imac 21.5" fine 2013 lento all'avvio e normalmente
thezippons
Apr 14 21:42:21 localhost kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
Apr 14 21:42:21 localhost kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=4 Enabled
Apr 14 21:42:21 localhost kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=6 Enabled
Apr 14 21:42:21 localhost kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=255 Disabled
Apr 14 21:42:21 localhost kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=255 Disabled
Apr 14 21:42:21 localhost kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=255 Disabled
Apr 14 21:42:21 localhost kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=255 Disabled
Apr 14 21:42:21 localhost kernel[0]: calling mpo_policy_init for TMSafetyNet
Apr 14 21:42:21 localhost kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
Apr 14 21:42:21 localhost kernel[0]: calling mpo_policy_init for AMFI
Apr 14 21:42:21 localhost kernel[0]: Security policy loaded: Apple Mobile File Integrity (AMFI)
Apr 14 21:42:21 localhost kernel[0]: calling mpo_policy_init for Sandbox
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.alf): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:21 localhost kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
Apr 14 21:42:21 localhost kernel[0]: calling mpo_policy_init for Quarantine
Apr 14 21:42:21 localhost kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
Apr 14 21:42:21 localhost kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
Apr 14 21:42:21 localhost kernel[0]: The Regents of the University of California. All rights reserved.
Apr 14 21:42:21 localhost kernel[0]: MAC Framework successfully initialized
Apr 14 21:42:21 localhost kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
Apr 14 21:42:21 localhost kernel[0]: AppleKeyStore starting (BUILT: Mar 23 2015 11:37:46)
Apr 14 21:42:21 localhost kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
Apr 14 21:42:21 localhost kernel[0]: ACPI: sleep states S3 S4 S5
Apr 14 21:42:21 localhost kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 1245
Apr 14 21:42:21 localhost kernel[0]: AppleIntelCPUPowerManagement: (built 11:31:44 Mar 23 2015) initialization complete
Apr 14 21:42:21 localhost kernel[0]: pci (build 11:38:56 Mar 23 2015), flags 0xe3000, pfm64 (36 cpu) 0xf80000000, 0x80000000
Apr 14 21:42:21 localhost kernel[0]: [ PCI configuration begin ]
Apr 14 21:42:21 localhost kernel[0]: console relocated to 0xf80020000
Apr 14 21:42:21 localhost kernel[0]: [ PCI configuration end, bridges 13, devices 16 ]
Apr 14 21:42:21 localhost kernel[0]: AppleThunderboltNHIType2::setupPowerSavings - GPE based runtime power management
Apr 14 21:42:21 localhost kernel[0]: mcache: 4 CPU(s), 64 bytes CPU cache line size
Apr 14 21:42:21 localhost kernel[0]: mbinit: done [96 MB total pool size, (64/32) split]
Apr 14 21:42:21 localhost kernel[0]: rooting via boot-uuid from /chosen: 2F5EEB6F-8DDF-3014-8819-2481B5B86CAC
Apr 14 21:42:21 localhost kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
Apr 14 21:42:21 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
Apr 14 21:42:21 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
Apr 14 21:42:21 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
Apr 14 21:42:21 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
Apr 14 21:42:21 localhost kernel[0]: AppleIntelCPUPowerManagementClient: ready
Apr 14 21:42:21 localhost kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/APPLE HDD HTS541010A9E662 Media/IOGUIDPartitionScheme/Customer@2
Apr 14 21:42:21 localhost kernel[0]: BSD root: disk0s2, major 1, minor 2
Apr 14 21:42:21 localhost kernel[0]: ARPT: 1.348995: srom rev:9
Apr 14 21:42:21 localhost kernel[0]: ARPT: 1.362616: BRCM tunables:
Apr 14 21:42:21 localhost kernel[0]: ARPT: 1.362622: pullmode[1] txringsize[ 256] txsendqsize[1024] reapmin[ 32] reapcount[ 128]
Apr 14 21:42:21 localhost kernel[0]: ARPT: 1.363049: wl0: Broadcom BCM4331, vendorID[0x14e4] BAR0[0xb1900004]
Apr 14 21:42:21 localhost kernel[0]: 7.15.166.24 (r541488)
Apr 14 21:42:21 localhost kernel[0]: hfs: mounted Macintosh HD on device root_device
Apr 14 21:42:21 localhost kernel[0]: VM Swap Subsystem is ON
Apr 14 21:42:21 localhost kernel[0]: IOKernelDebugger: registering debugger
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.AppleFileServer): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.audio.coreaudiod): Unknown key for array: seatbelt-profiles
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.auditd): The TimeOut key is no longer respected. It never did anything anyway.
Apr 14 21:42:21 localhost iconservicesagent[67]: iconservicesagent launched.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.autofsd): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.backupd-status): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.backupd.status.xpc): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.bsd.dirhelper): The TimeOut key is no longer respected. It never did anything anyway.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.cmio.AVCAssistant): ThrottleInterval set to zero. You're not that important. Ignoring.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.cmio.IIDCVideoAssistant): ThrottleInterval set to zero. You're not that important. Ignoring.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.cmio.VDCAssistant): ThrottleInterval set to zero. You're not that important. Ignoring.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.configd): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.coreduetd): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.CoreRAID): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:08 localhost com.apple.xpc.launchd[1] (com.apple.CoreRAID): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:42:21 localhost com.apple.SecurityServer[84]: Session 100000 created
Apr 14 21:42:21 localhost iconservicesagent[67]: Starting service with cache path: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.iconservices
Apr 14 21:42:21 localhost wirelessproxd[78]: updateScanner - central is not powered on: 0
Apr 14 21:42:21 localhost kernel[0]: pci pause: SDXC
Apr 14 21:42:22 localhost hidd[101]: void __IOHIDPlugInLoadBundles(): Loaded 0 HID plugins
Apr 14 21:42:22 localhost hidd[101]: ____IOHIDSessionScheduleAsync_block_invoke: thread_id=0x1094e6000
Apr 14 21:42:22 localhost hidd[101]: HID Session async scheduling initiated.
Apr 14 21:42:22 localhost hidd[101]: HID Session async root queue running at priority 63 and schedule 2.
Apr 14 21:42:22 localhost hidd[101]: HID Session async scheduling complete.
Apr 14 21:42:22 localhost hidd[101]: Successfully opened the IOHIDSession
Apr 14 21:42:23 localhost watchdogd[60]: [watchdog_daemon] @( wd_watchdog_open) - IOIteratorNext failed (kr=0)
Apr 14 21:42:23 localhost watchdogd[60]: [watchdog_daemon] @( wd_daemon_init) - could not initialize the hardware watchdog
Apr 14 21:42:23 localhost watchdogd[60]: [watchdog_daemon] @( main) - cannot initialize the watchdog service
Apr 14 21:42:23 localhost watchdogd[137]: [watchdog_daemon] @( wd_watchdog_open) - IOIteratorNext failed (kr=0)
Apr 14 21:42:23 localhost watchdogd[137]: [watchdog_daemon] @( wd_daemon_init) - could not initialize the hardware watchdog
Apr 14 21:42:23 localhost watchdogd[137]: [watchdog_daemon] @( main) - cannot initialize the watchdog service
Apr 14 21:42:23 localhost com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:42:24 localhost com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Apr 14 21:42:25 localhost com.apple.xpc.launchd[1] (com.apple.Kerberos.kdc[92]): Service exited with abnormal code: 1
Apr 14 21:42:25 localhost kdc[92]: krb5_kdc_set_dbinfo: failed to create root node: /Local/Default
Apr 14 21:42:25 localhost opendirectoryd[77]: BUG in libdispatch: 14D131 - 2004 - 0x5
Apr 14 21:42:25 localhost kdc[142]: label: default
Apr 14 21:42:25 localhost kdc[142]: dbname: od:/Local/Default
Apr 14 21:42:25 localhost kdc[142]: mkey_file: /var/db/krb5kdc/m-key
Apr 14 21:42:25 localhost kdc[142]: acl_file: /var/db/krb5kdc/kadmind.acl
Apr 14 21:42:25 localhost powerd[56]: Activity changes from 0xffff to 0x0. Assertions:1 HidState:0
Apr 14 21:42:25 localhost distnoted[108]: # distnote server daemon absolute time: 34.204012733 civil time: Tue Apr 14 21:42:25 2015 pid: 108 uid: 241 root: yes
Apr 14 21:42:25 localhost com.apple.usbmuxd[83]: usbmuxd-344.6 on Mar 16 2015 at 23:31:17, running 64 bit
Apr 14 21:42:25 localhost iconservicesd[66]: iconservicesd launched.
Apr 14 21:42:25 localhost iconservicesd[66]: Cache path: /Library/Caches/com.apple.iconservices.store
Apr 14 21:42:25 localhost kernel[0]: IOGraphics flags 0x43
Apr 14 21:42:25 localhost kernel[0]: NVDAStartup: Official
Apr 14 21:42:25 localhost configd[55]: preference: no sharing preferences
Apr 14 21:42:25 localhost kernel[0]: IOBluetoothUSBDFU::probe
Apr 14 21:42:25 localhost kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x828B FirmwareVersion - 0x0103
Apr 14 21:42:25 localhost kernel[0]: **** [IOBluetoothHostControllerUSBTransport][start] -- completed -- result = TRUE -- 0x1800 ****
Apr 14 21:42:25 localhost kernel[0]: **** [BroadcomBluetoothHostControllerUSBTransport][start] -- Completed (matched on Device) -- 0x1800 ****
Apr 14 21:42:25 localhost kernel[0]: NVDAGK100HAL loaded and registered
Apr 14 21:42:25 localhost kernel[0]: [IOBluetoothHCIController][staticBluetoothTransportShowsUp] -- Received Bluetooth Controller register service notification -- 0x1800
Apr 14 21:42:25 localhost kernel[0]: [IOBluetoothHCIController][start] -- completed
Apr 14 21:42:25 localhost kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
Apr 14 21:42:25 localhost kernel[0]: **** [IOBluetoothHCIController][ProcessBluetoothTransportShowsUpActionWL] -- Connected to the transport successfully -- 0xe480 -- 0xd000 -- 0x1800 ****
Apr 14 21:42:25 localhost kernel[0]: Previous shutdown cause: 0
Apr 14 21:42:25 localhost kernel[0]: DSMOS has arrived
Apr 14 21:42:25 localhost hidd[101]: IOHIDService compatibility thread running at priority 63 and schedule 2.
Apr 14 21:42:25 localhost kernel[0]: PPGTT is enabled
Apr 14 21:42:25 localhost kernel[0]: IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
Apr 14 21:42:25 localhost kernel[0]: IO80211Interface::efiNVRAMPublished():
Apr 14 21:42:25 localhost kernel[0]: bpfAttach len 64 dlt 12
Apr 14 21:42:25 localhost configd[55]: Wi-Fi interface detected
Apr 14 21:42:25 iMac-di-alessandro.local configd[55]: setting hostname to "iMac-di-alessandro.local"
Apr 14 21:42:25 iMac-di-alessandro.local configd[55]: network changed.
Apr 14 21:42:25 iMac-di-alessandro kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Apr 14 21:42:25 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:42:25 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:42:25 iMac-di-alessandro kernel[0]: bpfAttach len 94 dlt 163
Apr 14 21:42:25 iMac-di-alessandro kernel[0]: bpfAttach len 30 dlt 105
Apr 14 21:42:25 iMac-di-alessandro kernel[0]: bpfAttach len 52 dlt 127
Apr 14 21:42:25 iMac-di-alessandro kernel[0]: bpfAttach len 38 dlt 192
Apr 14 21:42:25 iMac-di-alessandro.local com.apple.SecurityServer[84]: Entering service
Apr 14 21:42:25 iMac-di-alessandro.local kdc[142]: WARNING Found KDC certificate (O=System Identity,CN=com.apple.kerberos.kdc)is missing the PK-INIT KDC EKU, this is bad for interoperability.
Apr 14 21:42:25 iMac-di-alessandro.local systemkeychain[149]: done file: /var/run/systemkeychaincheck.done
Apr 14 21:42:25 iMac-di-alessandro.local loginwindow[97]: Login Window Application Started
Apr 14 21:42:25 iMac-di-alessandro.local UserEventAgent[46]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Apr 14 21:42:25 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service "com.apple.ManagedClient.startup" tried to hijack endpoint "com.apple.ManagedClient.agent" from owner: com.apple.ManagedClient
Apr 14 21:42:25 iMac-di-alessandro.local thermald[52]: Waiting for OSTT support notification
Apr 14 21:42:25 iMac-di-alessandro.local digest-service[136]: label: default
Apr 14 21:42:25 iMac-di-alessandro.local digest-service[136]: dbname: od:/Local/Default
Apr 14 21:42:25 iMac-di-alessandro.local digest-service[136]: mkey_file: /var/db/krb5kdc/m-key
Apr 14 21:42:25 iMac-di-alessandro.local digest-service[136]: acl_file: /var/db/krb5kdc/kadmind.acl
Apr 14 21:42:25 iMac-di-alessandro.local UserEventAgent[46]: Captive: CNPluginHandler en1: Inactive
Apr 14 21:42:26 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Apr 14 21:42:26 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.lakitu): The JoinExistingSession key is only available to Application services.
