Alberto.G ha scritto: P.S.- Ai massimi esperti una indicazione (eventuale) sul da farsi. GRAZIE
Già ne accenna Kundalini, ma lo diciamo da sempre.iStefano & robbie & Alberto.G ha scritto:... CoreSpeech.framework...
EtreCheck version: 3.4.7 (461)
Report generated 2018-04-05 08:39:58
Runtime: 2:03
Performance: Excellent
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Click the [Clean up] link to delete unused files.
Hardware Information: ⓘ
iMac (Retina 5K, 27-inch, 2017)
iMac - model: iMac18,3
1 4,2 GHz Intel Core i7 (i7-7700K) CPU: 4-core
40 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
4 GB DDR4 2400 MHz ok
BANK 0/DIMM1
16 GB DDR4 2400 MHz ok
BANK 1/DIMM0
BANK 1/DIMM1
Handoff/Airdrop2: supported
Wireless: en1: 802.11 a/b/g/n/ac
iCloud Quota: 4.91 GB available
Video Information: ⓘ
Radeon Pro 580 - VRAM: 8192 MB
iMac
Disk Information: ⓘ
APPLE SSD SM0512L disk0: (500,28 GB) (Solid State - TRIM: Yes)
(disk0s1) <not mounted> [EFI]: 315 MB
(disk0s2) <not mounted> [APFS Container]: 499.96 GB
USB Information: ⓘ
USB30Bus
ASMedia AS2107
Terra Master DAS
Master DAS disk5: (4 TB)
EFI (disk5s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
Mac_BackUp (disk5s2 - Journaled HFS+) /Volumes/Mac_BackUp : 4.00 TB (2.27 TB free)
Terra Master DAS
Master DAS disk3: (1 TB)
EFI (disk3s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
Mac_Archivio_4 (disk3s2 - Journaled HFS+) /Volumes/Mac_Archivio_4 : 999.86 GB (357.83 GB free)
Terra Master DAS
Master DAS disk7: (1 TB)
EFI (disk7s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
Mac_Archivio_6 (disk7s2 - Journaled HFS+) /Volumes/Mac_Archivio_6 : 999.86 GB (502.95 GB free)
Terra Master DAS
Master DAS disk2: (1 TB)
EFI (disk2s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
Mac_Archivio (disk2s2 - Journaled HFS+) /Volumes/Mac_Archivio : 999.86 GB (320.21 GB free)
Master DAS disk4: (1 TB)
EFI (disk4s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
Mac_Archivio_2 (disk4s2 - Journaled HFS+) /Volumes/Mac_Archivio_2 : 999.86 GB (522.77 GB free)
Broadcom Corp. Bluetooth USB Host Controller
ASMedia AS2107
Apple, Inc. Keyboard Hub
Apple, Inc Apple Keyboard
GenesysLogic USB2.0 Hub
Generic USB Storage
TOSHIBA External USB 3.0
External USB 3.0 disk6: (1 TB)
EFI (disk6s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
Mac_Archivio_8 (disk6s2 - Journaled HFS+) /Volumes/Mac_Archivio_8 : 999.86 GB (555.61 GB free)
Western Digital My Passport 0830
My Passport 0830 disk8: (1 TB)
EFI (disk8s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
backup_roby (disk8s2 - Journaled HFS+) /Volumes/backup_roby : 999.83 GB (521.62 GB free)
USB31Bus
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
Mac_High_Sierra (disk1s1 - APFS) / [Startup]: 499.96 GB (392.41 GB free)
Physical disk: disk0s2 499.96 GB (392.41 GB free)
(disk1s2) <not mounted> [Preboot]: 499.96 GB
(disk1s3) <not mounted> [Recovery]: 499.96 GB
(disk1s4) /private/var/vm [VM]: 499.96 GB
System Software: ⓘ
macOS High Sierra 10.13.4 (17E199) - Time since boot: less than an hour
Gatekeeper: ⓘ
Anywhere [Fix Gatekeeper security]
Possible adware: ⓘ
Unknown file: ~/Library/LaunchAgents/mega.mac.megaupdater.plist
/Applications/MEGAsync.app/Contents/MacOS/MEGAupdater
One possible adware file found. [Remove/Report]
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.corespeechd.plist
/System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Executable not found!
