default 09:35:33.414692 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:33.712188 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:33.712508 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 20, EGID: 20
default 09:35:33.712869 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:33.721076 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:34.224994 +0100 gamed GKClientProxy: clientForBundleID:
default 09:35:34.225265 +0100 gamed GKClientProxy: updateIfRecentlyInstalled
default 09:35:34.225755 +0100 gamed GKClientProxy: clientForBundleID:
default 09:35:34.225888 +0100 gamed GKClientProxy: updateIfRecentlyInstalled
default 09:35:34.226773 +0100 gamed GKClientProxy: clientForBundleID:
default 09:35:34.226826 +0100 gamed GKClientProxy: updateIfRecentlyInstalled
default 09:35:34.250832 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:34.259351 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:34.630066 +0100 CommCenter #watchdog #I Callback Watchdog: checkin 34
default 09:35:34.630185 +0100 CommCenter #watchdog #I Server Watchdog: checkin 34
default 09:35:35.645283 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:36.340215 +0100 symptomsd a wifi flow named com.apple.usbmuxd is ignored (directly reachable target)
default 09:35:36.979221 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:37.445403 +0100 parentalcontrolsd -[ActivityTracker checkUserLogin:] [736:<private>] -- <private>
default 09:35:39.003689 +0100 kernel SmartBattery: finished polling type 4
default 09:35:39.014984 +0100 coreduetd CDDBatteryMonitor: received batterycallback, currentPercentage:77.418866!
default 09:35:39.015321 +0100 powerd Battery time remaining posted with value 0x20000000048019e
default 09:35:39.015389 +0100 powerd Battery capacity change posted with value 0x80051
default 09:35:39.219905 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:39.799763 +0100 kernel IOConsoleUsers: time(0) 0->0, lin 1, llk 0,
default 09:35:39.799777 +0100 kernel IOConsoleUsers: gIOScreenLockState 1, hs 0, bs 0, now 0, sm 0x0
error 09:35:39.800471 +0100 kernel loginwindow is not entitled
error 09:35:39.800581 +0100 kernel UserEventAgent is not entitled
default 09:35:41.206828 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:42.440341 +0100 parentalcontrolsd ScheduledExit [885:] -- <private>
default 09:35:42.672881 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.674011 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.674078 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.674151 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.674213 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.677933 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.678796 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.678889 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.678974 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.679037 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.683439 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:42.683785 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 20, EGID: 20
default 09:35:42.684355 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:42.693638 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:42.698404 +0100 UserEventAgent Unregistered XPC Activity: com.apple.syncdefaultsd
default 09:35:42.698930 +0100 DuetHeuristic-BM CANCELED: <private>!
default 09:35:42.699008 +0100 UserEventAgent SUBMITTING: <private>
default 09:35:42.699127 +0100 UserEventAgent Registered XPC Activity: com.apple.syncdefaultsd
default 09:35:42.699583 +0100 DuetHeuristic-BM Submitted Activity: <private>
default 09:35:42.699762 +0100 DuetHeuristic-BM Activity <private>: Optimal Score 0.4745 at <private> (Valid Until: <private>)
default 09:35:42.700090 +0100 DuetHeuristic-BM <private>:[
<private> ] sumScores:14.004326, denominator:19.010000, FinalDecision: Must Not Proceed FinalScore: 0.000000}
default 09:35:42.702360 +0100 syncdefaultsd subsystem: com.apple.icloudpreferences, category: iCloudPreferences, enable_level: 3, persist_level: 1, default_ttl: 7, info_ttl: 7, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 0, enable_private_data: 0
default 09:35:42.705193 +0100 syncdefaultsd subsystem: com.apple.securityd, category: csresource, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.705424 +0100 syncdefaultsd subsystem: com.apple.securityd, category: dirval, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.705754 +0100 syncdefaultsd subsystem: com.apple.securityd, category: unixio, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.705866 +0100 syncdefaultsd subsystem: com.apple.securityd, category: macho, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.706105 +0100 syncdefaultsd subsystem: com.apple.securityd, category: machorep, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.706244 +0100 syncdefaultsd subsystem: com.apple.securityd, category: cfloadfile, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.706493 +0100 syncdefaultsd subsystem: com.apple.securityd, category: cssm, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.706594 +0100 syncdefaultsd subsystem: com.apple.securityd, category: handleobj, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.706711 +0100 syncdefaultsd subsystem: com.apple.securityd, category: MDS_Scan, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.706863 +0100 syncdefaultsd subsystem: com.apple.securityd, category: MDS_API, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.706988 +0100 syncdefaultsd subsystem: com.apple.securityd, category: SSclnt, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.707702 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:42.707928 +0100 syncdefaultsd subsystem: com.apple.securityd, category: MDS_IO, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.708046 +0100 syncdefaultsd subsystem: com.apple.securityd, category: mdslock, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.708216 +0100 syncdefaultsd subsystem: com.apple.securityd, category: security_exception, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.708344 +0100 syncdefaultsd UNIX error exception: 17
default 09:35:42.708475 +0100 syncdefaultsd subsystem: com.apple.securityd, category: DBOpen, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.708583 +0100 syncdefaultsd subsystem: com.apple.securityd, category: dbsession, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.708841 +0100 syncdefaultsd subsystem: com.apple.securityd, category: atomicfile, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.708879 +0100 syncdefaultsd 0x7fc046412750 opened /private/var/db/mds/system/mdsDirectory.db: 50744 bytes
default 09:35:42.708948 +0100 syncdefaultsd 0x7fc046412750 closed /private/var/db/mds/system/mdsDirectory.db
default 09:35:42.710383 +0100 syncdefaultsd UNIX error exception: 17
default 09:35:42.710713 +0100 syncdefaultsd subsystem: com.apple.securityd, category: policy, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.710889 +0100 syncdefaultsd subsystem: com.apple.securityd, category: dateparse, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.711572 +0100 syncdefaultsd subsystem: com.apple.securityd, category: callback, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.711682 +0100 syncdefaultsd UNIX error exception: 17
