panic(cpu 0 caller 0xffffff800f11cce7): userspace panic: boot task failure: dirs_cleaner - required boot task executable not found @kern_shutdown.c:159
Panicked task 0xffffff8ba8478350: 3 threads: pid 1: launchd
Backtrace (CPU 0), panicked thread: 0xffffff8ba7fe0540, Frame : Return Address
0xffffffada44e3a20 : 0xffffff800e87befd
0xffffffada44e3a70 : 0xffffff800e9de636
0xffffffada44e3ab0 : 0xffffff800e9cd9a3
0xffffffada44e3b00 : 0xffffff800e81ba70
0xffffffada44e3b20 : 0xffffff800e87c2cd
0xffffffada44e3c40 : 0xffffff800e87ba86
0xffffffada44e3ca0 : 0xffffff800f114983
0xffffffada44e3d90 : 0xffffff800f11cce7
0xffffffada44e3db0 : 0xffffff800ee5e1e2
0xffffffada44e3e00 : 0xffffff800ee7cd33
0xffffffada44e3f40 : 0xffffff800ef86abb
0xffffffada44e3fa0 : 0xffffff800e81c236
Process name corresponding to current thread (0xffffff8ba7fe0540): launchd
Mac OS version:
21G531
Kernel version:
Darwin Kernel Version 21.6.0: Thu Mar 9 20:08:59 PST 2023; root:xnu-8020.240.18.700.8~1/RELEASE_X86_64
Kernel UUID: DFAC8C3A-BB7E-3E0A-9BC7-19B8D1B9A2A0
KernelCache slide: 0x000000000e600000
KernelCache base: 0xffffff800e800000
Kernel slide: 0x000000000e610000
Kernel text base: 0xffffff800e810000
__HIB text base: 0xffffff800e700000
System model name: iMac19,2 (Mac-63001698E7A34814)
System shutdown begun: NO
Panic diags file available: NO (0xe00002bc)
Hibernation exit count: 0
System uptime in nanoseconds: 86782148945
Last Sleep: absolute base_tsc base_nano
Uptime : 0x00000014349e924e
Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000
Wake : 0x0000000000000000 0x0000001f8e61804b 0x0000000000000000
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info:
Zone map: 0xffffff80746be000 - 0xffffffa0746be000
. PGZ : 0xffffff80746be000 - 0xffffff80756bf000
. VM : 0xffffff80756bf000 - 0xffffff8542125000
. RO : 0xffffff8542125000 - 0xffffff86db9f1000
. GEN0 : 0xffffff86db9f1000 - 0xffffff8ba8457000
. GEN1 : 0xffffff8ba8457000 - 0xffffff9074ebd000
. GEN2 : 0xffffff9074ebd000 - 0xffffff9541923000
. GEN3 : 0xffffff9541923000 - 0xffffff9a0e38a000
. DATA : 0xffffff9a0e38a000 - 0xffffffa0746be000
Metadata: 0xffffffffbcfee000 - 0xffffffffdcfee000
Bitmaps : 0xffffffffdcfee000 - 0xffffffffdffee000
last started kext at 2630246392: >!UHIDMouse 196 (addr 0xffffff800fe16000, size 8192)
loaded kexts:
|SCSITaskUserClient 456.140.3
>BCMWLANFirmware4387.Hashstore 1
>BCMWLANFirmware4378.Hashstore 1
>BCMWLANFirmware4377.Hashstore 1
>BCMWLANFirmware4364.Hashstore 1
>BCMWLANFirmware4355.Hashstore 1
>!AFileSystemDriver 3.0.1
@filesystems.tmpfs 1
@filesystems.lifs 1
@filesystems.hfs.kext 583.100.10
@BootCache 40
@!AFSCompression.!AFSCompressionTypeZlib 1.0.0
@!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
>!ASDXC 3.2.1
|!ABCM5701Ethernet 11.0.0
>!ABCMWLANBusInterfacePCIeMac 1
@filesystems.apfs 1934.141.2
>!AAHCIPort 351.100.4
@private.KextAudit 1.0
>!ARTC 2.0.1
>!AACPIButtons 6.1
>!ASMBIOS 2.1
>!AACPIEC 6.1
>!AAPIC 1.7
@!ASystemPolicy 2.0.0
@nke.applicationfirewall 402
|IOKitRegistryCompatibility 1
|EndpointSecurity 1
@Dont_Steal_Mac_OS_X 7.0.0
@kec.!AEncryptedArchive 1
>!UHIDMouse 196
>!AHIDMouse 196