Apr 14 21:42:26 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.accounts.dom): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:42:26 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:42:26 iMac-di-alessandro.local com.apple.kextd[49]: kext file:///System/Library/Extensions/BlackBerryVirtualPrivateNetwork.kext/ is in hash exception list, allowing to load
Apr 14 21:42:26 iMac-di-alessandro kernel[0]: RIMVirtualNetwork_start
Apr 14 21:42:26 iMac-di-alessandro kernel[0]: creating /dev/rimtun0
Apr 14 21:42:26 iMac-di-alessandro kernel[0]: RIMVPN MAC Address is 3a:bc:47:16:71:31
Apr 14 21:42:26 iMac-di-alessandro.local configd[55]: dhcp_arp_router: en1 SSID unavailable
Apr 14 21:42:26 iMac-di-alessandro.local locationd[86]: Logging binary sensor data to /var/folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/C/locationdSensors.bin
Apr 14 21:42:26 iMac-di-alessandro.local locationd[86]: Incorrect NSStringEncoding value 0x8000100 detected. Assuming NSASCIIStringEncoding. Will stop this compatiblity mapping behavior in the near future.
Apr 14 21:42:26 iMac-di-alessandro.local locationd[86]: NBB-Could not get UDID for stable refill timing, falling back on random
Apr 14 21:42:26 iMac-di-alessandro.local secinitd[165]: UID[0]: cache loaded: /System/Library/Caches/com.apple.app-sandbox-cache.plist
Apr 14 21:42:26 iMac-di-alessandro.local secinitd[165]: ctkd[164]: unable to get root path for bundle of main executable: /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Apr 14 21:42:26 iMac-di-alessandro.local digest-service[136]: digest-request: uid=0
Apr 14 21:42:26 iMac-di-alessandro.local locationd[86]: Location icon should now be in state 'Inactive'
Apr 14 21:42:26 iMac-di-alessandro.local digest-service[136]: digest-request: netr probe 0
Apr 14 21:42:26 iMac-di-alessandro.local digest-service[136]: digest-request: init request
Apr 14 21:42:26 iMac-di-alessandro.local digest-service[136]: digest-request: init return domain: BUILTIN server: IMAC-DI-ALESSANDRO indomain was: <NULL>
Apr 14 21:42:27 iMac-di-alessandro.local mdmclient[71]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:42:28 iMac-di-alessandro.local apsd[81]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
Apr 14 21:42:28 iMac-di-alessandro.local apsd[81]: Unable to bootstrap_look_up connection port 'com.apple.askpermission.aps' for user 0: Unknown service name
Apr 14 21:42:28 iMac-di-alessandro.local apsd[81]: Attempt to set push wake topics without dark wake enabled: ()
Apr 14 21:42:28 iMac-di-alessandro.local apsd[81]: <APSConnectionServer: 0x7fd089c42c40> Invalid mach port - Cleaning up this named port's topics. com.apple.askpermission.aps
Apr 14 21:42:28 iMac-di-alessandro.local findmydeviced[175]: findmydeviced has been launched
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic Sockets GetProcessNameFromSocket() failed errno[57] err[-1]
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic Sockets Unknown(-1), errno 0 UDS FD=3
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic Sockets UDS FD=3 ERROR: failed to get effective user ID, errno 0
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic SleepProxy BSP Server Disabled. Metric = 3373
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: AwdlD2d AwdlD2dInitialize: Initialized
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: D2D_IPC: Loaded
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic WABServer NetResolverEvent no resolvers, resetting domains
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic DNSResolver etc/hosts file changed: Event 0x7fd2405022e0 Flushed /etc/hosts cache
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic RemoteControl com.apple.discoveryd Starting XPC Server
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic SleepProxy Could not get the primary interface
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic RemoteControl com.apple.discoveryd.dnsproxy Starting XPC Server
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd[80]: Basic SleepProxy Sleep Proxy Server is not enabled
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd_helper[176]: Basic RemoteControl com.apple.discoveryd_helper Starting XPC Server
Apr 14 21:42:28 iMac-di-alessandro.local discoveryd_helper[176]: Detailed RemoteControl com.apple.discoveryd_helper XPC connection 0x7f9bd3f01100: start (pid=80, <unknown> not root)
Apr 14 21:42:28 iMac-di-alessandro.local configd[55]: network changed.
Apr 14 21:42:28 iMac-di-alessandro.local networkd[177]: networkd-412.20.3 pid 177
Apr 14 21:42:28 iMac-di-alessandro.local kdc[142]: KDC started
Apr 14 21:42:28 iMac-di-alessandro.local WindowServer[163]: Server is starting up
Apr 14 21:42:28 iMac-di-alessandro.local mds[62]: (FMW.Normal:1428) FMW 0 0
Apr 14 21:42:28 iMac-di-alessandro.local UserEventAgent[46]: nsurlsessiond_events plugin: adding token 1 for client softwareupdate_download_service
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: chardev_open
Apr 14 21:42:28 --- last message repeated 1 time ---
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: ARPT: 37.636921: createVirtIf(): ifRole = 1
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: AirPort_Brcm4360_P2PInterface::init name <p2p0> role 1
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: AirPort_Brcm4360_P2PInterface::init <p2p> role 1
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: setVIRTUAL_IF_CREATE: AWDL interface role (4)
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: ARPT: 37.650799: createVirtIf(): ifRole = 1
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: ARPT: 37.650810: Create AWDL virtif(AWDL): unit = 2, ifRole = 4
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: AirPort_Brcm4360_P2PInterface::init name <awdl0> role 4
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: AirPort_Brcm4360_P2PInterface::attachToBpf name <awdl0> role 4 successful attach to bpf type 147
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: AirPort_Brcm4360_P2PInterface::init <awdl> role 4
Apr 14 21:42:28 iMac-di-alessandro.local airportd[59]: airportdProcessDLILEvent: en1 attached (up)
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: AirPort: Link Up on awdl0
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::configure Dynamic country code not supported on this device
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: awdl0: promiscuous mode enable succeeded
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::getVHtCapabilityIE Unable to get vht capabilities ret 2d
Apr 14 21:42:28 iMac-di-alessandro kernel[0]: awdl0: promiscuous mode disable succeeded
Apr 14 21:42:28 iMac-di-alessandro.local blued[89]: Release the WiFi lock
Apr 14 21:42:28 iMac-di-alessandro.local blued[89]: HID Page timeout 4000
Apr 14 21:42:29 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:42:29 iMac-di-alessandro.local blued[89]: hciControllerOnline; HID devices? 2
Apr 14 21:42:29 iMac-di-alessandro.local blued[89]: Acquiring the wifi lock
Apr 14 21:42:29 iMac-di-alessandro.local blued[89]: Acquired the wifi lock
Apr 14 21:42:29 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlOperatingMode Setting the AWDL operation mode from AUTO to SUSPENDED
Apr 14 21:42:29 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlSuspendedMode() Suspending AWDL, enterQuietMode(true)
Apr 14 21:42:29 iMac-di-alessandro.local blued[89]: hostControllerOnline - Number of Paired devices = 4, List of Paired devices = (
"84-fc-fe-f2-d5-86",
"00-1d-df-4d-1f-4c",
"2c-f0-ee-36-c0-f3",
"28-cf-e9-68-12-f0"
Apr 14 21:42:29 iMac-di-alessandro.local blued[89]: link key found for device: 84-fc-fe-f2-d5-86
Apr 14 21:42:29 iMac-di-alessandro.local blued[89]: Save link key for device: 84-fc-fe-f2-d5-86
Apr 14 21:42:29 iMac-di-alessandro.local blued[89]: link key found for device: 28-cf-e9-68-12-f0
Apr 14 21:42:29 iMac-di-alessandro.local blued[89]: Save link key for device: 28-cf-e9-68-12-f0
Apr 14 21:42:29 iMac-di-alessandro kernel[0]: ARPT: 38.349845: MacAuthEvent en1 Auth result for: 02:bd:b9:e2:72:b7 MAC AUTH succeeded
Apr 14 21:42:29 iMac-di-alessandro kernel[0]: AirPort: Link Up on en1
Apr 14 21:42:29 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:42:29 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:42:29 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:42:29 iMac-di-alessandro kernel[0]: ARPT: 38.360751: AWDL Sync Enabled 0
Apr 14 21:42:31 iMac-di-alessandro.local discoveryd[80]: Basic SleepProxy Could not get the primary interface
Apr 14 21:42:31 iMac-di-alessandro.local discoveryd[80]: AwdlD2d AwdlD2dStartAdvertisingPair: 'imac-di-alessandro' Advertising service started
Apr 14 21:42:31 --- last message repeated 1 time ---
Apr 14 21:42:31 iMac-di-alessandro.local discoveryd[80]: AwdlD2d AwdlD2dStartAdvertisingPair: '874d89efff4f2c0b00000000000008efip6arpa' Advertising service started
Apr 14 21:42:31 iMac-di-alessandro kernel[0]: hfs: mounted Recovery HD on device disk0s3
Apr 14 21:42:31 iMac-di-alessandro.local fseventsd[50]: Logging disabled completely for device:1: /Volumes/Recovery HD
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothDevice::setProperties() -- calling hciController->CallCreateDeviceReporter() -- this = 0x3000
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothHCIController::CallCreateDeviceReporter -- calling enqueueAction() -- device = 0x3000
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothHCIController::CreateDeviceReporterAction -- device = = 0x3000
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothHCIController::CreateDeviceReporterAction -- calling CreateDeviceReporter() device = = 0x3000
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothHCIController::CreateDeviceReporter -- device = = 0x3000
Apr 14 21:42:33 iMac-di-alessandro.local blued[89]: Release the WiFi lock
Apr 14 21:42:33 iMac-di-alessandro.local blued[89]: Acquiring the wifi lock
Apr 14 21:42:33 iMac-di-alessandro.local blued[89]: Acquired the wifi lock
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: [BNBMouseDevice::init][85.3] init is complete
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: [BNBMouseDevice::handleStart][85.3] returning 1
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: [AppleMultitouchHIDEventDriver::start] entered
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothDevice::setProperties() -- calling hciController->CallCreateDeviceReporter() -- this = 0x7c00
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothHCIController::CallCreateDeviceReporter -- calling enqueueAction() -- device = 0x7c00
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothHCIController::CreateDeviceReporterAction -- device = = 0x7c00
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothHCIController::CreateDeviceReporterAction -- calling CreateDeviceReporter() device = = 0x7c00
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: IOBluetoothHCIController::CreateDeviceReporter -- device = = 0x7c00
Apr 14 21:42:33 iMac-di-alessandro kernel[0]: [AppleMultitouchDevice::start] entered
Apr 14 21:42:33 iMac-di-alessandro.local blued[89]: [setFeatureWithReportID] Could not set report
Apr 14 21:42:35 iMac-di-alessandro.local stackshot[95]: Timed out waiting for IOKit to finish matching.
Apr 14 21:42:38 iMac-di-alessandro.local apsd[81]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
Apr 14 21:42:38 iMac-di-alessandro.local BBDaemon[73]: WARNING: The sun_len field of a sockaddr_un structure passed to CFSocketSetAddress was not set correctly using the SUN_LEN macro.
Apr 14 21:42:38 --- last message repeated 2 times ---
Apr 14 21:42:38 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dpd[188]): Service exited with abnormal code: 75
Apr 14 21:42:39 iMac-di-alessandro.local blued[89]: Logging disabled
Apr 14 21:42:39 iMac-di-alessandro kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Apr 14 21:42:39 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:42:39 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
thezippons
Apr 14 21:42:39 iMac-di-alessandro kernel[0]: ARPT: 48.416611: AWDL Sync Enabled 0
Apr 14 21:42:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:42:40 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Warning: IPv6 listener multicast send failed en1, 49
Apr 14 21:42:41 --- last message repeated 8 times ---
Apr 14 21:42:41 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour stop listening on en1
Apr 14 21:42:42 iMac-di-alessandro kernel[0]: IOPPF: AppleIntelCPUPowerManagement mode
Apr 14 21:42:42 iMac-di-alessandro kernel[0]: [AGPM Controller] build GPUDict by Vendor10deDevice0fd8
Apr 14 21:42:42 iMac-di-alessandro kernel[0]: X86PlatformShim::sendPStates - Success!
Apr 14 21:42:42 --- last message repeated 3 times ---
Apr 14 21:42:42 iMac-di-alessandro kernel[0]: X86PlatformShim::sendStepper - Done!
Apr 14 21:42:42 iMac-di-alessandro.local WindowServer[163]: Session 257 retained (2 references)
Apr 14 21:42:42 iMac-di-alessandro.local WindowServer[163]: Session 257 released (1 references)
Apr 14 21:42:42 iMac-di-alessandro kernel[0]: en2: promiscuous mode enable succeeded
Apr 14 21:42:42 iMac-di-alessandro kernel[0]: en3: promiscuous mode enable succeeded
Apr 14 21:42:42 iMac-di-alessandro.local WindowServer[163]: init_page_flip: page flip mode is on
Apr 14 21:42:42 iMac-di-alessandro kernel[0]: en1: 802.11d country code set to 'IT'.
Apr 14 21:42:42 iMac-di-alessandro kernel[0]: en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
Apr 14 21:42:42 iMac-di-alessandro.local WindowServer[163]: Found 30 modes for display 0x00000000 [30, 0]
Apr 14 21:42:42 iMac-di-alessandro.local WindowServer[163]: Found 1 modes for display 0x00000000 [1, 0]
Apr 14 21:42:42 --- last message repeated 1 time ---
Apr 14 21:42:42 iMac-di-alessandro.local WindowServer[163]: mux_initialize: Couldn't find any matches
Apr 14 21:42:43 --- last message repeated 1 time ---
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: WSMachineUsesNewStyleMirroring: true
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x04280480: GL mask 0x1; bounds (0, 0)[1920 x 1080], 30 modes available
Main, Active, on-line, enabled, built-in, boot, Vendor 610, Model a012, S/N 0, Unit 0, Rotation 0
UUID 0x2838c3dda39478c14a5e57649bbc5643
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x003f003f: GL mask 0x8; bounds (0, 0)[4096 x 2160], 2 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 3, Rotation 0
UUID 0xffffffffffffffffffffffffffffffff
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 2, Rotation 0
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Set a breakpoint at CGSLogError to catch errors as they are logged.
