Pagina 10 di 14
Re: Aggiornamento Cocktail
Inviato: gio, 24 ago 2017 11:46
da faxus
Cocktail 11.0b1 Beta 1 (High Sierra Edition)
Annuncio, pur non usandolo, la disponibilità del tool per High Sierra.
Per ora in versione beta.
- software commerciale -
http://www.maintain.se/cocktail/" onclick="window.open(this.href);return false;
Queste le novità nella beta:
Added compatibility with macOS High Sierra 10.13
Updated Automator actions
Updated Help files
Other improvements and enhancements
Inviato: gio, 31 ago 2017 17:42
da Kernel Panic
Cocktail -
10.4.3
Cocktail 10.4.3 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added ability to easily add menu extras (menulets) to the macOS menu bar
Addresses compatibility issues with Little Snitch 4
Addresses an issue in which Cocktail may fail to disable virtual memory swapping
Various improvements to the Pilot
Other minor bug fixes.
Inviato: mer, 13 set 2017 21:07
da Kernel Panic
Cocktail -
10.4.4
Cocktail 10.4.4 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Improvements on the "Optimize network" procedure
Improvements on the "Clear Apple mobile devices logs and diagnostic messages" procedure
Addresses compatibility issues with Apple File System (APFS) volumes
Addresses an issue in which the uninstaller may fail to reset power management settings to their default values
Fixed a bug in which some items in /private/tmp folder were not deleted during clearing of the temporary files
Other minor bug fixes and improvements.
Inviato: lun, 25 set 2017 15:41
da Kernel Panic
Cocktail -
11.0
Cocktail 11.0 (High Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added macOS 10.13 High Sierra compatibility
Updated Help files
Other improvements and enhancements.
Inviato: mar, 17 ott 2017 23:14
da Kernel Panic
Cocktail -
11.0.1
Cocktail 11.0.1 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Addresses an issue in which Cocktail may fail to detect Mac OS Extended (HFS+) partitions
Addresses compatibility issues with macOS Server 5.4
Resolves a number of other issues discovered in the previous release.
Inviato: mar, 14 nov 2017 20:02
da Kernel Panic
Cocktail -
11.1
Cocktail 11.1 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Added ability to clear Twitter caches
Improvements on the "Clear Internet caches" procedure
"Disable support for page icons" (Interface > Safari) setting is now working properly
Addresses an issue in which VoiceOver stopped working after clearing audio components cache
Improvements on the "Purge inactive memory" procedure
Improvements on the "Clear the hibernate (sleepimage) file" procedure
Added macOS High Sierra 10.13.1 compatibility
Fixed compatibility issues with Boom 3D
Fixed a bug in which Google Chrome bookmarks have been reverted to an outdated version during clearing of the Internet caches
Updated Help files.
Inviato: ven, 15 dic 2017 02:50
da Kernel Panic
Cocktail -
11.2
Cocktail 11.2 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Added ability to clear boot caches
Improvements on the "Clear system caches" procedure
Improvements on the "Perform essential system maintenance" procedure
Major improvements on the "Clear Apple system logs and diagnostic messages" procedure
Fixed compatibility issues with NVIDIA graphics drivers and macOS High Sierra 10.13.2
Minor interface improvements
Updated Help files.
Inviato: mer, 10 gen 2018 02:26
da Kernel Panic
Cocktail -
11.2.1
Cocktail 11.2.1 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Addresses an issue in which Cocktail may disable Safari extensions
Fixed compatibility issues with AMD drivers
Fixed compatibility issues McAfee Endpoint Security
Added compatibility with macOS High Sierra 10.13.3
Resolves a number of other minor issues discovered in the previous release.
Inviato: gio, 08 feb 2018 03:24
da Kernel Panic
Cocktail -
11.3
Cocktail 11.3 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Added ability to thin or delete local Time Machine snapshots (System - Time Machine)
If you are using Time Machine with an external disk, Time Machine will keep a copy of the latest backups. This is done to ensure that all changes to files and documents will be backed up even when you're not connected to your Time Machine disk, however it can take up significant amounts of disk space. Cocktail can thin (purge) or completely delete local backups (called snapshots) and free up the space used by Time Machine. Warning: By deleting local Time Machine snapshots you reduce the effectiveness of your backups and you risk losing data.
Addresses an issue in which Cocktail may fail to purge inactive memory
Improvements on the "Clear Spotlight caches" procedure
Improvements on the "Clear Mail caches" procedure
Improvements on the "Clear Siri caches" procedure
Updated Help files.
Inviato: mar, 20 feb 2018 03:34
da Kernel Panic
Cocktail -
11.3.1
Inviato: mar, 06 mar 2018 19:01
da Kernel Panic
Cocktail -
11.4
Cocktail 11.4 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Added ability to clear macOS content cache
Content cache retains all sorts of Apple and iCloud related data. Devices on the local network can recognize the cache and retrieve what they need from the Mac instead of a new Internet download.
Added macOS High Sierra 10.13.4 compatibility
Updated Help files.
Inviato: mer, 21 mar 2018 13:58
da Kernel Panic
Cocktail -
11.5
Cocktail 11.5 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Added ability to clear iOS backups and software updates
Improvements on the "Clear User caches" procedure
Updated Help files.
Inviato: gio, 12 apr 2018 14:46
da Kernel Panic
Cocktail -
11.5.1
Cocktail 11.5.1 (High Sierra Edition) for users running macOS 10.13 High Sierra has been released.
Inviato: gio, 03 mag 2018 19:31
da Kernel Panic
Cocktail -
11.5.2
Cocktail 11.5.2 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Added ability to clear Messages caches
Fixed crash on startup that affected a small number of users
Addresses an issue in which Cocktail mail fail to restore default file associations
Resolved issue retrieving some volume information.
Inviato: ven, 25 mag 2018 05:24
da Kernel Panic
Cocktail -
11.5.3
Cocktail 11.5.3 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Major improvements on the "Perform essential system maintenance" procedure
Added compatibility with macOS High Sierra 10.13.5
Fixed compatibility issues with Microsoft Office 2016 (16.13)
Addresses an issue in which Defaults button may not be able to restore default Dock settings
Added a workaround for a conflict with System Preferences which could cause the control to mute the startup chime not to become active under certain conditions
Fixed a rare crash while searching for corrupted preference files
Other small enhancements.
