Per curiosità che sito era? Non mettere il link diretto, basta un accenno ......emanbass ha scritto: .... nell'ultima settimana ho guardato una serie TV in streaming (cosa che non avevo praticamente mai fatto) su un sito in cui si aprivano continuamente finestre di pubblicità e avvisi ....
EtreCheck version: 2.9.12 (265)
Report generated 2016-05-29 16:01:48
Runtime 2:08
Performance: Excellent
Click the [Remove] links to remove adware.
Hardware Information: ⓘ
MacBook Pro (13-inch, Mid 2012)
MacBook Pro - model: MacBookPro9,2
1 2.5 GHz Intel Core i5 CPU: 2-core
4 GB RAM
BANK 0/DIMM0
2 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Wireless: en1: 802.11 a/b/g/n
Battery: Health = Replace Soon - Cycle count = 1157
Video Information: ⓘ
Intel HD Graphics 4000 - VRAM: 384 MB
Color LCD 1280 x 800
System Software: ⓘ
OS X Lion 10.7.5 (11G63) - Time since boot: about 3 hours
Disk Information: ⓘ
TOSHIBA MK5065GSXF disk0 : (500,11 GB) (Rotational)
disk0s1 (disk0s1) <not mounted> : 210 MB
Macintosh HD (disk0s2) / : 499.25 GB (326.34 GB free)
HL-DT-ST DVDRW GS31N ()
USB Information: ⓘ
Apple Inc. BRCM20702 Hub
Thunderbolt Information: ⓘ
Apple, Inc. MacBook Pro
Adware: ⓘ
~/Library/Caches/com.apple.Safari/Extensions/Searchme.safariextension
~/Library/Safari/Extensions/Searchme.safariextz
2 adware files found. [Remove]
Kernel Extensions: ⓘ
/System/Library/Extensions
[not loaded] com.NovatelWireless.driver.NovatelWirelessUSBCDCECMControl (3.0.9 - 2016-02-01) [Support]
[not loaded] com.NovatelWireless.driver.NovatelWirelessUSBCDCECMData (3.0.9 - 2016-02-01) [Support]
[not loaded] com.ZTE.driver.ZTEUSBCDCACMData (ZTEDriver_MacV1.3.4 - 2016-02-01) [Support]
[not loaded] com.ZTE.driver.ZTEUSBMassStorageFilter (ZTEDriver_MacV1.3.4 - 2016-02-01) [Support]
[not loaded] com.novamedia.driver.IceraUSB_MSD_Bypass (NM Icera bypass V1.0 - 2016-02-01) [Support]
[not loaded] com.novatelwireless.driver.3G (v3.0.9 (017) - 2016-02-01) [Support]
[not loaded] com.novatelwireless.driver.DisableAutoInstall (v2.0.6 - 2016-02-01) [Support]
[not loaded] com.option.driver.Option72 (2.15.0 - 2016-02-01) [Support]
[not loaded] com.option.driver.OptionHS (3.26.0 - 2016-02-01) [Support]
[not loaded] com.option.driver.OptionMSD (1.21.0 - 2016-02-01) [Support]
[not loaded] com.option.driver.OptionQC (1.11.0 - 2016-02-01) [Support]
[not loaded] com.vodafone.driver (v3.0.9 (017) - 2016-02-01) [Support]
[not loaded] com.vodafone.driver.DisableAutoInstall (v2.0.6 - 2016-02-01) [Support]
[not loaded] com.zte.driver.cdc_ecm_qmi (1.0.0d1 - 2016-02-01) [Support]
[not loaded] com.zte.driver.cdc_usb_bus (1.0.0d1 - 2016-02-01) [Support]
[not loaded] de.novamedia.driver.NMLGEDriver (3.2.10 - 2016-02-01) [Support]
[not loaded] de.novamedia.driver.NMSamsung (0.0.2 - 2016-02-01) [Support]
[not loaded] de.novamedia.driver.NMSmartplugSCSIDevice (1.0.1 - 2016-02-01) [Support]
[not loaded] de.novamedia.oem.vodafone.vtp.huawei.cdc (0.0.2 - 2016-02-01) [Support]
/System/Library/Extensions/NMHuaweiPhonesVTPCDC.kext/Contents/Resources
[not loaded] de.novamedia.driver.NMUSBCDCACMData.VTP (3.2.6 - 2010-03-17) [Support]
/System/Library/Extensions/NMLGEDriver.kext/Contents/PlugIns
[not loaded] de.novamedia.driver.NMLGEUSBCDCACMControl (3.1.9 - 2010-03-17) [Support]
[not loaded] de.novamedia.driver.NMLGEUSBCDCACMData (3.1.9 - 2010-03-17) [Support]
/System/Library/Extensions/NMSamsungDriver_106.kext/Contents/PlugIns
[not loaded] de.novamedia.driver.NMUSBCDCACMControl (3.2.12 - 2010-03-17) [Support]
[not loaded] de.novamedia.driver.NMUSBCDCACMData (3.2.12 - 2010-03-17) [Support]
/System/Library/Extensions/NovatelWireless3G.kext/Contents/Plugins
[not loaded] com.novatelwireless.driver.3GData (v3.0.9 (017) - 2010-03-17) [Support]