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: WSSetWindowTransform: Singular matrix
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x003f003f: GL mask 0x8; bounds (2944, 0)[1 x 1], 2 modes available
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x003f003e: GL mask 0x4; bounds (2945, 0)[1 x 1], 1 modes available
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x003f003d: GL mask 0x2; bounds (2946, 0)[1 x 1], 1 modes available
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: CGXPerformInitialDisplayConfiguration
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x04280480: Unit 0; Vendor 0x610 Model 0xa012 S/N 0 Dimensions 18.70 x 10.51; online enabled built-in, Bounds (0,0)[1920 x 1080], Rotation 0, Resolution 1
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x003f003f: Unit 3; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2944,0)[1 x 1], Rotation 0, Resolution 1
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x003f003e: Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2945,0)[1 x 1], Rotation 0, Resolution 1
Apr 14 21:42:43 iMac-di-alessandro.local WindowServer[163]: Display 0x003f003d: Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2946,0)[1 x 1], Rotation 0, Resolution 1
Apr 14 21:42:44 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:44 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Apr 14 21:42:44 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Apr 14 21:42:44 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Apr 14 21:42:44 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:42:44 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Apr 14 21:42:44 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Apr 14 21:42:44 iMac-di-alessandro.local WindowServer[163]: GLCompositor: GL renderer id 0x01022727, GL mask 0x0000000f, accelerator 0x00003fab, unit 0, caps QEX|MIPMAP, vram 512 MB
Apr 14 21:42:44 iMac-di-alessandro.local WindowServer[163]: GLCompositor: GL renderer id 0x01022727, GL mask 0x0000000f, texture max 16384, viewport max {16384, 16384}, extensions NPOT|GLSL|FLOAT
Apr 14 21:42:44 iMac-di-alessandro.local WindowServer[163]: GLCompositor enabled for tile size [256 x 256]
Apr 14 21:42:44 iMac-di-alessandro.local WindowServer[163]: CGXGLInitMipMap: mip map mode is on
Apr 14 21:42:45 iMac-di-alessandro kernel[0]: ARPT: 54.164110: MacAuthEvent en1 Auth result for: 02:bd:b9:e2:72:b7 MAC AUTH succeeded
Apr 14 21:42:45 iMac-di-alessandro kernel[0]: AirPort: Link Up on en1
Apr 14 21:42:45 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:42:45 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:42:45 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:42:45 iMac-di-alessandro kernel[0]: ARPT: 54.172700: AWDL Sync Enabled 0
Apr 14 21:42:45 iMac-di-alessandro.local WindowServer[163]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -discovery
Apr 14 21:42:47 iMac-di-alessandro.local WindowServer[163]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04280480 device: 0x7f97d2e07150 isBackBuffered: 1 numComp: 3 numDisp: 3
Apr 14 21:42:47 iMac-di-alessandro.local WindowServer[163]: _CGXGLDisplayContextForDisplayDevice: acquired display context (0x7f97d2e07150) - enabling OpenGL
Apr 14 21:42:48 iMac-di-alessandro.local com.apple.AmbientDisplayAgent[207]: AmbientDisplayAgent started
Apr 14 21:42:48 iMac-di-alessandro.local com.apple.AmbientDisplayAgent[207]: AMBD initializing devices
Apr 14 21:42:48 iMac-di-alessandro.local WindowServer[163]: CGXSetDisplayColorProfileAndTransfer: Display 0x04280480: Unit 0; ColorProfile { 362476056 }; TransferFormula (1.000000, 1.000000, 1.000000)
Apr 14 21:42:48 iMac-di-alessandro.local com.apple.AmbientDisplayAgent[207]: AMBD Agent: xpc connection became invalid during event handler
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.btsa): This key does not do anything: OnDemand
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.coreservices.lsactivity): Unknown key for Boolean: DrainMessagesAfterFailedInit
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.helpd): This key does not do anything: OnDemand
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This key does not do anything: OnDemand
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.UserEventAgent-LoginWindow): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:42:48 iMac-di-alessandro PowerChime[213]: objc[213]: Class BUIPowerSource is implemented in both /System/Library/PrivateFrameworks/BatteryUIKit.framework/Versions/A/BatteryUIKit and /System/Library/CoreServices/PowerChime.app/Contents/MacOS/PowerChime. One of the two will be used. Which one is undefined.
Apr 14 21:42:48 iMac-di-alessandro.local PowerChime[213]: PowerChime: chime enabled by hardware: 0
Apr 14 21:42:48 iMac-di-alessandro.local PowerChime[213]: PowerChime disabled - ChimeOnNoHardware default: 0
Apr 14 21:42:48 iMac-di-alessandro askpermissiond[209]: objc[209]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Apr 14 21:42:48 iMac-di-alessandro.local DMProxy[205]: AMBD Services: connection interrupted: com.apple.AmbientDisplayAgent (Connection interrupted)
Apr 14 21:42:48 iMac-di-alessandro.local com.apple.SecurityServer[84]: Session 100005 created
Apr 14 21:42:48 iMac-di-alessandro.local askpermissiond[209]: StoreTransport: Resetting APS Connection using environment name production
Apr 14 21:42:48 iMac-di-alessandro.local apsd[81]: Unable to bootstrap_look_up connection port 'com.apple.askpermission.aps' for user 0: Unknown service name
Apr 14 21:42:48 iMac-di-alessandro.local discoveryd[80]: Basic SleepProxy Could not get the primary interface
Apr 14 21:42:48 iMac-di-alessandro.local UserEventAgent[215]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Apr 14 21:42:48 iMac-di-alessandro.local UserEventAgent[215]: user agent networkd: built Feb 12 2015 17:21:33
Apr 14 21:42:49 iMac-di-alessandro.local WiFiAgent[216]: [NO client logger] <Sep 9 2014 16:12:26> WIFICLOUDSYNC WiFiCloudSyncEngineCreate: created...
Apr 14 21:42:49 iMac-di-alessandro.local WiFiAgent[216]: [NO client logger] <Sep 9 2014 16:12:26> WIFICLOUDSYNC WiFiCloudSyncEngineRegisterCallbacks: WiFiCloudSyncEngineCallbacks version - 0, bundle id - com.apple.wifi.WiFiAgent
Apr 14 21:42:49 iMac-di-alessandro.local WiFiAgent[216]: securityd_message_with_reply_sync Failed to talk to secd after 4 attempts.
Apr 14 21:42:49 iMac-di-alessandro.local loginwindow[97]: Setting the initial value of the magsave brightness level 1
Apr 14 21:42:49 iMac-di-alessandro.local com.apple.AmbientDisplayAgent[207]: AMBD Agent: xpc connection became invalid during event handler
Apr 14 21:42:50 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ReportCrash.Root[220]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash.DirectoryService
Apr 14 21:42:50 iMac-di-alessandro.local lsregister[179]: LaunchServices: Begin database seeding
Apr 14 21:42:50 iMac-di-alessandro.local lsregister[179]: LaunchServices: Completed database seeding
Apr 14 21:42:50 iMac-di-alessandro.local loginwindow[97]: The current system was not found in the list of machines requiring a switch to a black background
Apr 14 21:42:50 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Apr 14 21:42:50 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Apr 14 21:42:50 iMac-di-alessandro.local loginwindow[97]: Login Window Started Security Agent
Apr 14 21:42:51 iMac-di-alessandro.local ReportCrash[220]: Invalid connection: com.apple.coresymbolicationd
Apr 14 21:42:54 iMac-di-alessandro.local mds[62]: (Volume.Normal:2464) volume:0x7f844d851800 ********** Bootstrapped Creating a default store:0 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/Recovery HD
Apr 14 21:42:54 iMac-di-alessandro kernel[0]: hfs: unmount initiated on Recovery HD on device disk0s3
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: en1: 802.11d country code set to 'X3'.
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: ARPT: 64.244914: AWDL Sync Enabled 0
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: ARPT: 64.627471: MacAuthEvent en1 Auth result for: 02:bd:b9:e2:72:b7 MAC AUTH succeeded
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: AirPort: Link Up on en1
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:42:55 iMac-di-alessandro kernel[0]: ARPT: 64.635966: AWDL Sync Enabled 0
Apr 14 21:42:58 iMac-di-alessandro.local _nsurlsessiond[226]: /usr/libexec/ntpd-wrapper: scutil key State:/Network/Global/DNS not present after 30 seconds
Apr 14 21:42:58 iMac-di-alessandro.local _nsurlsessiond[229]: Unable to resolve hostname(s)
Apr 14 21:42:58 iMac-di-alessandro.local ntpd[185]: drift PPM:0.000 -> -78.076
Apr 14 21:42:58 iMac-di-alessandro.local mds[62]: (Server.Warning:445) No stores registered for metascope "kMDQueryScopeComputer"
Apr 14 21:42:59 iMac-di-alessandro.local nsurlstoraged[232]: realpath() returned NULL for /var/root/Library/Caches/$(CFBundleIdentifier)
Apr 14 21:42:59 iMac-di-alessandro.local nsurlstoraged[232]: The read-connection to the DB=/var/root/Library/Caches/$(CFBundleIdentifier)/Cache.db is NOT valid. Unable to determine schema version.
Apr 14 21:42:59 --- last message repeated 1 time ---
Apr 14 21:42:59 iMac-di-alessandro.local nsurlstoraged[232]: ERROR: unable to determine file-system usage for FS-backed cache at /var/root/Library/Caches/$(CFBundleIdentifier)/fsCachedData. Errno=13
Apr 14 21:42:59 iMac-di-alessandro.local SecurityAgent[222]: This is the first run
Apr 14 21:42:59 iMac-di-alessandro.local SecurityAgent[222]: MacBuddy was run = 0
Apr 14 21:42:59 iMac-di-alessandro.local AppleIDAuthAgent[210]: AOSKit ERROR: Config request failed, url=https://setup.icloud.com/configurations/init, requestHeaders=
"Accept-Language" = "it-it";
"X-Mme-Client-Info" = "<iMac13,1> <Mac OS X;10.10.3;14D131> <com.apple.AOSKit/217>";
"X-Mme-Country" = US;
"X-Mme-Device-Id" = "CEA63987-B9E0-5691-A32E-A3553A9D8C59";
"X-Mme-Nac-Version" = 11A457;
"X-Mme-Setup-FCE048DE-F34F-4FAF-A6DD-6C8AC9DF0C54" = true;
"X-Mme-Timezone" = "GMT+2";
error=Error Domain=kCFErrorDomainCFNetwork Code=-1009 "The Internet connection appears to be offline." UserInfo=0x7fa85964cf90 {NSErrorFailingURLStringKey=https://setup.icloud.com/configurations/init, NSErrorFailingURLKey=https://setup.icloud.com/configurations/init, _kCFStreamErrorCodeKey=8, _kCFStreamErrorDomainKey=12, NSLocalizedDescription=The Internet connection appears to be offline.}, httpStatusCode=-1, responseHeaders=
(null)
Apr 14 21:42:59 iMac-di-alessandro.local AppleIDAuthAgent[210]: AppleIdAuth URL Error: Error Domain=AOSErrorDomain Code=1000 "The operation couldn’t be completed. (AOSErrorDomain error 1000.)"
