Rallentamenti Finder su 10.10.5
albertocchio
Oggetto del messaggio: Rallentamenti Finder su 10.10.5
Messaggio Inviato: sab, 19 set 2015 11:08
da un po' di tempo ho questa cosa che mi prude:
su un MacPro 5.1 2010 con Yosemite 10.10.5 dopo un certo numero di operazioni nel Finder avverto dei "paurosi" rallentamenti su apertura/chiusura/copia/incolla/sposta, ecc. l'unica soluzione per ripristinare la velocità è chiudere il Finder e riaprirlo, solo che questa procedura alla seconda volta comincia a dare problemi, a volte il Finder non si riavvia neppure e devo fare logout.
i messaggi su console, quando si nota il problema, sono questi:
16/09/15 09:46:15,561	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:46:15,705	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.14 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:46:16,854	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:46:16,969	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.12 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:46:20,919	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:46:21,019	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.10 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:46:27,306	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:46:27,472	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.17 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:47:18,397	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:47:18,537	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.14 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:47:19,687	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:47:19,807	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.12 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:47:23,756	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:47:23,864	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.11 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:47:50,649	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:47:50,805	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.16 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:48:50,742	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:48:50,860	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.12 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:48:51,887	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:48:53,897	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 3.01 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:48:55,109	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:48:55,244	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.14 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:48:56,725	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:48:56,841	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.12 seconds (server forcibly re-enabled them after 1.00 seconds)
16/09/15 09:49:03,291	WindowServer[180]	disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
16/09/15 09:49:03,539	WindowServer[180]	common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.25 seconds (server forcibly re-enabled them after 1.00 seconds)
e, ad onor del vero, ho notato spesso errori del WindowServer con numerazioni differenti.
EtreCheck da un solo errore su un Daemon Adobe che ignoro, tutto il resto sembra a posto.
aggiungo che, dopo ore di intenso utilizzo, capita che a fine giornata lo spegnimento non funziona, devo fare logout e selezionare spegni.
avete qualche idea/suggerimento?
tenchiù
type expert stocasso
Zen
Oggetto del messaggio: Re: Rallentamenti Finder su 10.10.5
Messaggio Inviato: sab, 19 set 2015 12:22
Cercando l'errore su Google, le informazioni che si ricavano sono molto poche. Sembra un problema causato da più fattori e presente in più versioni di OS X, e nemmeno limitato al Finder.
A questo punto, credo bisognerà ricercare il problema usando la testa:
  • Hai installato software come TotalFinder? Il primo passo sarebbe provare a rimuoverli.
  • considera di postare l'intero log di EtreCheck: a volte permette di ricavare importanti informazioni sul sistema e i suoi software
Ultima modifica di Zen il sab, 19 set 2015 13:13, modificato 1 volta in totale.
Some people argue software should be agnostic. They say it's arrogant for developers to limit features or ignore feature requests. They say software should always be as flexible as possible.
We think that's bullshit.
albertocchio
Messaggio Inviato: sab, 19 set 2015 12:32
tanx Zen. è da un po' che gogoleggio ma non trovo niente di utile.
non ho mai usato totalfinder, forse provato una volta, a meno che non sia stato usato da uno che mi ha sostituito qualche mese fa ma ne dubito.
Etrecheck, ti assicuro, mi da due stupidi errori che so già come risolvere… lunedì provo a rifarlo.
tighine
Eco & IT Expert
Eco & IT Expert
Messaggio Inviato: sab, 19 set 2015 15:14
Stato fisico del disco?
albertocchio
Messaggio Inviato: sab, 19 set 2015 15:19
direi più che buono, è un 2TB con meno di un anno d'uso. nessun test ha rilevato problemi.
forse uno dei problemi è che [purtroppo] non ci ho messo mano solo io… non l'ho formattato, non ho installato il system… solo le app & utils è farina del mio sacco.