One orphan file found. [Clean up]
Kernel Extensions: ⓘ
/Applications/Hands Off!.app
[loaded] com.metakine.handsoff.driver (3.2.6 - SDK 10.9) [Lookup]
/Applications/VMware Fusion.app
[not loaded] com.vmware.kext.vmci (10.0.1) [Lookup]
[not loaded] com.vmware.kext.vmioplug.17.1.2 (10.0.1) [Lookup]
[not loaded] com.vmware.kext.vmnet (10.0.1) [Lookup]
[not loaded] com.vmware.kext.vmx86 (10.0.1) [Lookup]
/System/Library/Extensions
[not loaded] com.joshuawise.kexts.HoRNDIS (8.0 - SDK 10.6) [Lookup]
Startup Items: ⓘ
TuxeraNTFSUnmountHelper: Path: /Library/StartupItems/TuxeraNTFSUnmountHelper
Startup items no longer function in OS X Yosemite or later
System Launch Agents: ⓘ
[failed] com.apple.corespeechd.plist (? ? ? - installed 2017-11-01) - /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd: Executable not found!
[not loaded] 8 Apple tasks
[loaded] 172 Apple tasks
[running] 112 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 36 Apple tasks
[loaded] 184 Apple tasks
[running] 113 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2018-03-28) [Lookup]
[failed] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2018-03-28) [Lookup]
[loaded] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2018-03-28) [Lookup]
[loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2018-03-28) [Lookup]
[running] com.metakine.handsoff.agent.plist (One Periodic Inc. - installed 2018-03-28) [Lookup]
[loaded] com.microsoft.update.agent.plist (Microsoft Corporation - installed 2018-03-28) [Lookup]
[loaded] com.oracle.java.Java-Updater.plist (? 589778fb 1a4bf56e - installed 2018-03-29) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2018-03-28) [Lookup]
[loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2018-03-28) [Lookup]
[loaded] com.adobe.acc.installer.plist (Adobe Systems, Inc. - installed 2018-03-28) [Lookup]
[running] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2018-03-28) [Lookup]
[loaded] com.linotype.FontExplorerX.securityhelper.plist (? a4b09c2d e7fe6307 - installed 2018-03-28) [Lookup]
[running] com.metakine.handsoff.daemon.plist (? 4c15aef7 6e2a6529 - installed 2018-03-28) [Lookup]
[loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2018-03-28) [Lookup]
[loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2016-06-11) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script e3fefdd2 - installed 2018-03-29) [Lookup]
User Launch Agents: ⓘ
[loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2018-03-28) [Lookup]
[not loaded] com.linotype.FontFolderProtector.plist (Linotype GmbH - installed 2018-03-31) [Lookup]
[loaded] mega.mac.megaupdater.plist (? b02fc3f7 2941a568 - installed 2018-04-04) [Lookup]
User Login Items: ⓘ
DelayedLauncher Applicazione
(/Applications/DelayedLauncher.app)
iTunesHelper Applicazione (Apple, Inc. - installed 2018-03-30)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
Internet Plug-ins: ⓘ
AdobePDFViewerNPAPI: 17.012.20098 (installed 2018-03-28) [Lookup]
AdobePDFViewer: 18.011.20038 (installed 2018-03-28) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2018-03-30)
JavaAppletPlugin: Java 8 Update 161 build 12 (installed 2018-03-29) Check version
AdobeAAMDetect: 3.0.0.0 (installed 2018-03-28) [Lookup]
Safari Extensions: ⓘ
[enabled] AdBlock - BetaFish, Inc. - https://getadblock.com (installed 2018-03-28)
