Calibre - 1.18
Changelog:
http://calibre-ebook.com/whats-new" onclick="window.open(this.href);return false;
Download:
http://calibre-ebook.com/download_osx" onclick="window.open(this.href);return false;
- Geniale
Ah! Giusto... Che oggi è venerdì.
Ormai non si dirà più giovedì gnocchi e venerdì pesce, ma giovedì gnocchi e venerdì Calibre
- Geniale
La 1.22 è pronta
New Features
A new tool to compare ebook files, showing the differences in their underlying text, styles and images side by side
The new compare tool is very useful in combination with the book editor. It allows you to see what changes have been made between checkpoints and what changes were made by automated tools. You can also compare different versions of the same ebook file. How to use each of these features is described below. Screenshots and help for using the new compare tool are at http://manual.calibre-ebook.com/diff.html" onclick="window.open(this.href);return false;
Edit book: Add a tool to view the list of checkpoints and compare the current state of the book to the state at the specified checkpoint. To use it click View->Checkpoints
Edit book: Add a tool to compare the book being currently edited with another file. To use it go to File->Compare to other book
Allow comparing the ORIGINAL_EPUB version of a book to the EPUB version by right clicking on the ORIGINAL_EPUB format in the book details panel. And the same for ORIGINAL_AZW3 and AZW3 formats.
Edit Book: Add a button to show the changes after various automated tools are run such as: remove unused CSS, subset embedded fonts, smarten punctuation, etc.
Edit Book: Add check for spine items with incorrect media-type specified in the manifest
Edit Book: Enable editing of page map XML files
DOCX Input: Improve handling of text boxes. Text boxes are still not supported, but they no longer cause errors or duplicate content when embedded inside paragraphs.
Closes tickets: 1273130
Edit Book: Add check for links that point to directories in the book instead of files.
Closes tickets: 1272769
Edit Book: Show the filename of the currently edited file in the title bar.
Closes tickets: 1272543
Bug Fixes
Edit Book: Fix unused CSS removal tool inserting namespace declaration at the top of the stylesheet
Edit book: Fix cover not being updated from the current cover in the calibre library when using Edit Book. Note that you can turn off metadata updating via Preferences->calibre Integration in the Edit Book Preferences.
Closes tickets: 1272730
Conversion: Add support for <style> and <link> tags outside the <head> tag.
Closes tickets: 1274339
Edit book: Fix undo not working for subsetting fonts
CHM Input: Handle CHM files with broken markup where all the content is placed inside the <head> tag.
Closes tickets: 1273512
DOCX Input: Fix padding-left of <ul>, <ol> being defaulted to 0 if no padding specified in the docx style, which breaks rendering for lists at the left margin of the document.
MOBI Output: Handle the value attribute on <li> tags.
Closes tickets: 1273559
EPUB Output: Fix splitting of HTML files not updating links in the <pageList> section of the NCX file
EPUB Input: Handle EPUB files with incorrect media types for the spine items when converting.
Closes tickets: 1273471
RTF Output: Fix failure to convert documents that contain comments with the -- string inside the comment.
Closes tickets: 1272588
Edit Book: Fix extra 1x1 unused GIF image being created when saving and re-opening AZW3 files.
Closes tickets: 1272410
Fix editing of narrow yes/no columns in the book list not very convenient
Closes tickets: 1272089
New news sources
Various Russian News sources by bug_me_not by Unknown
- Geniale
Disponibile la 1.23
New Features
Edit Book: Highlight the closest surrounding tag when editing HTML/XML
Edit Book: Add a tool to easily change the current paragraph (the paragraph containing the cursor) to a heading. Simply click the button with 'H1' on it and choose the heading level you want the current paragraph changed to.
Edit Book: When running Replace All add a button to the replaced message to show exactly what changes were done and allow them to be undone
Edit book: When checking book, detect case mismatches between links and the filenames of the files they point to and offer to auto-correct the links
Adding books: Implement a copy to clipboard button for when duplicates are found during the adding process. Useful if you wish to review the list of duplicates later.
Closes tickets: 1276918
Linux installer: Install appdata files for integration with software stores.
Closes tickets: 1271974
Edit book: Auto add a checkpoint when the book is first opened for editing
Bug Fixes
Edit Book: Fix a bug in AZW3 support that could cause images/fonts to get mixed up when saving and re-opening the book multiple times.
Closes tickets: 1276726
Edit Book: Fix individual find and replace not working in regex mode if the search expression uses lookbehind/lookahead operators
Compare books: Fix unchanged lines at the start of a change block being sometimes marked with a blue background, even though they contain no changes
Compare books: Fix incorrect scrolling when viewing all text and a large amount of text is present after the final change.
PDF Output: Fix a zero division error when the transformation matrix has a zero diagonal
Closes tickets: 1277102
calibredb add_custom_column: Fix a spurious error message when adding custom columns caused by the new db backend
calibredb list: Fix error if one of the requested fields is empty for all requested books
calibredb set_metadata: Fix setting series_index with the -f argument not working
Markdown input: Fix handling of very large files.
Closes tickets: 1212330
Edit book: Do not create savepoints when no changes are performed by automated tools such as smarten punctuation, remove unused css etc.
Edit Book: Fix a bug that would cause an error when a global operation like find/replace or polishing fails.
Closes tickets: 1275366
Metadata download: Workaround edelweiss.com no longer being able to search by author name. Search only by titles and filter the results returned by edelweiss to only include matching authors.
HTML 5 parser: Preserve non-core namespace declarations on the <html> tag
Workaround broken file chooser dialog on Ubuntu that does not auto-insert the specified extension.
Closes tickets: 1275125
Compare books: Fix error when previously different files become identical after beautifying
Edit Book: Fix subsetting embedded fonts not processing fonts included in a stylesheet that is itself referenced only by an @import rule
Edit Book: Fix the remove unused css tool changing the namespace prefix used for the XHTML namespace in the CSS sheet, if any
Conversion: Fix CSS selectors using the epub namespace being ignored
Compare books: Fix double clicking in the right panel not opening the correct file in the editor
New news sources
Disinformatico by isspro
Les Echos by Krittika Goyal
Improved news sources
Kathimerini
Cosmopolitan UK
wired.it
Gosc Niedzielny
New York Times Book Review
download qui per Mac
