ho acceso il Mac adesso e rispetto a questa mattina ho trovato all'avvio la scelta tra la mia utenza
e quella di un utente ospite sconosciuto che io non ho creato (non parlo del_xcsbuidagent che è un utente di sistema)
E inoltre non è possibile nemmeno eliminare, l'ho solo disattivato..
Non capisco come sia successo, non capisco cosa ho potuto fare stamani perchè si creasse questo ospite
Ho fatto una scansione con Etrecheck, che posto qui sotto =
EtreCheckPro version: 6.6 (66014)
Report generated: 2022-06-09 14:40:45
Download EtreCheckPro from
https://etrecheck.com
Runtime: 4:35
Performance: Good
Problem: Other problem
Description:
unknown guest user
Major Issues:
Anything that appears on this list needs immediate attention.
System Integrity Protection disabled - System Integrity Protection is disabled. This computer is at risk of malware infection.
Security updates disabled - Security updates are disabled. This computer is at risk of malware infection.
Apple security disabled - Apple security software is disabled. This computer is at risk of malware infection.
Obsolete hardware - This computer may be considered obsolete.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems or opportunities for improvement.
Time Machine auto backup disabled - Time Machine auto backups are disabled.
Heavy RAM usage - Apps are using a large amount of RAM.
Apps crashing - There have been numerous app crashes.
Clean up - There are orphan files that could be removed.
Unsigned files - There are unsigned software files installed. These files could be old, incompatible, and cause problems. They should be reviewed.
System modifications - There are a large number of system modifications running in the background.
32-bit Apps - This computer has 32-bits apps will not work on current versions of the operating system.
Kernel extensions present - This computer has kernel extensions that may not work in the future.
Hardware Information:
Mac Pro (Early 2008) - Obsolete!
Mac Pro Model: MacPro3,1
Dual 2,8 GHz Quad-Core Intel Xeon (Xeon(R)) CPU: 4-core
24 GB RAM - Upgradeable
Video Information:
ATI Radeon HD 4870 - VRAM: 1024 MB
S1910 1280 x 1024
Drives:
disk0 - Samsung SSD 850 PRO 256GB 256.06 GB (Solid State - TRIM: Yes)
External 6 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 - SSD (Journaled HFS+) 255.20 GB (102.60 GB used)
disk0s3 - Recovery HD (Journaled HFS+) [Recovery] 650 MB
disk1 - WDC WD1001FALS-41K1B0 1.00 TB (Mechanical)
Internal SATA 3 Gigabit Serial ATA
disk1s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk1s2 - T**********e (Journaled HFS+) 999.86 GB (470.91 GB used)
disk2 - WDC WD10EARS-00Y5B1 1.00 TB (Mechanical)
disk2s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk2s2 - L****o (Journaled HFS+) 999.86 GB (171.03 GB used)
Mounted Volumes:
disk0s2 - SSD
255.20 GB (102.60 GB used, 157.40 GB available, 152.34 GB free)
Journaled HFS+
Mount point: /
999.86 GB (470.91 GB used, 528.95 GB free)
Journaled HFS+
Mount point: /Volumes/T**********e
disk2s2 - L****o
999.86 GB (171.03 GB used, 828.83 GB free)
Journaled HFS+
Mount point: /Volumes/L****o
Network:
Interface en0: Ethernet 1
Interface en1: Ethernet 2
Interface en5: SAMSUNG_Android
Interface en6: iPad
Interface en7: iPad 2
Interface fw0: FireWire
Interface en3: Bluetooth PAN
iCloud Quota: 4.94 GB available
System Software:
macOS High Sierra 10.13.6 (17G14042)
Time since boot: Less than an hour
Configuration Files:
/etc/hosts - Count: 42
Security:
Gatekeeper: App Store and identified developers
System Integrity Protection: Disabled
Security Updates: Disabled
Antivirus software: Malwarebytes
Unsigned Files:
Launchd: ~/Library/LaunchAgents/com.cisco.videoguard10.uninstall.plist
Executable: /bin/sh ~/.cisco/VideoGuard/uninstall/cisco_videoguard10/condUninstall.sh
Details: Exact match found in the legitimate list - probably OK
Launchd: /Library/LaunchAgents/com.dosdude1.PatchUpdater.plist
Executable: /Applications/Utilities/Patch Updater.app/Contents/MacOS/Patch Updater -silent
Launchd: /Library/LaunchDaemons/com.oracle.java.Helper-Tool.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Helper-Tool
Launchd: /Library/LaunchAgents/com.brother.LOGINserver.plist
Executable: /Library/Printers/Brother/Utilities/Server/LOGINserver.app/Contents/MacOS/LOGINserver
Launchd: /Library/LaunchAgents/com.dd1.SIPLD.plist
Executable: /usr/local/sbin/SIPLD
Launchd: ~/Library/LaunchAgents/com.adobe.ARM.***.plist
Executable: /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/Updater/Adobe Acrobat Updater Helper.app/Contents/MacOS/Adobe Acrobat Updater Helper
Details: Close match found in the legitimate list - probably OK
Launchd: /Library/LaunchAgents/com.wacom.wacomtablet.plist
Executable: /Library/Application Support/Tablet/WacomTabletSpringboard
Launchd: /Library/LaunchAgents/com.adobe.CS5ServiceManager.plist
Executable: /Library/Application Support/Adobe/CS5ServiceManager/CS5ServiceManager.app/Contents/MacOS/CS5ServiceManager -launchedbylogin
Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Java-Updater.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Java Updater.app/Contents/MacOS/Java Updater -bgcheck
Launchd: /Library/LaunchDaemons/com.intel.haxm.plist
Executable: /Library/Extensions/intelhaxm.kext/Contents/Resources/haxm_start.sh
Launchd: /Library/LaunchDaemons/com.malwarebytes.mbam.settings.daemon.plist
Executable: /Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/SettingsDaemon.app/Contents/MacOS/SettingsDaemon
Launchd: /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Executable: /Library/Application Support/Adobe/OOBE/PDApp/UWA/UpdaterStartupUtility -mode=logon
Launchd: /Library/LaunchAgents/com.oracle.java.Java-Updater.plist
Launchd: ~/Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Executable: /Library/Application Support/Adobe/OOBE/PDApp/UWA/UpdaterStartupUtility -mode=scheduled
Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Helper-Tool.plist
Running app: /Library/Application Support/Tablet/WacomTabletDriver.app/Contents/Resources/WacomTouchDriver.app/Contents/MacOS/WacomTouchDriver
Running app: /Library/Printers/Brother/Utilities/Server/USBserver.app/Contents/MacOS/USBserver
Running app: /Library/Printers/Brother/Utilities/Server/NETserver.app/Contents/MacOS/NETserver
Running app: /Library/Application Support/Tablet/WacomTabletDriver.app/Contents/Resources/TabletDriver.app/Contents/MacOS/TabletDriver
Plugin: /Library/Internet Plug-Ins/Default Browser.plugin
Plugin: /Library/Internet Plug-Ins/Silverlight.plugin
Plugin: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin
Preference Pane: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/deploy/JavaControlPanel.prefPane
Preference Pane: /Library/PreferencePanes/WacomTablet.prefPane
Apps: 29
Old Applications:
50 32-bit apps
Kernel Extensions:
/Library/Application Support/CleverFiles/BackService.app
[Not Loaded] SecureDisk.kext - com.cleverfiles.SecureDisk (1.0 - SDK 10.14)
[Not Loaded] SecureDisk_11.kext - com.cleverfiles.SecureDisk-11 (1.0 - SDK 10.16)
/Library/Extensions
[Loaded] intelhaxm.kext - com.intel.kext.intelhaxm (7.5.1 - SDK 10.9)
[Not Loaded] HoRNDIS.kext - com.joshuawise.kexts.HoRNDIS (9.2 - SDK 10.11)
[Loaded] ufsd_NTFS.kext - com.paragon-software.filesystems.ntfs (15.9.314 - SDK 10.10)
