Aggiornamenti Terze Parti vari
Oggetto del messaggio: Re: Aggiornamenti Terze Parti vari
Messaggio Inviato: mar, 19 feb 2019 15:00
Kodi 18.1 "Leia"
64.3MB dmg
173.6MB su disco
https://kodi.tv/download
Kodi Entertaiment Center, Kodi, è un programma open source per la gestione di un completo media center.
È disponibile per Android, macOS, Windows, Linux, Apple TV, Raspberry Pi, Odroid C-2 e box con SoC AMLogic.
https://kodi.wiki/view/Main_Page
https://it.wikipedia.org/wiki/Kodi
Novità in 18.1 (solo macOS):
Speed up Player and Playlists operations with JSON-RPC
Define a senseful default value for advanced settings "updateemptytagsinterval"
Revert edge case crash fix that caused DVDs to be not recognised on Mac OS
Add date to the log records
Flush streamplayers if abort is requested which solves waiting too long (on skipping DVD intros, for example)
Fix ListitemAbsolute and ListItemPosition in GUI engine
Ignore very first "server not reachable" notification for PVR servers
Use extended result codes for SQLite
update SSL CA trust store
Handle empty vertex buffers in GUIFontTTFGL which caused a hard crash
Reintroduce setting "Close channel OSD after switching channels" for PVR
Avoid attempt to load music info for smartplaylists
Fix Top 100 Albums regression
RenderCapture: Only query Occlusion if GL lower 1.5
Check current mode if whitelist doesn't match and take correct action
Fix PVR input stream creation for pvr file items only containing a path and no recording/channel tag.
Fix playing VP9 streams using inputstream addon. It failed because codec extradata is non-existent for this stream codec.
Catch an exception while reading or writing a file
Fix logical "or" operation in GUI engine
Check the system capabilities to support sleep states S1/S2/S3/S4 before reporting them as available
Several Estuary cosmetic fixes
Messaggio Inviato: mar, 19 feb 2019 19:41
Seashore - 2.4.0
Seashore è un editor di immagini free e open source, basato su GIMP e sin dagli inizi nativo per OS X, dispone di tutte le funzioni basilari e anche di più ed è in grado di soddisfare le esigenze di utenti che non hanno necessità di usare programmi professionali.
What's New in Seashore:
Fix major bug where layers were not displayed when selection in use - all users running 2.3.0+ should upgrade !. Sorry !!! Also, I added a 'crop layer' to crop tool, so at least you get something new too...
Seashore is now available on the App Store !!! >>> https://itunes.apple.com/it/app/id1448648921
The current source-code can be found on github
>>> https://sourceforge.net/projects/seashore/
Messaggio Inviato: mer, 27 feb 2019 11:18
Telegram Swift 4.9.9
https://rink.hockeyapp.net/apps/6ed2ac3 ... ffcb74e81f
Versione nativa di Telegram Messenger per MacOS.
In questa versione si alternano alfa, beta e stabili, senza problemi funzionali.
È la versione più aggiornata basata sul linguaggio Swift 3.
OS X 10.11 El Capitan+
l'aggiornamento da app è sempre poco più corposo che l'installazione da zero
dmg 27.79MB
74.8MB su disco
Esistono separate edizioni per 10.6 e 10.7 nelle versioni classiche.
Le altre versioni per Mac:
Telegram Desktop
https://desktop.telegram.org
Telegram Messenger LLP su App Store
https://itunes.apple.com/us/app/telegra ... d946399090
Sorgenti
https://github.com/overtake/TelegramSwift
Estrema sicurezza e inviolabilità dei contenuti condivisi fra gli utenti.
Le chat cifrate appaiono essere blindate.
Per questo Telegram è stato proibito in qualche paese.
In Russia, suo paese d'origine, in Turchia e altrove.
Perché non rilascia le chiavi d'accesso anche a richiesta di polizia e magistratura.
Attualmente è il canale di diffusione di organizzazioni terroristiche e criminali.
Ma anche di streaming, coupon, occasioni, mercatini settoriali e di varie merci, download illegali ecc.
E una famosa chat di iMattacchioni.
Novità in 4.9.9:
Call settings
Pingù
Oggetto del messaggio: iMattacchioni
Messaggio Inviato: mer, 27 feb 2019 12:02
puoi dirlo forte!
I'm Pingù
FORUM iMaccanici:
Argomenti senza risposta: search.php?search_id=unanswered
Oggetto del messaggio: Re: iMattacchioni
Messaggio Inviato: mer, 27 feb 2019 12:41
puoi dirlo forte!
