imac late 2013 beachballing e poco reattivo in generale
lampros choutos
il mio imac late 2013 21,5 con installato el capitan aggiornato risulta lento anche se la cpu non risulta impegnata
T_Pol
ciao lampros choutos.
scarica questo: http://www.etresoft.com/etrecheck" onclick="window.open(this.href);return false; e posta il risultato.
cosi vediamo come e messo il sistema operativo.
abbi pazienza, che qualcuno guarda.
lampros choutos
ho avviato etrecheck, ecco il risultatoEtreCheck version: 2.9.13 (267)
Report generated 2016-08-06 21:17:32
Runtime 1:29
Performance: Excellent
Problem: Computer is too slow
Hardware Information: ⓘ
iMac (21.5-inch, Late 2013)
iMac - model: iMac14,1
1 2,7 GHz Intel Core i5 CPU: 4-core
BANK 0/DIMM0
4 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Wireless: en1: 802.11 a/b/g/n/ac
Video Information: ⓘ
Intel Iris Pro
iMac 1920 x 1080
System Software: ⓘ
OS X El Capitan 10.11.6 (15G31) - Time since boot: about 5 hours
Disk Information: ⓘ
APPLE HDD HTS541010A9E662 disk0 : (1 TB) (Rotational)
Macintosh HD (disk0s2) / : 999.35 GB (954.82 GB free)
USB Information: ⓘ
Apple Inc. BRCM20702 Hub
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Gatekeeper: ⓘ
Kernel Extensions: ⓘ
/System/Library/Extensions
[not loaded] com.devguru.driver.SamsungComposite (1.4.31 - SDK 10.6 - 2016-07-19) [Support]
/System/Library/Extensions/ssuddrv.kext/Contents/PlugIns
[not loaded] com.devguru.driver.SamsungACMControl (1.4.31 - SDK 10.6 - 2015-03-02) [Support]
[not loaded] com.devguru.driver.SamsungACMData (1.4.31 - SDK 10.6 - 2015-03-02) [Support]
[not loaded] com.devguru.driver.SamsungMTP (1.4.31 - SDK 10.5 - 2015-03-02) [Support]
[not loaded] com.devguru.driver.SamsungSerial (1.4.31 - SDK 10.6 - 2015-03-02) [Support]
System Launch Agents: ⓘ
[not loaded] 7 Apple tasks
[loaded] 160 Apple tasks
[running] 71 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 47 Apple tasks
[loaded] 157 Apple tasks
[running] 87 Apple tasks
Launch Agents: ⓘ
[not loaded] com.maintain.PurgeInactiveMemory.plist (2016-05-18) [Support]
[not loaded] com.maintain.Restart.plist (2016-05-18) [Support]
[not loaded] com.maintain.ShutDown.plist (2016-05-18) [Support]
[running] com.maintain.SystemEvents.plist (2016-05-18) [Support]
[loaded] org.macosforge.xquartz.startx.plist (2014-08-11) [Support]
Launch Daemons: ⓘ
[loaded] com.adobe.fpsaud.plist (2016-06-29) [Support]
[not loaded] com.maintain.HideSpotlightMenuBarIcon.plist (2016-05-18) [Support]
[loaded] com.microsoft.office.licensing.helper.plist (2012-04-02) [Support]
[loaded] org.macosforge.xquartz.privileged_startx.plist (2014-08-11) [Support]
Other Apps: ⓘ
[running] com.etresoft.EtreCheck.43232
[loaded] 404 Apple tasks
[running] 175 Apple tasks
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 22.0.0.209 - SDK 10.9 (2016-07-13) [Support]
QuickTime Plugin: 7.7.3 (2016-07-19)
Flash Player: 22.0.0.209 - SDK 10.9 (2016-07-13) [Support]
PepperFlashPlayer: 22.0.0.209 - SDK 10.6 (2016-07-13) [Support]
Default Browser: 601 - SDK 10.11 (2016-07-19)
Safari Extensions: ⓘ
AdBlock - BetaFish, Inc. - https://getadblock.com" onclick="window.open(this.href);return false; (2016-05-21)
3rd Party Preference Panes: ⓘ
Flash Player (2016-06-29) [Support]
Time Machine: ⓘ
Time Machine not configured!
Top Processes by CPU: ⓘ
4% WindowServer
2% com.apple.WebKit.WebContent(3)
2% kernel_task
2% fontd
0% cloudpaird
Top Processes by Memory: ⓘ
993 MB kernel_task
639 MB com.apple.WebKit.WebContent(3)
197 MB Safari
115 MB cfprefsd(2)
90 MB mdworker(5)
Virtual Memory Information: ⓘ
3.16 GB Free RAM
4.84 GB Used RAM (1.76 GB Cached)
0 B Swap Used
Diagnostics Information: ⓘ
Aug 6, 2016, 03:37:46 PM Self test - passed
Questa accoppiata è la causa della lentezza.
APPLE HDD Rotational
Stavo per rispondere, ma già mi ha anticipato Fragrua.
Infatti con quella configurazione hardware hai buone prestazioni solo fino Mavericks.
Se vuoi essere all'altezza, metti un SSD.
Per il resto, un po' contribuiscono alla lentezza il software Samsung e Maintain.
