Problemi e crolli del Finder con Sierra
mauriziotis
Dopo aggiornamento a Sierra 10.12.6 il Finder va in crash e non si apre con questo errore.
Inoltre, se vado nella cartella "/System/Library/Frameworks/" non trovo "SafariServices.framework" a cui fa riferimento il log.
Qualche suggerimento?
Grazie mille in anticipo.
Process:               Finder [41860]
Path:                  /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
Identifier:            Finder
Version:               10.12.5 (10.12.5)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Finder [41860]
User ID:               501
Date/Time:             2017-09-03 11:36:37.009 +0200
OS Version:            Mac OS X 10.12.6 (16G29)
Report Version:        12
Anonymous UUID:        EEFB40C2-3B7D-E0D3-04C9-7E39ED21F2E6
Sleep/Wake UUID:       070C4C99-A92F-4456-AE89-2BEC6D644403
Time Awake Since Boot: 7400 seconds
Time Since Wake:       1600 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
  Referenced from: /System/Library/PrivateFrameworks/AOSAccounts.framework/Versions/A/AOSAccounts
  Reason: image not found
mauriziotis
Ecco qui errori che trovo facendo un EtreCheck
Disk Information: ⓘ
    OCZ-VERTEX4 disk0: (256,06 GB) (Solid State - TRIM: No)
    [Show SMART report]
        EFI (disk0s1 - MS-DOS FAT32) <not mounted>  [EFI]: 210 MB
        Sierra (disk0s2 - Journaled HFS+) /  [Startup]: 255.20 GB (12.55 GB free) (Low!)
        Recovery HD (disk0s3 - Journaled HFS+) <not mounted>  [Recovery]: 650 MB
System Launch Agents: ⓘ
    [failed]    com.apple.CalendarAgent.plist (Apple, Inc. - installed 2017-03-23)
    [failed]    com.apple.CallHistorySyncHelper.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.Finder.plist (Apple, Inc. - installed 2017-08-31)
    [failed]    com.apple.SocialPushAgent.plist (Apple, Inc. - installed 2017-03-23)
    [failed]    com.apple.Spotlight.plist (Apple, Inc. - installed 2017-08-31)
    [failed]    com.apple.TMHelperAgent.SetupOffer.plist (Apple, Inc. - installed 2017-08-31)
    [failed]    com.apple.WiFiVelocityAgent.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.askpermissiond.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.assistantd.plist (Apple, Inc. - installed 2017-03-23)
    [failed]    com.apple.bird.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.coreservices.appleid.authentication.plist (Apple, Inc. - installed 2017-07-15)
    [failed]    com.apple.icloud.fmfd.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.keyboardservicesd.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.notificationcenterui.plist (Apple, Inc. - installed 2017-08-31)
    [failed]    com.apple.parsecd.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.passd.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.sharingd.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.systemprofiler.plist (? a6998f70 d21f37a8 - installed 2017-08-31)
    [not loaded]    7 Apple tasks
    [loaded]    191 Apple tasks
    [running]    66 Apple tasks
System Launch Daemons: ⓘ
    [failed]    com.apple.backupd.plist (Apple, Inc. - installed 2017-07-15)
    [failed]    com.apple.familycontrols.plist (Apple, Inc. - installed 2017-04-29)
    [failed]    com.apple.mtmfs.plist (Apple, Inc. - installed 2017-07-15)
    [not loaded]    41 Apple tasks
    [loaded]    176 Apple tasks
    [running]    96 Apple tasks
Kundalini
Uhmm, il resoconto di EtreCheck andrebbe postato per intero.
È un po' come un film, non puoi farmi vedere il trailer, dove appare un'immagine del cadavere, si ode lo sparo di una pistola nel buio, balena una mano che brandisce un coltello e poi pretendere alla fine che ti dica che il colpevole è il maggiordomo.
Comunque per me il colpevole è il maggiordomo :D
Disk Information: ⓘ
[Show SMART report]
Non è che hai il disco pieno, o quasi?
Un altro indiziato:
Se funziona, non aggiustarlo.
Posso aggiungere ben poco.
(intervengo solo perché avevo suggerito io di postare queste cose).
Quel disco per poter liberare il necessario potenziale per il sistema deve aver almeno 40GB liberi.
Provvedi, aiutati anche con OmnidiskSweeper
https://www.omnigroup.com/more" onclick="window.open(this.href);return false;
Papirai meglio cosa ingombra e cosa puoi convenientemente eliminare.
