Loro.fenix ha scritto:ma non lo capiranno mai ...
Di già?! Non è giusto.mattleega ha scritto:fenix, benvenuto nel club.
Tutto questo sarebbe petaloso!faxus ha scritto:È abbastanza ovvio.
Che faresti tu se vedessi un picassinatto?
EtreCheck version: 3.4 (420)
Report generated 2017-07-16 08:14:22
Runtime: 4:51
Performance: Good
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Click the [Clean up] link to delete unused files.
Problem: Beachballing
Hardware Information: ⓘ
MacBook Air (13-inch, Mid 2013)
MacBook Air - model: MacBookAir6,2
1 1,3 GHz Intel Core i5 (i5-4250U) CPU: 2-core
4 GB RAM Not upgradeable
BANK 0/DIMM0
2 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Wireless: en0: 802.11 a/b/g/n/ac
Battery: Health = Normal - Cycle count = 192
iCloud Quota: 4.90 GB available
Video Information: ⓘ
Intel HD Graphics 5000 - VRAM: 1536 MB
Color LCD 1440 x 900
Disk Information: ⓘ
APPLE SSD SD0128F disk0: (121,33 GB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [APFS Container]: 120.47 GB
(disk0s3) <not mounted> [KernelCoreDump]: 655 MB
USB Information: ⓘ
USB30Bus
Apple Inc. BRCM20702 Hub
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
MacintosHD (disk1s1 - APFS) / [Startup]: 120.47 GB (77.04 GB free)
Physical disk: APPLE SSD SD0128F 120.47 GB (77.04 GB free)
(disk1s2) <not mounted> [Preboot]: 120.47 GB
(disk1s3) <not mounted> [Recovery]: 120.47 GB
VM (disk1s4 - APFS) /private/var/vm : 120.47 GB (77.04 GB free)
System Software: ⓘ
macOS 10.13 (17A306f) - Time since boot: less than an hour
Configuration files: ⓘ
/etc/hosts - Count: 33
Gatekeeper: ⓘ
Possible adware: ⓘ
Unknown file: /System/Library/LaunchDaemons/org.ntp.ntpd-legacy.plist
/usr/libexec/ntpd-wrapper
One possible adware file found. [Remove/Report]
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.NVMeAgent.plist
/usr/libexec/NVMeAgent
Executable not found!
One orphan file found. [Clean up]
Kernel Extensions: ⓘ
/Applications/Disk Sensei.app
[not loaded] org.cindori.TrimEnabler (1.0 - SDK 10.10) [Lookup]
/Applications/MacCheck.app
[not loaded] com.micromat.driver.SPDKernel (1.0 - SDK 10.9) [Lookup]
/Applications/Parallels Desktop.app
[not loaded] com.parallels.kext.hypervisor (12.0.2 41353 - SDK 10.9) [Lookup]
[not loaded] com.parallels.kext.netbridge (12.0.2 41353 - SDK 10.9) [Lookup]
[not loaded] com.parallels.kext.usbconnect (12.0.2 41353 - SDK 10.9) [Lookup]
[not loaded] com.parallels.kext.vnic (12.0.2 41353 - SDK 10.9) [Lookup]
/Applications/eqMac/eqMac.app
[not loaded] com.bitgapp.eqMacDriver (1.5.2 - SDK 10.10) [Lookup]
/Library/Application Support/VirtualBox
[loaded] org.virtualbox.kext.VBoxDrv (5.1.8) [Lookup]
[loaded] org.virtualbox.kext.VBoxNetAdp (5.1.8) [Lookup]
[loaded] org.virtualbox.kext.VBoxNetFlt (5.1.8) [Lookup]
[loaded] org.virtualbox.kext.VBoxUSB (5.1.8) [Lookup]
/Library/Extensions
[loaded] com.Cycling74.driver.Soundflower (2.0b2 - SDK 10.10) [Lookup]
System Launch Agents: ⓘ
[failed] com.apple.NVMeAgent.plist (? ? ? - installed 2017-06-30) - /usr/libexec/NVMeAgent: Executable not found!