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/SandboxedServiceRunner.xpc/Contents/MacOS/SandboxedServiceRunner error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/SecurityAgent.xpc
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/XPCServices/com.apple.SpeechRecognitionCore.brokerd.xpc/Contents/MacOS/com.apple.SpeechRecognitionCore.brokerd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/SecurityAgent.xpc
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/XPCServices/DataDetectorsDynamicData.xpc/Contents/MacOS/DataDetectorsDynamicData error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/SecurityAgent.xpc
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCTimeStampingService.xpc/Contents/MacOS/XPCTimeStampingService error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/SecurityAgent.xpc
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/com.apple.DictionaryServiceHelper error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/SecurityAgent.xpc
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCKeychainSandboxCheck.xpc/Contents/MacOS/XPCKeychainSandboxCheck error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/SecurityAgent.xpc
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/IOKit.framework/Versions/A/XPCServices/IOServiceAuthorizeAgent.xpc/Contents/MacOS/IOServiceAuthorizeAgent error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/SecurityAgent.xpc
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Failed to bootstrap path: path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCTimeStampingService.xpc, error = 1: Operation not permitted
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/XPCServices/DataDetectorsDynamicData.xpc, error = 1: Operation not permitted
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/XPCServices/com.apple.SpeechRecognitionCore.brokerd.xpc, error = 1: Operation not permitted
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Failed to bootstrap path: path = /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/SandboxedServiceRunner.xpc, error = 1: Operation not permitted
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Failed to bootstrap path: path = /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc, error = 1: Operation not permitted
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Failed to bootstrap path: path = /System/Library/Frameworks/IOKit.framework/Versions/A/XPCServices/IOServiceAuthorizeAgent.xpc, error = 1: Operation not permitted
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Failed to bootstrap path: path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCKeychainSandboxCheck.xpc, error = 1: Operation not permitted
Apr 14 21:42:59 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.222): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/SecurityAgent.xpc
Apr 14 21:43:02 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:02 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Apr 14 21:43:02 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Apr 14 21:43:02 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Apr 14 21:43:02 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:43:02 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Apr 14 21:43:02 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Apr 14 21:43:02 iMac-di-alessandro.local mds_stores[208]: (Permissions.Error:1719) Failed stat on perm journal with error 9
Apr 14 21:43:03 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr[219]): Service exited due to signal: Segmentation fault: 11
Apr 14 21:43:03 iMac-di-alessandro.local ReportCrash[220]: Saved crash report for tunmgr[219] version 1.0.77 (6573334) to /Library/Logs/DiagnosticReports/tunmgr_2015-04-14-214303_iMac-di-alessandro.crash
Apr 14 21:43:03 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:43:05 iMac-di-alessandro kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Apr 14 21:43:05 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:43:05 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:43:05 iMac-di-alessandro kernel[0]: ARPT: 74.670316: AWDL Sync Enabled 0
Apr 14 21:43:06 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Warning: IPv6 listener multicast send failed en1, 49
Apr 14 21:43:07 --- last message repeated 6 times ---
Apr 14 21:43:07 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour stop listening on en1
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlOperatingMode Setting the AWDL operation mode from SUSPENDED to AUTO
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlAutoMode Resuming AWDL
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlOperatingMode Setting the AWDL operation mode from AUTO to SUSPENDED
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlSuspendedMode() Suspending AWDL, enterQuietMode(true)
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: ARPT: 77.633676: MacAuthEvent en1 Auth result for: 02:bd:b9:e2:72:b7 MAC AUTH succeeded
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: AirPort: Link Up on en1
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:43:08 iMac-di-alessandro kernel[0]: ARPT: 77.643801: AWDL Sync Enabled 0
Apr 14 21:43:12 iMac-di-alessandro.local discoveryd[80]: Basic SleepProxy Could not get the primary interface
Apr 14 21:43:13 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:43:18 iMac-di-alessandro kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Apr 14 21:43:18 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:43:18 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:43:18 iMac-di-alessandro kernel[0]: ARPT: 87.703117: AWDL Sync Enabled 0
Apr 14 21:43:18 iMac-di-alessandro kernel[0]: ARPT: 88.082655: MacAuthEvent en1 Auth result for: 02:bd:b9:e2:72:b7 MAC AUTH succeeded
Apr 14 21:43:18 iMac-di-alessandro kernel[0]: AirPort: Link Up on en1
Apr 14 21:43:18 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:43:18 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:43:18 iMac-di-alessandro kernel[0]: ARPT: 88.094464: AWDL Sync Enabled 0
Apr 14 21:43:23 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:43:28 iMac-di-alessandro kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Apr 14 21:43:28 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:43:28 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:43:28 iMac-di-alessandro kernel[0]: ARPT: 98.103256: AWDL Sync Enabled 0
Apr 14 21:43:29 iMac-di-alessandro.local SecurityAgent[222]: User info context values set for Ale
Apr 14 21:43:29 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Warning: IPv6 listener multicast send failed en1, 49
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Warning: IPv6 listener multicast send failed en1, 49
Apr 14 21:43:30 --- last message repeated 1 time ---
Apr 14 21:43:30 iMac-di-alessandro.local SecurityAgent[222]: Login Window login proceeding
Apr 14 21:43:30 iMac-di-alessandro.local loginwindow[97]: Login Window - Returned from Security Agent
Apr 14 21:43:30 iMac-di-alessandro.local loginwindow[97]: USER_PROCESS: 97 console
Apr 14 21:43:30 iMac-di-alessandro kernel[0]: AppleKeyStore:Sending lock change 0 for handle -501
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.BBLaunchAgent): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.BBLaunchAgent): Please switch away from OnDemand to KeepAlive.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.blackberrylink.BlackBerry-Link-Helper-Agent): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.blackberrylink.BlackBerry-Link-Helper-Agent): Please switch away from OnDemand to KeepAlive.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (net.culater.SIMBL.Agent): Please switch away from OnDemand to KeepAlive.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.btsa): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.coreservices.lsactivity): Unknown key for Boolean: DrainMessagesAfterFailedInit
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.diagnostics_agent): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dock.fullscreen): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dock.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dock.notificationcenter): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dock.appstore): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dock.remotedesktoppicture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dock.launchpad): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dock.downloads): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.EscrowSecurityAlert): Unknown key for string: seatbelt-profiles
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.Finder): ThrottleInterval set to zero. You're not that important. Ignoring.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.FontRegistryUIAgent): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ATS.FontValidator): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ATS.FontValidatorConduit): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.gamed): The JetsamProperties key is not available on this platform.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.gamed): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.gamed): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.helpd): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.installd.user): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100005.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.mbpluginhost.user.plist, caller = loginwindow.97
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.midiserver.io): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.notificationcenterui.alerts): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.notificationcenterui.tcc): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.notificationcenterui.agent): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100005.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, caller = loginwindow.97
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.PubSub.Agent): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.quicklook.ui.helper.active): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ReportCrash): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ReportCrash.Self): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.rtcreportingd): The UserName key is not supported for non-System services.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.SafariCloudHistoryPushAgent): The UserName key is not supported for non-System services.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.sharingd): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): events/array
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): bundleid/string
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.speech.speechdatainstallerd): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ssinvitationagent): This key does not do anything: OnDemand
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.window_proxies.startup): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.window_proxies): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.systemuiserver.ServiceProvider): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dockextra.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.SUISMessaging): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ipodserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.systemuiserver.screencapture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.tsm.uiserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.dockling.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.UserEventAgent-Aqua): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.usernoted): This service is defined to be constantly running and is inherently inefficient.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (org.openbsd.ssh-agent): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100005.Aqua): Failed to bootstrap path: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, error = 17: File exists
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100005.Aqua): Failed to bootstrap path: path = /System/Library/LaunchAgents/com.apple.mbpluginhost.user.plist, error = 17: File exists
Apr 14 21:43:30 iMac-di-alessandro.local distnoted[247]: # distnote server agent absolute time: 99.962980510 civil time: Tue Apr 14 21:43:30 2015 pid: 247 uid: 501 root: no
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.FolderActions.enabled): Please switch away from OnDemand to KeepAlive.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.spotify.webhelper): Unknown key for string: SpotifyPath
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.spotify.webhelper): The NetworkState key is no longer respected. Please remove it.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Apr 14 21:43:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Apr 14 21:43:31 iMac-di-alessandro.local lsregister[250]: LaunchServices: Begin database seeding
Apr 14 21:43:31 iMac-di-alessandro.local lsregister[250]: LaunchServices: Completed database seeding
Apr 14 21:43:31 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Warning: IPv6 listener multicast send failed en1, 49
Apr 14 21:43:31 --- last message repeated 1 time ---
Apr 14 21:43:31 iMac-di-alessandro.local UserEventAgent[245]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Apr 14 21:43:31 iMac-di-alessandro.local UserEventAgent[245]: com.apple.TMHelperAgent.SetupOffer enabled
Apr 14 21:43:31 iMac-di-alessandro.local UserEventAgent[245]: user agent networkd: built Feb 12 2015 17:21:33
Apr 14 21:43:31 iMac-di-alessandro.local UserEventAgent[245]: received an unknown event from daemon
Apr 14 21:43:31 iMac-di-alessandro.local tccd[231]: Communications error: <OS_xpc_error: <error: 0x7fff72ec2c60> { count = 1, contents =
"XPCErrorDescription" => <string: 0x7fff72ec2f70> { length = 18, contents = "Connection invalid" }
Apr 14 21:43:31 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour stop listening on en1
Apr 14 21:43:31 iMac-di-alessandro.local WindowServer[163]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -login
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Apr 14 21:43:31 iMac-di-alessandro.local pboard[266]: Attempt to unlink previous shared memory during startup returned an error. Continuing...
Apr 14 21:43:31 iMac-di-alessandro.local DMProxy[265]: AMBD Services: connection interrupted: com.apple.AmbientDisplayAgent (Connection interrupted)
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.AmbientDisplayAgent[207]: AmbientDisplayAgent started
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.AmbientDisplayAgent[207]: AMBD initializing devices
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelDevice.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelSharedUserClient.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDSIVideoContext.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class Gen6DVDContext.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelDevice.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelSharedUserClient.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMain.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMedia.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextVEBox.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOBluetoothDeviceUserClient.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOHIDParamUserClient.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOSurfaceRootUserClient.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the mach service named com.apple.AirPlayXPCHelper.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named AirPlay.driver requires extending the sandbox for the mach service named com.apple.wirelessproxd.
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: 2015-04-14 09:43:31.398308 PM [AirPlay] BTLE discovery removing all devices
Apr 14 21:43:31 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlPeerTrafficRegistration Clearing AirPlay peer 00:00:00:00:00:00
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: 2015-04-14 09:43:31.405319 PM [AirPlay] Resetting AWDL traffic registration.
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: 2015-04-14 09:43:31.405611 PM [AirPlay] Deregister AirPlay traffic for AWDL at MAC 00:00:00:00:00:00 with target infra non critical PeerIndication=0 err=0
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the IOKit user-client class IOBluetoothDeviceUserClient.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.blued.
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.audio.DriverHelper[267]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.bluetoothaudiod.
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: 2015-04-14 09:43:31.415808 PM [AirPlay] BTLE client stopping to browse for AirPlay Solo Target Presence.
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: 2015-04-14 09:43:31.415975 PM [AirPlay] BTLE client starting to browse for AirPlay Solo Target Presence.
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: 2015-04-14 09:43:31.417004 PM [AirPlay] BTLE client stopped to browse for AirPlay Solo Target Presence.
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: 2015-04-14 09:43:31.417186 PM [AirPlay] BTLE client started to browse for AirPlay Solo Target Presence.
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: Logging disabled
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: 2015-04-14 09:43:31.445554 PM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and for input
Apr 14 21:43:31 iMac-di-alessandro.local coreaudiod[262]: 2015-04-14 09:43:31.446542 PM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and for input
Apr 14 21:43:31 iMac-di-alessandro.local bluetoothaudiod[271]: Logging disabled
Apr 14 21:43:31 iMac-di-alessandro.local WindowServer[163]: CGXSetDisplayColorProfileAndTransfer: Display 0x04280480: Unit 0; ColorProfile { 362476056 }; TransferFormula (1.000000, 1.000000, 1.000000)
Apr 14 21:43:31 iMac-di-alessandro.local com.apple.AmbientDisplayAgent[207]: AMBD Agent: xpc connection became invalid during event handler
Apr 14 21:43:31 iMac-di-alessandro.local Console[251]: Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100005.Aqua): Could not import service from caller: caller = otherbsd.246, service = com.veri.memoir-osx.launchhelper, error = 119: Service is disabled
Apr 14 21:43:31 iMac-di-alessandro.local otherbsd[246]: Could not submit LoginItem job com.veri.memoir-osx.launchhelper: 119: Service is disabled
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100005.Aqua): Could not import service from caller: caller = otherbsd.246, service = com.apple.photostream-agent, error = 119: Service is disabled
Apr 14 21:43:31 iMac-di-alessandro.local otherbsd[246]: Could not submit LoginItem job com.apple.photostream-agent: 119: Service is disabled
Apr 14 21:43:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100005.Aqua): Could not import service from caller: caller = otherbsd.246, service = com.freemacsoft.AppCleaner-Helper, error = 119: Service is disabled
Apr 14 21:43:31 iMac-di-alessandro.local otherbsd[246]: Could not submit LoginItem job com.freemacsoft.AppCleaner-Helper: 119: Service is disabled
Apr 14 21:43:31 iMac-di-alessandro.local iconservicesagent[276]: iconservicesagent launched.
Apr 14 21:43:31 iMac-di-alessandro.local iconservicesagent[276]: Starting service with cache path: /var/folders/24/qhzxh3ns3892hj_yw_qbq8m80000gn/C/com.apple.iconservices
Apr 14 21:43:32 iMac-di-alessandro kernel[0]: ARPT: 102.075604: MacAuthEvent en1 Auth result for: 02:bd:b9:e2:72:b7 MAC AUTH succeeded
Apr 14 21:43:32 iMac-di-alessandro kernel[0]: AirPort: Link Up on en1
Apr 14 21:43:32 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:43:32 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:43:32 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:43:32 iMac-di-alessandro kernel[0]: ARPT: 102.084428: AWDL Sync Enabled 0
Apr 14 21:43:33 iMac-di-alessandro.local SystemUIServer[260]: Cannot find executable for CFBundle 0x7feb62e1d830 </System/Library/CoreServices/Menu Extras/Clock.menu> (not loaded)
Apr 14 21:43:33 iMac-di-alessandro kernel[0]: firefox (map: 0xffffff8018677a50) triggered DYLD shared region unnest for map: 0xffffff8018677a50, region 0x7fff90a00000->0x7fff90c00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
Apr 14 21:43:33 iMac-di-alessandro.local SystemUIServer[260]: Cannot find executable for CFBundle 0x7feb62e1dc50 </System/Library/CoreServices/Menu Extras/Volume.menu> (not loaded)
Apr 14 21:43:33 iMac-di-alessandro.local backupd[166]: Property list invalid for format: 200 (property lists cannot contain NULL)
Apr 14 21:43:33 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:43:33 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.accounts.dom): The _DirtyJetsamMemoryLimit key is not available on this platform.
thezippons
Apr 14 21:43:33 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.lakitu): The JoinExistingSession key is only available to Application services.
