brew install youtube-dl
MacBook-Pro-di-Fabio:~ faxus$ which youtube-dl
/usr/local/bin/youtube-dl
MacBook-Pro-di-Fabio:~ faxus$ youtube-dl https://youtu.be/iVaqQe3V498
[youtube] iVaqQe3V498: Downloading webpage
[youtube] iVaqQe3V498: Downloading video info webpage
[youtube] iVaqQe3V498: Extracting video information
[youtube] iVaqQe3V498: Downloading js player vfl8jhACg
ERROR: Signature extraction failed: Traceback (most recent call last):
File "/usr/local/bin/youtube-dl/youtube_dl/extractor/youtube.py", line 1162, in _decrypt_signature
video_id, player_url, s
File "/usr/local/bin/youtube-dl/youtube_dl/extractor/youtube.py", line 1085, in _extract_signature_function
cache_res = res(test_string)
File "/usr/local/bin/youtube-dl/youtube_dl/extractor/youtube.py", line 1138, in <lambda>
return lambda s: initial_function([s])
File "/usr/local/bin/youtube-dl/youtube_dl/jsinterp.py", line 254, in resf
res, abort = self.interpret_statement(stmt, local_vars)
File "/usr/local/bin/youtube-dl/youtube_dl/jsinterp.py", line 55, in interpret_statement
v = self.interpret_expression(expr, local_vars, allow_recursion)
File "/usr/local/bin/youtube-dl/youtube_dl/jsinterp.py", line 211, in interpret_expression
raise ExtractorError('Unsupported JS expression %r' % expr)
ExtractorError: Unsupported JS expression u'oE["do"](a,67)'; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
(caused by ExtractorError(u'Unsupported JS expression u\'oE["do"](a,67)\'; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.',)); please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
MacBook-Pro-di-Fabio:~ faxus$ youtube-dl -U
Updating to version 2017.05.18 ...
ERROR: no write permissions on /usr/local/bin/youtube-dl
MacBook-Pro-di-Fabio:~ faxus$ sudo chown -R $(whoami):admin /usr/local
MacBook-Pro-di-Fabio:~ faxus$ chmod a+x /usr/local/bin/youtube-dl
MacBook-Pro-di-Fabio:~ faxus$ sudo youtube-dl -U
Password:
Updating to version 2017.05.18.1 ...
Updated youtube-dl. Restart youtube-dl to use the new version.
[download] Destination: Amy Winehouse - Fuck Me Pumps-iVaqQe3V498.mp4
[download] 100% of 13.72MiB in 00:11
Figurati.faxus ha scritto: .... Evvai, grazie Kernel Panic
ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
==> This script will install:
/usr/local/bin/brew
/usr/local/share/doc/homebrew
/usr/local/share/man/man1/brew.1
/usr/local/share/zsh/site-functions/_brew
/usr/local/etc/bash_completion.d/brew
/usr/local/Homebrew
==> The following new directories will be created:
/usr/local/Cellar
/usr/local/Homebrew
/usr/local/Frameworks
/usr/local/bin
/usr/local/etc
/usr/local/include
/usr/local/lib
/usr/local/opt
/usr/local/sbin
/usr/local/share
/usr/local/var
Press RETURN to continue or any other key to abort
==> /usr/bin/sudo /bin/mkdir -p /usr/local/Cellar /usr/local/Homebrew /usr/local/Frameworks /usr/local/bin /usr/local/etc /usr/local/include /usr/local/lib /usr/local/opt /usr/local/sbin /usr/local/share /usr/local/share/zsh /usr/local/share/zsh/site-functions /usr/local/var
Password:
==> /usr/bin/sudo /bin/chmod g+rwx /usr/local/Cellar /usr/local/Homebrew /usr/local/Frameworks /usr/local/bin /usr/local/etc /usr/local/include /usr/local/lib /usr/local/opt /usr/local/sbin /usr/local/share /usr/local/share/zsh /usr/local/share/zsh/site-functions /usr/local/var
==> /usr/bin/sudo /bin/chmod 755 /usr/local/share/zsh /usr/local/share/zsh/site-functions
==> /usr/bin/sudo /usr/sbin/chown faxus /usr/local/Cellar /usr/local/Homebrew /usr/local/Frameworks /usr/local/bin /usr/local/etc /usr/local/include /usr/local/lib /usr/local/opt /usr/local/sbin /usr/local/share /usr/local/share/zsh /usr/local/share/zsh/site-functions /usr/local/var
==> /usr/bin/sudo /usr/bin/chgrp admin /usr/local/Cellar /usr/local/Homebrew /usr/local/Frameworks /usr/local/bin /usr/local/etc /usr/local/include /usr/local/lib /usr/local/opt /usr/local/sbin /usr/local/share /usr/local/share/zsh /usr/local/share/zsh/site-functions /usr/local/var
==> /usr/bin/sudo /bin/mkdir -p /Users/faxus/Library/Caches/Homebrew
==> /usr/bin/sudo /bin/chmod g+rwx /Users/faxus/Library/Caches/Homebrew
==> /usr/bin/sudo /usr/sbin/chown faxus /Users/faxus/Library/Caches/Homebrew
==> /usr/bin/sudo /bin/mkdir -p /Library/Caches/Homebrew
==> /usr/bin/sudo /bin/chmod g+rwx /Library/Caches/Homebrew
==> /usr/bin/sudo /usr/sbin/chown faxus /Library/Caches/Homebrew
==> Downloading and installing Homebrew...