Poi posta un nuovo EtreCheck, integrale, per favore
mauriziotis
Liberato spazio, ecco l'EtreCheck integrale:
EtreCheck version: 3.4.4 (448)
Report generated 2017-09-03 11:45:15
Runtime: 11:37
Performance: Poor
Problem: Apps are crashing
Hardware Information: ⓘ
    MacBook (13-inch, Late 2009)
    MacBook - model: MacBook6,1
    1 2,26 GHz Intel Core 2 Duo (Duo) CPU: 2-core
        BANK 0/DIMM0
            4 GB DDR3 1333 MHz ok
        BANK 1/DIMM0
    Wireless:  en1: 802.11 a/b/g/n
    Battery: Health = Normal - Cycle count = 250
Video Information: ⓘ
    NVIDIA GeForce 9400M - VRAM: 256 MB
        Color LCD 1280 x 800
Disk Information: ⓘ
    [Show SMART report]
        Sierra (disk0s2 - Journaled HFS+) /  [Startup]: 255.20 GB (89.55 GB free)
    MATSHITADVD-R   UJ-898  ()
USB Information: ⓘ
     USBBus
        Microsoft Microsoft Nano Transceiver 1.1
        Apple Inc. BRCM2070 Hub
     USBBus
     USB20Bus
        Apple Inc. Built-in iSight
     USB20Bus
System Software: ⓘ
    macOS Sierra  10.12.6 (16G29) - Time since boot: about 12 hours
Gatekeeper: ⓘ
Kernel Extensions: ⓘ
        /Applications/Tunnelblick.app
    [not loaded]    net.tunnelblick.tap (20141104 (Tunnelblick build 4625)) [Lookup]
    [not loaded]    net.tunnelblick.tun (20141104 (Tunnelblick build 4625)) [Lookup]
Launch Agents: ⓘ
    [failed]    com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2017-04-02) [Lookup]
    [running]    com.teamviewer.teamviewer.plist (TeamViewer GmbH - installed 2017-09-02) [Lookup]
    [running]    com.teamviewer.teamviewer_desktop.plist (TeamViewer GmbH - installed 2017-09-02) [Lookup]
Launch Daemons: ⓘ
    [loaded]    com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2017-04-02) [Lookup]
    [loaded]    com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2017-04-02) [Lookup]
    [loaded]    com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2017-03-09) [Lookup]
    [loaded]    com.teamviewer.Helper.plist (TeamViewer GmbH - installed 2017-07-27) [Lookup]
    [running]    com.teamviewer.teamviewer_service.plist (TeamViewer GmbH - installed 2017-09-02) [Lookup]
    [loaded]    net.tunnelblick.tunnelblick.tunnelblickd.plist (Jonathan Bullard - installed 2017-04-09) [Lookup]
User Launch Agents: ⓘ
    [loaded]    com.google.keystone.agent.plist (Google, Inc. - installed 2017-07-10) [Lookup]
    [running]    com.spotify.webhelper.plist (Spotify - installed 2017-09-02) [Lookup]
    [loaded]    net.tunnelblick.tunnelblick.LaunchAtLogin.plist (Jonathan Bullard - installed 2016-10-09) [Lookup]
User Login Items: ⓘ
    iTunesHelper    Applicazione (? 0 - installed 2017-07-20)
        (/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
    Spotify    Applicazione - Hidden
        (/Applications/Spotify.app)
Internet Plug-ins: ⓘ
    QuickTime Plugin: 7.7.3 (installed 2017-08-31)
    AdobePDFViewer: 17.009.20058 (installed 2017-07-18) [Lookup]
    AdobePDFViewerNPAPI: 17.009.20058 (installed 2017-07-18) [Lookup]
3rd Party Preference Panes: ⓘ
    None
Time Machine: ⓘ
    Skip System Files: NO
    Auto backup: YES
    Volumes being backed up:
        Sierra: Disk size: 255.20 GB Disk used: 242.66 GB
    Destinations:
        (null) [(null)]
        Total size: 319.73 GB
        Total number of backups: 1
        Oldest backup: 28/01/17, 17:45
        Last backup: 28/01/17, 17:45
            Backup size 319.73 GB < (Disk used 242.66 GB X 3)
Top Processes by CPU: ⓘ
        72%   	ReportCrash
        23%   	TeamViewer_Desktop
        21%   	WindowServer
        11%   	(passd)
         8%   	kernel_task
Top Processes by Memory: ⓘ
    600 MB    	kernel_task
    462 MB    	ReportCrash
    230 MB    	Google Chrome
    152 MB    	TeamViewer
    143 MB    	TeamViewer_Desktop