>usb.IOUSBHostHIDDevice 1.2
>usb.!UHub 1.2
>usb.cdc 5.0.0
>usb.networking 5.0.0
>usb.!UHostCompositeDevice 1.2
>!AThunderboltPCIDownAdapter 4.1.1
>!AThunderboltDPInAdapter 8.5.1
>!AThunderboltDPAdapter!F 8.5.1
>!AHPM 3.4.4
>!A!ILpssI2C!C 3.0.60
>!A!ILpssI2C 3.0.60
>!A!ILpssDmac 3.0.60
>!ABSDKextStarter 3
|IOSurface 302.14
@filesystems.hfs.encodings.kext 1
>!AThunderboltNHI 7.2.81
|IOThunderbolt!F 9.3.3
|IONVMe!F 2.1.0
>!ABCMWLANCoreMac 1.0.0
|IOSerial!F 11
|IO80211!F 1200.12.2b2
|IOSkywalk!F 1.0
>mDNSOffloadUserClient 1.0.1b8
>IOImageLoader 1.0.0
>!AOLYHALMac 1
>corecapture 1.0.4
>!AXsanScheme 3
|IOAHCIBlock!S 333.140.2
|IOAHCI!F 297
>usb.!UHostPacketFilter 1.0
|IOUSB!F 900.4.2
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
>!ASMCRTC 1.0
|IOSMBus!F 1.1
|IOHID!F 2.0.0
|IOTimeSync!F 1040.3
|IONetworking!F 3.4
>DiskImages 493.0.0
|IO!B!F 9.0.0
|IOReport!F 47
$quarantine 4
$sandbox 300.0
@kext.!AMatch 1.0.0d1
|CoreAnalytics!F 1
>!ASSE 1.0
>!AKeyStore 2
>!UTDM 533.120.2
|IOUSBMass!SDriver 210.120.3
|IOSCSIBlockCommandsDevice 456.140.3
|IO!S!F 2.1
|IOSCSIArchitectureModel!F 456.140.3
>!AMobileFileIntegrity 1.0.5
$!AImage4 4.2.0
@kext.CoreTrust 1
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>!ACredentialManager 1.0
>KernelRelayHost 1
|IOUSBHost!F 1.2
>!UHostMergeProperties 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
>!AACPIPlatform 6.1
>!ASMC 3.1.9
|IOPCI!F 2.9
|IOACPI!F 1.4
>watchdog 1
@kec.pthread 1
@kec.Libm 1
@kec.corecrypto 12.0
OK, a pensarci, in fondo il problema con il WD backup di TimeMachine era dovuto ad una mancanza di corrente e credo che ne acquisterò un'altro.Alberto.G ha scritto: ↑dom, 30 apr 2023 12:24Riprendo la discussione.
1) nuovo disco per Time Machine.
Qui ognuno dice la sua. Chi sostiene che gli hard disk della WD sono assolutamente da perdere, chi sostiene invece che sono ottimi perché non hanno mai dato problemi, altri dicono che sono buoni e da preferire quelli di Toshiba, ecc. ecc.
Facendo un riassunto su marche che ho visto più citate sul nostro forum sono queste:
- WD
- Toshiba
- Seagate.
Ad esempio, io ho 2 marche: WD da 4TB e da 1TB e poi Toshiba Canvio Basics da 1TB e tutti con cavo USB 3.0: fino ad oggi mai avuto problemi.
Ho letto che vorresti uno da 2TB. Ora dipende da quanta roba hai su disco e quanto penseresti in futuro di averne. Poi dipende anche se opti per un backup in automatico ovvero per uno eseguito ogni tanto, a tua discrezione.
Ho scelto, fin da subito, il backup in automatico fatto da TM e mi trovo molto bene (a me piace anche poter vedere file salvati tanto tempo prima… ma è poi una mia fissazione!).
Vedo anche che i 4TB cominciano ad essere stretti (a disposizione ho solo 1,44TB).
Ti ho dato più informazioni visto che hai il desiderio di acquistarne uno, ritengo più grande in capacità.
3) ultima cosa: fino ad oggi non ho mai avuto occasione di provare la funzione Ripristina di Utility Disco e non potrei dare una risposta nel merito.
Ho provato invece, molte volte (una dozzina), ad utilizzare CCC, sempre con la funzione attiva di “Assistente per la copia avviabile legacy…” e mi sono trovato sempre bene.