default 09:35:42.712274 +0100 syncdefaultsd subsystem: com.apple.securityd, category: secpref, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.712920 +0100 syncdefaultsd subsystem: com.apple.securityd, category: keyDate, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.715129 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.716094 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:42.716564 +0100 syncdefaultsd subsystem: com.apple.securityd, category: trustSettings, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.718716 +0100 syncdefaultsd subsystem: com.apple.securityd, category: trustSettingsEval, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.718834 +0100 syncdefaultsd subsystem: com.apple.securityd, category: codedir, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.719407 +0100 syncdefaultsd subsystem: com.apple.securityd, category: staticCode, enable_level: 0, persist_level: 0, default_ttl: 0, info_ttl: 0, debug_ttl: 0, generate_symptoms: 0, enable_oversize: 0, privacy_setting: 2, enable_private_data: 0
default 09:35:42.722697 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.722764 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.722847 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.722935 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.727174 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.728821 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.728887 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.728946 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.729002 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.733540 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.734499 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.734574 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.734639 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.734698 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.735404 +0100 syncdefaultsd UNIX error exception: 2
default 09:35:42.735452 +0100 syncdefaultsd MacOS error: -67068
default 09:35:42.738525 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.739355 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.739409 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.739502 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.739571 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.743914 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.745028 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.745083 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.745166 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.745262 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.749433 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.750530 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.750586 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.750667 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.750731 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.754783 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.755966 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.756016 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.756069 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.756161 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.760834 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.762150 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.762205 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.762289 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.762382 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.765463 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.766202 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.766257 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.766337 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.766399 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.769106 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.769868 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.769973 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.770058 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.770119 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.773449 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.774192 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.774245 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.774324 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.774387 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.778208 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.778980 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.779036 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.779125 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.779191 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.781944 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.782639 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.782693 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.782775 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.782869 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.786056 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.786747 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.786801 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.786879 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.786941 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.789865 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.790551 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.790606 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.790684 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.790747 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.793725 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.794433 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.794489 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.794567 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.794630 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.797769 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.798505 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.798560 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.798642 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.798736 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.801770 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.802553 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.802601 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.802659 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.802717 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.805758 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.806633 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.806687 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.806753 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.806835 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.811623 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.812978 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.813042 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.813119 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.813185 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.816665 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.817410 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.817465 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.817547 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.817641 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.820775 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.822026 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.822083 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.822156 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.822220 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.829365 