Aggiornamenti VirtualBox
pierecall
grazie franz :wink:
Già disponibile il nuovo VirtualBox 3.2.6.
What's new in this version:
VMM: fixed host crash when running 64-bit guests on 32-bit hosts with certain Intel CPUs (VT-x only; bug #6166)
VMM: allow 64-bit SMP guests on 32-bit hosts (VT-x and AMD-V only; does not apply to Mac OS X, which already supports it)
VMM: fixed Guru mediation if guests with more than 2GB are booted with VT-x/AMD-V disabled (bug #5740)
VMM: fixed TR limit trashing (VT-x and 64-bit host only; bug #7052)
Page Fusion: several bug fixes for SMP guests (including bug #6964)
Teleportation: several fixes and improvements
Mac OS X server guests: compatibility fix
EFI: fixed memory detection for guests with 2GB or more RAM assigned
GUI: added a workaround for a Linux kernel bug which affecting asynchronous I/O on ext4 / xfs file systems (Linux hosts only)
GUI: added setting for multiple VRDP connections; useful if multiple screens are enabled
GUI: another fix for the keyboard capturing bug under metacity (bug #6727)
GUI: fixed quit dialog when used in seamless or fullscreen mode (Mac OS X hosts only; bug #6938)
GUI: handle the extra key on the Brazilian keyboard on X11 hosts again (bug #7022).
2D Video acceleration: fixed crashes when leaving the fullscreen mode (bug #6768)
VBoxManage: fixed storageattach error handling (bug #6927)
VBoxManage: fixed dhcpserver add (3.2.0 regression; bug #7031)
Storage: fixed hang with images located on filesystems which don't support async I/O (bug #6905)
Storage: fixed raw disks on Windows hosts (3.2.0 regression; bug #6987)
LsiLogic: fixed hang with older Linux guests
BusLogic: fixed hang during I/O
SATA: set initial number of ports to 1 as some guests can't handle 30 ports (e.g. CentOS 4 and FreeBSD; bug #6984)
SATA: performance improvement
SCSI: fixed error when using the full format option during Windows installation (bug #5101)
iSCSI: fixed authentication (bug #4031)
Host-only/bridged networking: fixed excessive host kernel warnings under certain circumstances (Linux hosts only; 3.2.0 regression; bug #6872)
NAT: fixed potential memory leaks
NAT: increased the size of the memory pool for 16K Jumbo frames (performance tweak)
NAT: allow to link/unlink the network cable even if the VM is currently paused
E1000: disconnect cable was not properly handled if the NIC was not yet initialized by the guest
OVF: export performance optimization
OVF: upgraded OS type definitions to CIM 2.25.0 so that Windows 7 and other OSes are now tagged correctly on export
Settings: the setting for disabling the host I/O cache was sometimes not properly saved
Settings: save machine state into XML correctly even when snapshot folder has been changed to a non-default location (bug #5656)
USB: allow the guest to disable an EHCI port
USB: find a valid language ID before querying strings (bug #7034)
POSIX hosts: fixed several memory leaks (3.2.0 regression)
Solaris hosts: fixed VDI access problem under certain circumstances (IDE/SATA; 3.2.0 regression)
Solaris hosts: fixed VM fails to start on 32-bit hosts (3.2.0 regression; bug #6899)
Windows hosts (32-bit): increase guest RAM limit if the host kernel allows for more virtual address space
Linux Additions: re-read a directory after a file was removed (bug #5251)
Linux Additions: install the DRI driver in the right location on ArchLinux guests (bug #6937)
X11 Additions: fixed spurious mouse movement events (bug #4260)
Solaris Additions: fixed guest control execution
Windows Additions: automatic logon on Windows Vista/Windows 7 is now able to handle renamed and principal user accounts; added various bugfixes
Windows Additions: improved command line parsing of the installer
Windows Additions: fixed driver verifier bugcheck in VBoxMouse (bug #6453)
3D support: fixed OpenGL support for 32bit apps under 64bit Windows guests
Buck
Maccanico Pro
Maccanico Pro
C'è qualcosa che mi sfugge....
ho installato VB (Intel Mac), durante la configurazione mi chiede che macchina virtuale voglio...mettiamo che scelga OS2, il tutto parte, ma mi appare uno schermo nero con la scritta FATAL: no bootable medium found! System halted.