[failed] com.apple.touristd.plist (Apple, Inc. - installed 2017-07-07)
[not loaded] 7 Apple tasks
[loaded] 174 Apple tasks
[running] 77 Apple tasks
[killed] 29 Apple tasks
29 processes killed due to insufficient RAM
System Launch Daemons: ⓘ
[failed] com.apple.analyticsd.plist (Apple, Inc. - installed 2017-07-07)
[not loaded] 38 Apple tasks
[loaded] 180 Apple tasks
[running] 85 Apple tasks
[killed] 24 Apple tasks
24 processes killed due to insufficient RAM
Launch Agents: ⓘ
[running] com.bjango.istatmenusagent.plist (Bjango Pty Ltd - installed 2016-11-23) [Lookup]
[running] com.bjango.istatmenusnotifications.plist (Bjango Pty Ltd - installed 2016-11-23) [Lookup]
[running] com.bjango.istatmenusstatus.plist (Bjango Pty Ltd - installed 2016-11-23) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2017-03-29) [Lookup]
[not loaded] com.maintain.LogOut.plist (Apple, Inc. - installed 2017-07-07)
[not loaded] com.maintain.PurgeInactiveMemory.plist (Apple, Inc. - installed 2017-07-07)
[not loaded] com.maintain.Restart.plist (Apple, Inc. - installed 2017-07-07)
[not loaded] com.maintain.ShutDown.plist (Apple, Inc. - installed 2017-07-07)
[not loaded] com.maintain.Sleep.plist (Apple, Inc. - installed 2017-07-07)
[running] com.maintain.SystemEvents.plist (Apple, Inc. - installed 2017-07-07)
[loaded] com.oracle.java.Java-Updater.plist (? 85f5a7c be93c7fb - installed 2017-05-22) [Lookup]
[running] net.culater.SIMBL.Agent.plist (? 4a576751 1fea012b - installed 2016-10-26) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.fpsaud.plist (? 2afb3af7 18a4fa69 - installed 2017-06-23) [Lookup]
[running] com.bjango.istatmenusdaemon.plist (Bjango Pty Ltd - installed 2016-11-23) [Lookup]
[running] com.cleverfiles.cfbackd.plist (Justin Johnson - installed 2017-03-26) [Lookup]
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2017-04-24) [Lookup]
[not loaded] com.maintain.CocktailScheduler.plist (Apple, Inc. - installed 2017-07-07)
[not loaded] com.maintain.HideSpotlightMenuBarIcon.plist (Apple, Inc. - installed 2017-07-07)
[loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2017-02-18) [Lookup]
[loaded] com.micromat.MacCheckWorkerDaemon.plist (? ? ? - installed 2016-06-10) [Lookup]
[loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2016-06-11) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script e3fefdd2 - installed 2017-03-15) [Lookup]
[running] com.tunnelbear.mac.tbeard.plist (TunnelBear, Inc./ - installed 2017-03-25) [Lookup]
[loaded] org.cindori.SenseiTool.plist (Oskar Groth - installed 2016-10-18) [Lookup]
[not loaded] org.virtualbox.startup.plist (Shell Script 700b9385 - installed 2016-10-23) [Lookup]
User Launch Agents: ⓘ
[running] com.spotify.webhelper.plist (Spotify - installed 2016-11-19) [Lookup]
[running] com.tunnelbear.mac.tbeara.plist (TunnelBear, Inc./ - installed 2017-03-25) [Lookup]
[not loaded] org.virtualbox.vboxwebsrv.plist (? e782d02b 4262cc6f - installed 2016-10-23) [Lookup]
User Login Items: ⓘ
Alfred 3 Applicazione
(/Applications/Alfred 3.app)
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 26.0.0.137 (installed 2017-07-15) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2017-07-07)
Flash Player: 26.0.0.137 (installed 2017-07-15) [Lookup]
PepperFlashPlayer: 26.0.0.131 (installed 2017-06-24) [Lookup]
googletalkbrowserplugin: 5.41.3.0 (installed 2015-12-11) [Lookup]
Silverlight: 5.1.50901.0 (installed 2016-12-01) [Lookup]
JavaAppletPlugin: Java 8 Update 131 build 11 (installed 2017-05-22) Check version
User internet Plug-ins: ⓘ
Folx3Plugin: 3.0.1 (installed 2017-07-16) [Lookup]
Safari Extensions: ⓘ
[enabled] Ghostery - GHOSTERY, Inc. - https://www.ghostery.com/ (installed 2017-06-25)
[enabled] Adblock Plus - Eyeo GmbH - https://adblockplus.org/ (installed 2017-05-31)
[enabled] Folx - Eltima Software (installed 2017-06-24)
3rd Party Preference Panes: ⓘ
AppTrap (installed 2016-10-30) [Lookup]
Fan Control (installed 2007-10-27) [Lookup]
Flash Player (installed 2017-06-23) [Lookup]
FUSE (installed 2016-12-01) [Lookup]
GeekTool (installed 2016-09-01) [Lookup]
Hosts (installed 2012-09-11) [Lookup]
Java (installed 2017-05-22) [Lookup]
Time Machine: ⓘ
Time Machine not configured!
Top Processes by CPU: ⓘ
22% touristd
22% touristd
20% WindowServer
17% com.apple.WebKit.WebContent
13% kernel_task
Top Processes by Memory: ⓘ
807 MB kernel_task
320 MB Safari
134 MB com.apple.WebKit.WebContent
120 MB mds_stores
85 MB Finder
Input Output Process name
792 KB 27 KB com.apple.WebKit.Networking
73 KB 30 KB cloudd
19 KB 14 KB mDNSResponder
17 KB 10 KB Safari
10 KB 3 KB netbiosd
Virtual Memory Information: ⓘ
605 MB Available RAM
17 MB Free RAM
3.41 GB Used RAM
588 MB Cached files
1.16 GB Swap Used
Software installs: ⓘ
Adobe Flash Player: (installed 2017-06-22)
Adobe Pepper Flash Player: (installed 2017-06-24)
Adobe Flash Player: (installed 2017-07-15)
Diagnostics Information: ⓘ
2017-07-16 08:09:27 EtreCheck.app Hang [Open]
2017-07-16 07:35:47 Little Snitch Network Monitor.app Crash [Open]
Cause: *** Terminating app due to uncaught exception 'm5bd74dd9', reason: ': 268435459'
abort() called
terminating with uncaught exception of type NSException
2017-07-15 23:51:55 iconservicesagent Crash [Open]
Files deleted by EtreCheck: ⓘ
2017-07-16 08:06:43 - /Library/LaunchDaemons/com.apple.installer.cleanupinstaller.plist - Unknown
2017-07-16 08:06:43 - /System/Library/LaunchAgents/com.apple.NVMeAgent.plist - Unknown
Messaggi spostati in macOS High Sierra - discussione tecnica.faxus ha scritto:Tieni presente che avresti dovuto postare questa verifica nella discussione di High Sierra.