Apr 14 21:43:33 iMac-di-alessandro.local secinitd[286]: UID[501]: cache loaded: /System/Library/Caches/com.apple.app-sandbox-cache.plist
Apr 14 21:43:33 iMac-di-alessandro.local com.apple.SecurityServer[84]: Session 100009 created
Apr 14 21:43:33 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.quicklook[282]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Apr 14 21:43:33 iMac-di-alessandro.local SystemUIServer[260]: Could not find image named 'greenmarker'.
Apr 14 21:43:33 iMac-di-alessandro.local sharingd[284]: 21:43:33.645 : Starting Up...
Apr 14 21:43:33 iMac-di-alessandro.local sharingd[284]: 21:43:33.649 : Device Capabilities (Handoff:YES, Instant Hotspot:YES, AirDrop:YES, Legacy AirDrop:YES, Remote Disc:YES)
Apr 14 21:43:33 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imdmessageservices.IMDMessageServicesAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:43:33 iMac-di-alessandro.local logind[98]: -[SessionManager getClient:withRole:inAuditSession:]:241: ERROR: No session dictionary for audit session 100009
Apr 14 21:43:33 iMac-di-alessandro.local logind[98]: _SMGetSessionAgent:73: ERROR: __SMGetClientForAuditSessionAgent failed 2
Apr 14 21:43:33 iMac-di-alessandro.local IMDPersistenceAgent[295]: SACShieldWindowShowing:925: ERROR: NULL response
Apr 14 21:43:34 --- last message repeated 1 time ---
Apr 14 21:43:34 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:43:34 iMac-di-alessandro.local blued[89]: ****** properties = 0x118, permissions = 0x8, write? 0, w/o res? 0
Apr 14 21:43:35 iMac-di-alessandro.local CalendarAgent[292]: Exception fetching ABCDContact in context <ABManagedObjectContext: 0x7f9c73482280>: keypath birthdayComponents not found in entity <NSSQLEntity ABCDContact id=21>
Apr 14 21:43:35 iMac-di-alessandro.local CalendarAgent[292]: Error fetching ABCDContact in context <ABManagedObjectContext: 0x7f9c73482280>: (null) (null)
Apr 14 21:43:35 iMac-di-alessandro.local identityservicesd[298]: <IMMacNotificationCenterManager: 0x7faaa2d75240>: Configuring notification center for identifier: com.apple.iChat topics: (
"com.apple.private.alloy.icloudpairing",
"com.apple.private.alloy.continuity.encryption",
"com.apple.private.alloy.continuity.activity",
"com.apple.private.alloy.idstransfers",
"com.apple.private.ids",
"com.apple.private.alloy.phonecontinuity",
"com.apple.private.alloy.continuity.auth",
"com.apple.private.alloy.idsremoteurlconnection",
"com.apple.private.alloy.screensharing",
"com.apple.private.alloy.maps",
"com.apple.private.alloy.callhistorysync",
"com.apple.private.alloy.continuity.tethering"
Apr 14 21:43:35 iMac-di-alessandro.local identityservicesd[298]: <IMMacNotificationCenterManager: 0x7faaa2d75240>: NC Disabled: NO
Apr 14 21:43:35 iMac-di-alessandro.local identityservicesd[298]: <IMMacNotificationCenterManager: 0x7faaa2d75240>: DND Enabled: NO
Apr 14 21:43:35 iMac-di-alessandro.local identityservicesd[298]: <IMMacNotificationCenterManager: 0x7faaa2d75240>: Updating enabled: YES (Topics: (
Apr 14 21:43:35 iMac-di-alessandro.local talagent[259]: CGSConnectionRelinquishWindowRights(cid, result, reservedRights): CGError 1001 on line 875
Apr 14 21:43:35 iMac-di-alessandro com.apple.iCloudHelper[309]: objc[309]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Apr 14 21:43:35 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:43:35 --- last message repeated 1 time ---
Apr 14 21:43:35 iMac-di-alessandro.local callservicesd[307]: Failed to get the bundle id
Apr 14 21:43:35 iMac-di-alessandro.local AppleIDAuthAgent[310]: AOSKit ERROR: Config request failed, url=https://setup.icloud.com/configurations/init, requestHeaders=
"X-Mme-Country" = IT;
"X-Mme-Timezone" = CEST;
error=Error Domain=kCFErrorDomainCFNetwork Code=-1009 "The Internet connection appears to be offline." UserInfo=0x7fde4845e750 {NSErrorFailingURLStringKey=https://setup.icloud.com/configurations/init, NSErrorFailingURLKey=https://setup.icloud.com/configurations/init, _kCFStreamErrorCodeKey=8, _kCFStreamErrorDomainKey=12, NSLocalizedDescription=The Internet connection appears to be offline.}, httpStatusCode=-1, responseHeaders=
(null)
Apr 14 21:43:35 iMac-di-alessandro.local AppleIDAuthAgent[310]: AppleIdAuth URL Error: Error Domain=AOSErrorDomain Code=1000 "The operation couldn’t be completed. (AOSErrorDomain error 1000.)"
Apr 14 21:43:35 iMac-di-alessandro.local sharingd[284]: 21:43:35.641 : BTLE scanning started
Apr 14 21:43:35 iMac-di-alessandro.local sharingd[284]: 21:43:35.641 : Scanning mode Contacts Only
Apr 14 21:43:35 iMac-di-alessandro.local sharingd[284]: 21:43:35.643 : BTLE scanner Powered On
Apr 14 21:43:36 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): The _DirtyJetsamPriority key is not available on this platform.
Apr 14 21:43:36 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:43:36 iMac-di-alessandro.local com.apple.iCloudHelper[309]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:36 iMac-di-alessandro.local imagent[290]: [Warning] SMSServiceSession: Error no IDS Service available for SMS Relay
Apr 14 21:43:36 --- last message repeated 1 time ---
Apr 14 21:43:36 iMac-di-alessandro.local discoveryd[80]: Basic SleepProxy Could not get the primary interface
Apr 14 21:43:36 iMac-di-alessandro.local fmfd[313]: Initialized sandbox
Apr 14 21:43:36 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:43:36 iMac-di-alessandro.local apsd[81]: Peer [pid=313] requested push wake but lacks APSPushWakeEntitlement
Apr 14 21:43:36 iMac-di-alessandro.local sandboxd[314] ([313]): fmfd(313) deny file-read-data /Users/Ale/Library/Preferences/com.apple.security.plist
Apr 14 21:43:37 iMac-di-alessandro.local CalendarAgent[292]: [com.apple.calendar.store.log.caldav.queue] [Account refresh failed with error: Error Domain=NSURLErrorDomain Code=-1009 "La connessione a Internet sembra non essere in linea." UserInfo=0x7f9c75d04cd0 {AccountName=iCloud, CalDAVErrFromRefresh=YES, NSUnderlyingError=0x7f9c759180b0 "La connessione a Internet sembra non essere in linea.", NSErrorFailingURLKey=https://pizzo.alessandro96%40xxxxxxx.co ... principal/, NSLocalizedDescription=La connessione a Internet sembra non essere in linea., _kCFStreamErrorDomainKey=12, NSErrorFailingURLStringKey=https://pizzo.alessandro96%40xxxxxxx.co ... principal/, _kCFStreamErrorCodeKey=8}]
Apr 14 21:43:38 iMac-di-alessandro.local CalendarAgent[292]: [com.apple.calendar.store.log.caldav.queue] [Account refresh failed with error: Error Domain=NSURLErrorDomain Code=-1009 "La connessione a Internet sembra non essere in linea." UserInfo=0x7f9c75b1b5d0 {AccountName=Google, CalDAVErrFromRefresh=YES, NSUnderlyingError=0x7f9c75917200 "La connessione a Internet sembra non essere in linea.", NSErrorFailingURLKey=https://pizzo.alessandro96%40xxxxxxx.co ... .com/user/, NSLocalizedDescription=La connessione a Internet sembra non essere in linea., _kCFStreamErrorDomainKey=12, NSErrorFailingURLStringKey=https://pizzo.alessandro96%40xxxxxxx.co ... .com/user/, _kCFStreamErrorCodeKey=8}]
Apr 14 21:43:38 iMac-di-alessandro.local CalendarAgent[292]: [com.apple.calendar.store.log.caldav.queue] [Adding [<CalDAVAccountRefreshQueueableOperation: 0x7f9c7366f440; Sequence: 0>] to failed operations.]
Apr 14 21:43:38 iMac-di-alessandro.local CalendarAgent[292]: [com.apple.calendar.store.log.caldav.queue] [Adding [<CalDAVAccountRefreshQueueableOperation: 0x7f9c73751910; Sequence: 0>] to failed operations.]
Apr 14 21:43:38 iMac-di-alessandro.local firefox[254]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.3 instead of 10.10.3. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
Apr 14 21:43:38 iMac-di-alessandro.local firefox[254]: 0 CarbonCore 0x00007fff82c2a2b7 ___Gestalt_SystemVersion_block_invoke + 113
Apr 14 21:43:38 iMac-di-alessandro.local firefox[254]: 1 libdispatch.dylib 0x00007fff84282c13 _dispatch_client_callout + 8
Apr 14 21:43:38 iMac-di-alessandro.local firefox[254]: 2 libdispatch.dylib 0x00007fff84282b26 dispatch_once_f + 117
Apr 14 21:43:38 iMac-di-alessandro.local firefox[254]: 3 CarbonCore 0x00007fff82bb3456 _Gestalt_SystemVersion + 987
Apr 14 21:43:38 iMac-di-alessandro.local firefox[254]: 4 CarbonCore 0x00007fff82bb26e3 Gestalt + 144
Apr 14 21:43:38 iMac-di-alessandro.local firefox[254]: 5 XUL 0x00000001042aba21 vpx_reset_mmx_state + 536561
Apr 14 21:43:39 iMac-di-alessandro.local CalendarAgent[292]: [com.apple.calendar.store.log.caldav.queue] [Adding [<CalDAVRefreshDelegateListQueueableOperation: 0x7f9c73754a50; Sequence: 0>] to failed operations.]
Apr 14 21:43:39 iMac-di-alessandro.local Spotlight[277]: Took 7.55s to get the token
Apr 14 21:43:39 iMac-di-alessandro.local Finder[261]: Took 4.90s to get the token
Apr 14 21:43:39 iMac-di-alessandro.local Mail[257]: Took 5.57s to get the token
Apr 14 21:43:39 iMac-di-alessandro.local Spotlight[277]: spot: agent checkin
Apr 14 21:43:39 iMac-di-alessandro Finder[261]: assertion failed: 14D131: libxpc.dylib + 62495 [D35D0DB2-D7BD-3BE4-8378-062BFE545E1D]: 0x89
Apr 14 21:43:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:43:39 --- last message repeated 1 time ---
Apr 14 21:43:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Apr 14 21:43:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:43:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Apr 14 21:43:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Apr 14 21:43:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Apr 14 21:43:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:43:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Apr 14 21:43:39 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Apr 14 21:43:39 iMac-di-alessandro.local com.apple.internetaccounts[316]: Additional Logging , array retured in signedInAccounts is (
"<IAAccount: 0x61800005b870> -- uid: C67DF589-F270-4F4B-A236-326B2A173F96; loginName: pizzo.alessandro96@xxxxxxx.com; provider: com.apple.account.icloud; parent: (null)\n\taccount ID: pizzo.alessandro96@xxxxxxx.com - com.apple.account.icloud - \n\tprovider attrs: {\n IADSIDKey = 1768440396;\n accountDescription = iCloud;\n \"com.apple.InternetAccounts.loginName\" = \"pizzo.alessandro96@xxxxxxx.com\";\n \"com.apple.InternetAccounts.provider\" = \"com.apple.account.icloud\";\n fullName = iCloud;\n}"
Apr 14 21:43:39 iMac-di-alessandro.local com.apple.internetaccounts[316]: Adding listener
Apr 14 21:43:39 iMac-di-alessandro.local com.apple.internetaccounts[316]: Returning accountUIDs: (
Apr 14 21:43:39 iMac-di-alessandro.local com.apple.internetaccounts[316]: [Warning] IMAccount: 0x7fb1e0c09750 [ID: 7655402F-0229-45CE-9042-4D1121933FC9 Service: IMService[Jabber] Login: pizzo.alessandro96@xxxxxxx.com Active: YES LoginStatus: Non in linea]: Couldn't load service icon from (null)
Apr 14 21:43:39 iMac-di-alessandro.local nsurlsessiond[255]: Being asked if container with identifier com.apple.clouddocs.com.apple.CloudDocs.container-metadata is foreground before getting callback from BRContainersMonitor!
Apr 14 21:43:40 --- last message repeated 1 time ---
Apr 14 21:43:40 iMac-di-alessandro.local nsurlsessiond[255]: Being asked if container with identifier com.apple.clouddocs.com.apple.SharedDocs is foreground before getting callback from BRContainersMonitor!
Apr 14 21:43:40 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.PeerManager[323]): Could not find and/or execute program specified by service: 2: No such file or directory: /Applications/BlackBerry Link.app/Contents/Resources/P2P/PeerManager
Apr 14 21:43:40 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.PeerManager[323]): Service setup event to handle failure and will not launch until it fires.
Apr 14 21:43:40 iMac-di-alessandro PowerChime[334]: objc[334]: Class BUIPowerSource is implemented in both /System/Library/PrivateFrameworks/BatteryUIKit.framework/Versions/A/BatteryUIKit and /System/Library/CoreServices/PowerChime.app/Contents/MacOS/PowerChime. One of the two will be used. Which one is undefined.