[Not Loaded] LegacyUSBInjector.kext - com.parrotgeek.LegacyUSBInjector (1.0)
[Loaded] SIPManager.kext - com.parrotgeek.SIPManager (1.0 - SDK 10.12)
/System/Library/Extensions
[Not Loaded] heimdall.kext - au.com.glassechidna.heimdall_usb_shield (6.0)
[Loaded] SoundflowerSigned.kext - com.Cycling74.driver.Soundflower (1.6.7 - SDK 10.7)
[Loaded] SATSMARTDriver.kext - org.dungeon.driver.SATSMARTDriver (0.8.1 - SDK 10.6)
~/Library/Services/ToastIt.service/Contents/MacOS
[Not Loaded] TDIXController64.kext - com.roxio.TDIXController (2.0)
System Launch Daemons:
[Not Loaded] 38 Apple tasks
[Loaded] 199 Apple tasks
[Running] 100 Apple tasks
System Launch Agents:
[Not Loaded] 19 Apple tasks
[Loaded] 180 Apple tasks
[Running] 95 Apple tasks
Launch Daemons:
[Running] com.crystalidea.macsfancontrol.smcwrite.plist (Ilya Parniuk - installed 2020-10-05)
[Running] com.easeus.ensdaemon.plist (CHENGDU Yiwo Tech Development Co., Ltd - installed 2022-03-06)
[Loaded] com.google.keystone.daemon.plist (Google LLC - installed 2022-04-15)
[Loaded] com.intel.haxm.plist (Not signed - installed 2020-08-04)
[Loaded] com.iriun.cmio.DPA.camera.plist (Vesa Heikkila - installed 2022-02-01)
[Loaded] com.iriun.cmio.DPA.camerb.plist (Vesa Heikkila - installed 2022-02-01)
[Loaded] com.iriun.cmio.DPA.camerc.plist (Vesa Heikkila - installed 2022-02-01)
[Loaded] com.iriun.cmio.DPA.camerd.plist (Vesa Heikkila - installed 2022-02-01)
[Other] com.malwarebytes.mbam.rtprotection.daemon.plist (Not signed - installed 2019-10-14)
[Loaded] com.malwarebytes.mbam.settings.daemon.plist (Not signed - installed 2019-10-14)
[Loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2022-05-12)
[Loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2018-02-24)
[Not Loaded] com.oracle.java.Helper-Tool.plist (Not signed - installed 2022-04-26)
[Loaded] com.paragon-software.ntfs.loader.plist (Apple - installed 2022-06-03)
[Running] com.paragon-software.ntfsd.plist (Paragon Software GmbH - installed 2022-06-03)
[Loaded] com.teamviewer.Helper.plist (TeamViewer GmbH - installed 2021-02-23)
[Not Loaded] com.teamviewer.teamviewer_service.plist (TeamViewer GmbH - installed 2021-02-23)
[Not Loaded] com.wdc.WDPrivilegedHelper.plist (Western Digital Corporation Branded Products Group - installed 2021-08-07)
[Not Loaded] org.virtualbox.startup.plist (Not signed - installed )
Launch Agents:
[Not Loaded] com.adobe.AAM.Updater-1.0.plist (Not signed - installed 2017-11-17)
[Loaded] com.adobe.CS5ServiceManager.plist (Not signed - installed 2017-11-17)
[Running] com.brother.LOGINserver.plist (Not signed - installed 2017-11-17)
[Loaded] com.dd1.SIPLD.plist (Not signed - installed 2017-11-17)
[Loaded] com.dosdude1.PatchUpdater.plist (Not signed - installed 2017-11-17)
[Running] com.easeus.EaseUSNotify.plist (CHENGDU Yiwo Tech Development Co., Ltd - installed 2022-03-06)
[Loaded] com.google.keystone.agent.plist (Google LLC - installed 2022-04-15)
[Loaded] com.google.keystone.xpcservice.plist (Google LLC - installed 2022-04-15)
[Other] com.malwarebytes.mbam.frontend.agent.plist (Not signed - installed 2019-10-14)
[Loaded] com.microsoft.update.agent.plist (Microsoft Corporation - installed 2022-05-12)
[Not Loaded] com.oracle.java.Java-Updater.plist (Not signed - installed 2022-04-26)
[Running] com.paragon-software.ntfs.notification-agent.plist (Paragon Software GmbH - installed 2022-06-03)
[Not Loaded] com.teamviewer.teamviewer.plist (TeamViewer GmbH - installed 2021-02-23)
[Not Loaded] com.teamviewer.teamviewer_desktop.plist (TeamViewer GmbH - installed 2021-02-23)
[Running] com.wacom.wacomtablet.plist (Not signed - installed 2017-11-17)
User Launch Agents:
[Loaded] com.adobe.AAM.Updater-1.0.plist (Not signed - installed 2016-11-24)
[Loaded] com.adobe.ARM.***.plist (Not signed - installed 2016-12-14)
[Running] com.amazon.music.plist (AMZN Mobile LLC - installed 2021-11-22)
[Not Loaded] com.amazon.music.startup.plist (Not signed - installed 2021-11-22)
[Loaded] com.cisco.videoguard10.plist (Cisco Video Technologies Israel Ltd - installed 2020-10-01)
[Loaded] com.cisco.videoguard10.uninstall.plist (Not signed - installed 2020-10-01)
[Running] com.cisco.videoguardmonitor.plist (Cisco Video Technologies Israel Ltd - installed 2020-10-01)
[Not Loaded] org.virtualbox.vboxwebsrv.plist (Not signed - installed 2019-05-09)
User Login Items:
[Running] AppCleaner SmartDelete (Julien Ramseier - installed 2021-04-10)
Modern Login Item
/Applications/AppCleaner.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app
[Not Loaded] Garmin Express Service (Garmin International - installed 2018-08-21)
Modern Login Item
/Applications/Garmin Express.app/Contents/Library/LoginItems/Garmin Express Service.app
[Not Loaded] LaunchAtLogin (Serhiy Mytrovtsiy - installed 2022-06-09)
Modern Login Item
/Applications/Stats.app/Contents/Library/LoginItems/LaunchAtLogin.app
[Not Loaded] TeamViewerMeetingLoginItem (TeamViewer GmbH - installed 2021-02-23)
Modern Login Item
/Applications/TeamViewer.app/Contents/Library/LoginItems/TeamViewerMeetingLoginItem.app
[Not Loaded] PhotoStreamAgent (App Store - installed 2017-11-17)
Modern Login Item
/Applications/iPhoto.app/Contents/Library/LoginItems/PhotoStreamAgent.app
[Running] Android File Transfer Agent (Google, Inc. - installed 2020-12-07)
Application
~/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app
Internet Plug-ins:
Default Browser: (? - installed 2019-09-21)
Silverlight: 5.1.50901.0 (? - installed 2019-09-19)
JavaAppletPlugin: Java 8 Update 333 build 02 (? - installed 2022-05-03)
Audio Plug-ins:
AirPlay: 2.0 (Apple - installed 2020-10-01)
AppleTimeSyncAudioClock: 1.0 (Apple - installed 2020-10-01)
iSightAudio: 7.7.3 (Apple - installed 2020-10-01)
BridgeAudioSP: 4.69.2 (Apple - installed 2020-11-17)
AppleAVBAudio: 683.1 (Apple - installed 2020-10-01)
BluetoothAudioPlugIn: 6.0.7 (Apple - installed 2020-10-01)
IriunMic: 1.3 (Iriun Oy - installed 2021-12-15)
CoreMediaIO Plug-ins:
AppleCamera: 400.6.01 (Apple - installed 2017-11-17)
IriunCamera: 1.5 (Vesa Heikkila - installed 2022-02-01)
iOSScreenCapture: 814.0 (Apple - installed 2017-11-17)
Safari Extensions:
ABP (App Store - installed 2022-01-28)
ABP Control Panel (App Store - installed 2022-01-28)
3rd Party Preference Panes:
FUSE (Benjamin Fleischer - installed 2017-11-17)
Java (? - installed 2022-04-26)
WacomTablet (? - installed 2017-11-17)
Backup:
Skip System Files: No
Mobile backups: No
Auto backup: No
Volumes being backed up:
SSD: Disk size: 255.20 GB - Disk used: 102.86 GB
Destinations:
T**********e [Local] (Last used)
Total size: 999.86 GB
Total number of backups: 21
Oldest backup: 2014-04-09 18:28:01
Last backup: 2022-06-06 18:35:23
Performance:
System Load: 1.71 (1 min ago) 1.93 (5 min ago) 1.51 (15 min ago)
Nominal I/O speed: 0.00 MB/s
File system: 20.25 seconds
Write speed: 385 MB/s
Read speed: 390 MB/s
CPU Usage Snapshot:
Type Overall
System: 1 %
User: 2 %
Idle: 98 %
Top Processes Snapshot by CPU:
Process (count) CPU (Source - Location)
EtreCheckPro 6.46 % (Etresoft, Inc.)
com.apple.WebKit.WebContent (16) 4.90 % (Apple)
WindowServer 2.84 % (Apple)
Safari 2.66 % (Apple)
kernel_task 1.00 % (Apple)
Top Processes Snapshot by Memory:
Process (count) RAM usage (Source - Location)
com.apple.WebKit.WebContent (16) 2.17 GB (Apple)
kernel_task 1.06 GB (Apple)
EtreCheckPro 599 MB (Etresoft, Inc.)