[enabled] Translate - SideTree.com - Apps for Mac - http://SideTree.com/extensions.html#Translate (installed 2018-03-28)
3rd Party Preference Panes: ⓘ
Java (installed 2017-12-20) [Lookup]
Tuxera NTFS (installed 2018-03-29) [Lookup]
Time Machine: ⓘ
Skip System Files: NO
Auto backup: YES
Volumes being backed up:
Mac_High_Sierra: Disk size: 499.96 GB Disk used: 107.55 GB
Destinations:
Mac_Recover [Local]
Total size: 319.73 GB
Total number of backups: 19
Oldest backup: 28/03/2018, 16:37
Last backup: 04/04/2018, 17:25
Backup size 319.73 GB < (Disk used 107.55 GB X 3)
Top Processes by CPU: ⓘ
4% WindowServer
2% launchd
2% kernel_task
2% Safari
1% com.apple.WebKit.WebContent
Top Processes by Memory: ⓘ
2.27 GB kernel_task
925 MB iTunes
783 MB Safari
438 MB com.apple.WebKit.WebContent
414 MB mds_stores
Input Output Process name
342 KB 63 KB com.apple.WebKit.Networking
290 KB 46 KB mDNSResponder
189 KB 14 KB Mail
63 KB 954 B Safari
18 KB 31 KB ath
7.80 WindowServer
5.06 com.apple.WebKit.WebContent
3.50 Safari
0.88 cloudd
Virtual Memory Information: ⓘ
30.28 GB Available RAM
24.93 GB Free RAM
9.72 GB Used RAM
5.35 GB Cached files
0 B Swap Used
Revealer: (installed 2018-03-28)
Adobe DNG Converter 10.2: 10.2 (installed 2018-03-28)
Bridge CC 2018.0: (installed 2018-03-28)
Dreamweaver: (installed 2018-03-28)
After Effects CC 2018: (installed 2018-03-28)
Illustrator: (installed 2018-03-28)
InDesign: (installed 2018-03-28)
Adobe Photoshop Lightroom Classic CC 2018 v7.2.0: (installed 2018-03-28)
Media Encoder CC 2018: (installed 2018-03-28)
Photoshop: (installed 2018-03-28)
Premiere CC 2018: (installed 2018-03-28)
Microsoft Office 2016 per Mac: (installed 2018-03-28)
Microsoft AutoUpdate: (installed 2018-03-28)
Microsoft Office 2016 Volume License Serializer: (installed 2018-03-28)
Adobe Acrobat DC: (installed 2018-03-28)
Adobe Acrobat DC (18.011.20038): (installed 2018-03-28)
Photomatix Pro 6.0.3: (installed 2018-03-28)
LRTimelapse 5: (installed 2018-03-28)
FileMaker Pro 16 Advanced: (installed 2018-03-28)
DJI Assistant 2: (installed 2018-03-28)
HoRNDIS: (installed 2018-03-28)
Noiseware 5 Plug-in for Photoshop build (5033): (installed 2018-03-28)
EPSON PC-FAX: (installed 2018-03-28)
ARMDC Agent Installer: (installed 2018-03-28)
Java 8 Update 161: (installed 2018-03-29)
Tuxera NTFS 2018: (installed 2018-03-29)
Copy'em Paste Helper: 2.2.2 (installed 2018-03-30)
2018-04-05 07:53:39 Adobe Desktop Service.app Crash [Open]
Cause: terminating with uncaught exception of type esd::no_resource_lock: This object is not locking an item
abort() called
2018-04-05 07:52:51 Last shutdown cause: 0 - Power loss
2018-04-04 07:59:45 Sync Folders Pro.app High CPU use [Open] [Details]
2018-04-02 18:52:21 LRTimelapse 5.app High CPU use [Open] [Details]
faxus ha scritto:A mio parere va bene così, non capisco perché hai dubbi.
I file denunciati dal check non sono un problema.
Se usi MEGA puoi lasciare quello nella libreria del disco.
E un residuo di OS più vecchi come speech non è un problema in nessun senso.
Neanche una vecchia versione scaduta di Java che hai installato.
Se vuoi sistema, ma non è una disfunzione né un problema
Ok non importa, grazie comunque!faxus ha scritto:Non so a che ri riferisci.
Ho letto che temevi problemi.
Reali non ne vedo, tanto da frenare l'aggiornamento.
Come detto, se vuoi puoi benissimo sistemare.
È facile senza possibilità di sbagliare.