Apr 14 21:43:40 iMac-di-alessandro com.apple.xpc.launchd[1] (com.facebook.videochat.Ale.updater[333]): Service exited with abnormal code: 1
Apr 14 21:43:40 iMac-di-alessandro.local PowerChime[334]: PowerChime: chime enabled by hardware: 0
Apr 14 21:43:40 iMac-di-alessandro.local PowerChime[334]: PowerChime disabled - ChimeOnNoHardware default: 0
Apr 14 21:43:40 iMac-di-alessandro.local xpcproxy[346]: CFPreferences could not connect to its daemon.
Preferences using the connection 0x0 will be volatile and will not be persisted to disk.
Apr 14 21:43:40 iMac-di-alessandro.local xpcproxy[347]: CFPreferences could not connect to its daemon.
Apr 14 21:43:40 iMac-di-alessandro.local Keychain Circle Notification[326]: Posted at launch: (
Apr 14 21:43:40 iMac-di-alessandro.local apsd[81]: Attempt to set push wake topics without dark wake enabled: ()
Apr 14 21:43:40 iMac-di-alessandro.local NotificationCenter[328]: Layout still needs update after calling -[NCScrollView layout]. NCScrollView or one of its superclasses may have overridden -layout without calling super. Or, something may have dirtied layout in the middle of updating it. Both are programming errors in Cocoa Autolayout. The former is pretty likely to arise if some pre-Cocoa Autolayout class had a method called layout, but it should be fixed.
Apr 14 21:43:41 iMac-di-alessandro.local SpotlightNetHelper[352]: CGSConnectionByID: 0 is not a valid connection ID.
Apr 14 21:43:41 iMac-di-alessandro.local SpotlightNetHelper[352]: Invalid Connection ID 0
Apr 14 21:43:41 iMac-di-alessandro.local thermald[52]: invalid attribute or value, default to yes
Apr 14 21:43:41 iMac-di-alessandro askpermissiond[335]: objc[335]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Apr 14 21:43:41 iMac-di-alessandro.local backupd[166]: Property list invalid for format: 200 (property lists cannot contain NULL)
Apr 14 21:43:41 iMac-di-alessandro.local apsd[81]: Attempt to set push wake topics without dark wake enabled: ()
Apr 14 21:43:41 iMac-di-alessandro.local CoreServicesUIAgent[308]: unexpected message <OS_xpc_error: <error: 0x7fff72ec2c60> { count = 1, contents =
Apr 14 21:43:41 iMac-di-alessandro.local locationd[86]: Couldn't find a requirement string for masquerading client /System/Library/PrivateFrameworks/Parsec.framework
Apr 14 21:43:41 iMac-di-alessandro.local locationd[86]: could not get apple languages array, assuming english
Apr 14 21:43:41 --- last message repeated 1 time ---
Apr 14 21:43:41 iMac-di-alessandro.local NotificationCenter[328]: Layout still needs update after calling -[NSView layout]. NSView or one of its superclasses may have overridden -layout without calling super. Or, something may have dirtied layout in the middle of updating it. Both are programming errors in Cocoa Autolayout. The former is pretty likely to arise if some pre-Cocoa Autolayout class had a method called layout, but it should be fixed.
Apr 14 21:43:42 iMac-di-alessandro.local locationd[86]: Couldn't find a requirement string for masquerading client /System/Library/Frameworks/NotificationCenter.framework/PlugIns/com.apple.ncplugin.weather.appex
Apr 14 21:43:42 iMac-di-alessandro.local locationd[86]: could not get apple languages array, assuming english
Apr 14 21:43:42 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:43:42 iMac-di-alessandro.local secd[299]: SOSPeerCoderInitializeForPeer Found data but couldn't make coder for iHPO0ta8nsG9Ro25kD2Hb3SApN: (null)
Apr 14 21:43:42 iMac-di-alessandro.local apsd[81]: Attempt to set push wake topics without dark wake enabled: ()
Apr 14 21:43:42 iMac-di-alessandro.local CloudKeychainProxy[353]: __45-[UbiqitousKVSProxy doEnsurePeerRegistration]_block_invoke <UB---e-C---> ensurePeerRegistration called, success ((null))
Apr 14 21:43:42 iMac-di-alessandro.local storeaccountd[354]: AccountServiceDelegate: Accepting new connection <NSXPCConnection: 0x7f91d9409e70> connection from pid 328 with interface <AccountServiceInterface: 0x7f91d940b540> (PID 328)
Apr 14 21:43:42 iMac-di-alessandro.local storeaccountd[354]: AccountServiceDelegate: Accepting new connection <NSXPCConnection: 0x7f91d941c970> connection from pid 352 with interface <AccountServiceInterface: 0x7f91d941cd70> (PID 352)
Apr 14 21:43:42 iMac-di-alessandro.local Keychain Circle Notification[326]: rawStatus 0, #applicants 0, #peers 1, err=(null)
Apr 14 21:43:42 iMac-di-alessandro.local Keychain Circle Notification[326]: Checking validity of 0 notes
Apr 14 21:43:42 iMac-di-alessandro.local Keychain Circle Notification[326]: writeToStorage plist={
applcationDate = "0000-12-30 00:00:00 +0000";
lastCircleStatus = 0;
lastWritten = "2015-04-14 19:43:42 +0000";
pendingApplicationReminder = "4001-01-01 00:00:00 +0000";
pendingApplicationReminderInterval = 172800;
Apr 14 21:43:42 iMac-di-alessandro.local Spotlight[277]: applications query - started
Apr 14 21:43:42 iMac-di-alessandro.local askpermissiond[335]: StoreTransport: Resetting APS Connection using environment name production
Apr 14 21:43:42 iMac-di-alessandro.local sandboxd[314] ([337]): cloudpaird(337) deny file-read-data /Users/Ale/Library/Preferences/com.apple.security.plist
Apr 14 21:43:42 iMac-di-alessandro.local AddressBookSourceSync[350]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:43 iMac-di-alessandro.local thermald[52]: invalid attribute or value, default to yes
Apr 14 21:43:43 iMac-di-alessandro kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Apr 14 21:43:43 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:43:43 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:43:43 iMac-di-alessandro kernel[0]: ARPT: 112.193053: AWDL Sync Enabled 0
Apr 14 21:43:43 iMac-di-alessandro.local WiFiAgent[341]: [NO client logger] <Sep 9 2014 16:12:26> WIFICLOUDSYNC WiFiCloudSyncEngineCreate: created...
Apr 14 21:43:43 iMac-di-alessandro.local WiFiAgent[341]: [NO client logger] <Sep 9 2014 16:12:26> WIFICLOUDSYNC WiFiCloudSyncEngineRegisterCallbacks: WiFiCloudSyncEngineCallbacks version - 0, bundle id - com.apple.wifi.WiFiAgent
Apr 14 21:43:43 iMac-di-alessandro.local apsd[81]: Attempt to set push wake topics without dark wake enabled: ()
Apr 14 21:43:43 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Warning: IPv6 listener multicast send failed en1, 49
Apr 14 21:43:43 iMac-di-alessandro.local mapspushd[363]: [Warning] Services all disappeared, removing all accounts
Apr 14 21:43:43 iMac-di-alessandro.local mapspushd[363]: [Warning] Services all disappeared, removing all enabled accounts
Apr 14 21:43:43 iMac-di-alessandro.local mapspushd[363]: [Warning] Services all disappeared, removing all dependent devices
Apr 14 21:43:43 iMac-di-alessandro kernel[0]: ARPT: 112.579873: MacAuthEvent en1 Auth result for: 02:bd:b9:e2:72:b7 MAC AUTH succeeded
Apr 14 21:43:43 iMac-di-alessandro kernel[0]: AirPort: Link Up on en1
Apr 14 21:43:43 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:43:43 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:43:43 iMac-di-alessandro kernel[0]: ARPT: 112.595439: AWDL Sync Enabled 0
Apr 14 21:43:43 iMac-di-alessandro.local askpermissiond[335]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:43 iMac-di-alessandro.local nsurlstoraged[232]: realpath() returned NULL for /var/db/locationd/Library/Caches/com.apple.locationd
Apr 14 21:43:43 iMac-di-alessandro.local nsurlstoraged[232]: The read-connection to the DB=/var/db/locationd/Library/Caches/com.apple.locationd/Cache.db is NOT valid. Unable to determine schema version.
Apr 14 21:43:43 --- last message repeated 1 time ---
Apr 14 21:43:43 iMac-di-alessandro.local nsurlstoraged[232]: ERROR: unable to determine file-system usage for FS-backed cache at /var/db/locationd/Library/Caches/com.apple.locationd/fsCachedData. Errno=13
Apr 14 21:43:43 iMac-di-alessandro.local AddressBookSourceSync[350]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:43 iMac-di-alessandro.local WindowServer[163]: disable_update_timeout: UI updates were forcibly disabled by application "Firefox" for over 1.00 seconds. Server has re-enabled them.
Apr 14 21:43:43 iMac-di-alessandro.local locationd[86]: Location icon should now be in state 'Active'
Apr 14 21:43:44 iMac-di-alessandro.local apsd[81]: Attempt to set push wake topics without dark wake enabled: ()
Apr 14 21:43:44 iMac-di-alessandro.local askpermissiond[335]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:44 iMac-di-alessandro.local maspushagent[365]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:44 iMac-di-alessandro.local AddressBookSourceSync[350]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:45 iMac-di-alessandro.local Spotlight[277]: applications query - finished in 2.8 seconds
Apr 14 21:43:45 iMac-di-alessandro.local mapspushd[363]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:45 iMac-di-alessandro.local askpermissiond[335]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:45 iMac-di-alessandro.local maspushagent[365]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:45 iMac-di-alessandro.local AddressBookSourceSync[350]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:46 iMac-di-alessandro.local WindowServer[163]: common_reenable_update: UI updates were finally reenabled by application "Firefox" after 3.28 seconds (server forcibly re-enabled them after 1.00 seconds)
Apr 14 21:43:46 iMac-di-alessandro.local WindowServer[163]: disable_update_timeout: UI updates were forcibly disabled by application "Location Menu" for over 1.00 seconds. Server has re-enabled them.
Apr 14 21:43:46 iMac-di-alessandro.local mapspushd[363]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:46 iMac-di-alessandro.local askpermissiond[335]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:46 iMac-di-alessandro.local maspushagent[365]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:46 iMac-di-alessandro.local AddressBookSourceSync[350]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:47 iMac-di-alessandro.local mapspushd[363]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:47 iMac-di-alessandro.local askpermissiond[335]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:47 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.spindump[373]): Service exited with abnormal code: 75
Apr 14 21:43:47 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.spindump): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:43:47 iMac-di-alessandro.local AddressBookSourceSync[350]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:47 iMac-di-alessandro.local maspushagent[365]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:48 iMac-di-alessandro.local mapspushd[363]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:48 iMac-di-alessandro.local askpermissiond[335]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:48 iMac-di-alessandro.local maspushagent[365]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:49 iMac-di-alessandro.local mapspushd[363]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:50 iMac-di-alessandro.local maspushagent[365]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:50 iMac-di-alessandro.local WindowServer[163]: disable_update_timeout: UI updates were forcibly disabled by application "talagent" for over 1.00 seconds. Server has re-enabled them.
Apr 14 21:43:50 iMac-di-alessandro.local mapspushd[363]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Apr 14 21:43:51 iMac-di-alessandro.local talagent[259]: CGSConnectionRelinquishWindowRights(cid, result, reservedRights): CGError 1001 on line 875
Apr 14 21:43:51 iMac-di-alessandro.local WindowServer[163]: common_reenable_update: UI updates were finally reenabled by application "Location Menu" after 6.41 seconds (server forcibly re-enabled them after 1.00 seconds)
Apr 14 21:43:51 iMac-di-alessandro.local Paragon Updater[331]: opening log at /Users/Ale/Library/Logs/paragon.Paragon-Updater.log ...
Apr 14 21:43:51 iMac-di-alessandro.local Paragon Updater[331]: done
Apr 14 21:43:51 iMac-di-alessandro.local Paragon Updater[331]: Updater started. Updater version: 1.100
Apr 14 21:43:52 iMac-di-alessandro.local Paragon Updater[331]: Arguments: --check, --delay=30
Apr 14 21:43:52 iMac-di-alessandro.local WindowServer[163]: common_reenable_update: UI updates were finally reenabled by application "talagent" after 3.42 seconds (server forcibly re-enabled them after 1.00 seconds)
Apr 14 21:43:53 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:43:53 iMac-di-alessandro kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Apr 14 21:43:53 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:43:53 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:43:53 iMac-di-alessandro.local locationd[86]: Location icon should now be in state 'Inactive'
Apr 14 21:43:54 iMac-di-alessandro kernel[0]: ARPT: 123.273421: AWDL Sync Enabled 0
Apr 14 21:43:54 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Warning: IPv6 listener multicast send failed en1, 49
Apr 14 21:43:55 --- last message repeated 4 times ---
Apr 14 21:43:55 iMac-di-alessandro.local storeaccountd[354]: AccountServiceDelegate: Accepting new connection <NSXPCConnection: 0x7f91d970d130> connection from pid 370 with interface <AccountServiceInterface: 0x7f91d97052a0> (PID 370)
Apr 14 21:43:55 iMac-di-alessandro.local mapspushd[363]: 2015-04-14 21:43:55.607, 363, cbc12ef0, [MapsAnnouncements]: Failed to load announcements document: Error Domain=NSURLErrorDomain Code=-1009 "La connessione a Internet sembra non essere in linea." UserInfo=0x7fbccbd29470 {NSUnderlyingError=0x7fbccbd2bb50 "La connessione a Internet sembra non essere in linea.", NSErrorFailingURLStringKey=http://gspe21.ls.apple.com/config/annou ... on=10.10.3, NSErrorFailingURLKey=http://gspe21.ls.apple.com/config/annou ... on=10.10.3, _kCFStreamErrorDomainKey=12, _kCFStreamErrorCodeKey=8, NSLocalizedDescription=La connessione a Internet sembra non essere in linea.}
Apr 14 21:43:55 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Warning: IPv6 listener multicast send failed en1, 49
Apr 14 21:43:56 --- last message repeated 3 times ---
Apr 14 21:43:56 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour stop listening on en1
Apr 14 21:43:56 iMac-di-alessandro.local storeaccountd[354]: AccountServiceDelegate: Accepting new connection <NSXPCConnection: 0x7f91d942f450> connection from pid 370 with interface <AccountServiceInterface: 0x7f91d940b870> (PID 370)
Apr 14 21:43:56 iMac-di-alessandro.local nsurlstoraged[232]: realpath() returned NULL for /var/root/Library/Caches/ocspd
Apr 14 21:43:56 iMac-di-alessandro.local nsurlstoraged[232]: The read-connection to the DB=/var/root/Library/Caches/ocspd/Cache.db is NOT valid. Unable to determine schema version.
