Kernel panic
Questo è il posto giusto per presentarvi agli altri Maccanici ;)
Miki88
in console ci so arrivare, ma non so recuperare il report
Miki88 ha scritto:
mar, 25 set 2018 20:26
Li trovi in Library/Logs, sotto la voce DiagnosticsReporter
Miki88
Fri Sep 21 10:17:03 PDT 2018
creating system keychain entries
...Generating key pair...
...creating certificate...
Serial Number : 40 83 DA 74
Issuer Name :
Common Name : com.apple.systemdefault
Org : System Identity
Subject Name :
Cert Sig Algorithm : OID : < 06 09 2A 86 48 86 F7 0D 01 01 0B >
alg params : 05 00
Not Before : 17:17:06 Sep 21, 2018
Not After : 17:17:06 Sep 16, 2038
Pub Key Algorithm : OID : < 06 09 2A 86 48 86 F7 0D 01 01 01 >
alg params : 05 00
Pub key Bytes : Length 270 bytes : 30 82 01 0A 02 82 01 01 ...
CSSM Key :
Algorithm : RSA
Key Size : 2048 bits
Key Use : CSSM_KEYUSE_ENCRYPT CSSM_KEYUSE_VERIFY CSSM_KEYUSE_WRAP
Signature : 256 bytes : 54 14 67 85 EA 58 C4 67 ...
Extension struct : OID : < 06 03 55 1D 0F >
Critical : FALSE
usage : DigitalSignature KeyEncipherment DataEncipherment
Extension struct : OID : < 06 03 55 1D 25 >
Critical : FALSE
purpose 0 : OID : < 06 09 2A 86 48 86 F7 63 64 04 04 >
..cert stored in Keychain.
..identity registered for domain com.apple.systemdefault.
Fri Sep 21 10:17:07 PDT 2018
...System identity already exists for domain com.apple.systemdefault. Done.
Serial Number : 11 DC 7F FF
Issuer Name :
Common Name : com.apple.kerberos.kdc
Subject Name :
alg params : 05 00
Not Before : 17:17:08 Sep 21, 2018
Not After : 17:17:08 Sep 16, 2038
alg params : 05 00
CSSM Key :
Algorithm : RSA
Key Use : CSSM_KEYUSE_ENCRYPT CSSM_KEYUSE_VERIFY CSSM_KEYUSE_WRAP CSSM_KEYUSE_DERIVE
Signature : 256 bytes : 4C 6D 5B D9 28 29 CE F4 ...
Critical : FALSE
Critical : FALSE
purpose 0 : OID : < 06 08 2B 06 01 05 05 07 03 01 >
purpose 1 : OID : < 06 07 2B 06 01 05 02 03 05 >
..identity registered for domain com.apple.kerberos.kdc.
added /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc to acl for com.apple.kerberos.kdc
hod-admin: krb5_kt_start_seq_get: keytab /etc/krb5.keytab access failed: No such file or directory
Done LKDC setup
No matching processes were found
Serial Number : 19 7D E3 C5
Issuer Name :
Subject Name :
alg params : 05 00
Not Before : 17:17:15 Sep 21, 2018
Not After : 17:17:15 Sep 16, 2038
alg params : 05 00
CSSM Key :
Algorithm : RSA
Signature : 256 bytes : CD 7B 27 4B 37 E6 48 D7 ...
Critical : FALSE
Critical : FALSE
/System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc already in acl
Done LKDC setup
Dovresti trovare quello postato prima.
Andava benissimo.
Mancavano solo poche righe.
Questo qui non ho capito neanche cos'è.
Devi cercare esattamente quello, panic report e che abbia le stesse cose già postate
mattleega ha scritto:
mar, 25 set 2018 20:19
... Temo di aprire il post e leggere...
che...
Miki88
Anonymous UUID: FE91FBE9-F609-A427-35B8-938D47800D3C
Sat Sep 22 14:30:44 2018
*** Panic Report ***
Machine-check capabilities: 0x0000000000000c09
family: 6 model: 37 stepping: 2 microcode: 16
signature: 0x20652
Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz
9 error-reporting banks
mp_kdp_enter(): 7, 1, 4 TIMED-OUT WAITING FOR NMI-ACK, PROCEEDING
panic(cpu 3 caller 0xffffff800e18811a): "Machine Check at 0xffffff800e18dda1, registers:\n" "CR0: 0x000000008001003b, CR2: 0x000000011090dbaf, CR3: 0x0000000012174000, CR4: 0x00000000000026e0\n" "RAX: 0x0000000000000000, RBX: 0x0000000000000003, RCX: 0x000000006aed8458, RDX: 0x0000000000000000\n" "RSP: 0xffffff8117ebbd10, RBP: 0xffffff8117ebbd10, RSI: 0x0000000000000002, RDI: 0x0000000000000240\n" "R8: 0xffffff80204eb700, R9: 0x00000000a2bd5bbe, R10: 0x0000000000000000, R11: 0xffffff8020db1800\n" "R12: 0x00000000a356a3c1, R13: 0x7fffffffffffffff, R14: 0x7fffffffffffffff, R15: 0xffffff7f912c59f8\n" "RFL: 0x0000000000000002, RIP: 0xffffff800e18dda1, CS: 0x0000000000000008, SS: 0x0000000000000000\n" "Error code: 0x0000000000000000\n"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/xnu/xnu-4570.71.2/osfmk/i386/trap_native.c:168
Backtrace (CPU 3), Frame : Return Address
0xffffff800df4db30 : 0xffffff800e06c1c6
0xffffff800df4db80 : 0xffffff800e195274
0xffffff800df4dbc0 : 0xffffff800e187544
0xffffff800df4dc30 : 0xffffff800e01e1e0
0xffffff800df4dc50 : 0xffffff800e06bc3c
0xffffff800df4dd80 : 0xffffff800e06b9fc
0xffffff800df4dde0 : 0xffffff800e18811a
0xffffff800df4ded0 : 0xffffff800e01ea5f
0xffffff8117ebbd10 : 0xffffff800e18f59b
0xffffff8117ebbd20 : 0xffffff7f912a7eb1
0xffffff8117ebbd50 : 0xffffff7f912a7f61
0xffffff8117ebbd90 : 0xffffff7f912a1a20
0xffffff8117ebbe60 : 0xffffff7f912a0fe9
0xffffff8117ebbf10 : 0xffffff800e18934c
0xffffff8117ebbf30 : 0xffffff800e08a4a2
0xffffff8117ebbf80 : 0xffffff800e08aa70
0xffffff8117ebbfa0 : 0xffffff800e01d557
Kernel Extensions in backtrace:
com.apple.driver.AppleIntelCPUPowerManagement(220.50.1)[9D594B5E-4A7C-37DD-90E9-16DDBDA6C758]@0xffffff7f9129f000->0xffffff7f912c8fff
BSD process name corresponding to current thread: kernel_task
Mac OS version:
17G65
e qui si complica... kernel_task boh, chissà se fax...
Miki88
@scialla che vuoi dire?
Non implica : com.apple.driver.AppleIntelCPUPowerManagement ???
Prova ad avviare col tasto ⇧ abbassato e verifica se accade ancora
Torna a “Saluti Maccanici”
Visitano il forum: Nessuno e 21 ospiti