Ma non sono problemi
Report generated 2018-05-15 21:00:04
Runtime: 3:06
Performance: Good
MacBook Pro (Retina, Mid 2012)
MacBook Pro - model: MacBookPro10,1
1 2,3 GHz Intel Core i7 (i7-3615QM) CPU: 4-core
8 GB RAM Not upgradeable
BANK 0/DIMM0
4 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Wireless: en0: 802.11 a/b/g/n
Battery: Health = Normal - Cycle count = 20
Intel HD Graphics 4000 - VRAM: 1536 MB
Color LCD
NVIDIA GeForce GT 650M - VRAM: 1024 MB
Disk Information: ⓘ
APPLE SSD SM256E disk0: (251 GB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [APFS Container]: 183.00 GB
BOOTCAMP (disk0s3 - NTFS) /Volumes/BOOTCAMP : 67.79 GB (21.35 GB free)
USB Information: ⓘ
USB20Bus
hub_device
USB20Bus
hub_device
hub_device
Apple Inc. BRCM20702 Hub
USB30Bus
Virtual disks: ⓘ
[redacted] (disk1s1 - APFS) / [Startup]: 183.00 GB (112.99 GB free)
Physical disk: disk0s2 183.00 GB (112.99 GB free)
(disk1s2) <not mounted> [Preboot]: 183.00 GB
(disk1s3) <not mounted> [Recovery]: 183.00 GB
(disk1s4) /private/var/vm [VM]: 183.00 GB
TunesKit Spotify Converter (disk2s2 - HFS+) /Volumes/TunesKit Spotify Converter : 25 MB (16 MB free)
Physical disk: Disk Image 25 MB (16 MB free)
TunesKit Spotify Converter 1.1.1.784 (disk3s1 - HFS+) /private/tmp/tnt31445/mount : 21 MB (12 MB free)
Physical disk: Disk Image 21 MB (12 MB free)
Free_Download_Install (disk4s1 - HFS+) /Volumes/Free_Download_Install : 4 MB (3 MB free)
Physical disk: Disk Image 4 MB (3 MB free)
TunesKit Spotify Converter 1.1.1.784 (disk5s1 - HFS+) /private/tmp/tnt29493/mount : 21 MB (12 MB free)
DeezLoader 3.1.0 (disk6s1 - HFS+) /Volumes/DeezLoader 3.1.0 : 161 MB (2 MB free)
Physical disk: Disk Image 161 MB (2 MB free)
TunesKit Spotify Converter 1.2.1.1071 (disk7s1 - HFS+) /private/tmp/tnt2472/mount : 21 MB (11 MB free)
Physical disk: Disk Image 21 MB (11 MB free)
System Software: ⓘ
macOS High Sierra 10.13.4 (17E199) - Time since boot: about 5 hours
Configuration files: ⓘ
/etc/hosts - Count: 39
Gatekeeper: ⓘ
Clean up: ⓘ
/Library/LaunchAgents/com.malwarebytes.mbam.frontend.agent.plist
/Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/FrontendAgent.app/Contents/MacOS/FrontendAgent
/Library/LaunchDaemons/com.malwarebytes.mbam.rtprotection.daemon.plist
/Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/RTProtectionDaemon.app/Contents/MacOS/RTProtectionDaemon
/Library/LaunchDaemons/com.malwarebytes.mbam.settings.daemon.plist
/Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/SettingsDaemon.app/Contents/MacOS/SettingsDaemon
~/Library/LaunchAgents/com.mangonel.zb.plist
~/Library/mangonel.zb/mangonel.zb.app/Contents/MacOS/mangonel.zb
5 orphan files found. [Clean up]
/Applications/Paragon CampTune.app
[not loaded] com.paragon-software.kernelio.kext (1.0 - SDK 10.12) [Lookup]
/Library/Extensions
[loaded] com.malwarebytes.mbam.rtprotection (3.3 - SDK 10.13) [Lookup]
[failed] com.apple.corespeechd.plist (? ? ? - installed 2018-02-27) - /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd: Executable not found!
[not loaded] 37 Apple tasks
[loaded] 183 Apple tasks
[running] 114 Apple tasks
Launch Agents: ⓘ
[running] com.bjango.istatmenus.agent.plist (Bjango Pty Ltd - installed 2018-05-10) [Lookup]
[running] com.bjango.istatmenus.status.plist (Bjango Pty Ltd - installed 2018-05-10) [Lookup]
[failed] com.malwarebytes.mbam.frontend.agent.plist (? 631295be 0 - installed 2018-05-02) [Lookup] - /Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/FrontendAgent.app/Contents/MacOS/FrontendAgent: Executable not found!