Apr 14 21:43:59 --- last message repeated 1 time ---
Apr 14 21:43:56 iMac-di-alessandro.local nsurlstoraged[232]: ERROR: unable to determine file-system usage for FS-backed cache at /var/root/Library/Caches/ocspd/fsCachedData. Errno=13
Apr 14 21:43:57 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:44:01 --- last message repeated 2 times ---
Apr 14 21:44:01 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.ReportCrash.Root[385]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash.DirectoryService
Apr 14 21:44:04 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:44:05 --- last message repeated 1 time ---
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Apr 14 21:44:05 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Apr 14 21:44:07 iMac-di-alessandro.local findNames[388]: dispatch_semaphore_wait() time out: -[IMKUserDictionary reloadWithCompletionHandler:]
Apr 14 21:44:07 iMac-di-alessandro.local com.apple.iCloudHelper[309]: AOSKit ERROR: Storage usage request failed, appleID=pizzo.alessandro96@xxxxxxx.com, url=https://p19-quota.icloud.com:443/quotas ... eUsageInfo, requestHeaders=
thezippons
"Accept-Language" = "it-it";
Authorization = "...";
"X-Mme-Client-Info" = "<iMac13,1> <Mac OS X;10.10.3;14D131> <com.apple.AOSKit/217 (com.apple.CloudPhotosConfiguration/1.0)>";
"X-Mme-Device-Id" = "CEA63987-B9E0-5691-A32E-A3553A9D8C59";
error=Error Domain=AOSErrorDomain Code=1000 "Impossibile completare l'operazione. (AOSErrorDomain errore 1000.)" UserInfo=0x7fa848f16bd0 {UnderlyingError=La connessione a Internet sembra non essere in linea., DialogInfo={
DialogType = Unknown;
}}, httpStatusCode=-1
Apr 14 21:44:07 iMac-di-alessandro.local com.apple.CloudPhotosConfiguration[383]: [AOSAccounts] : [MMRetrieveQuotaUsage] : account pizzo.alessandro96@xxxxxxx.com _AOSAccountRetrieveStorageUsageInfo failed with error Impossibile completare l'operazione. (AOSErrorDomain errore 1000.) and reason (null) domain AOSErrorDomain
Apr 14 21:44:07 iMac-di-alessandro.local com.apple.iCloudHelper[309]: AOSKit ERROR: (pizzo.alessandro96@xxxxxxx.com) Ramp state request failed, url=https://p19-availability.icloud.com:443 ... ure=photos, requestHeaders=
error=Error Domain=AOSErrorDomain Code=1000 "Impossibile completare l'operazione. (AOSErrorDomain errore 1000.)" UserInfo=0x7fa848c26b40 {UnderlyingError=La connessione a Internet sembra non essere in linea., DialogInfo={
Apr 14 21:44:07 iMac-di-alessandro.local com.apple.CloudPhotosConfiguration[383]: Unable to get service ramp state information: Error Domain=AOSErrorDomain Code=1000 "Impossibile completare l'operazione. (AOSErrorDomain errore 1000.)" UserInfo=0x7f9302c3a5c0 {UnderlyingError=Error Domain=kCFErrorDomainCFNetwork Code=-1009 "La connessione a Internet sembra non essere in linea." UserInfo=0x7f9302c3ac30 {NSErrorFailingURLStringKey=https://p19-availability.icloud.com:443 ... ure=photos, NSErrorFailingURLKey=https://p19-availability.icloud.com:443 ... ure=photos, _kCFStreamErrorCodeKey=8, _kCFStreamErrorDomainKey=12, NSLocalizedDescription=La connessione a Internet sembra non essere in linea.}, DialogInfo={
Apr 14 21:44:07 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:44:08 iMac-di-alessandro.local com.apple.InputMethodKit.UserDictionary[389]: -[PFUbiquitySwitchboardEntryMetadata setUseLocalStorage:](834): CoreData: Ubiquity: ale~CEA63987-B9E0-5691-A32E-A3553A9D8C59:UserDictionary
Using local storage: 1
Apr 14 21:44:08 iMac-di-alessandro.local com.apple.iCloudHelper[309]: AOSKit ERROR: Storage usage request failed, appleID=pizzo.alessandro96@xxxxxxx.com, url=https://p19-quota.icloud.com:443/quotas ... eUsageInfo, requestHeaders=
error=Error Domain=AOSErrorDomain Code=1000 "Impossibile completare l'operazione. (AOSErrorDomain errore 1000.)" UserInfo=0x7fa848c19d80 {UnderlyingError=La connessione a Internet sembra non essere in linea., DialogInfo={
Apr 14 21:44:08 iMac-di-alessandro.local com.apple.CloudPhotosConfiguration[383]: [AOSAccounts] : [MMRetrieveQuotaUsage] : account pizzo.alessandro96@xxxxxxx.com _AOSAccountRetrieveStorageUsageInfo failed with error Impossibile completare l'operazione. (AOSErrorDomain errore 1000.) and reason (null) domain AOSErrorDomain
Apr 14 21:44:08 iMac-di-alessandro.local cloudphotosd[351]: +[CSLogger preferencesChanged:] reconfiguring logging
error=Error Domain=AOSErrorDomain Code=1000 "Impossibile completare l'operazione. (AOSErrorDomain errore 1000.)" UserInfo=0x7fa848f19750 {UnderlyingError=La connessione a Internet sembra non essere in linea., DialogInfo={
Apr 14 21:44:08 iMac-di-alessandro.local cloudphotosd[351]: Determine service transition start: service=com.apple.photo.icloud.sharedstreams personId=1768440396 lastKnownPersonId=1768440396 targetState=1
Apr 14 21:44:08 iMac-di-alessandro.local cloudphotosd[351]: Determine service transition end: 3, currentState: 3, shouldEnableService: 1
Apr 14 21:44:08 iMac-di-alessandro.local cloudphotosd[351]: Determine service transition start: service=com.apple.photo.icloud.myphotostream personId=1768440396 lastKnownPersonId=1768440396 targetState=1
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlOperatingMode Setting the AWDL operation mode from SUSPENDED to AUTO
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlAutoMode Resuming AWDL
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlOperatingMode Setting the AWDL operation mode from AUTO to SUSPENDED
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlSuspendedMode() Suspending AWDL, enterQuietMode(true)
Apr 14 21:44:09 iMac-di-alessandro.local recentsd[384]: Failed to get Mail account information in a timely manner
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: ARPT: 138.993713: MacAuthEvent en1 Auth result for: 02:bd:b9:e2:72:b7 MAC AUTH succeeded
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: AirPort: Link Up on en1
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: ARPT: 139.004831: AWDL Sync Enabled 0
Apr 14 21:44:09 iMac-di-alessandro kernel[0]: AirPort: RSN handshake complete on en1
Apr 14 21:44:10 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:44:13 --- last message repeated 1 time ---
Apr 14 21:44:13 iMac-di-alessandro.local configd[55]: network changed: DNS* Proxy
Apr 14 21:44:13 iMac-di-alessandro.local discoveryd[80]: Basic SleepProxy Could not get the primary interface
Apr 14 21:44:13 iMac-di-alessandro.local UserEventAgent[46]: Captive: [CNInfoNetworkActive:1709] en1: SSID 'coccobello' making interface primary (protected network)
Apr 14 21:44:13 iMac-di-alessandro.local UserEventAgent[46]: Captive: CNPluginHandler en1: Evaluating
Apr 14 21:44:13 iMac-di-alessandro.local UserEventAgent[46]: Captive: en1: Probing 'coccobello'
Apr 14 21:44:13 iMac-di-alessandro.local networkd[177]: +[NETLedBelly stopFastFail] Clearing ledbelly failure cache
Apr 14 21:44:14 --- last message repeated 1 time ---
Apr 14 21:44:14 iMac-di-alessandro.local configd[55]: network changed: v4(en1!:192.168.1.7) DNS+ Proxy+ SMB
Apr 14 21:44:14 iMac-di-alessandro.local UserEventAgent[46]: Captive: CNPluginHandler en1: Authenticated
Apr 14 21:44:15 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:44:15 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:44:17 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr[372]): Service exited due to signal: Abort trap: 6
Apr 14 21:44:17 iMac-di-alessandro kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Apr 14 21:44:17 iMac-di-alessandro kernel[0]: en1: channel changed to 1
Apr 14 21:44:17 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:44:17 iMac-di-alessandro kernel[0]: ARPT: 146.770498: AWDL Sync Enabled 0
Apr 14 21:44:17 iMac-di-alessandro.local ReportCrash[385]: Saved crash report for tunmgr[372] version 1.0.77 (6573334) to /Library/Logs/DiagnosticReports/tunmgr_2015-04-14-214417_iMac-di-alessandro.crash
Apr 14 21:44:17 iMac-di-alessandro.local UserEventAgent[46]: Captive: CNPluginHandler en1: Inactive
Apr 14 21:44:17 iMac-di-alessandro.local networkd[177]: +[NETLedBelly stopFastFail] Clearing ledbelly failure cache
Apr 14 21:44:17 iMac-di-alessandro.local netbiosd[400]: network_reachability_changed : network is not reachable, netbiosd is shutting down
Apr 14 21:44:17 iMac-di-alessandro.local configd[55]: network changed: v4(en1-:192.168.1.7) DNS- Proxy-
Apr 14 21:44:17 iMac-di-alessandro.local discoveryd[80]: Basic WABServer NetResolverEvent no resolvers, resetting domains
Apr 14 21:44:17 iMac-di-alessandro.local storeassetd[398]: AssetServiceDelegate: Accepting new connection <NSXPCConnection: 0x7fa3d1501d60> connection from pid 394 with interface <AssetServiceInterface: 0x7fa3d1502f90> (PID 394)
Apr 14 21:44:18 iMac-di-alessandro kernel[0]: ARPT: 147.143901: MacAuthEvent en1 Auth result for: 02:bd:b9:e2:72:b7 MAC AUTH succeeded
Apr 14 21:44:18 iMac-di-alessandro kernel[0]: AirPort: Link Up on en1
Apr 14 21:44:18 iMac-di-alessandro kernel[0]: en1: BSSID changed to 02:bd:b9:e2:72:b7
Apr 14 21:44:18 iMac-di-alessandro kernel[0]: en1: channel changed to 6
Apr 14 21:44:18 iMac-di-alessandro kernel[0]: en1::IO80211Interface::postMessage bssid changed
Apr 14 21:44:18 iMac-di-alessandro kernel[0]: ARPT: 147.149169: AWDL Sync Enabled 0
Apr 14 21:44:18 iMac-di-alessandro kernel[0]: AirPort: RSN handshake complete on en1
Apr 14 21:44:18 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Failed to enable multicast listener sending for V4 socket en1, 49
Apr 14 21:44:18 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour,Warn Warning: IPv4 listener multicast send failed en1, 49
Apr 14 21:44:18 iMac-di-alessandro.local networkd[177]: +[NETLedBelly stopFastFail] Clearing ledbelly failure cache
Apr 14 21:44:18 iMac-di-alessandro.local configd[55]: network changed: DNS* Proxy
Apr 14 21:44:18 iMac-di-alessandro.local UserEventAgent[46]: Captive: [CNInfoNetworkActive:1709] en1: SSID 'coccobello' making interface primary (cache indicates network not captive)
Apr 14 21:44:18 iMac-di-alessandro.local UserEventAgent[46]: Captive: CNPluginHandler en1: Evaluating
Apr 14 21:44:18 iMac-di-alessandro.local UserEventAgent[46]: Captive: en1: Not probing 'coccobello' (cache indicates not captive)
Apr 14 21:44:18 iMac-di-alessandro.local UserEventAgent[46]: Captive: CNPluginHandler en1: Authenticated
Apr 14 21:44:18 iMac-di-alessandro.local configd[55]: network changed: v4(en1!:192.168.1.7) DNS+ Proxy+ SMB
Apr 14 21:44:18 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 1 seconds. Pushing respawn out by 9 seconds.