Dove ho sbagliato?
Devo inserire per caso un CD di installazione del SO scelto?
Claudio
________________
iPhone 4 16Gb bianco
iPad Air 16Gb bianco
Appena rilasciato VirtualBox 3.2.10.
Link diretto: http://dlc.sun.com.edgesuite.net/virtua ... 23-OSX.dmg
Ecco a voi il nuovo VirtualBox 4.0.0!!!
Link diretto:
http://dlc.sun.com.edgesuite.net/virtua ... 51-OSX.dmg
È uscito VirtualBox 4.0.4, per chi preferisce un Windows virtualizzato ad una partizione.
Pronto per il download VirtualBox 4.0.6, con numerose migliorie.
Rilasciato VirtualBox 4.0.8
http://www.virtualbox.org/wiki/Downloads
This is a maintenance release. The following items were fixed and/or added:
Mac OS X hosts: fixed incompatibility with recent Mac OS X versions in 64-bit mode (bug #8474)
Mac OS X hosts: fixed incompatibility with hosts with more than 16 cores (bug #8389)
Mac OS X hosts: fixed painting corruptions on a second monitor in 64-bit mode (bug #7606)
GUI: restored functionality to set an empty host key to disallow any host key combination (4.0.6 regression; bug #8793)
VBoxManage: added controlvm screenshotpng subcommand for saving the screenshot of a running VM in PNG format
VBoxHeadless: fixed potential crash during shutdown (Windows hosts only)
NAT: built-in services use the correct Ethernet addresses in Ethernet header and in ARP requests
Host-only networking: fixed adapter reference counting
E1000: fixed rare guest crashes with Linux SMP guests (bug #8755)
SATA: fixed guest disk corruption under rare circumstances (only relevant for guests with more than 2GB RAM; bug #8826)
Storage: fixed data corruption after a snapshot was taken with asynchronous I/O enabled (bug #8498)
Floppy: several improvement
HPET: another fix for time jumps (bug #8707)
USB: removed assumption that string descriptors are null-terminated (Windows hosts only)
3D support: fixed a potential crash when resizing the guest window
3D support: fixed GNOME 3 rendering under Ubuntu 11.04 and Fedora 15
Snapshots: fixed another bug which could lose entries in the media registry when restoring a snapshot (bug #8363)
Shared Folders: don't stop mounting the other valid folders if one host folder is inaccessible (4.0.6 regression)
Linux Additions: check whether gcc and make are installed before building kernel modules (bug #8795)
Solaris Additions: added support for X.Org Server 1.10
Guest Additions: fixed inappropriate Guest Additions update notification when using vendor-specific version suffixes (bug #8844)
macbio
fragrua ha scritto:Rilasciato il nuovo VirtualBox 3.2.
Queste le note di rilascio in inglese:
Following the acquisition of Sun Microsystems by Oracle Corporation, the product is now called Oracle VM VirtualBox and all references were changed without impacting compatibility
Experimental support for Mac OS X guests (see the manual for more information)
Memory ballooning to dynamically in- or decrease the amount of RAM used by a VM (64-bit hosts only) (see the manual for more information)
Page Fusion automatically de-duplicates RAM when running similar VMs thereby increasing capacity. Currently supported for Windows guests on 64-bit hosts (see the manual for more information)
CPU hot-plugging for Linux (hot-add and hot-remove) and certain Windows guests (hot-add only) (see the manual for more information)
New Hypervisor features: with both VT-x/AMD-V on 64-bit hosts, using large pages can improve performance (see the manual for more information); also, on VT-x, unrestricted guest execution is now supported (if nested paging is enabled with VT-x, real mode and protected mode without paging code runs faster, which mainly speeds up guest OS booting)
Support for deleting snapshots while the VM is running
Support for multi-monitor guest setups in the GUI for Windows guests (see the manual for more information)
USB tablet/keyboard emulation for improved user experience if no Guest Additions are available (see the manual for more information).