remote: Counting objects: 6434, done.
remote: Compressing objects: 100% (3903/3903), done.
remote: Total 6434 (delta 3716), reused 4259 (delta 2327), pack-reused 0
Receiving objects: 100% (6434/6434), 3.58 MiB | 1.08 MiB/s, done.
Resolving deltas: 100% (3716/3716), done.
From https://github.com/Homebrew/brew
* [new branch] master -> origin/master
* [new tag] 0.1 -> 0.1
* [new tag] 0.2 -> 0.2
* [new tag] 0.3 -> 0.3
* [new tag] 0.4 -> 0.4
* [new tag] 0.5 -> 0.5
* [new tag] 0.6 -> 0.6
* [new tag] 0.7 -> 0.7
* [new tag] 0.7.1 -> 0.7.1
* [new tag] 0.8 -> 0.8
* [new tag] 0.8.1 -> 0.8.1
* [new tag] 0.9 -> 0.9
* [new tag] 0.9.1 -> 0.9.1
* [new tag] 0.9.2 -> 0.9.2
* [new tag] 0.9.3 -> 0.9.3
* [new tag] 0.9.4 -> 0.9.4
* [new tag] 0.9.5 -> 0.9.5
* [new tag] 0.9.8 -> 0.9.8
* [new tag] 0.9.9 -> 0.9.9
* [new tag] 1.0.0 -> 1.0.0
* [new tag] 1.0.1 -> 1.0.1
* [new tag] 1.0.2 -> 1.0.2
* [new tag] 1.0.3 -> 1.0.3
* [new tag] 1.0.4 -> 1.0.4
* [new tag] 1.0.5 -> 1.0.5
* [new tag] 1.0.6 -> 1.0.6
* [new tag] 1.0.7 -> 1.0.7
* [new tag] 1.0.8 -> 1.0.8
* [new tag] 1.0.9 -> 1.0.9
* [new tag] 1.1.0 -> 1.1.0
* [new tag] 1.1.1 -> 1.1.1
* [new tag] 1.1.10 -> 1.1.10
* [new tag] 1.1.11 -> 1.1.11
* [new tag] 1.1.12 -> 1.1.12
* [new tag] 1.1.13 -> 1.1.13
* [new tag] 1.1.2 -> 1.1.2
* [new tag] 1.1.3 -> 1.1.3
* [new tag] 1.1.4 -> 1.1.4
* [new tag] 1.1.5 -> 1.1.5
* [new tag] 1.1.6 -> 1.1.6
* [new tag] 1.1.7 -> 1.1.7
* [new tag] 1.1.8 -> 1.1.8
* [new tag] 1.1.9 -> 1.1.9
* [new tag] 1.2.0 -> 1.2.0
* [new tag] 1.2.1 -> 1.2.1
* [new tag] 1.2.2 -> 1.2.2
* [new tag] 1.2.3 -> 1.2.3
HEAD is now at 3fe3205 Merge pull request #2775 from reitermarkus/language
==> Tapping homebrew/core
Cloning into '/usr/local/Homebrew/Library/Taps/homebrew/homebrew-core'...
remote: Counting objects: 4439, done.
remote: Compressing objects: 100% (4243/4243), done.
remote: Total 4439 (delta 35), reused 465 (delta 12), pack-reused 0
Receiving objects: 100% (4439/4439), 3.53 MiB | 1.07 MiB/s, done.
Resolving deltas: 100% (35/35), done.
Tapped 4240 formulae (4,482 files, 11MB)
==> Cleaning up /Library/Caches/Homebrew...
==> Migrating /Library/Caches/Homebrew to /Users/faxus/Library/Caches/Homebrew..
==> Deleting /Library/Caches/Homebrew...
Already up-to-date.
==> Installation successful!
==> Homebrew has enabled anonymous aggregate user behaviour analytics.
