da qualche tempo Foto si chiude inaspettatamente
Grazie a chi vorrà aiutarmi a risolvere. Qui ho trovato sempre un valido supporto.
Ecco etrecheck
EtreCheck version: 3.4.7 (461)
Report generated 2018-03-19 16:54:27
Runtime: 3:46
Performance: Good
Problem: Apps are crashing
Hardware Information: ⓘ
iMac (21.5-inch, Mid 2010)
iMac - model: iMac11,2
1 3,06 GHz Intel Core i3 (i3) CPU: 2-core
BANK 0/DIMM0
2 GB DDR3 1333 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
BANK 1/DIMM1
Wireless: en1: 802.11 a/b/g/n
iCloud Quota: 2.45 GB available
Video Information: ⓘ
ATI Radeon HD 4670 - VRAM: 256 MB
iMac 1920 x 1080
Disk Information: ⓘ
WDC WD20EARX-00MMMB0 disk1: (2 TB) (Rotational)
[Show SMART report]
EFI (disk1s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
(disk1s2) <not mounted> [CoreStorage Container]: 2.00 TB
Recovery HD (disk1s3 - HFS+) <not mounted> [Recovery]: 650 MB
Samsung SSD 850 EVO 500GB disk0: (500,11 GB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [CoreStorage Container]: 499.76 GB
(disk0s3) <not mounted> [Boot]: 134 MB
USB Information: ⓘ
USB20Bus
hub_device
Apple Inc. Built-in iSight
USB20Bus
hub_device
Apple Internal Memory Card Reader
Apple Inc. BRCM2046 Hub
Virtual disks: ⓘ
Fusion Drive (disk2 - Journaled HFS+) / [Startup]: 2.49 TB (1.75 TB free)
Physical disk: disk0s2 499.76 GB Online
Physical disk: disk1s2 2.00 TB Online
System Software: ⓘ
macOS High Sierra 10.13.3 (17D102) - Time since boot: about 6 hours
Gatekeeper: ⓘ
Kernel Extensions: ⓘ
/Library/Extensions
[not loaded] com.avid.usb.fasttrackc400.driver (M-Audio Fast Track C400 1.2.12 - SDK 10.7) [Lookup]
/System/Library/Extensions
[not loaded] com.focusrite.driver.usb.audio (2.9 - SDK 10.9) [Lookup]
[loaded] com.hzsystems.terminus.driver (4) [Lookup]
[not loaded] com.novationmusic.driver.usb.audio (2.7 - SDK 10.9) [Lookup]
System Launch Agents: ⓘ
[not loaded] 9 Apple tasks
[loaded] 156 Apple tasks
[running] 94 Apple tasks
[killed] 31 Apple tasks
31 processes killed due to insufficient RAM
System Launch Daemons: ⓘ
[not loaded] 34 Apple tasks
[loaded] 181 Apple tasks
[running] 91 Apple tasks
[killed] 26 Apple tasks
26 processes killed due to insufficient RAM
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2017-04-13) [Lookup]
[running] com.avid.fasttrackc400.helper.plist (? 25acf25f 4e90e9fb - installed 2018-02-02) [Lookup]
[failed] com.google.keystone.agent.plist (Google, Inc. - installed 2018-02-04) [Lookup]
[loaded] com.oracle.java.Java-Updater.plist (? c8d126fb 1a4bf56e - installed 2018-02-10) [Lookup]
[not loaded] com.teamviewer.teamviewer.plist (TeamViewer GmbH - installed 2017-12-13) [Lookup]
[not loaded] com.teamviewer.teamviewer_desktop.plist (TeamViewer GmbH - installed 2017-12-05) [Lookup]
[loaded] org.macosforge.xquartz.startx.plist (Apple Inc. - XQuartz - installed 2016-10-26) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-02-24) [Lookup]
[loaded] com.apple.aelwriter.plist (Apple, Inc. - installed 2012-01-16)
[failed] com.apple.qmaster.qmasterd.plist (Apple, Inc. - installed 2010-08-26)
[loaded] com.bombich.ccchelper.plist (? bc948f55 4617ba95 - installed 2016-12-27) [Lookup]
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2018-03-05) [Lookup]
[loaded] com.novation.automap.pluginhelper.plist (? 78eec3d1 56acebd7 - installed 2018-02-24) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script e3fefdd2 - installed 2017-12-20) [Lookup]