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.830941 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.831008 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.831060 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.831111 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.835558 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.836833 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.836891 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.836933 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.836980 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.842165 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.843269 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.843329 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.843369 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.843412 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.848686 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.849952 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.850007 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.850051 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.850087 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.853855 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.855017 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.855075 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.855114 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.855153 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.858655 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.859373 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.859428 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.859467 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.859498 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.862544 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.863262 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.863317 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.863377 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.863436 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.866610 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:42.867335 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.867392 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.867474 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:42.867542 +0100 syncdefaultsd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:43.440062 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:43.457133 +0100 parentalcontrolsd main [157:] -- <private>
default 09:35:43.459203 +0100 parentalcontrolsd main [175:] -- <private>
default 09:35:43.463166 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:43.463886 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:43.463984 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:43.464061 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:43.464125 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:43.464400 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:43.464466 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:43.464533 +0100 authd MacOS error: -67050
default 09:35:43.469050 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:43.469767 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:43.469899 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:43.475130 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:43.476058 +0100 parentalcontrolsd -[ActivityTracker userLoggedIn] [1135:<private>] -- <private>
default 09:35:43.476221 +0100 parentalcontrolsd -[ActivityTracker userLoggedIn] [1147:<private>] -- <private>
default 09:35:43.476903 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:43.477369 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:43.477506 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:43.479693 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:43.480358 +0100 parentalcontrolsd -[ActivityTracker checkUserLogin:] [736:<private>] -- <private>
default 09:35:43.734836 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:43.735221 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 20, EGID: 20
default 09:35:43.735863 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:43.744158 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.119600 +0100 kernel IOConsoleUsers: time(0) 0->0, lin 1, llk 0,
default 09:35:45.119618 +0100 kernel IOConsoleUsers: gIOScreenLockState 1, hs 0, bs 0, now 0, sm 0x0
default 09:35:45.135647 +0100 com.apple.preferences.icloud.remoteservice Calling completion on basic login UI instance for username <private>
default 09:35:45.136193 +0100 akd Successfully obtained password. Time for SRP auth.
error 09:35:45.137394 +0100 accountsd "Failed to get an NSManagedObjectID for account type (null)"
error 09:35:45.137616 +0100 akd "Error returned from daemon: <private>"
error 09:35:45.138385 +0100 accountsd "Failed to get an NSManagedObjectID for account type (null)"
error 09:35:45.138565 +0100 akd "Error returned from daemon: <private>"
default 09:35:45.138636 +0100 akd Creating new AK account for Apple ID: <private>
default 09:35:45.139410 +0100 akd Context eligibility for piggybacking: YES
default 09:35:45.139688 +0100 secd DeviceInCircle: akd[398] lacks entitlement keychain-cloud-circle
default 09:35:45.139777 +0100 secd Starting as:non-member v:null
default 09:35:45.139923 +0100 secd Finished as:non-member v:null
error 09:35:45.140072 +0100 akd Failed to check circle status: <private>
default 09:35:45.140248 +0100 akd ApplePushService: <APSConnection: 0x7ffc7560d100> asked for publicToken, got <e7190ac0 690df463 539887ef 7250f792 4cf23ab6 0a2ca28c c99e6039 7bc10081>
default 09:35:45.140352 +0100 akd Skipping waiting for push token with connection: <private>
default 09:35:45.140498 +0100 akd Client is eligible for piggybacking: YES
default 09:35:45.141620 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.141773 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.142053 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.146133 +0100 akd Client has indicated that we should offer HSA 2.0 upgrade.
default 09:35:45.146181 +0100 akd Password available. Will ask for bootstrap password-based auth.
default 09:35:45.146521 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.146641 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.146915 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.150851 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.150955 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.151195 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.155245 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.155993 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.156481 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.156649 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.156739 +0100 akd User is member of local group
default 09:35:45.156780 +0100 akd User belongs to local, checking passcode
default 09:35:45.157095 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.157200 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.157423 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.161851 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.161955 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.164006 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.164103 +0100 opendirectoryd finding record to do authentication
default 09:35:45.164246 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.295806 +0100 com.apple.AccountPolicyHelper (91.24.2) AuthenticationAllowed completed: record "GL-HansaWorld", result: Success (0).
