quando si spenge lo riavvio e poi prendo il log da ?Hammarby ha scritto:Posta il log e vediamo perché si spegne...
si tutto quanto fatto.faxus ha scritto:Ma anche, hai provato a reimpostare NVRAM e soprattutto SMC?
Più facilmente lo trovi raccolto sul client per i log di OS X.priore ha scritto:... prendo il log da ?...
Apr 22 17:32:25 WIN7-MAC identityservicesd[335]: <IMMacNotificationCenterManager: 0x7fac3850d7a0>: notification observer: com.apple.iChat notification: __CFNotification 0x7fac38565920 {name = _NSDoNotDisturbEnabledNotification}
Apr 22 17:32:25 WIN7-MAC identityservicesd[335]: <IMMacNotificationCenterManager: 0x7fac3850d7a0>: NC Disabled: NO
Apr 22 17:32:25 WIN7-MAC identityservicesd[335]: <IMMacNotificationCenterManager: 0x7fac3850d7a0>: DND Enabled: YES
Apr 22 17:32:25 WIN7-MAC identityservicesd[335]: <IMMacNotificationCenterManager: 0x7fac3850d7a0>: Updating enabled: NO (Topics: (
Apr 22 17:32:38 WIN7-MAC identityservicesd[335]: <IMMacNotificationCenterManager: 0x7fac3850d7a0>: notification observer: com.apple.iChat notification: __CFNotification 0x7fac3858dad0 {name = _NSDoNotDisturbDisabledNotification}
Apr 22 17:32:38 WIN7-MAC identityservicesd[335]: <IMMacNotificationCenterManager: 0x7fac3850d7a0>: NC Disabled: NO
Apr 22 17:32:38 WIN7-MAC identityservicesd[335]: <IMMacNotificationCenterManager: 0x7fac3850d7a0>: DND Enabled: NO
Apr 22 17:32:38 WIN7-MAC identityservicesd[335]: <IMMacNotificationCenterManager: 0x7fac3850d7a0>: Updating enabled: YES (Topics: (
Apr 22 17:43:17 WIN7-MAC com.apple.xpc.launchd[1] (com.apple.WebKit.WebContent.8C732179-0401-4B8E-8D59-68FB813CE1F1[355]): Service exited with abnormal code: 1
Apr 22 17:43:28 WIN7-MAC nsurlstoraged[895]: realpath() returned NULL for /var/root/Library/Caches/ocspd
Apr 22 17:43:28 WIN7-MAC nsurlstoraged[895]: The read-connection to the DB=/var/root/Library/Caches/ocspd/Cache.db is NOT valid. Unable to determine schema version.
Apr 22 17:43:29 --- last message repeated 1 time ---
Apr 22 17:43:28 WIN7-MAC nsurlstoraged[895]: ERROR: unable to determine file-system usage for FS-backed cache at /var/root/Library/Caches/ocspd/fsCachedData. Errno=13
Apr 22 17:44:03 WIN7-MAC locationd[276]: Location icon should now be in state 'Active'
Apr 22 17:44:04 WIN7-MAC locationd[276]: NETWORK: requery, 0, 0, 0, 0, 7, items, fQueryRetries, 0, fLastRetryTimestamp, 514565509.7
Apr 22 17:44:05 WIN7-MAC locationd[276]: Location icon should now be in state 'Inactive'
Apr 22 17:44:40 WIN7-MAC networkd[188]: -[NETClientConnection scrubParametersForEntitlements:] client com.apple.WebKi.351 setting source application without entitlement
Apr 22 17:45:10 --- last message repeated 14 times ---
Apr 22 17:45:10 WIN7-MAC networkd[188]: -[NETClientConnection scrubParametersForEntitlements:] client com.apple.WebKi.351 setting source application without entitlement
Apr 22 17:45:40 --- last message repeated 11 times ---
Apr 22 17:45:40 WIN7-MAC networkd[188]: -[NETClientConnection scrubParametersForEntitlements:] client com.apple.WebKi.351 setting source application without entitlement
Apr 22 17:45:41 WIN7-MAC networkd[188]: -[NETClientConnection scrubParametersForEntitlements:] client com.apple.WebKi.351 setting source application without entitlement
Apr 22 17:46:12 --- last message repeated 6 times ---
Apr 22 17:47:44 WIN7-MAC nbagent[9895]: XPC Activity invoked with state=0
Apr 22 17:47:44 WIN7-MAC nbagent[9895]: XPC Activity invoked with state=2
Apr 22 17:47:44 WIN7-MAC storeaccountd[333]: AccountServiceDelegate: Accepting new connection <NSXPCConnection: 0x7ffec25cb510> connection from pid 9895 with interface <AccountServiceInterface: 0x7ffec2555860> (PID 9895)
Apr 22 17:47:45 WIN7-MAC storeaccountd[333]: ADI: {
"Accept-Ranges" = bytes;
"Cache-Control" = "max-age=14400";
Connection = "Keep-Alive";
"Content-Encoding" = gzip;
"Content-Language" = "en-us";
"Content-Length" = 166;
"Content-Type" = "application/x-apple-plist";
Date = "Sat, 22 Apr 2017 15:47:45 GMT";
Etag = "\"bc-53fe058a53700\"";
Expires = "Sat, 22 Apr 2017 19:47:45 GMT";
"Keep-Alive" = "timeout=15, max=351";
"Last-Modified" = "Thu, 27 Oct 2016 22:34:36 GMT";
Server = Apache;
Apr 22 17:47:45 WIN7-MAC sandboxd[1104] ([9896]): nbstated(9896) deny ipc-posix-shm-read-data com.apple.AppleDatabaseChanged
Apr 22 17:51:02 localhost bootlog[0]: BOOT_TIME 1492876262 0
Apr 22 17:51:05 localhost kernel[0]: Previous shutdown cause: -128
Apr 22 17:51:05 localhost kernel[0]: DSMOS has arrived
Sì, corrisponde, rientra nella genericità degli avvisipriore ha scritto:... Aprendo il Mac "per puro caso" ho visto che accendendolo c'è una "piccola scintilla" sul cavo sinistro che dalla MB va al monitor, a questo punto credo che sia quello che manda in protezione l'alimentazione e si spegne tutto, anche perché dopo lo spegnimento l'unico modo per accenderlo è staccare alimentatore e batteria e riattaccare tutto...
Un riparatore potrebbe averne facilmente una sostituzione da una carcassa per ricambi.priore ha scritto:... Ho cercato su internet questo cavo ma non si trova, credo che sarà un bel problema sostituirlo...