[loaded] com.microsoft.update.agent.plist (Microsoft Corporation - installed 2018-05-06) [Lookup]
Launch Daemons: ⓘ
[running] com.bjango.istatmenus.daemon.plist (Bjango Pty Ltd - installed 2018-05-10) [Lookup]
[loaded] com.bjango.istatmenus.installerhelper.plist (Bjango Pty Ltd - installed 2018-05-10) [Lookup]
[failed] com.malwarebytes.mbam.rtprotection.daemon.plist (? 8373887a 0 - installed 2018-05-02) [Lookup] - /Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/RTProtectionDaemon.app/Contents/MacOS/RTProtectionDaemon: Executable not found!
[loaded] com.malwarebytes.mbam.settings.daemon.plist (? a40d558f 0 - installed 2018-05-02) [Lookup] - /Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/SettingsDaemon.app/Contents/MacOS/SettingsDaemon: Executable not found!
[not loaded] com.microsoft.OneDriveUpdaterDaemon.plist (? 0 ? - installed 2018-05-06) [Lookup]
[loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2018-05-06) [Lookup]
[loaded] com.paragon-software.installer.plist (Paragon Software GmbH - installed 2018-05-11) [Lookup]
[loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2018-05-07) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2018-05-07) [Lookup]
[failed] com.mangonel.zb.plist (? 23425d9 0 - installed 2018-05-07) [Lookup] - ~/Library/mangonel.zb/mangonel.zb.app/Contents/MacOS/mangonel.zb: Executable not found!
[running] com.spotify.webhelper.plist (Spotify - installed 2018-05-15) [Lookup]
User Login Items: ⓘ
iTunesHelper Applicazione (Apple, Inc. - installed 2018-04-14)
OneDrive Applicazione - Hidden
(/Applications/OneDrive.app)
Magnet Applicazione
(/Applications/Magnet.app)
Backup e sincronizzazione di Google Applicazione
(/Applications/Backup and Sync.app)
Dropbox Applicazione
(/Applications/Dropbox.app)
StartUpHelper SMLoginItem - Hidden (Spotify - installed 2018-05-14)
(~/.Trash/Spotify.app/Contents/Library/LoginItems/StartUpHelper.app)
StartUpHelper SMLoginItem - Hidden (Spotify - installed 2018-05-04)
(/Applications/Spotify.app/Contents/Library/LoginItems/StartUpHelper.app)
AppCleaner SmartDelete SMLoginItem - Hidden (Julien Ramseier - installed 2018-05-07)
(~/Downloads/AppCleaner.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app)
(/Applications/AppCleaner.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app)
QuickTime Plugin: 7.7.3 (installed 2018-03-28)
[enabled] Amazon Assistant for Safari - Amazon - https://www.amazon.com/gp/BIT/AmazonAssistant/TOU (installed 2018-04-18)
[enabled] AdGuard AdBlocker - adguard - http://adguard.com (installed 2018-04-22)
[enabled] Player for YouTube™ (Flash version) - James Fray - http://add0n.com/youtube-tools.html?from=flash (installed 2018-04-19)
None
Time Machine: ⓘ
Time Machine not configured!
