Benvenuto.Pizzi89 ha scritto:... quando il Mac si surriscalda ho notato che si rallenta molto fino a bloccarsi e far apparire la rotella con l'arcobaleno...
... mi sono reso conto che le ventole (o la ventola) non parte più e penso che sia questo il motivo per cui il mio Mac quando si surriscalda si impalla...
Così :)
EtreCheck version: 3.3 (383)
Report generated 2017-05-17 13:09:44
Runtime: 2:00
Performance: Excellent
Click the [Clean up] link to delete unused files.
Hardware Information: ⓘ
MacBook Pro (13-inch, Mid 2012)
MacBook Pro - model: MacBookPro9,2
1 2,5 GHz Intel Core i5 (i5-3210M) CPU: 2-core
4 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
2 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Wireless: en1: 802.11 a/b/g/n
Battery: Health = Replace Soon - Cycle count = 1132
Video Information: ⓘ
Intel HD Graphics 4000 - VRAM: 1536 MB
Color LCD 1280 x 800
System Software: ⓘ
macOS Sierra 10.12.4 (16E195) - Time since boot: about 13 hours
Disk Information: ⓘ
Samsung SSD 850 EVO 250GB disk0 : (250,06 GB) (Solid State - TRIM: No)
[Show SMART report]
EFI (disk0s1 - MS-DOS FAT32) <not mounted> : 210 MB
Recovery HD (disk0s3 - Journaled HFS+) <not mounted> [Recovery]: 650 MB
SSD 250 (disk1 - Journaled HFS+) / [Startup]: 248.86 GB (36.96 GB free)
Encrypted AES-XTS Unlocked
Core Storage: disk0s2 249.20 GB Online
MATSHITADVD-R UJ-8A8 ()
USB Information: ⓘ
Apple Inc. BRCM20702 Hub
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Configuration files: ⓘ
/etc/hosts - Count: 1
Gatekeeper: ⓘ
Clean up: ⓘ
com.adobe.ARM.[...].plist
/Applications/Adobe Reader.app/Contents/MacOS/Updater/Adobe Reader Updater Helper.app/Contents/MacOS/Adobe Reader Updater Helper semi-auto
Executable not found!
~/Library/LaunchAgents/com.divx.agent.postinstall.plist
/Library/Internet Plug-Ins/DivX Plus Web Player.plugin/Contents/Resources/extensions-installer install safari DivXHTML5 /Library/Internet Plug-Ins/DivX Plus Web Player.plugin/Contents/Resources/DivXHTML5.safariextz
~/Library/LaunchAgents/com.spotify.webhelper.plist
~/Library/Application Support/Spotify/SpotifyWebHelper
3 orphan files found. [Clean up]
Kernel Extensions: ⓘ
/Library/Extensions
[not loaded] com.ZTE.driver.ZTEUSBCDCACMData (ZTEDriver_MacV1.6.1 - SDK 10.9) [Lookup]
[not loaded] com.ZTE.driver.ZTEUSBMassStorageFilter (ZTEDriver_MacV1.6.1 - SDK 10.9) [Lookup]
[loaded] com.kairos.driver.DuetDisplay (1.2.0 - SDK 10.11) [Lookup]
[not loaded] com.zte.driver.cdc_ecm_qmi (1.4.1 - SDK 10.9) [Lookup]
[not loaded] com.zte.driver.cdc_usb_bus (1.4.1 - SDK 10.9) [Lookup]
/Library/Extensions/HuaweiDataCardDriver_10_9.kext/Contents/PlugIns
[not loaded] com.MBB.driver.MBBACMData (5.01.01.00 - SDK 10.8) [Lookup]
[not loaded] com.MBB.driver.MBBActivateDriver (5.01.00 - SDK 10.8) [Lookup]
[not loaded] com.MBB.driver.MBBEthernetData (5.01.01.00 - SDK 10.8) [Lookup]
Startup Items: ⓘ
HWNetMgr: Path: /Library/StartupItems/HWNetMgr
HWPortDetect: Path: /Library/StartupItems/HWPortDetect
StartOuc: Path: /Library/StartupItems/StartOuc
Startup items no longer function in OS X Yosemite or later
System Launch Agents: ⓘ
[not loaded] 6 Apple tasks
[loaded] 175 Apple tasks
[running] 86 Apple tasks
[killed] 15 Apple tasks
15 processes killed due to insufficient RAM
System Launch Daemons: ⓘ
[not loaded] 41 Apple tasks
[loaded] 174 Apple tasks
[running] 96 Apple tasks
[killed] 7 Apple tasks
7 processes killed due to insufficient RAM
Launch Agents: ⓘ
[failed] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2017-01-11) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2017-03-29) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2017-01-11) [Lookup]
[loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2017-01-11) [Lookup]
[loaded] com.adobe.fpsaud.plist (Unknown - installed 2017-04-27) [Lookup]
[loaded] com.embraceware.awaken.plist (Unknown - installed 2013-01-23) [Lookup]
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2017-04-18) [Lookup]
[loaded] com.microsoft.office.licensing.helper.plist (Unknown - installed 2010-09-23) [Lookup]
[loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2015-09-11) [Lookup]
[running] com.tunnelbear.mac.tbeard.plist (TunnelBear, Inc./ - installed 2017-05-02) [Lookup]
User Launch Agents: ⓘ
[failed] com.adobe.ARM.[...].plist (Unknown - installed 2013-03-19) [Lookup] - /Applications/Adobe Reader.app/Contents/MacOS/Updater/Adobe Reader Updater Helper.app/Contents/MacOS/Adobe Reader Updater Helper: Executable not found!
[loaded] com.divx.agent.postinstall.plist (Unknown - installed 2013-05-04) [Lookup] - /Library/Internet Plug-Ins/DivX Plus Web Player.plugin/Contents/Resources/extensions-installer: Executable not found!
[running] com.nds.pcshow.plist (Shell script - installed 2017-03-23)
[loaded] com.nds.pcshow.uninstall.plist (Shell script - installed 2017-03-23)
[failed] com.spotify.webhelper.plist (Unknown - installed 2017-05-04) [Lookup] - ~/Library/Application Support/Spotify/SpotifyWebHelper: Executable not found!
[running] com.tunnelbear.mac.tbeara.plist (TunnelBear, Inc./ - installed 2016-12-16) [Lookup]
[loaded] com.valvesoftware.steamclean.plist (Unknown - installed 2017-05-04) [Lookup]
User Login Items: ⓘ
smcFanControl Applicazione
(/private/var/folders/vz/g36g33sx1rz8mdp4lkkmzz6w0000gn/T/AppTranslocation/8852E476-A354-45F7-8ACE-8C480E4F7638/d/smcFanControl.app)
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 25.0.0.171 (installed 2017-05-09) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2017-04-08)
AdobePDFViewerNPAPI: 17.009.20044 (installed 2017-04-13) [Lookup]
AdobePDFViewer: 17.009.20044 (installed 2017-04-13) [Lookup]
Flash Player: 25.0.0.171 (installed 2017-05-09) [Lookup]
SharePointBrowserPlugin: 14.3.6 (installed 2013-09-09) [Lookup]
PepperFlashPlayer: 25.0.0.171 (installed 2017-05-09) [Lookup]
Silverlight: 5.1.50901.0 (installed 2016-10-23) [Lookup]
JavaAppletPlugin: 15.0.1 (installed 2014-02-05) Check version
Safari Extensions: ⓘ
[enabled] AdBlock - BetaFish, Inc. - https://getadblock.com (installed 2017-04-30)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2017-04-27) [Lookup]
MacFUSE (installed 2008-12-19) [Lookup]
Time Machine: ⓘ
Skip System Files: NO
Auto backup: YES
Volumes being backed up:
SSD 250: Disk size: 248.86 GB Disk used: 211.90 GB
Destinations:
time machine [Local]
Total size: 1.00 TB
Total number of backups: 7
Oldest backup: 13/05/15, 11:25
Last backup: 13/05/15, 17:24
Size of backup disk: Excellent
Backup size 1.00 TB > (Disk size 248.86 GB X 3)
Top Processes by CPU: ⓘ
5% WindowServer
4% firefox
3% XRG
3% kernel_task
3% RdrCEF
Top Processes by Memory: ⓘ
704 MB kernel_task
422 MB com.apple.WebKit.WebContent(6)
251 MB firefox
197 MB Safari
119 MB MTLCompilerService(10)
Input Output Process name
189 KB 84 KB mDNSResponder
21 KB 9 KB netbiosd
8 KB 5 KB apsd
5 KB 3 KB assistantd
4 KB 3 KB firefox
7.40 WindowServer
5.48 firefox
3.56 RdrCEF
2.46 XRG
0.14 NDSPCShowServer
Virtual Memory Information: ⓘ
671 MB Available RAM
61 MB Free RAM
3.35 GB Used RAM
610 MB Cached files
914 MB Swap Used
Diagnostics Information: ⓘ
2017-05-16 23:10:54 Self test - passed
2017-05-16 22:54:55 ~/Library/Logs/DiagnosticReports/com.apple.WebKit.Plugin.32_2017-05-16-225455_[redacted].crash