mds_stores 363 MB (Apple)
com.apple.SafariServices.ExtensionHelper 169 MB (Apple)
Top Processes Snapshot by Network Use:
Process (count) Input / Output (Source - Location)
com.apple.WebKit.Networking 194 KB / 18 KB (Apple)
apsd 10 KB / 15 KB (Apple)
mDNSResponder 14 KB / 11 KB (Apple)
Safari 10 KB / 981 B (Apple)
com.apple.Safari.SearchHelper 6 KB / 888 B (Apple)
Top Processes Snapshot by Energy Use:
Process (count) Energy (0-100) (Source - Location)
WindowServer 3 (Apple)
com.apple.WebKit.WebContent (16) 2 (Apple)
launchd 1 (Apple)
Safari 0 (Apple)
com.apple.preferences.users.remoteservice 0 (Apple)
Virtual Memory Information:
Physical RAM: 24 GB
Free RAM: 15.92 GB
Used RAM: 4.64 GB
Cached files: 3.44 GB
Available RAM: 19.36 GB
Swap Used: 0 B
Software Installs (past 60 days):
Install Date Name (Version)
2022-05-03 Java 8 Update 333 (1.8.333.02)
2022-05-12 Microsoft AutoUpdate (4.47.22050700)
2022-05-16 The Unarchiver (4.3.5)
2022-05-26 Prism Video File Converter (9.28)
2022-05-30 华为手机助手 (12.0.310)
2022-06-03 product (0)
2022-06-03 Install (4.2)
2022-06-03 kext-installer (1.0)
2022-06-07 Folder-Compare-Lite (2.12)
2022-06-07 Compare & Sync Folders (1.5)
2022-06-07 CompareMerge2 (3.6)
2022-06-08 1Password 7 (7.9.5)
2022-06-08 Keeper Password Manager (16.6.1)
Clean up:
/Library/LaunchAgents/com.malwarebytes.mbam.frontend.agent.plist
/Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/FrontendAgent.app/Contents/MacOS/FrontendAgent
Executable not found
~/Library/LaunchAgents/org.virtualbox.vboxwebsrv.plist
/Applications/VirtualBox.app/Contents/MacOS/vboxwebsrv
/Library/LaunchDaemons/com.malwarebytes.mbam.rtprotection.daemon.plist
/Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/RTProtectionDaemon.app/Contents/MacOS/RTProtectionDaemon
Diagnostics Information (past 7-30 days):
2022-06-09 09:48:15 accountsd Memory (5 times)
Executable: /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
2022-06-09 08:45:22 com.paragon-software.ntfs.notification-agent.app Crash (7 times)
Executable: /Library/Application Support/Paragon Software/com.paragon-software.ntfs.notification-agent.app
Details:
*** Terminating app due to uncaught exception 'NSInvalidArgumentExcept
ion', reason: '*** -[__NSPlaceholderDictionary initWithObjects:forKeys
:count:]: attempt to insert nil object from objects[0]'
abort() called
terminating with uncaught exception of type NSException
2022-06-08 23:40:53 trustd Memory
Executable: /usr/libexec/trustd
2022-06-08 23:04:18 Keychain Access.app Memory
Executable: /Applications/Utilities/Keychain Access.app
2022-06-08 18:46:58 installd Memory
Executable: /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd
2022-06-08 18:20:36 iCloudPref.prefPane Crash
Executable: /System/Library/PreferencePanes/iCloudPref.prefPane
2022-06-07 18:46:00 Java Updater.app Crash
Details:
dyld: launch, loading dependent libraries
2022-06-07 18:33:08 com.apple.WebKit.WebContent Memory (6 times)
Executable: /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
2022-06-07 15:12:03 secd Memory (2 times)
Executable: /usr/libexec/secd
2022-06-07 08:57:59 WacomTabletDriver.app Crash (2 times)
Executable: /Library/Application Support/Tablet/WacomTabletDriver.app
2022-06-06 18:23:44 lsd Memory (2 times)
Executable: /usr/libexec/lsd
2022-06-06 18:19:17 iBooks.app Crash
Executable: /Applications/iBooks.app
Details:
dyld3: launch started
Sandbox creation failed: Container object initialization failed.
You don’t have permission to save the file “Application Support” in th
e folder “Library”.
NSCocoaErrorDomain:513
2022-06-06 18:19:16 com.apple.geod Crash
Executable: /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
Details:
e folder “Library”.
2022-06-06 17:07:35 AppleSpell Memory (2 times)
Executable: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
2022-06-06 12:00:32 mdworker Memory
Executable: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
End of report