9% WindowServer
6% Safari
5% com.apple.WebKit.WebContent
3% kernel_task
2% hidd
890 MB kernel_task
540 MB com.apple.WebKit.WebContent
459 MB Safari
201 MB WhatsApp Helper
162 MB Finder
195 KB 177 KB Dropbox
174 KB 119 KB mDNSResponder
106 KB 7 KB Telegram
40 KB 22 KB WhatsApp
27 KB 6 KB netbiosd
13.48 WindowServer
9.52 com.apple.WebKit.WebContent
6.96 Safari
3.20 hidd
0.66 Mail
2.28 GB Available RAM
94 MB Free RAM
5.72 GB Used RAM
2.19 GB Cached files
52 MB Swap Used
Magnet: 2.1.0 (installed 2018-04-19)
product: (installed 2018-05-05)
Paragon Camptune X 10.10.20_MAC599: (installed 2018-05-05)
Battery Monitor: 2.4.3 (installed 2018-05-05)
Dr. Unarchiver: 1.3.3 (installed 2018-05-06)
MacKeeper: (installed 2018-05-06)
AdwareAnalyzer: (installed 2018-05-06)
Mactracker: 7.7.3 (installed 2018-05-06)
Microsoft Office 2016 per Mac: (installed 2018-05-06)
Microsoft AutoUpdate: (installed 2018-05-06)
Microsoft Office 2016 Volume License Serializer: (installed 2018-05-06)
Speedtest: 1.3 (installed 2018-05-07)
CopyClip: 1.9 (installed 2018-05-07)
Dr. Cleaner: 3.3.4 (installed 2018-05-07)
App Cleaner & Uninstaller: 4.9.2 (installed 2018-05-07)
Malwarebytes for Mac: (installed 2018-05-10)
Polarr Photo Editor: 5.0.2 (installed 2018-05-14)
WhatsApp: 0.2.9230 (installed 2018-05-14)
Telegram: 3.8.2 (installed 2018-05-15)
sudo rm -rf /Library/Application\ Support/Malwarebytes /Library/LaunchAgents/com.malwarebytes.mbam.frontend.agent.plist /Library/LaunchDaemons/com.malwarebytes.mbam.rtprotection.daemon.plist /Library/LaunchDaemons/com.malwarebytes.mbam.settings.daemon.plist /Library/Extensions/com.malwarebytes.mbam.rtprotection
sudo rm /Applications/Mackeeper.app ~/Library/Application\ Support/MacKeeper Helper ~/Library/Caches/com.zeobit.MacKeeper ~/Library/Caches/com.zeobit.MacKeeper.Helper ~/Library/Caches/com.mackeeper.MacKeeper ~/Library/Caches/com.mackeeper.MacKeeper.Helper ~/Library/Caches/LaunchAgents/com.zeobit.MacKeeper.Helper.plist ~/Library/LaunchAgents/com.zeobit.MacKeeper.plugin.Backup.agent.plist ~/Library/LaunchAgents/com.mackeeper.MacKeeper.Helper.plist ~/Library/Logs/MacKeeper.log ~/Library/Logs/MacKeeper.log.signed ~/Library/Preferences/com.zeobit.MacKeeper.plist ~/Library/Preferences/com.zeobit.MacKeeper.Helper.plist ~/Library/Preferences/com.mackeeper.MacKeeper.plist ~/Library/Preferences/com.mackeeper.MacKeeper.Helper.plist /Library/Application\ Support/MacKeeper /Library/LaunchDaemons/com.zeobit.MacKeeper.AntiVirus.plist /Library/LaunchDaemon/com.zeobit.MacKeeper.plugin.AntiTheft.daemon.plist /private/tmp/com.mackeeper.MacKeeper.Installer.config /private/var/db/receipts/com.mackeeper.MacKeeper.affid.pkg.plist /private/var/db/receipts/com.mackeeper.MacKeeper.affid.pkg.bom /private/var/db/receipts/com.mackeeper.MacKeeper.pkg.plist /private/var/db/receipts/com.mackeeper.MacKeeper.pkg.bom /Library/Preferences/.3FAD0F65-FC6E-4889-B975-B96CBF807B78
sudo rm -rf ~/Library/LaunchAgents/com.mangonel.zb.plist ~/Library/mangonel.zb/mangonel.zb.app/Contents/MacOS/mangonel.zb
losisat ha scritto:...questo è il mio report
non riesco ad eliminare una voce
Clean up: ⓘ
se clicco mi dice che il programma è vecchio e necessita dell'ultima versione
Grossi problemi non e ho a parte che ogni tanto, mentre navigo, si apre da sola una pagina di safari dove si dice che ho il mac infetto e discaricare mackeeper.....
Ringrazio anticipatamente
Scusate, stavo analizzando, rispondo tra poco.mattleega ha scritto:Allora vai su ...losisat ha scritto:... non riesco ad eliminare ...
/System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd...