default 09:35:45.296036 +0100 opendirectoryd Verify password result: 5000
default 09:35:45.296094 +0100 opendirectoryd ODRecordVerifyPassword failed with error 'Invalid credentials' (5000)
default 09:35:45.296246 +0100 akd Sending prkgen: YES
default 09:35:45.296301 +0100 akd The client indicated support for ckgen: YES
error 09:35:45.297128 +0100 accountsd "Failed to get an NSManagedObjectID for account type (null)"
error 09:35:45.297291 +0100 akd "Error returned from daemon: <private>"
error 09:35:45.297349 +0100 akd Nil account cannot possibly have a password-reset-token-backup token!
default 09:35:45.297401 +0100 akd Require escrow PRK: YES
default 09:35:45.297442 +0100 akd Will ask for ckgen.
default 09:35:45.299575 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.299684 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.299921 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:45.306356 +0100 akd SendRequestAndCreateResponse: submissing a request to: <private>
default 09:35:45.307057 +0100 akd UNIX error exception: 17
default 09:35:45.307136 +0100 akd 0x7ffc75655330 opened /private/var/db/mds/system/mdsDirectory.db: 50744 bytes
default 09:35:45.307215 +0100 akd 0x7ffc75655330 closed /private/var/db/mds/system/mdsDirectory.db
default 09:35:45.307374 +0100 akd UNIX error exception: 17
default 09:35:45.307496 +0100 akd 0x7ffc75438640 opened /Users/GL-HansaWorld/Library/Keychains/login.keychain-db: 71632 bytes
default 09:35:45.307606 +0100 akd 0x7ffc75438640 closed /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:45.309029 +0100 akd loading /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:45.310923 +0100 akd 0x7ffc755534c0 opened /Library/Keychains/System.keychain: 53476 bytes
default 09:35:45.310990 +0100 akd 0x7ffc755534c0 closed /Library/Keychains/System.keychain
default 09:35:45.312275 +0100 akd loading /Library/Keychains/System.keychain
default 09:35:45.314678 +0100 akd TIC TCP Conn Start [3:0x7ffc755845e0]
default 09:35:45.517021 +0100 akd TIC TCP Conn Event [3:0x7ffc755845e0]: 1 Err(0)
default 09:35:45.517075 +0100 akd TIC TCP Conn Connected [3:0x7ffc755845e0]: Err(0)
default 09:35:45.517252 +0100 akd TIC Enabling TLS [3:0x7ffc755845e0]
default 09:35:45.680647 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:45.716549 +0100 akd TIC TLS Event [3:0x7ffc755845e0]: 2, Pending(0)
default 09:35:45.717845 +0100 akd TIC TLS Event [3:0x7ffc755845e0]: 20, Pending(0)
default 09:35:45.718390 +0100 akd TIC TCP Conn Event [3:0x7ffc755845e0]: 8 Err(0)
default 09:35:45.718442 +0100 akd TIC TLS Handshake Complete [3:0x7ffc755845e0]
default 09:35:45.956551 +0100 akd -[AIASSession URLSession:dataTask:didReceiveData:]: <private> got more data: 1218 bytes
default 09:35:45.956929 +0100 akd -[AIASSession URLSession:task:didCompleteWithError:]: <private>: (null)
default 09:35:45.957223 +0100 akd SendRequestAndCreateResponse: completed request <private>
default 09:35:45.973835 +0100 gamed GKClientProxy: clientForBundleID:
default 09:35:45.974305 +0100 gamed GKClientProxy: updateIfRecentlyInstalled
default 09:35:45.975493 +0100 gamed GKClientProxy: clientForBundleID:
default 09:35:45.975772 +0100 gamed GKClientProxy: updateIfRecentlyInstalled
default 09:35:45.975837 +0100 gamed GKClientProxy: clientForBundleID:
default 09:35:45.975971 +0100 gamed GKClientProxy: updateIfRecentlyInstalled
default 09:35:45.996644 +0100 akd SendRequestAndCreateResponse: submissing a request to: <private>
default 09:35:46.004444 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:46.686324 +0100 akd -[AIASSession URLSession:dataTask:didReceiveData:]: <private> got more data: 5190 bytes
default 09:35:46.686570 +0100 akd -[AIASSession URLSession:dataTask:didReceiveData:]: <private> got more data: 3729 bytes
default 09:35:46.686796 +0100 akd -[AIASSession URLSession:task:didCompleteWithError:]: <private>: (null)
default 09:35:46.687641 +0100 akd SendRequestAndCreateResponse: completed request <private>
error 09:35:46.688424 +0100 akd Invalid/missing value for key alias: (null)
default 09:35:46.688608 +0100 akd Successfully obtained new CK from SRP
default 09:35:46.688651 +0100 akd Successfully obtained new PRK from SRP
default 09:35:46.688697 +0100 akd Success!