    Input     	Output    	Process name
    278 MB    	6 MB      	TeamViewer_Service
    110 KB    	96 KB     	mDNSResponder
    9 KB      	6 KB      	netbiosd
    8 KB      	4 KB      	apsd
    720 B     	720 B     	ntpd
    38129479.80	EscrowSecurityAlert
    38129479.80	syncdefaultsd
     30.00	ReportCrash
     18.82	WindowServer
     10.92	TeamViewer_Desktop
Virtual Memory Information: ⓘ
    2.84 GB   	Available RAM
    272 MB    	Free RAM
    5.16 GB   	Used RAM
    2.57 GB   	Cached files
    0 B       	Swap Used
Software installs: ⓘ
    TeamViewer: 12.0.81460 (installed 2017-08-08)
Diagnostics Information: ⓘ
    2017-09-03 11:41:44    bird Crash [Open]
        Cause:        dyld: launch, loading dependent libraries
    2017-09-03 11:41:44    System Information.app Crash [Open]
    2017-09-03 11:41:42    Spotlight.app Crash [Open]
    2017-09-03 11:41:41    keyboardservicesd Crash [Open]
    2017-09-03 11:41:39    system_profiler Crash [Open]
        Cause:        dyld: launch, running initializers
        /usr/lib/libSystem.B.dylib
    2017-09-03 11:41:37    Finder.app Crash [Open]
    2017-09-03 11:41:36    NotificationCenter.app Crash [Open]
    2017-09-03 11:41:36    sharingd Crash [Open]
    2017-09-03 11:41:35    parentalcontrolsd Crash [Open]
    2017-09-03 11:41:34    mtmfs Crash [Open]
    2017-09-03 11:41:30    TMCacheDelete Crash [Open]
    2017-09-03 11:41:26    cloudpaird Crash [Open]
    2017-09-03 11:41:23    findmydeviced Crash [Open]
    2017-09-03 11:41:22    AppleIDAuthAgent Crash [Open]
    2017-09-03 11:41:20    assistantd Crash [Open]
    2017-09-03 11:41:09    EscrowSecurityAlert.app Crash [Open]
    2017-09-03 11:41:07    passd Crash [Open]
    2017-09-03 11:41:04    CalendarAgent Crash [Open]
    2017-09-03 11:41:04    suggestd Crash [Open]
    2017-09-03 11:40:36    askpermissiond Crash [Open]
    2017-09-03 11:40:35    WiFiVelocityAgent Crash [Open]
    2017-09-03 11:40:34    fmfd Crash [Open]
    2017-09-03 11:40:26    CallHistorySyncHelper Crash [Open]
    2017-09-03 11:40:14    ~/Library/Logs/DiagnosticReports/Spotlight_2017-09-03-114014_[redacted].crash Crash Missing!
    2017-09-03 11:40:14    cloudphotosd.app Crash [Open]
        Cause:        /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/PhotoLibraryPrivate
        Assertion failure in void testCompatibleVersion(), /Library/Caches/com.apple.xbs/Sources/PhotoApp_SubFrameworks/PhotoApp-3150.4.120/lib/photolibrary/PhotoLibraryPrivate/PhotoLibraryPrivate.m:23
        The application built with PhotoLibraryPrivate version 3161.04.140 but is running with version 3150.04.120.
        abort() called
    2017-09-03 11:40:11    ~/Library/Logs/DiagnosticReports/Spotlight_2017-09-03-114011_[redacted].crash Crash Missing!
    2017-09-03 11:40:09    ~/Library/Logs/DiagnosticReports/System Information_2017-09-03-114009_[redacted].crash Crash Missing!
    2017-09-03 11:40:02    ~/Library/Logs/DiagnosticReports/System Information_2017-09-03-114002_[redacted].crash Crash Missing!
    2017-09-03 11:40:01    ~/Library/Logs/DiagnosticReports/System Information_2017-09-03-114001_[redacted].crash Crash Missing!
    2017-09-03 11:40:01    ~/Library/Logs/DiagnosticReports/Spotlight_2017-09-03-114001_[redacted].crash Crash Missing!
    2017-09-03 11:39:58    syncdefaultsd Crash [Open]
    2017-09-03 11:39:58    cloudd Crash [Open]
    2017-09-03 11:39:38    parsecd Crash [Open]
    2017-09-03 11:33:54    brctl Crash [Open]
    2017-09-03 11:17:35    ~/Library/Logs/DiagnosticReports/WiFiVelocityAgent_2017-09-03-111735_[redacted].crash Crash Missing!
    2017-09-03 11:16:25    ~/Library/Logs/DiagnosticReports/WiFiVelocityAgent_2017-09-03-111625_[redacted].crash Crash Missing!