[running] com.surteesstudios.hddfancontroldaemon.plist (Surtees Studios Limited - installed 2014-06-04) [Lookup]
[loaded] com.teamviewer.Helper.plist (TeamViewer GmbH - installed 2017-12-05) [Lookup]
[not loaded] com.teamviewer.teamviewer_service.plist (TeamViewer GmbH - installed 2017-12-13) [Lookup]
[running] net.exirion.ssdfanctrl.plist (? 6fbe74f0 4fb5f732 - installed 2013-10-31) [Lookup]
[loaded] org.macosforge.xquartz.privileged_startx.plist (Apple Inc. - XQuartz - installed 2016-10-26) [Lookup]
User Launch Agents: ⓘ
[loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2017-09-13) [Lookup]
[running] com.hp.devicemonitor.plist (HP Inc. - installed 2018-03-19) [Lookup]
[running] com.spotify.webhelper.plist (Spotify - installed 2017-02-07) [Lookup]
User Login Items: ⓘ
Dropbox Applicazione
(/Applications/Dropbox.app)
HP Device Monitor SMLoginItem - Hidden (HP Inc. - installed 2017-12-21)
(/Library/Printers/hp/Frameworks/HPDeviceMonitoring.framework/Versions/1.0/Helpers/HP Device Monitor Manager.app/Contents/Library/LoginItems/HP Device Monitor.app)
Internet Plug-ins: ⓘ
AdobeAAMDetect: AdobeAAMDetect 1.0.0.0 (installed 2017-04-13) [Lookup]
FlashPlayer-10.6: 29.0.0.113 (installed 2018-03-13) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2018-02-01)
Flash Player: 29.0.0.113 (installed 2018-03-13) [Lookup]
o1dbrowserplugin: 5.41.3.0 (installed 2015-12-16) [Lookup]
googletalkbrowserplugin: 5.41.3.0 (installed 2015-12-11) [Lookup]
Silverlight: 5.1.50901.0 (installed 2017-02-09) [Lookup]
JavaAppletPlugin: Java 8 Update 161 build 12 (installed 2018-02-10) Check version
Safari Extensions: ⓘ
[enabled] Awesome Screenshot - Diigo - http://www.diigo.com/ (installed 2017-03-02)
[enabled] Skype Click to Call - Skype - http://skype.com (installed 2013-05-08)
Audio Plug-ins: ⓘ
DVCPROHDAudio: 1.3.2 (installed 2012-01-27)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2018-02-24) [Lookup]
HDD Fan Control (installed 2014-10-29) [Lookup]
Java (installed 2018-02-10) [Lookup]
M-Audio Fast Track C400 Control Panel (installed 2018-02-02) [Lookup]
YAMAHA-USBMIDIPatch (installed 2012-07-10) [Lookup]
Time Machine: ⓘ
Skip System Files: NO
Mobile backups: OFF
Auto backup: YES
Volumes being backed up:
Fusion Drive: Disk size: 2.49 TB Disk used: 745.31 GB
Destinations:
TC1 [Network]
Total size: 3.00 TB
Total number of backups: 30
Oldest backup: 23/12/2017, 13:26
Last backup: 19/03/2018, 16:22
Size of backup disk: Adequate
Backup size 3.00 TB > (Disk used 745.31 GB X 3)
Top Processes by CPU: ⓘ
69% photoanalysisd
28% VTDecoderXPCService
21% WindowServer
20% Safari
17% photolibraryd
Top Processes by Memory: ⓘ
830 MB com.apple.WebKit.WebContent
786 MB kernel_task
242 MB Safari
190 MB Dropbox
181 MB photoanalysisd
Input Output Process name
21 MB 518 KB Dropbox
3 MB 220 KB mDNSResponder
1 MB 471 KB com.apple.WebKit.Networking
186 KB 302 KB apsd
121 KB 55 KB Skype
42.90 photoanalysisd
39.04 com.apple.WebKit.WebContent
23.68 WindowServer
22.00 VTDecoderXPCService
13.70 Safari
Virtual Memory Information: ⓘ
2.74 GB Available RAM
15 MB Free RAM
5.26 GB Used RAM
2.73 GB Cached files
271 MB Swap Used
Automap: (installed 2018-02-24)
Novation USB 1.1 Driver: (installed 2018-02-24)
Adobe Flash Player: (installed 2018-03-13)
2018-03-19 16:53:26 qmasterd Crash [Open]
Cause: dyld: launch, loading dependent libraries
2018-03-19 11:17:03 AppleSpell Crash [Open]
Cause: objc_msgSend() selector name: respondsToSelector:
2018-03-17 13:16:40 Photos.app Hang [Open]