Grazie...
iMATTACCHIONI
Messaggio Inviato: mar, 12 mar 2019 12:35
Telegram Swift 5.0
dmg 27.8MB
74.8MB su disco
Telegram Desktop
Sorgenti
Novità in 5.0:
Multi accounts Support
Passcode and Login design improvements
Pingù
Messaggio Inviato: mar, 12 mar 2019 14:19
... e di colore Verde!
I'm Pingù
FORUM iMaccanici:
Messaggio Inviato: mar, 12 mar 2019 17:44
.... Attualmente è il canale di diffusione di organizzazioni terroristiche e criminali.
Ma anche di streaming, coupon, occasioni, mercatini settoriali e di varie merci, download illegali ecc....
Considerato che, come mi hai spiegato tempo fa, non è del tutto anonimo, continuo a non capire come facciano non dico terroristi e criminali di professione ma semplici utenti che vogliono solo condividere streaming, coupon e vari download "illegali" in totale anonimato ad affidarsi a questa rete di contatti .....
Messaggio Inviato: mar, 12 mar 2019 18:05
... come mi hai spiegato tempo fa, non è del tutto anonimo....
Credo tu abbia capito un'altra cosa, o forse ho detto un'altra cosa.
Preciso che:
1) se hai un numero a te intestato e collegato ad un telefono a te intestato e se lo usi con il tuo nome e cognome sei visibile con quelle credenziali.
In questo caso puoi usare anche un nick, se è impostato su Telegram, e sarà riconoscibile solo il tuo numero solo a chi lo ha in agenda.
In questo caso puoi usare comunque una chat cifrata, poi cancellarla, e il suo contenuto sarà per sempre irrecuperabile, anche in caso di acquisizione del telefonino.
2) se hai un numero acquistato sul mercato nero ed un telefonino usa e getta e se lo usi con un nick sei visibile con quei dati, in pratica anonimi.
In questo caso il nick e il tuo numero anonimi saranno visibili a chi ti colleghi e solo a loro..
In questo caso puoi usare anche una chat cifrata, poi cancellarla, e il suo contenuto sarà irrecuperabile.
Quindi di fatto è riconoscibile solo il numero.
Se questo è anonimo, cioè non riferibile ad una persona, non si può risalire ad una persona.
Se il telefonino è usa e getta l'abbinamento tra il numero e il telefonino non è utile a riconoscere un utente qualsiasi.
Le chat cifrate non sono leggibili se intercettate.
Le chat cifrate possono essere cancellate manualmente o a scadenza impostabile.
Le chat cifrate non sono disponibili sul server di Telegram.
Telegram non mette a disposizione di nessuno i codici di decrittazione per nessun motivo, per questo è vietato in alcuni paesi.
Così credo che sia sommariamente chiaro
PS- Probabilmente ti ho detto che pure se compari nella nostra chat su Telegram, per esempio, come KP, il tuo numero sarà visibile.
E se qualcuno vuole chiamarti al telefono lo potrà fare.
E se ha in agenda quel numero o, non so come, lo ottiene dal gestore, saprà come ti chiami
Messaggio Inviato: mer, 13 mar 2019 02:39
... saprà come ti chiami
Antò?
Messaggio Inviato: mer, 13 mar 2019 08:11
nio :)
Messaggio Inviato: mer, 20 mar 2019 07:05
Tor Browser Bundle 8.0.7
Dmg 65.9MB dmg - localizzato in lingua italiana
Aggiornamento 65.9MB
151.9MB su disco
È un Tor Bundle, già pronto su una versione di Firefox preparata per l’uso.
Il popolare software Tor assicura l’anonimato delle comunicazioni attraverso una rete distribuita di relay, gestiti da volontari in tutto il mondo.
Impedisce a chiunque di monitorare la connessione Internet e di conoscere quali siti vengono visitati,.
Impedisce ai siti visitati da rilevare la locazione e qualsiasi altro dato del visitatore.
Consente di accedere a siti che sono bloccati.
Tor Browser Bundle è multipiattaforma, non necessita di altro software ed è pronto per essere utilizzato.
Può essere installato ed usato anche su una chiavetta usb, quindi portatile.
https://www.torproject.org/projects/torbrowser.html.en
https://blog.torproject.org/new-release-tor-browser-806
Aggiornamenti in sottofondo tramite il canale Aurora, come in Firefox Quantum Developer
Cliccando il pulsante di identità del sito (posto a sinistra dell'URL) si vedrà il circuito.
Novità in 8.0.7:
* Update Firefox to 60.6.0esr
* Update Tor to 0.3.5.8
* Update Torbutton to 2.0.11