default 09:35:46.688785 +0100 akd Passing PET, not password.
default 09:35:46.689259 +0100 akd Providing raw password to an internal client.
default 09:35:46.689618 +0100 akd Providing PRK to an internal client.
default 09:35:46.690109 +0100 com.apple.preferences.icloud.remoteservice Calling delegate...
default 09:35:46.695173 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:46.696181 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.696242 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.696487 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: Previously performed ACAccount lookup for user=lopes@hansaworld.com (nothing found)
default 09:35:46.696757 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.696889 +0100 com.apple.iCloudHelper 0x7fde887079b0 opened /private/var/db/mds/system/mdsDirectory.db: 50744 bytes
default 09:35:46.696955 +0100 com.apple.iCloudHelper 0x7fde887079b0 closed /private/var/db/mds/system/mdsDirectory.db
default 09:35:46.697138 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.697317 +0100 com.apple.iCloudHelper 0x7fde8853b900 opened /Users/GL-HansaWorld/Library/Keychains/login.keychain-db: 71632 bytes
default 09:35:46.697384 +0100 com.apple.iCloudHelper 0x7fde8853b900 closed /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.698923 +0100 com.apple.iCloudHelper loading /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.701023 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: No stored info found for user=lopes@hansaworld.com (acct=0x8851a670)
default 09:35:46.704343 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:46.705178 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.705241 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.705482 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: Previously performed ACAccount lookup for user=lopes@hansaworld.com (nothing found)
default 09:35:46.705685 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.705846 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.705962 +0100 com.apple.iCloudHelper 0x7fde884086f0 opened /Users/GL-HansaWorld/Library/Keychains/login.keychain-db: 71632 bytes
default 09:35:46.706057 +0100 com.apple.iCloudHelper 0x7fde884086f0 closed /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.707171 +0100 com.apple.iCloudHelper loading /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.709095 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: No stored info found for user=lopes@hansaworld.com (acct=0x8841c440)
default 09:35:46.712888 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:46.713925 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.714017 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.714273 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: Previously performed ACAccount lookup for user=lopes@hansaworld.com (nothing found)
default 09:35:46.714526 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.714759 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.714899 +0100 com.apple.iCloudHelper 0x7fde8840fe80 opened /Users/GL-HansaWorld/Library/Keychains/login.keychain-db: 71632 bytes
default 09:35:46.714971 +0100 com.apple.iCloudHelper 0x7fde8840fe80 closed /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.715440 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:46.716928 +0100 com.apple.iCloudHelper loading /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.717081 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.717155 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.717506 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: Previously performed ACAccount lookup for user=lopes@hansaworld.com (nothing found)
default 09:35:46.719079 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: No stored info found for user=lopes@hansaworld.com (acct=0x88629a70)
default 09:35:46.719508 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: No stored info found for user=lopes@hansaworld.com (acct=0x8854c920)
default 09:35:46.719786 +0100 com.apple.iCloudHelper AOSKit WARN: In authStringForAccount: (lopes@hansaworld.com), no locally cached info found...
default 09:35:46.719988 +0100 com.apple.iCloudHelper AOSKit WARN: (lopes@hansaworld.com) In photo retrieval request, missing required info (numAuthHeaders=0, url=https://setup.icloud.com/setup/account/getPhoto)
error 09:35:46.720390 +0100 com.apple.preferences.icloud.remoteservice [AOSAccounts] : [MMCopyMeCardImageFromiCloud] : error from _AOSAccountRetrieveMeCardImage Error Domain=AOSErrorDomain Code=1000 "(null)"
default 09:35:46.723057 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:46.724094 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.724173 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.724413 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: Previously performed ACAccount lookup for user=lopes@hansaworld.com (nothing found)
default 09:35:46.724650 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.724827 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.724960 +0100 com.apple.iCloudHelper 0x7fde8862bbe0 opened /Users/GL-HansaWorld/Library/Keychains/login.keychain-db: 71632 bytes
default 09:35:46.725028 +0100 com.apple.iCloudHelper 0x7fde8862bbe0 closed /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.726255 +0100 com.apple.iCloudHelper loading /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.728551 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: No stored info found for user=lopes@hansaworld.com (acct=0x88629d00)
error 09:35:46.730185 +0100 accountsd "<private> is trying to verify account credentials for account: <private>"
error 09:35:46.730323 +0100 accountsd "ACDAuthenticationPluginManager: an authentication plugin of class (null) for auth type (null) could not be instantiated! Load Error: (null)"
error 09:35:46.730367 +0100 accountsd "No auth plugin to verify credentials for accounts of type (null)"
error 09:35:46.730602 +0100 com.apple.preferences.icloud.remoteservice [AOSAccounts] : [__AuthenticateACAccount_block_invoke_2] : Verification failed: Error Domain=com.apple.accounts Code=4 "No auth plugin to verify credentials for accounts of type (null)" UserInfo={NSLocalizedDescription=No auth plugin to verify credentials for accounts of type (null)}.