Auguri per le tue prove!
panic(cpu 6 caller 0xffffff80193cdd93): Kernel trap at 0xffffff80199aec1b, type 14=page fault, registers:
CR0: 0x0000000080010033, CR2: 0x0000000000000020, CR3: 0x000000026a064032, CR4: 0x00000000003626e0
RAX: 0x0000000000000000, RBX: 0x0000000000000000, RCX: 0x0000000000000000, RDX: 0x0000000000420000
RSP: 0xffffffffff9bb8a0, RBP: 0xffffffffff9bb900, RSI: 0xffffffffff9bb7e8, RDI: 0x0000000000000000
R8: 0x0000000000000000, R9: 0x0000000000000002, R10: 0x0000000000002400, R11: 0x0000000000002400
R12: 0xffffffffff9bb998, R13: 0xffffff7faefdb000, R14: 0x00000000153ca000, R15: 0x0000000000000000
RFL: 0x0000000000010246, RIP: 0xffffff80199aec1b, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0x0000000000000020, Error code: 0x0000000000000000, Fault CPU: 0x6, PL: 0, VF: 0
Panicked task 0xffffff90828d4030: 2 threads: pid 394: kernelmanagerd
Backtrace (CPU 6), panicked thread: 0xffffff9a1b048540, Frame : Return Address
0xffffffffff9bb250 : 0xffffff801927befd
0xffffffffff9bb2a0 : 0xffffff80193de636
0xffffffffff9bb2e0 : 0xffffff80193cd9a3
0xffffffffff9bb330 : 0xffffff801921ba70
0xffffffffff9bb350 : 0xffffff801927c2cd
0xffffffffff9bb470 : 0xffffff801927ba86
0xffffffffff9bb4d0 : 0xffffff8019b14983
0xffffffffff9bb5c0 : 0xffffff80193cdd93
0xffffffffff9bb740 : 0xffffff80193cda76
0xffffffffff9bb790 : 0xffffff801921ba70
0xffffffffff9bb7b0 : 0xffffff80199aec1b
0xffffffffff9bb900 : 0xffffff80199adcd8
0xffffffffff9bb970 : 0xffffff80199ade8c
0xffffffffff9bb9f0 : 0xffffff80199bc586
0xffffffffff9bbc10 : 0xffffff80199bbd05
0xffffffffff9bbc70 : 0xffffff80199ba13e
0xffffffffff9bbcf0 : 0xffffff80199cdbe6
0xffffffffff9bbd80 : 0xffffff80192f4f6b
0xffffffffff9bbdd0 : 0xffffff8019256a2b
0xffffffffff9bbe60 : 0xffffff801926d339
0xffffffffff9bbef0 : 0xffffff80193b060a
0xffffffffff9bbfa0 : 0xffffff801921c256
Process name corresponding to current thread (0xffffff9a1b048540): kernelmanagerd
Mac OS version:
21G531
Kernel version:
KernelCache slide: 0x0000000019000000
KernelCache base: 0xffffff8019200000
Kernel slide: 0x0000000019010000
Kernel text base: 0xffffff8019210000
__HIB text base: 0xffffff8019100000
System uptime in nanoseconds: 144156881718
Uptime : 0x00000021906b7740
Wake : 0x0000000000000000 0x0000001dd0ab7063 0x0000000000000000
Zone info:
Zone map: 0xffffff8082165000 - 0xffffffa082165000
. PGZ : 0xffffff8082165000 - 0xffffff8083166000
. VM : 0xffffff8083166000 - 0xffffff854fbcc000
. RO : 0xffffff854fbcc000 - 0xffffff86e9498000
. GEN0 : 0xffffff86e9498000 - 0xffffff8bb5efe000
. GEN1 : 0xffffff8bb5efe000 - 0xffffff9082964000
. GEN2 : 0xffffff9082964000 - 0xffffff954f3ca000
. GEN3 : 0xffffff954f3ca000 - 0xffffff9a1be31000
. DATA : 0xffffff9a1be31000 - 0xffffffa082165000
Metadata: 0xffffff805f155000 - 0xffffff807f155000
Bitmaps : 0xffffff807f155000 - 0xffffff8082155000
last started kext at 2846636626: >usb.IOUSBHostHIDDevice 1.2 (addr 0xffffff801c423000, size 40960)
loaded kexts:
@filesystems.lifs 1
@BootCache 40
>!ASDXC 3.2.1
>!AACPIButtons 6.1
>!ARTC 2.0.1
>!ASMBIOS 2.1
>!AACPIEC 6.1
>!AAPIC 1.7
|EndpointSecurity 1
>usb.!UHub 1.2
>usb.cdc 5.0.0
>!AHPM 3.4.4
>!A!ILpssI2C 3.0.60
>!A!ILpssDmac 3.0.60
>!ABSDKextStarter 3
|IOSurface 302.14
|IONVMe!F 2.1.0
|IOSerial!F 11
|IOSkywalk!F 1.0
>IOImageLoader 1.0.0
>!AOLYHALMac 1
>corecapture 1.0.4
>!AXsanScheme 3
|IOAHCI!F 297
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
|IOUSB!F 900.4.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
>!ASMCRTC 1.0
|IOSMBus!F 1.1
|IOHID!F 2.0.0
|IOTimeSync!F 1040.3
|IONetworking!F 3.4
>DiskImages 493.0.0
|IO!B!F 9.0.0
|IOReport!F 47
$quarantine 4
$sandbox 300.0
|CoreAnalytics!F 1
>!ASSE 1.0
>!AKeyStore 2
>!UTDM 533.120.2
|IO!S!F 2.1
$!AImage4 4.2.0
@kext.CoreTrust 1
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>KernelRelayHost 1
|IOUSBHost!F 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
>!AACPIPlatform 6.1
>!ASMC 3.1.9
|IOPCI!F 2.9
|IOACPI!F 1.4
>watchdog 1
@kec.pthread 1
@kec.Libm 1
Innanzitutto buon primo maggio!Pingus ha scritto: ↑ven, 28 apr 2023 14:37
Scusami avevo letto (poco) e trovato poco tempo per risponderti bene e con attenzione.