/System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Plugin.32.xpc/Contents/MacOS/com.apple.WebKit.Plugin.32
Application Specific Information:
abort() called
*** error for object 0x5717010: pointer being freed was not allocated
2017-05-16 22:47:37 ~/Library/Logs/DiagnosticReports/mapspushd_2017-05-16-224737_[redacted].crash
/System/Library/CoreServices/mapspushd
2017-05-15 13:41:18 ~/Library/Logs/DiagnosticReports/com.apple.WebKit.Plugin.32_2017-05-15-134118_[redacted].crash
abort() called
*** error for object 0x578b010: pointer being freed was not allocated
2017-05-15 12:40:16 ~/Library/Logs/DiagnosticReports/com.apple.WebKit.Plugin.32_2017-05-15-124016_[redacted].crash
abort() called
*** error for object 0x5796010: pointer being freed was not allocated
smartctl 6.5 2016-05-07 r4318 [Darwin 16.5.0 x86_64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Samsung based SSDs
Device Model: Samsung SSD 850 EVO 250GB
Serial Number: S21PNSBFC03555T
LU WWN Device Id: 5 002538 da0046844
Firmware Version: EMT01B6Q
User Capacity: 250,059,350,016 bytes [250 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4c
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed May 17 13:23:03 2017 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x53) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 133) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 5932
12 Power_Cycle_Count 0x0032 090 090 000 Old_age Always - 9180
177 Wear_Leveling_Count 0x0013 090 090 000 Pre-fail Always - 198
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0
181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
183 Runtime_Bad_Block 0x0013 100 099 010 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 061 047 000 Old_age Always - 39
195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0
199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0
235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 32
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 14382930309
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Warning! SMART Selective Self-Test Log Structure error: invalid SMART checksum.
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
255 0 65535 Read_scanning was never started
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
sudo trimforce enable
sudo launchctl unload /Library/LaunchDaemons/com.adobe.ARMDC.Communicator.plist;sudo launchctl unload /Library/LaunchDaemons/com.adobe.ARMDC.SMJobBlessHelper.plist;sudo launchctl unload /Library/LaunchAgents/com.adobe.ARMDCHelper.*.plist
sudo rm -rf /Library/LaunchDaemons/com.adobe.ARMDC.Communicator.plist /Library/LaunchDaemons/com.adobe.ARMDC.SMJobBlessHelper.plist /Library/LaunchAgents/com.adobe.ARMDCHelper.*.plist /Applications/Adobe\ Acrobat\ Reader\ DC.app /Library/Preferences/com.adobe.reader.DC.WebResource.plist /Library/Application\ Support/Adobe/ARMDC /Library/Application\ Support/Adobe/ARMNext /Library/Application\ Support/Adobe/HelpCfg /Library/Application\ Support/Adobe/Reader/DC /Library/Internet\ Plug-Ins/AdobePDFViewer.plugin /Library/Internet\ Plug-Ins/AdobePDFViewerNPAPI.plugin /Library/PrivilegedHelperTools/com.adobe.ARMDC.* ~/Library/Application\ Support/Adobe/AcroCef ~/Library/Application\ Support/Adobe/Acrobat/DC ~/Library/Application\ Support/CEF ~/Library/Logs/DiagnosticReports/AdobeReader_*.crash ~/Library/Preferences/com.adobe.AdobeRdrCEF.plist /private/var/db/receipts/com.adobe.RdrServicesUpdater.* /private/var/db/receipts/com.adobe.acrobat.DC.* /private/var/db/receipts/com.adobe.armdc.*
Visitano il forum: Google [Bot] e 3 ospiti