error 09:35:46.730680 +0100 com.apple.preferences.icloud.remoteservice [AOSAccounts] : [ReportAuthErrorNotification] : AOSTransactionGetError No auth plugin to verify credentials for accounts of type (null) reason (null)
error 09:35:46.730832 +0100 com.apple.preferences.icloud.remoteservice [AOSUI] : -[MMAccountMgr signInFailed:] signin failed: info = <CFBasicHash 0x60000086cc80 [0x7fffe5556d80]>{type = mutable dict, count = 2,
entries =>
0 : <CFString 0x7fffe651e0b0 [0x7fffe5556d80]>{contents = "AccountID"} = <CFString 0x60000064d740 [0x7fffe5556d80]>{contents = "lopes@hansaworld.com"}
2 : <CFString 0x7fffe651e6b0 [0x7fffe5556d80]>{contents = "AccountError"} = <CFNumber 0x27 [0x7fffe5556d80]>{value = +0, type = kCFNumberSInt32Type}
default 09:35:46.734310 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:46.735284 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.735362 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.735611 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: Previously performed ACAccount lookup for user=lopes@hansaworld.com (nothing found)
default 09:35:46.735830 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.736112 +0100 com.apple.iCloudHelper UNIX error exception: 17
default 09:35:46.736253 +0100 com.apple.iCloudHelper 0x7fde8861c9c0 opened /Users/GL-HansaWorld/Library/Keychains/login.keychain-db: 71632 bytes
default 09:35:46.736324 +0100 com.apple.iCloudHelper 0x7fde8861c9c0 closed /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.737628 +0100 com.apple.iCloudHelper loading /Users/GL-HansaWorld/Library/Keychains/login.keychain-db
default 09:35:46.739756 +0100 com.apple.iCloudHelper AOSKit INFO: (com.apple.systempreferences/14.0) ACCT LOOKUP: No stored info found for user=lopes@hansaworld.com (acct=0x88715e80)
default 09:35:46.743651 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:46.744549 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.744612 +0100 com.apple.iCloudHelper CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:46.745235 +0100 com.apple.preferences.icloud.remoteservice Delegate says to continue? NO
error 09:35:46.745450 +0100 akd Force-failing auth, because client says to.
default 09:35:46.745518 +0100 akd Attempting to show login error: <private>
default 09:35:47.662811 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:47.807890 +0100 akd Another attempt at getting basic login info has completed!
error 09:35:47.808023 +0100 akd Something bad happened! <private>
default 09:35:47.808208 +0100 akd Cleared to end auth with context <private>.
error 09:35:47.808507 +0100 com.apple.preferences.icloud.remoteservice Remote authentication service returned an error: <private>
default 09:35:47.808771 +0100 com.apple.preferences.icloud.remoteservice Connection to akd was invalidated.
