Gravit Designer 3.2
dmg 60.2MB, idem aggiornamento (è stato di molto ridotto)
143.5 su disco (era 399.2MB)
OS X 10.9.0 Mavericks+
https://itunes.apple.com/it/app/gravit- ... 4923?mt=12" onclick="window.open(this.href);return false;
https://designer.io" onclick="window.open(this.href);return false;
https://gravit.io" onclick="window.open(this.href);return false;
Un'applicazione per il disegno vettoriale.
Multipiattaforma, anche online, con cloud proprio, gratuita.
Sta cominciando a diventare competitiva...
Novità in 3.2:
The cornerstone of this release is symbols. They allow you to create reusable components, that sync to each other, but can still be modified individually to allow for multiple variations of the same symbol. If you have reached a dead end, however, you can always reset an instance.
All symbols are available from a new sidebar, which allows you to drag in components to your design quickly.
Hand in hand with symbols goes the ability to set anchoring options for layers in groups, too. This gives you even more options to create standalone elements, which adjust to the parent group. If you are creating responsive designs regularly (who isn’t these days?), this is a huge time saver.
More improvements:
- Open recent files list
- Improvements to color swatches: You can rearrange them, they now show the opacity, RGB/CMYK indicator, export and import them.
- Improved visibility of themes: We made sure that each theme is as accessible as possible.
- New “Mask with Shape” option: Now available from a right-click, it also allows that the potential mask is above the content.
- Snap Package for Linux
- Improvements to pages: Flip their dimensions and trim them to the content.
- Ability to resize layers with the keyboard: The arrow keys combined with the + and - keys allow you to quickly resize layers.
- Reduced file size of desktop apps
And:
- Groups can be created from individual layers.
- Layers are highlighted in the Layers panel when you hover them on the canvas.
- “Make exportable” also includes the PDF file format.
- While showing the measurements guides with Alt, it’s still possible to move layers.
- Assets are exported with lowercase file endings.
- Tutorials were moved into the “Help” menu in the menu bar.
- Checking the “Keep Ratio” switch also applies to elements that are resized on the canvas.
- All icons from icons8.com are available in the Libraries tab.
- Simplified image cropping: It’s not only easier to catch the selection handles, but also to move the image inside the frame and to reset it.
- Anchoring also works for groups, not only for individual elements.
- Lines also snap to pixels when dragging.
- Clicking on the font size field selects the value to enable quick changes.
- The grid is now shown no matter if you switch it on in the inspector or the menu bar.
- New checkbox “Scale font on resizing” for text layers, that lets you decide whether the text frame is resized or the font size itself.
- New “Flatten” option (from “Modify” in the menu bar) converts the currently selected layer or group to a flattened bitmap
And Several fixes...