LsiLogic SAS controller emulation (see the manual for more information)
RDP video acceleration (see the manual for more information)
NAT engine configuration via API and VBoxManage
Use of host I/O cache is now configurable (see the manual for more information)
Guest Additions: added support for executing guest applications from the host system (replaces the automatic system presimparation feature; see the manual for more information)
OVF: enhanced OVF support with custom namespace to preserve settings that are not part of the base OVF standard
http://www.virtualbox.org/wiki/Changelog
Se qualcuno vuole può tradurle in italiano!
io ci ho provato:
A seguito dell'acquisizione di Sun Microsystems da parte di Oracle Corporation, il prodotto è ora chiamato Oracle VM VirtualBox e tutti i riferimenti sono stati modificati senza alcun impatto sulle compatibilità
Supporto sperimentale per Mac OS X ospiti (vedere il manuale per maggiori informazioni)
Mongolfiera di memoria in modo dinamico in-o diminuire la quantità di RAM utilizzata da un VM (host a 64-bit only) (vedere il manuale per ulteriori informazioni)
Page Fusion automaticamente de-duplica RAM durante l'esecuzione di macchine virtuali simili aumentando così la capacità. Attualmente sono supportati per gli ospiti su host Windows a 64-bit (vedere il manuale per maggiori informazioni)
CPU hot-plug per Linux (hot-add e hot-remove) e alcuni guest Windows (hot-add solo) (vedere il manuale per maggiori informazioni)
Nuove caratteristiche Hypervisor: con entrambi i VT-x/AMD-V su host a 64-bit, con pagine di grandi dimensioni può migliorare le prestazioni (vedi il manuale per maggiori informazioni); anche, VT-x, senza restrizioni di esecuzione della clientela è ora supportata (se nidificate di spostamento è attivata con VT-x, modalità reale e in modalità protetta senza codice di paging corre più veloce, che accelera soprattutto su boot del sistema operativo guest)
Supporto per l'eliminazione di istantanee, mentre il VM è in esecuzione
Il supporto per configurazioni multi-monitor della clientela nella GUI di Windows per gli ospiti (vedere il manuale per maggiori informazioni)
Tavoletta USB / emulazione di tastiera per una migliore esperienza utente se non Guest Additions sono disponibili (vedere il manuale per maggiori informazioni).
LsiLogic emulazione controller SAS (vedere il manuale per maggiori informazioni)
RDP accelerazione video (vedere il manuale per maggiori informazioni)
Motore di configurazione NAT tramite API e VBoxManage
Uso di host di I / O cache ora è configurabile (vedere il manuale per maggiori informazioni)
Guest Additions: aggiunto il supporto per l'esecuzione di applicazioni guest dal sistema host (sostituisce la funzione automatica di presimparation sistema, consultare il manuale per maggiori informazioni)
OVF: migliorato il supporto a OVF namespace personalizzato per mantenere le impostazioni che non fanno parte della base standard OVF
Sparkle
purtroppo c'è un solo programma che mi costringe ad dover usare ancora win. Vabbé.
Ho aggiornato stamattina e un messaggio mi dice che ci sono problemi con il controller USB 2.0, allora mi consiglia di disabilitarlo e di andare avanti così finchè non ci sarà un fix della situazione, in effetti dal messaggio che per ora non posso postare, viene fuori che esiste una incompatibilità tra il controller USB ottimizzato per la versione 4.0.6 e la versione attuale di VirtualBox. Sto sbagliando qualcosa oppure chissacosadevofare?
Grazie.
Aloha
Stay hungry, stay foolish
Pronto VirtualBox 4.0.10
Rilasciato testè VirtualBox 4.0.12
Rilasciato VirtualBox 4.1.0
This version is a major update…
Rilasciato ieri VirtualBox 4.1.2.
Torna a “Aggiornamenti”