    2017-09-03 11:14:42    ~/Library/Logs/DiagnosticReports/CallHistorySyncHelper_2017-09-03-111442_[redacted].crash Crash Missing!
    2017-09-03 04:33:21    ReportCrash Crash [Open]
        Cause:        Analyzing process: NotificationCenter[27280], path: /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter; parent process: [1], path: /sbin/launchd
        Analyzing process: Finder[27283], path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder; parent process: [1], path: /sbin/launchd
        Analyzing process: suggestd[27282], path: /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd; parent process: [1], path: /sbin/launchd
        Analyzing process: Finder[4012], path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder; parent process: [1], path: /sbin/launchd
        Analyzing process: Finder[27276], path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder; parent process: [1], path: /sbin/launchd
    2017-09-03 02:21:30    ManagedClient.app Crash [Open]
    2017-09-02 23:32:22    backupd Crash [Open]
    2017-09-02 23:31:57    SocialPushAgent.app Crash [Open]
    2017-09-02 23:30:37    UserAccountUpdater Crash [Open]
    2017-09-02 23:23:09    Mail.app Crash [Open]
    2017-09-02 23:23:00    Safari.app Crash [Open]
    2017-09-02 23:22:39    storeaccountd Crash [Open]
    2017-09-02 22:58:44    TMHelperAgent.app Crash [Open]
    2017-09-02 22:54:16    Kernel Panic [Open] [Details]
        3rd Party Kernel Extensions: None
    2017-09-02 22:00:28    Siri.app Crash [Open]
    2017-09-02 21:45:15    AppleSpell Crash [Open]
    2017-09-02 21:39:04    Google Chrome.app Hang [Open]
    2017-09-01 01:45:04    installer Crash [Open]
    2017-09-01 01:41:41    Preview.app Hang [Open]
    2017-09-01 01:17:46    App Store.app Hang [Open]
    2017-09-01 00:35:04    UserEventAgent Crash [Open]
        Cause:        dyld: in dlopen()
    2017-09-01 00:26:05    Problem Reporter.app Crash [Open]
    2017-08-31 20:12:08    Spotify.app Crash [Open]
Hai il sistema messo male, a mio parere irrecuperabile.
Probabilmente necessita di una reinstallazione radicale.
hai un backup recente e utilizzabile?
Quello del 28/1/17 non sembra molto aggiornato.
Fai una copia almeno della cartella utente, con i dati
Puoi provare prima con una reinstallazione semplice da Recovery o con un aggiornamento combinato
Kundalini
Altro che maggiordomo, qui è tutta la servitù di casa Apple che congiura; ci sono tutti, Safari, TM, iCloud, Spotlight, Finder...
Davvero brutto, ma brutto brutto brutto. Non ricordo altri resoconti EC con altrettanti crash di cose Apple.
Alberto.G
Stato: Connesso
Kundalini ha scritto:Davvero brutto, ma brutto brutto brutto. ...
Purtroppo sì!
Scorrendo il report (parte finale, quella di diagnostica), mi sono quasi raddrizzati i capelli!
Mi spiace per 'mauriziotis' che ha subìto quel danno.
Ma, mi domando, cosa o chi può aver danneggiato così tanto quel sistema ?
I massimi esperti del forum potrebbero, anche a grandi linee, trarre delle ipotesi sulle possibili cause ?
Chiedo questo, perché ritengo che possa tornare utile a tutti, soprattutto quando la causa è da addebitare al fattore "umano".
Alberto.G ha scritto:... (si potrebbe)... anche a grandi linee, trarre delle ipotesi sulle possibili cause ?
È indimostrabile che la causa sia un errore umano.
Non ci sono tracce evidenti di cause inequivocabili.
E andarle a cercare, non essendo praticabile una ricostruzione, è quanto mai una perdita di tempo
mauriziotis
La cosa è stata provocata dall'aggiornamento da Sierra 10.12.5 a Sierra 10.12.6 andato male.
mauriziotis ha scritto:La cosa è stata provocata dall'aggiornamento ... andato male.
Ovvio.
Ma è come dire: è morto di morte.
Ti interessa, invece, stare a cercare le prove che sia stato un installer con pacchetto incompleto?
Oppure una microinterruzione di alimentazione, se non uno sbalzo?
O un conflitto nell'installazione, un errore della mappa del disco, permessi incoerenti?
La mancata esecuzione di uno script, una punizione divina, la sfortuna cosmica?
E via elencando in modo non scientifico.
Non credo, e comunque non servirebbe a nulla saperlo
Torna a “macOS Sierra 10.12”
