https://testmysite.io/
Il test eseguito con l'utility di Netlify per un sito web in host sul provider Fastnom risulta con scarsissimi risultati. Non riconosce neanche il certificato SSL e l'HTTPS... suggerite altri test di controllo?
- TTFB: Time it takes for the user’s browser to begin receiving your website. Affects your page load speed significantly, which affects google search ranking, bounce rates and conversions;
- Full Download of HTML: Time it takes the user’s browser to download the full HTML page. Additional components, javascript and events won’t load before this happens. Affects your page load speed significantly, which affects google search ranking, bounce rates and conversions;
- HTTPS: Google’s search index gives preferential ranking to sites secured with HTTPS, and proposals are in place to mark standard HTTP sites as insecure.
See Five Reasons You Want HTTPS for your Static Site for more information;
- HTTPS2: Enabling HTTP2 will make your site load faster. HTTP2 is an update to the HTTP protocol engineered to improve performance of the web with consideration for how modern web applications are built;
- Valid SSL certificate: Testing if the SHA certificate is up-to-date. Some servers use an old encryption mechanism that’s no longer secure when using HTTPS. An obsolete or broken certificate means your users will get warnings in certain browsers.