Dico la mia velocemente comunque.
La prima cosa che ti avrei chiesto ed imputato alla questione lentezza è l'aver fatto un clone.
Al contrario di altri, io, sicuramente, dopo un clone farei: cancello cache sistema, libreria, utente, logs sistema libreria utente, Onyx e/o MacPilot per launchservices, dylcache, logs, dns, kernelcache, spotlight, etc. poi reset pram se applicabile, avvio -alt- con selezione disco, impostazione disco avvio (lo so dovrebbe farlo da solo ma…) e altro se mi viene in mente ahahah
Secondo me non è né il disco né il box, ma macOS che odia sempre di più il clone perché colì perché colà Apple come sempre ci fa!
Sicuramente da zero, importando i dati, migrazione, poi corri.
Ho riguardato iMac27 con box e disco nmve e siamo messi molto bene e meglio di un iMac con ssd sata, sia in velocità che avvio.
Tranquillo, andrà benone poi!
Grazie J.T. Kirk, ho letto con interesse la pagina che hai indicato, ma il problema discusso lì risultava essere le custodie con il chipset JMS583 e suggerivano custodie come la mia che ha un chipset Realtek RT9210. Infatti, una volta avviato, tutto funziona egregiamente. Io cercavo di accelerare l'avvio e ci sono riuscito a farlo un pochino dai 03:00 e a volte oltre ai 01:50 circa di ora inizializzando il Crucial P3 e clonandolo di nuovo utilizzando CCC invece di SuperDuper.J.T.Kirk ha scritto: ↑lun, 01 mag 2023 11:16Con I box esterni per NVMe è un terno al lotto.
Come ti ha detto fragrua devi fare dei test incrociati.
I più facili da fare sono cavetto e box (e meno costosi).
https://forums-macrumors-com.translate. ... _tr_pto=sc
Ma dai, mica dovevi saperlo, giustamente come dici tu, a volte sono proprio i dettagli che ci sfuggono.
Infatti, sto lavorando sul disco esterno e non ci sono problemi. Ho provato a scollegare e ricollegare il disco esterno e ho pure cambiato porta USB-C, ma il volume che contiene il SO risulta sempre disattivato. Anche se sembra assurdo, visto che il volume che contiene il SO Monterey è disattivato, ma tutto funziona, mi chiedo se il mac si stia appoggiando sul sistema operativo del volume del Macintosh HD (fusondrive). Però ho paura di disattivare il volume del Macintosh HD per vedere se è così.Alberto.G ha scritto: ↑lun, 01 mag 2023 11:23Però mi sento in dovere di ringraziarti perché sei disponibile a fornirci più indicazioni possibili, anche se possono sembrare banali, riguardo a ciò che ti sta succedendo con i due dischi, entrambi con identico sistema macOS, uno dei quali collegato via USB-C.
Tutto può diventare utile sapere anche perché, essendo in un forum, altre persone potrebbero dare il loro contributo e, magari, dare anche la soluzione.
In questi casi di kernel panic, ma non solo, tutto può avere un senso (vedi esempio la PRAM, vedi il volume Crucial Monterey disattivato, ecc.).
Proprio riguardo al volume citato è che, questo, è proprio il volume che contiene il sistema operativo Monterey… e non dovrebbe essere disattivato (come si evidenzia bene in foto).
Da come scrivi ritengo che ora tu stia lavorando con il disco P3 esterno e, mi sembra, senza avere problemi.
Speriamo bene! Comunque dacci sempre notizie… anche quelle che possono apparire insignificanti.
