.1)
[Not Loaded] EyeTVVoyagerAudioBlock.kext (1.1)
System Launch Agents:
[Not Loaded]
7 Apple tasks
[Loaded]
194 Apple tasks
[Running]
81 Apple tasks
System Launch Daemons:
[Not Loaded]
43 Apple tasks
[Loaded]
180 Apple tasks
[Running]
93 Apple tasks
[Other]
3 Apple tasks
User Login Items:
Macs Fan Control Application (Ilya Parniuk
(/Applications/Macs Fan Control.app)
Firefox Application (Mozilla Corporation
(/Applications/Firefox.app)
Internet Plug-ins:
QuickTime Plugin: 7.7.3 (installed 2017-03-23)
Time Machine:
Time Machine Not Configured!
Top Processes by CPU:
Process (count)
Source
% of CPU
firefox
Mozilla Corporation
88
plugin-container (4)
Mozilla Corporation
18
WindowServer
Apple
10
MacsFanControl
Ilya Parniuk
1
kernel_task
Apple
0
Top Processes by Memory:
Process (count)
Source
RAM usage
Mozilla Corporation
898 MB
kernel_task
Apple
613 MB
firefox
Mozilla Corporation
338 MB
UserEventAgent (2)
Apple
146 MB
iconservicesagent (2)
Apple
145 MB
Top Processes by Network Use:
Process
Source
Input
Output
firefox
Mozilla Corporation
1 MB
45 KB
mDNSResponder
Apple
47 KB
12 KB
netbiosd
Apple
9 KB
1 KB
apsd
Apple
4 KB
2 KB
ntpd
Apple
1 KB
1 KB
Top Processes by Energy Use:
Process (count)
Source
Energy usage (0-100)
firefox
Mozilla Corporation
25
Mozilla Corporation
5
WindowServer
Apple
5
MacsFanControl
Ilya Parniuk
0
configd
Apple
0
Virtual Memory Information:
Available RAM
6.16 GB
Free RAM
2.82 GB
Used RAM
5.84 GB
Cached files
3.34 GB
Swap Used
0 B
Diagnostics Information (past 7 days):
2018-03-03 19:01:01 Firefox.app CPU
2018-03-03 18:48:45 Last Shutdown Cause: 3 - Hard shutdown
2018-03-03 17:47:06 system_installd CPU
End of report
Cambiato titolofaxus ha scritto:Per favore cambiate il titolo.
Non siamo su un forum di minus habens che usano Windows.
Basta "Problema video".
Vedo adesso la risposta di Fragrua.
Con cui ovviamente concordo.
Strano il comportamento del cestino.
Per pure curiosità, puoi provare a vedere se senza EyeTV lo fa?
Non ho mai copiato nulla.faxus ha scritto:Non è che hai inizializzato e poi copiato tutto sopra come prima?
Quei documenti mi sembrano tanto elementi del disco, del sistema e di Windows.
Dovresti reinstallare da zero, da chiavetta installante.
Poi importare, con Assistente Migrazione solo l'utente (o gli utenti).
E basta
Ciao scialla e grazie.Scialla ha scritto:Se ti rivolgi a Torino, fammi sapere, che chiedo un codice sconto. Abbiamo attivato una convenzione.
C'è un Topic in evidenza (il primo) nella sezione HW
Non è tantissimo, ma meglio che niente!
Se cancelli l'intero disco non capisco come puoi cancellare "in più" anche il volume principale...visualdrome ha scritto:... Seleziono il disco interno e faccio erase... sia della partizione più "esterna" che di quella "interna"...
Sbagli tutto.visualdrome ha scritto:... Come si spiega che:
- stamattina il disco interno era uguale a prima (tutte le cartelle nei documenti con file di progetti, film, musica...)
- la seconda volta il disco era pulito ma il cestino manteneva quelle cartelle che non riesce a cancellare.
Sbaglio qualcosa?...
Ma non avevi inizializzato?visualdrome ha scritto:... Comunque da un po (cancellazione di tutte le applicazioni tranne FFox, Skype e VLC) non sta più mostando i problema.
Sbaglio ad esprimermi: in utility Disk ogni disco è indicato nella colonna di sinistra con 2 nomi, uno all'interno dell'altro; formatto entrambi i dischi.faxus ha scritto:Se cancelli l'intero disco non capisco come puoi cancellare "in più" anche il volume principale...visualdrome ha scritto:... Seleziono il disco interno e faccio erase... sia della partizione più "esterna" che di quella "interna"...
Ma non avevi inizializzato?[/quote]visualdrome ha scritto:... Comunque da un po (cancellazione di tutte le applicazioni tranne FFox, Skype e VLC) non sta più mostando i problema.
I file che vedi nel cestino potrebbero benissimo essere su questo secondo HD... se lo espelli scompaiono dal cestino?visualdrome ha scritto:...L'unico dubbio è che il secondo HD è collegato internamente al posto del lettore: è meglio se lo smonto tramite Utility Disk prima dell'installazione?
Visitano il forum: Nessuno e 36 ospiti