Apr 14 21:44:19 iMac-di-alessandro.local discoveryd[80]: Basic Bonjour stop listening on en1
Apr 14 21:44:19 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:44:19 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlOperatingMode Setting the AWDL operation mode from SUSPENDED to AUTO
Apr 14 21:44:19 iMac-di-alessandro kernel[0]: IO80211AWDLPeerManager::setAwdlAutoMode Resuming AWDL
Apr 14 21:44:19 iMac-di-alessandro.local storeassetd[398]: addOperation <UpdateOperation: 0x7fa3d171b7b0>{name = '(null)'}
Apr 14 21:44:20 iMac-di-alessandro.local locationd[86]: PBRequester failed with Error Error Domain=NSURLErrorDomain Code=-1009 "The Internet connection appears to be offline." UserInfo=0x7f8a60e20de0 {NSUnderlyingError=0x7f8a60f478a0 "The Internet connection appears to be offline.", NSErrorFailingURLStringKey=https://gs-loc.apple.com/clls/wloc, NSErrorFailingURLKey=https://gs-loc.apple.com/clls/wloc, _kCFStreamErrorDomainKey=12, _kCFStreamErrorCodeKey=8, NSLocalizedDescription=The Internet connection appears to be offline.}
Apr 14 21:44:20 iMac-di-alessandro.local locationd[86]: NETWORK: no response from server, reachability, 2, queryRetries, 0
Apr 14 21:44:20 iMac-di-alessandro.local cloudphotosd[351]: Determine service transition start: service=com.apple.photo.icloud.cloudphoto personId=1768440396 lastKnownPersonId=1768440396 targetState=1
Apr 14 21:44:20 iMac-di-alessandro.local cloudphotosd[351]: Determine service transition end: 3, currentState: 3, shouldEnableService: 1
Apr 14 21:44:22 iMac-di-alessandro.local Paragon Updater[331]: [Paragon NTFS for Mac] no installed version found
Apr 14 21:44:22 iMac-di-alessandro.local Paragon Updater[331]: [Paragon ExtFS for Mac] no installed version found
Apr 14 21:44:23 iMac-di-alessandro.local Paragon Updater[331]: update available? NO
Apr 14 21:44:23 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.netbiosd): Service only ran for 9 seconds. Pushing respawn out by 1 seconds.
Apr 14 21:44:23 iMac-di-alessandro.local apsd[81]: Illegal subject name missing 'courier.push.apple.com' (2.5.4.3): ({
label = "2.5.4.6";
"localized label" = "2.5.4.6";
type = string;
value = US;
label = "2.5.4.8";
"localized label" = "2.5.4.8";
type = string;
value = California;
label = "2.5.4.7";
"localized label" = "2.5.4.7";
type = string;
value = Cupertino;
label = "2.5.4.10";
"localized label" = "2.5.4.10";
type = string;
value = "Apple Inc.";
label = "2.5.4.3";
"localized label" = "2.5.4.3";
type = string;
value = "courier.sandbox.push.apple.com";
Apr 14 21:44:27 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.StreamingUnzipService): The _DirtyJetsamPriority key is not available on this platform.
Apr 14 21:44:27 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.StreamingUnzipService): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:44:27 iMac-di-alessandro.local nsurlsessiond[255]: Being asked if container with identifier com.apple.clouddocs.com.apple.TextInput is foreground before getting callback from BRContainersMonitor!
Apr 14 21:44:27 --- last message repeated 1 time ---
Apr 14 21:44:27 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:44:27 iMac-di-alessandro.local storedownloadd[405]: DownloadServiceDelegate: Accepting new connection <NSXPCConnection: 0x7f85c1c02330> connection from pid 398 with interface <DownloadServiceInterface: 0x7f85c1c03dc0> (PID 398)
Apr 14 21:44:27 iMac-di-alessandro.local storedownloadd[405]: DownloadServiceDelegate: Accepting new connection <NSXPCConnection: 0x7f85c1d1bcb0> connection from pid 398 with interface <DownloadServiceInterface: 0x7f85c1d1ad40> (PID 398)
Apr 14 21:44:28 iMac-di-alessandro.local storeassetd[398]: AssetServiceDelegate: Accepting new connection <NSXPCConnection: 0x7fa3d1730c70> connection from pid 405 with interface <AssetServiceInterface: 0x7fa3d173efb0> (PID 405)
Apr 14 21:44:30 iMac-di-alessandro.local locationd[86]: NETWORK: requery, 0, 0, 0, 0, 6, items, fQueryRetries, 1, fLastRetryTimestamp, 0.0
Apr 14 21:44:30 iMac-di-alessandro.local com.apple.SecurityServer[84]: Session 100007 created
Apr 14 21:44:33 iMac-di-alessandro.local com.apple.InputMethodKit.UserDictionary[389]: -[PFUbiquitySwitchboardEntryMetadata setUseLocalStorage:](834): CoreData: Ubiquity: ale~CEA63987-B9E0-5691-A32E-A3553A9D8C59:UserDictionary
Using local storage: 0
Apr 14 21:44:33 iMac-di-alessandro.local bird[278]: setting error: Error Domain=BRCloudDocsErrorDomain Code=5 "Impossibile completare l'operazione. (BRCloudDocsErrorDomain errore 5 - No document at URL)" UserInfo=0x7f9be9e0ffe0 {NSDescription=No document at URL, NSFilePath=/Users/Ale/Library/Mobile Documents/com~apple~TextInput/Dictionaries/Ale~CEA63987-B9E0-5691-A32E-A3553A9D8C59/UserDictionary/SAlQVUhF7208e6_gvZx_zdKx1U1AzKGem3HO2pLKjgY=/A19ED578-E17A-475D-8DB9-8A733A3C5F8B.1.cdt, NSUnderlyingError=0x7f9be9e0edb0 "Impossibile completare l'operazione. File o directory inesistente"}
Apr 14 21:44:33 iMac-di-alessandro.local com.apple.InputMethodKit.UserDictionary[389]: __45-[PFUbiquityFilePresenter processPendingURLs]_block_invoke(439): CoreData: Ubiquity: Librarian returned a serious error for starting downloads Error Domain=BRCloudDocsErrorDomain Code=5 "Impossibile completare l'operazione. (BRCloudDocsErrorDomain errore 5 - No document at URL)" UserInfo=0x7ff548611ab0 {NSDescription=No document at URL, NSFilePath=/Users/Ale/Library/Mobile Documents/com~apple~TextInput/Dictionaries/Ale~CEA63987-B9E0-5691-A32E-A3553A9D8C59/UserDictionary/SAlQVUhF7208e6_gvZx_zdKx1U1AzKGem3HO2pLKjgY=/A19ED578-E17A-475D-8DB9-8A733A3C5F8B.1.cdt, NSUnderlyingError=0x7ff548612320 "Impossibile completare l'operazione. File o directory inesistente"} with userInfo {
NSDescription = "No document at URL";
NSFilePath = "/Users/Ale/Library/Mobile Documents/com~apple~TextInput/Dictionaries/Ale~CEA63987-B9E0-5691-A32E-A3553A9D8C59/UserDictionary/SAlQVUhF7208e6_gvZx_zdKx1U1AzKGem3HO2pLKjgY=/A19ED578-E17A-475D-8DB9-8A733A3C5F8B.1.cdt";
NSUnderlyingError = "Error Domain=NSPOSIXErrorDomain Code=2 \"Impossibile completare l'operazione. File o directory inesistente\" UserInfo=0x7ff5486066c0 {NSDescription=No such file or directory}";
} for these urls: (
"file:///Users/Ale/Library/Mobile%20Documents/com~apple~TextInput/Dictionaries/Ale~CEA63987-B9E0-5691-A32E-A3553A9D8C59/UserDictionary/SAlQVUhF7208e6_gvZx_zdKx1U1AzKGem3HO2pLKjgY=/A19ED578-E17A-475D-8DB9-8A733A3C5F8B.1.cdt"
Apr 14 21:44:33 iMac-di-alessandro.local cloudphotosd[351]: New connection request from 396
Apr 14 21:44:34 iMac-di-alessandro.local com.apple.photomoments[412]: Photomoments process awakened.
Apr 14 21:44:35 iMac-di-alessandro.local com.apple.photomoments[412]: Connection error while checking Apple Internalness. Error: Error Domain=NSCocoaErrorDomain Code=4099 "Couldn’t communicate with a helper application." (The connection to service named com.apple.CrashReporterSupportHelper was invalidated.) UserInfo=0x7feb006305b0 {NSDebugDescription=The connection to service named com.apple.CrashReporterSupportHelper was invalidated.}
Apr 14 21:44:36 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imdmessageservices.IMDMessageServicesAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:44:36 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:44:36 iMac-di-alessandro.local com.apple.geod[415]: Connection error while checking Apple Internalness. Error: Error Domain=NSCocoaErrorDomain Code=4099 "Couldn’t communicate with a helper application." (The connection to service named com.apple.CrashReporterSupportHelper was invalidated.) UserInfo=0x7f92da407810 {NSDebugDescription=The connection to service named com.apple.CrashReporterSupportHelper was invalidated.}
Apr 14 21:44:36 iMac-di-alessandro.local cloudphotosd[351]: Media stream daemon starting...
Apr 14 21:44:38 iMac-di-alessandro.local filecoordinationd[281]: sandboxing denied subscription to progress on category com.apple.cpl.ctepqfdar+kvpuiwr64pmq (bundle id com.apple.cloudphotosd, EF53DEDC-C2CA-4A40-B140-10395C965FA3)
Apr 14 21:44:38 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:44:40 iMac-di-alessandro.local sandboxd[314] ([412]): com.apple.photom(412) deny mach-lookup com.apple.CrashReporterSupportHelper
Apr 14 21:44:40 iMac-di-alessandro.local cloudphotosd[351]: <MSASStateMachine: 0x7f954bc48e90>: Successfully checked for changes updates.
Apr 14 21:44:40 iMac-di-alessandro.local sandboxd[314] ([415]): com.apple.geod(415) deny mach-lookup com.apple.CrashReporterSupportHelper
Apr 14 21:44:48 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:45:19 --- last message repeated 2 times ---
Apr 14 21:45:19 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:45:21 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.quicklook[430]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Apr 14 21:45:30 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:45:41 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 1 seconds. Pushing respawn out by 9 seconds.
Apr 14 21:45:50 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:45:50 iMac-di-alessandro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Apr 14 21:46:00 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:46:26 --- last message repeated 2 times ---
Apr 14 21:46:26 iMac-di-alessandro.local mds[62]: (Volume.Normal:2464) volume:0x7f844d01ac00 ********** Bootstrapped Creating a default store:0 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/firmwaresyncd.wqVtdD
Apr 14 21:46:31 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:46:35 iMac-di-alessandro.local SystemUIServer[260]: Attempt to use XPC with a MachService that has HideUntilCheckIn set. This will result in unpredictable behavior: com.apple.backupd.status.xpc
Apr 14 21:46:41 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:47:11 --- last message repeated 2 times ---
Apr 14 21:47:11 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:47:42 --- last message repeated 2 times ---
Apr 14 21:47:42 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:48:12 --- last message repeated 2 times ---
Apr 14 21:48:12 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:48:43 --- last message repeated 2 times ---
Apr 14 21:48:43 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:49:13 --- last message repeated 2 times ---
Apr 14 21:49:13 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:49:44 --- last message repeated 2 times ---
Apr 14 21:49:44 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:50:14 --- last message repeated 2 times ---
Apr 14 21:50:14 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Apr 14 21:50:45 --- last message repeated 2 times ---
Apr 14 21:50:45 iMac-di-alessandro com.apple.xpc.launchd[1] (com.rim.tunmgr): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
ecco qui!!! ( mamma quanta roba!!!)) erano le 21:41 e 9 secondi
thezippons ha scritto:faxus devo dirti che confronto a prima è molto piu veloce...
Basta un poco di zucchero e la pillola va giù…
thezippons ha scritto:però mi piacerebbe togliere del tutto ste "schifezze"
Ci hai preso gusto eh con Dr.Faxus?
Ripeti TUTTI i comandi dai, dall'inizio della discussione.
Fai tutto insieme poi riavvia.
Solo un pezzo per volta non funziona.
Poi posta solo EtreCheck, vediamo se ce l'hai fatta...
fragrua ha scritto:... Ci hai preso gusto....
Hahahaha... Fortissima, mi hai sorpreso...
Favorisci!
:D
Kundalini
Qualcuno può per cortesia rimuovere dal log i dati dell'account del povero thezippons.
Perché altrimenti domani si troverà la casella mail spammata di brutto, e persino una zappa come il sottoscritto proverà a craccargli la PW per comprarsi sull'AppStore Final Cut Pro a 299,99 € :D.
Se funziona, non aggiustarlo.
Kundalini ha scritto:Qualcuno può per cortesia rimuovere dal log i dati dell'account del povero thezippons.
Fatto… manca qualcosa?
tighine
(Solo un po' più di monitoraggio preventivo, direi).
Bonnie3
Ahahahhaha bellissima l'immagine :D
Tighine credo debba essere compito dell'utente che posta il log controllare che non ci siano dati personali ;)
thezippons
vi ringrazio delle "minacce" ma essendo solo un apprendista meccanico non avevo la più pallida idea che ci potessero essere i miei dati dentro...
Thezippons, ripeti tutti i comandi dati relativi.
Hai ancora quel controllo di BlackBerry sulla rete
kato
fragrua ha scritto:Ci hai preso gusto eh con Dr.Faxus?
Applausi. Tremo a indovinare la specialità medica del dottore.
Torna a “OS X Yosemite 10.10”