Read the analytics documentation (and how to opt-out) here:
http://docs.brew.sh/Analytics.html
==> Next steps:
- Run `brew help` to get started
- Further documentation:
http://docs.brew.sh
MacBook-Pro-di-Fabio:~ faxus$ Brew update
Already up-to-date.
MacBook-Pro-di-Fabio:~ faxus$ brew upgrade
MacBook-Pro-di-Fabio:~ faxus$ brew cleanup
MacBook-Pro-di-Fabio:~ faxus$ brew doctor
Please note that these warnings are just used to help the Homebrew maintainers
with debugging if you file an issue. If everything you use Homebrew for is
working fine: please don't worry and just ignore them. Thanks!
Warning: You are using macOS 10.13.
We do not provide support for this pre-release version.
You may encounter build failures or other breakages.
Please create pull-requests instead of filing issues.
Warning: Ruby version 2.3.3 is unsupported on 10.13. Homebrew
is developed and tested on Ruby 2.0, and may not work correctly
on other Rubies. Patches are accepted as long as they don't cause breakage
on supported Rubies.
Roba da tutti.macbio ha scritto:Roba da grandi!!!
brew install wget
brew tap caskroom/cask
Updating Homebrew...
MacBook-Pro-di-Fabio:~ faxus$ brew cask --version
Homebrew-Cask 1.2.3
caskroom/homebrew-cask (git revision ebe0; last commit 2017-06-16)
MacBook-Pro-di-Fabio:~ faxus$ brew update
Updated 2 taps (homebrew/core, caskroom/cask).
==> New Formulae
bitcoin iamy jose pycodestyle
==> Updated Formulae
amazon-ecs-cli ghostscript n
amqp-cpp git-annex openh264
angular-cli git-ftp openttd
ansifilter gitlab-ci-multi-runner openvpn
ansiweather gjs opus
antigen gnuradio orientdb
app-engine-go-64 gsl oscats
appscale-tools gsmartcontrol osquery
arangodb gtk+3 osrm-backend
artifactory gtkmm3 packer
automake gtksourceview3 packetbeat
aws-sdk-cpp gucharmap paket
awscli haproxy passenger
bluepill heroku pdf-redact-tools
cairo hg-fast-export pdftoedn
chakra highlight postgrest
checkstyle hugo pwntools
chronograf hyperscan pyenv
conan influxdb pyinvoke
convox jenkins qt
csmith jetty rbenv
dcos-cli jetty-runner rmlint
dhall-json jhipster roswell
dieharder jruby securefs
docker-compose jsonnet sourcery
docker-compose-completion kibana srtp
docker-credential-helper kitchen-sync svgcleaner
eigen kops swiftformat
elasticsearch kotlin swiftlint
expat kubernetes-cli syncthing-inotify
fabric kubernetes-helm tee-clc
feedgnuplot languagetool teleport
fibjs leaps terragrunt
filebeat libgosu tinyxml2
fio libhttpseverywhere translate-toolkit
fits libnfs ttyd
flatbuffers libqalculate twarc
flowgrind libtensorflow unrar
folly llnode valgrind
format-udf logstash vert.x
freetds lsdvd vim
fsql macvim wartremover
fuseki mapcrafter webpack
gammu mcabber yle-dl
gauge meson youtube-dl
gegl metricbeat zsh
getdns minisat
brew update
To restore the stashed changes to /usr/local/Homebrew/Library/Taps/caskformula/homebrew-caskformula run:
'cd /usr/local/Homebrew/Library/Taps/caskformula/homebrew-caskformula && git stash pop'
To restore the stashed changes to /usr/local/Homebrew/Library/Taps/caskroom/homebrew-cask run:
'cd /usr/local/Homebrew/Library/Taps/caskroom/homebrew-cask && git stash pop'
Updated 3 taps (caskformula/caskformula, caskroom/cask, homebrew/core).
==> New Formulae
asdf ...
automake ✔...
cairo ✔...
nmap ✔...
fontconfig ✔...
glib ✔...
sqlite ✔...
gsl ✔...
harfbuzz ✔...
youtube-dl ✔...
zsh
leaps
==> Renamed Formulae
osh -> etsh
==> Deleted Formulae
snescom
To restore the stashed changes to ...
Sono aggiornamenti entrambi.Kernel Panic ha scritto:... Che differenza c'è tra brew update e brew upgrade?...
No, doctor segnala gli errori di installazione, di percorso ed altro.Kernel Panic ha scritto:... Con brew doctor mi limito ad aggiornare Brew?...
Wesnoth è un gioco.Kernel Panic ha scritto:... Cos'è Wesnoth?...
Visitano il forum: trendiction [Bot] e 17 ospiti