error 09:35:48.901586 +0100 com.apple.preferences.icloud.remoteservice [iCloud Pref] : Error Domain=AKAuthenticationError Code=-7034 "(null)" : AKAuthenticationErrorForcedFailure
default 09:35:49.483501 +0100 parentalcontrolsd -[ActivityTracker checkUserLogin:] [736:<private>] -- <private>
default 09:35:49.632505 +0100 CommCenter #watchdog #I Server Watchdog: checkin 35
default 09:35:49.632437 +0100 CommCenter #watchdog #I Callback Watchdog: checkin 35
default 09:35:49.639870 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
error 09:35:50.999773 +0100 com.apple.preferences.icloud.remoteservice [AOSAccounts] : [-[ACAccountStore(iCloudAccount) icaAppleAccounts]] : icaAppleAccountType returned no account type
default 09:35:50.000354 +0100 com.apple.preferences.icloud.remoteservice delegateIdentifier returning com.apple.private.ids
default 09:35:50.004163 +0100 accountsd "<private> (<private>) received"
error 09:35:50.005745 +0100 com.apple.preferences.icloud.remoteservice [AOSAccounts] : [-[ACAccountStore(iCloudAccount_Private) accountWithAccountType:userName:]] : returned nil for accountType com.apple.account.iTunesStore
error 09:35:50.006313 +0100 com.apple.preferences.icloud.remoteservice [AOSAccounts] : [-[ACAccountStore(iCloudAccount_Private) accountWithAccountType:userName:]] : returned nil for accountType com.apple.account.iTunesStore
default 09:35:50.006857 +0100 com.apple.preferences.icloud.remoteservice Request with <private>
default 09:35:50.007219 +0100 com.apple.preferences.icloud.remoteservice "The connection to ACDAccountStore was invalidated."
default 09:35:50.007971 +0100 akd Requesting clearance to begin auth with context <private>...
default 09:35:50.008158 +0100 akd Cleared to begin auth with context <private>!
default 09:35:50.008232 +0100 akd Current context does not permit non-interactive auth.
error 09:35:50.008304 +0100 akd Context did not provide a username and/or password.
default 09:35:50.008395 +0100 akd Collecting user credentials...
default 09:35:50.008455 +0100 akd -[AKAppleIDAuthenticationService _validateUsernameMatchesAltDSIDForAuthContext:] (1592) called
default 09:35:50.008507 +0100 akd No altDSID on context. Nothing to validate.
default 09:35:51.885077 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:52.138690 +0100 accountsd "Idle-exit-preventing transaction ended!"
default 09:35:53.755310 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:53.755832 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 20, EGID: 20
default 09:35:53.756496 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:53.767509 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:53.869859 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
default 09:35:54.553933 +0100 parentalcontrolsd ScheduledExit [885:] -- <private>
default 09:35:54.703845 +0100 kernel IO80211Interface::updateReport _peerManager is missing
default 09:35:55.499509 +0100 parentalcontrolsd main [157:] -- <private>
default 09:35:55.501859 +0100 parentalcontrolsd main [175:] -- <private>
default 09:35:55.506130 +0100 trustd cert[2]: AnchorTrusted =(leaf)[force]> 0
default 09:35:55.506846 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:55.506908 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:55.507007 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:55.507089 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:55.507341 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:55.507411 +0100 authd CSSM Exception: -2147411889 CSSMERR_CL_UNKNOWN_TAG
default 09:35:55.507477 +0100 authd MacOS error: -67050
default 09:35:55.512329 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:55.513075 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:55.513205 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:55.518740 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:55.519518 +0100 parentalcontrolsd -[ActivityTracker userLoggedIn] [1135:<private>] -- <private>
default 09:35:55.519650 +0100 parentalcontrolsd -[ActivityTracker userLoggedIn] [1147:<private>] -- <private>
default 09:35:55.520635 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:55.521132 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:55.521411 +0100 opendirectoryd queuing request to connection - '<private>'
default 09:35:55.523848 +0100 opendirectoryd Client: <private>, UID: 0, EUID: 0, GID: 0, EGID: 0
default 09:35:55.524539 +0100 parentalcontrolsd -[ActivityTracker checkUserLogin:] [736:<private>] -- <private>
default 09:35:56.115693 +0100 opendirectoryd Client: <private>, UID: 501, EUID: 501, GID: 20, EGID: 20
Ti ringrazio moltissimo del supporto, nel weekend potrei procedere con l'inizializzazione.faxus ha scritto: 2) Reinstalla da zero, importando i soli dati utenti
Considera che due mesi fa ti avrei risposto, dopo la beta pubblica 2, tra una settimana.faxus ha scritto:E siamo arrivati alla beta pubblica 8 di macOS Sierra 10.12.4.
Cosa mai avranno da mettere a punto che non riescono...
... Cose da pazzi, stanno lavorando da mesi e mesi su puttanate.
A parte il miglioramento di visualizzazione PDF...