/System/Library/Extensions/Vodafone.kext/Contents/Plugins
[not loaded] com.vodafone.driver.Data (v3.0.9 (017) - 2010-03-17) [Support]
System Launch Agents: ⓘ
[not loaded] 5 Apple tasks
[loaded] 115 Apple tasks
[running] 13 Apple tasks
System Launch Daemons: ⓘ
[running] de.novamedia.nmnetmgrd.plist (2010-03-12) [Support]
[not loaded] 65 Apple tasks
[loaded] 123 Apple tasks
[running] 38 Apple tasks
Launch Agents: ⓘ
[loaded] com.google.keystone.agent.plist (2016-03-01) [Support]
Launch Daemons: ⓘ
[failed] com.adobe.fpsaud.plist (2016-05-10) [Support]
[loaded] com.apple.remotepairtool.plist
[loaded] com.google.keystone.daemon.plist (2016-03-01) [Support]
[loaded] com.macpaw.CleanMyMac2.Agent.plist (2016-01-25) [Support]
User Launch Agents: ⓘ
[loaded] com.apple.AddressBook.ScheduledSync.PHXC...plist
[loaded] com.facebook.videochat.[redacted].plist (2014-08-09) [Support]
[loaded] com.macpaw.CleanMyMac2Helper.diskSpaceWatcher.plist (2016-05-28) [Support]
[loaded] com.macpaw.CleanMyMac2Helper.scheduledScan.plist (2016-05-28) [Support]
[loaded] com.macpaw.CleanMyMac2Helper.trashWatcher.plist (2016-05-28) [Support]
[running] com.spotify.webhelper.plist (2016-05-16) [Support]
User Login Items: ⓘ
iTunesHelper Applicazione Hidden (/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
VMCStatusMenu Applicazione (/Applications/Vodafone Utilities/VMCStatusMenu.app)
Android File Transfer Agent Applicazione (~/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app)
Other Apps: ⓘ
[loaded] 0x7f8cda6029e0.mach_init.Inspector
[running] [0x0-0x10010].com.google.android.mtpagent
[running] [0x0-0x2f02f].com.etresoft.EtreCheck
[running] [0x0-0xf00f].de.novamedia.VMCStatusMenue
[loaded] 348 Apple tasks
[running] 129 Apple tasks
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 21.0.0.242 - SDK 10.6 (2016-05-20) [Support]
Flash Player: 21.0.0.242 - SDK 10.6 (2016-05-20) [Support]
QuickTime Plugin: 7.7.1 (2015-03-23)
Google Earth Web Plug-in: 7.1 (2015-06-17) [Support]
JavaAppletPlugin: 14.9.0 - SDK 10.7 (2012-05-09) Check version
Unity Web Player: UnityPlayer version 5.0.3f2 - SDK 10.6 (2015-06-17) [Support]
Safari Extensions: ⓘ
Searchme - Spigot, Inc. - http://www.spigot.com/" onclick="window.open(this.href);return false; (2016-02-06) Adware! [Remove]
3rd Party Preference Panes: ⓘ
Flash Player (2016-05-10) [Support]
Time Machine: ⓘ
Time Machine information requires OS X 10.8 "Mountain Lion" or later.
Top Processes by CPU: ⓘ
4% Safari
3% WindowServer
2% fontd
2% WebProcess
0% loginwindow
Top Processes by Memory: ⓘ
721 MB WebProcess
131 MB Safari
53 MB mds
41 MB WindowServer
41 MB Finder
Virtual Memory Information: ⓘ
1.60 GB Free RAM
2.40 GB Used RAM
0 B Swap Used
Diagnostics Information: ⓘ
May 29, 2016, 12:56:55 PM Self test - passed
/code]
Ho eliminato l'ultimo, mentre i primi due file non li trovo all'interno della cartella LaunchAgentsfaxus ha scritto: Elimina manualmente questi file:
~/Library/LaunchAgents/com.spigot.SearchProtection.plist
~/Library/LaunchAgents/com.spigot.ApplicationManager.plist
~/Library/Application Support/Spigot/
La ~ (tilde) indica la libreria utente.
Ci puoi accedere dal menù Vai del Finder, tenendo premuto il tasto ⌥ e scegliendo Libreria.
È sufficiente, il resto probabilmente era già stato eliminato da Etreemanbass ha scritto:... Ho eliminato l'ultimo, mentre i primi due file non li trovo all'interno della cartella LaunchAgents
Grazie fax.faxus ha scritto: Non scaricare nulla anche se viene detto che è indispensabile alla fruizione dei contenuti.
Impostare con i limiti necessari i pannelli sicurezza e privacy del browser.
AdBlock, AdBlockPlus e Adguard AdBlocker daranno una mano e non vanno disabilitati se il sito lo chiede.
Dopo pulire sempre i cookie
Visitano il forum: Nessuno e 30 ospiti