Per altri versi accettabili
lampros choutos
Grazie per le vostre risposte, volevo poi chiedere:
mi conviene tornare al sistema operativo precedente? e posso eliminare i file che mi avete detto tramite easyfind?
lampros choutos ha scritto:... mi conviene tornare al sistema operativo precedente? ...
1) Ti conviene mettere un SSD
viewtopic.php?f=8&t=38412" onclick="window.open(this.href);return false;
2) Dovresti tornare a Mavericks
lampros choutos ha scritto:... posso eliminare i file che mi avete detto tramite easyfind?
Solo come rifinitura eventuale di disinstallazione.
Per il software Samsung devi andare sul sito da dove l'hai scaricato.
Trovare esattamente il/iprogrammi scaricati con la versione precisa e:
- consultare le FAQ
- verificare se esiste un unistaller e scaricarlo/applicarlo
- trovare l'elenco dei file installati ed eliminarli
Per Maintain fai lo stesso, anche se dovrebbe essere assai più facile
Controlla poi, con EtreCheck e EasyFind se l'operazione è stata eseguita completamente
lampros choutos
Buongiorno, dovrei aver eliminato i file legati a samsung e maintain , posto un nuovo report di etrecheck per vedere se qualcosa è cambiato.
Report generated 2016-08-08 15:28:41
Runtime 1:48
Problem: Beachballing
BANK 0/DIMM0
BANK 1/DIMM0
Intel Iris Pro
iMac 1920 x 1080
System Software: ⓘ
OS X El Capitan 10.11.6 (15G31) - Time since boot: about one hour
Disk Information: ⓘ
Macintosh HD (disk0s2) / : 999.35 GB (955.08 GB free)
USB Information: ⓘ
Gatekeeper: ⓘ
[loaded] 159 Apple tasks
[running] 72 Apple tasks
[loaded] 162 Apple tasks
[running] 82 Apple tasks
Launch Agents: ⓘ
Launch Daemons: ⓘ
Other Apps: ⓘ
[loaded] 408 Apple tasks
[running] 167 Apple tasks
Time Machine: ⓘ
2% WindowServer
1% fontd
1% kernel_task
0% cloudpaird
718 MB kernel_task
393 MB com.apple.WebKit.WebContent(2)
106 MB mdworker(6)
74 MB mds_stores
74 MB Safari
4.43 GB Free RAM
3.56 GB Used RAM (1.53 GB Cached)
0 B Swap Used
Aug 8, 2016, 01:38:00 PM Self test - passed
Sembra che hai operato bene.
Aggiorna Xquartz alla 2.7.9 se lo usi
lampros choutos
sembra essere leggermente migliorato, ma continuo a notare dei lag soprattuto nel gioco hearthstone anche a grafica bassa e risoluzione minima
che non dovrebbero essere causati da problemi di rete in quanto su un altro pc windows il gioco funziona bene.. che sia per la scheda grafica?
I giochi impegnano molto la scheda grafica.
Il disco e le risorse attive del sistema.
Per la scheda grafica puoi fare ben poco.
Puoi capire meglio con GfXCardStatus https://gfx.io" onclick="window.open(this.href);return false;
Per disco abbiamo detto che ti serve un SSD e comunque molto spazio disponibile.
Giocando, devi il più possibile non impegnare altre risorse come attività in sottofondo, plugin attivi, altri processi.
Il Mac ha un'architettura, un'organizzazione di sistema e impostazioni varie scarsamente adatte al gioco.
Sia pure online
Simone.m
Hardware Expert
Hardware Expert
Hearthstone è leggerissimo come gioco Faxus, penso che prenda più risorse qualcosa come Photoshop. Secondo me è solo lento per via dell'hard disk meccanico
PowerMac G4 dual CPU
PowerMac 6500
Allora queste sono le parole conclusive di quanto già detto più volte
lampros choutos
Salve a tutti. Innanzitutto vi ringrazio per le risposte e per i consigli che mi avete fornito, ora ho più chiara la situazione, detto questo credo che l'unica cosa che posso fare ,è andare a sostituire al più presto l'hard disk meccanico con un SSD. Saluti.
fragrua ha scritto:Questa accoppiata è la causa della lentezza.
faxus ha scritto:Stavo per rispondere, ma già mi ha anticipato Fragrua.
Riprendo questa discussione solo per togliermi una curiosità...
Da quello che scrivete, deduco che sia accertato che le versioni di OsX successive a Mavericks abbiano bisogno di più risorse e di computer più performanti per girare bene. Non è una cosa tanto strana né sbagliata a priori, non dico questo, le nuove versioni di OsX hanno evidentemente delle funzioni in più che abbisognano di computer più veloci...
Dato per scontato quanto detto sopra, comunque, non è sbagliato pensare che pure su Mac che potrebbero reggere senza problemi El Capitan, un OS più "leggero" come Mavericks giri più in scioltezza e in generale in maniera più veloce. Giusto?
Magari chi non ha bisogno di queste funzioni "nuove" (o ne sia piuttosto disinteressato, come me, tanto da non sapere nemmeno quali esse siano) potrebbe pensare che aggiornare a El Capitan per vedersi poi rallentare il Mac possa non valerne la pena...
(Colpitemi, sono pronto! :wink: :P )
